Κυριακή, 11 Οκτ 2026, 16:56:52
    [Σήμερα στις 00:55]
    Σύνολο μηνυμάτων: 310013
    Επισκέπτες: 33
    Συνολικά: 35
    Σελίδες: 1 ... 8 9 10 [11] 12 13 14 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 206835 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #150 στις: Πέμπτη, 24 Νοε 2016, 20:37:15 »
    Νέες Παραλαβές Νοεμβρίου απο www.Diamond-Models.gr
    Νέα Συνεργασία με ATJ Turbines Made in Korea
    ATJ-140-SV Turbine Engine 14Kg Thrust
    Detailed Information
    2016 all new version ATJ140SV , 14kg thrust turbine jet engine
    it's super value engine in the world . This is all new design turbine , all different then old Ti series The new type V3 burner long life and fast ignition EGT sensor ,
    fuel and burner valve Inside the engine front cover , one FASTO fitting for fuel inlet engine. full Inconel 600 material combustion chamber long use life over 300hr
    Inconel 713 material made turbine wheel and NGV , Diffuser , intake , upper cover , engine case .. etc made by T6061 aviation level aluminum rod barCNC machine to finish product ,
    long life starter motor low working temperature
    We also keep aluminum starter case not use plastic starter case
    Xicoy V10 kerostart ECU and GSU easy to use .
    ATJ140SV Turbine engine Specifications
    Dimensions : Outer Diameter 99mm; Length: 276mm
    Weight : 1470grams (including starter)
    Maximum thrust : 14KG @ 123,000rpm
    Idle RPM : 35,000 Idle
    thrust @ 35,000 : 0.6 KG
    EGT : 400 - 550 degree C
    Fuel Consumption : @ max rpm 490 gms/min
    Fuel/ oil : Jet fuel or Kerosene or Diesel + 5% oil (synthetic turbine engine oil)
    ATJ140SV Engine package include
    1. Turbine engine
    2. Engine Mount set
    3. Fuel pump set
    4. ECU ( Xicoy V10 Kerostart )
    5. GSU (Xicoy  GSU for V10 ECU )
    6. 4mm Fuel tube
    7. Fuel filter
    8. Fuel cut off valve
    9. FOD screen
    10. Electronic cables
    11. User’s manual
    « Απάντηση #151 στις: Πέμπτη, 24 Νοε 2016, 20:50:54 »
    Νέα Σειρά Φορτιστών  SC-608 DC 150W 8A και SC-620 DC 500W 20A
    Technical data
    Input voltage:9-30 V (DC)
    Charging power:max. 500 W
    Discharging power:max. 150 W
    Charging current:0,1-20,0 A
    Discharging current:0,1-5,0 A
    Balancing current:1 A/Zelle
    Cell count:1-18 Ni; 1-6S Li/LiHV
    Pb voltage:1-12S
    Dimensions:115 x 130 x 52 mm
    Weight:289 g
    Technical data
    Input voltage:9-32 V (DC)
    Charging power:max. 150 W
    Discharging power:max. 5 W
    Charging current:0,1-8,0 A
    Discharging current:0,1-3,0 A
    Balancing current:500 mA/Zelle
    Cell count:1-18 NiMH; 1-6S Li/LiHV
    Pb voltage:1-12S
    Dimensions:88 x 58 x 21 mm
    Weight:110 g
    « Απάντηση #152 στις: Τετάρτη, 28 Δεκ 2016, 16:09:45 »
    Νέες Παραλαβές Δεκεμβρίου απο www.Diamond-Models.gr
    « Απάντηση #153 στις: Τετάρτη, 11 Ιαν 2017, 15:47:49 »
    Νέες Παραλαβες Ιανουάριος 2017. Καλή Χρονιά !!!
    4 in 1 Ultimate Retract Device for Landing Gear
    Upgrade TS5828L 5.8Ghz Switchable 25mW / 600mW 48CH AV FPV Transmitter Module Readytosky For FPV Racer 130 QAV X R QAV210
    CRRCpro 2 in1 Gas Engine CDI Igniter with Remote Flameout Switch RPM Tachometer
    DU-BRO Snow Skis .60 class
    CRRCPRO CNC Ultimate Air Trap Tank 125ml for Turbojets Airplane Blue
    R-PLANES PIONEER 2,4 GHz RTF Mode 2 wingspan:1400mm
    « Απάντηση #154 στις: Δευτέρα, 23 Ιαν 2017, 19:21:08 »
    Νέες Παραλαβες από Eurokit Ιανουάριος 2017
    « Απάντηση #155 στις: Πέμπτη, 2 Φεβ 2017, 20:16:38 »
    « Απάντηση #156 στις: Πέμπτη, 2 Φεβ 2017, 20:23:37 »
    « Απάντηση #157 στις: Τετάρτη, 8 Φεβ 2017, 10:47:45 »
    Νέες Παραλαβες Φεβρουάριος 2017
    και αλλα πολλα
    « Απάντηση #158 στις: Τρίτη, 14 Φεβ 2017, 17:43:00 »
    Νέες Παραλαβές 14 Φεβρουαρίου 2017
    « Απάντηση #159 στις: Τρίτη, 14 Φεβ 2017, 17:49:33 »
    « Απάντηση #160 στις: Πέμπτη, 23 Φεβ 2017, 21:18:50 »
    Νέες Παραλαβές 22 Φεβρουαρίου 2017
    [/size]
    « Απάντηση #161 στις: Δευτέρα, 27 Φεβ 2017, 10:07:01 »
    Νέες Παραλαβές 24 Φεβρουαρίου 2017
    HSD F-16 FALCON PnP Version 2 Turbine Jet
    « Απάντηση #162 στις: Δευτέρα, 13 Μαρ 2017, 16:40:47 »
    Νέα Παραλαβή απο www.Diamond-Models.gr
    Black Horse Thunderbirds EDF ARTF
    [/color][/b][/size]
    Inspired by a classic jet trainer aircraft the Sky Jet is a simply beautiful model.
    Built from quality balsa and ply using the latest in CAD design and CNC construction techniques, weight is kept to a minimum.
    The Sky Jet is designed to suit 90mm electric ducted fan units such as Wemotec 90mm Midi Fan Evo.
    That combined with an HET 650-68-2000 motor, 120A ESC and a 6S 22.2v 6,700mAh Li-Po (2x 6S 3,350mAh in parallel).
    It would also suit turbine conversions (no turbine information is supplied).
    • Suits an electric retract set capable of 5kg weight
    • Balsa & Ply construction using CAD design
    • Covered in Oracover
    • Detailed cockpit
    • Tip tanks included
    Specification
    EDF Fan Diameter:    HET 650-68-2000 (Rec.)
    Wingspan:    1,400mm (55.12")
    Length:    1,350mm (53.15")
    Weight:    4,000g (8.8 lb)
    Servos:    8 Mini (Req.)
    Radio System:    8 Channel (Req.)
    Electric Motor:    90mm (Req.)
    Speed Controller:    120A (Req.)
    LiPo:    2x 6S 22.2v 3350mAh (Req.)[/url]
    « Απάντηση #163 στις: Τετάρτη, 15 Μαρ 2017, 10:20:03 »
    Νέα Παραλαβή Fiala Propellers απο www.Diamond-Models.gr
    « Απάντηση #164 στις: Σάββατο, 18 Μαρ 2017, 10:41:24 »
    Νέα Παραλαβή 15-3-2017
    Σελίδες: 1 ... 8 9 10 [11] 12 13 14 ... 24     Πάνω
