Κυριακή, 11 Οκτ 2026, 06:08:26
    [Σήμερα στις 00:55]
    Σύνολο μηνυμάτων: 310013
    Επισκέπτες: 45
    Συνολικά: 45
    Σελίδες: 1 ... 11 12 13 [14] 15 16 17 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 206784 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #195 στις: Τρίτη, 11 Σεπ 2018, 19:08:36 »
    Νέες Παραλαβές Σεπτεμβρίου Νο:2
    Το Hobby σας είναι η δουλειά μας
    « Απάντηση #196 στις: Πέμπτη, 13 Σεπ 2018, 19:01:56 »
    [/img]
    With the CARF-Models F4U-1D Corsair a dream comes true for us – and maybe for you, too.
    Specifications
    110" (2800 mm)
    87" (2200 mm)
    39 - 46 Lbs (18 - 21 kg) dry
    80-150 cc two-stroke-engine or 250 cc radial-engine
    Description
    The ARF version of our plugin wing Corsair is in our opinion always a good choice.
    - all flaps with their offset hinges are readily installed.
    - all control horns are installed
    - cowling is factory installed
    - stab is completely installed
    - landing gear installation is prepared up to simply bolting the gear in place
    - gear doors are all hinged
    - tail gear former and servo mounts are installed
    For you left to finish are mainly installation jobs, such as:
    - one glue joint fin attachment (not glued on for packing and shipping reasons)
    - linkage, servo and other RC installation
    - engine installation
    - retract installation and final gear door cylinder installation
    - canopy and cockpit installation
    - final scale detailing and painting
    All parts are detailed, silver painted composite components, light weight and not only “prefabricated” but really ARF’ed. Why bother with hundreds of building hours if you can get around it for as little upcharge as it is? A detailed instruction manual not only guides you through the remaining build, shows you how much work you’ve saved...
    Note: This ARF Corsair is the perfect way to spend money wisely. All the work is done for you.
    Used colors:
    - Fine silver
    « Απάντηση #197 στις: Παρασκευή, 28 Σεπ 2018, 15:56:00 »
    Νέες Παραλαβές Σεπτεμβρίου από www.diamond-models.gr
    [/size]
    και πολλα άλλα αξεσουαρ
    « Απάντηση #198 στις: Πέμπτη, 18 Οκτ 2018, 16:25:22 »
    Νέες Παραλαβές Οκτωβρίου 2018
    [/size]
    « Απάντηση #199 στις: Τετάρτη, 9 Ιαν 2019, 16:59:18 »
    Νέες Παραλαβές Ιανουαρίου 2019...Καλή Χρονιά !!!
    « Απάντηση #200 στις: Τετάρτη, 9 Ιαν 2019, 17:11:02 »
    « Απάντηση #201 στις: Σάββατο, 12 Ιαν 2019, 10:37:12 »
    [/color]
    « Απάντηση #202 στις: Σάββατο, 26 Ιαν 2019, 12:38:01 »
    Νέες Παραλαβές 29 Ιανουαρίου 2019
    [/b]
    « Απάντηση #203 στις: Σάββατο, 26 Ιαν 2019, 12:43:01 »
    [urlhttp://www.diamond-models.gr/]
    [/url]
    « Απάντηση #204 στις: Τετάρτη, 6 Μαρ 2019, 18:47:49 »
    Νέες Παραλαβές 6 Μαρτίου 2019
    [/url]
    « Απάντηση #205 στις: Παρασκευή, 22 Μαρ 2019, 17:08:09 »
    Νέες Παραλαβές 22 Μαρτίου 2019
    « Απάντηση #206 στις: Παρασκευή, 22 Μαρ 2019, 17:15:01 »
    « Απάντηση #207 στις: Παρασκευή, 22 Μαρ 2019, 17:23:22 »
    « Απάντηση #208 στις: Δευτέρα, 22 Απρ 2019, 12:57:27 »
    Ευχές
    « Απάντηση #209 στις: Παρασκευή, 24 Μαΐ 2019, 10:18:11 »
    Νέες Παραλαβές Μαίου απο www.Diamond-Models.gr
    και πολλά άλλα αξεσουάρ[/color][/b][/size]
    [/url]
    Σελίδες: 1 ... 11 12 13 [14] 15 16 17 ... 24     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: www.Diamond-Models.gr
