Τρίτη, 13 Οκτ 2026, 07:59:26
    [Χθες στις 13:52]
    Online σήμερα: 38
    Επισκέπτες: 39
    Συνολικά: 39
    Σελίδες: 1 ... 5 6 7 [8] 9 10 11 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 207014 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #105 στις: Τρίτη, 14 Ιουλ 2015, 18:23:07 »
    BIG Quad Sky Spy with FPV Display 5" and 2.4 GHz LCD Tx including HD Cam RTF 350mm
    Stable flight, great looks, bright LEDs for
    Position detection and of course a modern
    2.4GHz remote control with LCD display and
    Additional screen. On this can in real time
    the razor-sharp image, which consists of the
    Drone is an integrated Cam gesendetet considered
    will. The Drone can also great push of a button
    360 ° flips run. An ultra-modern
    Gyro allows the drone quietly in the
    Air stand. About easy-to-use buttons
    on the screen, the cam is driven, thus
    is a full control of the recordings at any time
    from ground level possible. Using the remote control
    can set three speeds
    will. At dusk or in the
    Darkness ensure the luminous LEDs on the
    Bottom of the drone for a breathtaking
    Flight picture. In the extensive delivery
    are optional mountable propeller protectors,
    a 2GB micro SD memory card and a USB Card reader included.
    Latest gyro technology
    Screen for the reception of the live image
    7.4V 700mAh Li-Po battery with (replaceable)
    Length diagonal (from wave to wave): approx 39cm
    Width (from wave to wave): ca. 28 cm
    Height: 9cm
    Range about 65 m
    Flight time: up 7 min.
    Included:
    Big Sky Spy
    2.4GHz remote control with display viewer
    Screen to receive the live image
    4 x propeller protection
    Power supply for charging the battery
    4 x spare propellers
    2GB Micro SD Memory Card
    1 x USB card reader
    1 x Screwdriver
    Operating instructions (English)
    Το Hobby σας είναι η δουλειά μας
    « Απάντηση #106 στις: Πέμπτη, 23 Ιουλ 2015, 12:01:27 »
    Νέες Παραλαβές Ιουλίου
    Viper Jet Large Electric Ducted Fan Plane PNP Green
    Viper Jet Large Electric Ducted Fan Plane PNP Red
    Description:
    This stunning new electric ducted fan model is perfect for the flyer who wants all the performance and presence of a jet turbine model but without any of the complications, risk or expense that go with jet engines. The combination of a high power brushless motor and specially designed 11 bladed 90mm fan give you the power and authentic jet sound to match the superb looks of this model.
    The flight envelope is awesome, as you would expect from a model this good looking and you will find it a pleasure to fly. Don't worry about the landings either as the Viper Jet will slow with the flaps and remain composed giving you the chance to show off your perfect landing skills.
    Fitted with 11 servos as standard and the latest in electronic retracts all you need to add is your receiver of choice and a battery. The retracts system features sequenced doors that open before the legs come down and then close once the wheels are tucked away.
    Wingspan    1450mm (57")
    Length    1274mm (50")
    Flying Weight    3050g (107.6oz)
    Servos    11 x 9g
    Recommended Battery    5000mAh 22.2v Li-Po
    « Απάντηση #107 στις: Παρασκευή, 4 Σεπ 2015, 13:22:09 »
    Black Horse Wild Hots ARTF
    Specifications:
    Wild and Fun, that's what the 'Wild Hots' is all about.
    Always intended as an all out aerobatic model for the most demanding pilot, the Wild Hots can be as tame or as wild as you like. The key is in the radio setup, not the limitations of the model.
    Built from Laser cut balsa and ply parts with Oracover covering for durability.
    get into the radical world, try a Wild Hots!
    Wingspan: 1020mm (40.16")
    Length: 1190mm (46.85")
    Weight: 1.1kg (2.42 lb)
    Servos: 4 (Req.)
    Radio System: 4 Channel (Req.)
    Electric Motor: 2820/05 (Rec.)
    LiPo: 3S 2200mAh 20C (Rec.)
    ESC Rec: 40A SW (Rec.)
    « Απάντηση #108 στις: Πέμπτη, 24 Σεπ 2015, 10:38:40 »
    Νέες Παραλαβές σε JP All ALU CNC EDFs New Version
    JP 105mm Alu CNC EDF Unit with motor(12S) New
    12S / 118A / 7.4kg(thrust)
    JP 90 mm Ducted fan Alu CNC 12S unit with motor New Version
    Typical 12S Li-Po Set Up:
        RPM: 50000 rpm
        Kv Rating: 1057Kv (outrunner motor included)
        Battery: 12s 44.4V
        Static Thrust: 5.1kg
        Start: Soft
        Timing: Low
        Amp Rating: 96 amp esc or higher
    JP Super version 70mm EDF with motor for 6S
    6S Li-Po Set Up:
        RPM: 59,940 rpm
        Kv Rating: 2700
        Battery: 6s 22.2V
        Static Thrust: 5.07 lb./ 2.745kg
        Amp Rating: 75 amp esc or higher
    « Απάντηση #109 στις: Τρίτη, 29 Σεπ 2015, 12:16:33 »
    Νέες Παραλαβές Σεπτεμβρίου
    Mitsubishi A6M Zero ARF 1.700mm 0.91-1.25cu engine with Retracts
    Technical data
    Scale:1:7
    Wingspan:1.700 mm
    Length:1.298 mm
    Engine:91-125cu
    Weight:ca. 4.200 g
    Material:Holz
    Covering:ORACOVER (Lichtgrau 21-011)
    Wing area:49,1 dm²
    Functions
    Elevator:
    Rudder:
    Ailerons:
    Flaps:
    Motor:
    Tail wheel:
    Retracts:
    Instruction manual:
    Deutsch, Englisch
    « Τελευταία τροποποίηση: Σάββατο, 3 Οκτ 2015, 14:30:11 από DIAMOND » Καταγράφηκε
    « Απάντηση #110 στις: Σάββατο, 3 Οκτ 2015, 14:39:54 »
    Νέες Παραλαβές Οκτωμβρίου
    Graupner RACE Copter ALPHA 250Q ready for HoTT BnF
    Pure flight fun:
    Since now on, it says: 'Let's get ready for Airrace "!
    The new Alpha 250 is a purebred FPV Race Quadrocopter, developed for flying with video glasses from the 'I' perspective. Experience model flies like a flight simulator on the PC. Equipped with FPV camera experience the flying experience as a simulator or in the real plane, the FPV racing with quadrocopters becomes always more and more popular.
    So 'racetrack layout' with gates, flags, or even pipes are created that must be flown through, or it is set a certain distance to trees with corridors.
    The chassis of the ALPHA 250 consists entirely of carbon fiber, which is extremely rigid and insensitive. The double bottom, which gives a streamlined look, even allows the installation of 4 Brushless ESC, and stowing over long cable.
    An ideal addition to this is the use of the gyro-receiver GR-18 or GR-24 PRO, which already contains a full Flight Control for attitude stabilization. Thus can be dispensed with an additional board together with additional cables. The 4 brushless controllers cables are simply plugged into the receiver and gyro will do the rest. About the telemetry menu of the HoTT transmitter then is possible to complete the setup of the gyro receiver. It is also possible to customize to your own needs the sensitivity of the flight control very easily via the telemetry receiver menus of the GR-18. For more information about the copter software for Gyro receiver can be found on our website.
    The Voltage Module allows for the timely warning of empty battery voltage, so that the model can be landed in time and safely.
    Because of the easy handling, the model is suited for all model pilots, even those coming out of the car or boat area and of course it is suitable for gamers.
    The quality model is fully assembled and adjusted and therefore very fast and easy to fly.
    Features:
        80-100 km/h with original equipment and 3S LiPo
        Very stable
        Modular construction, so that in case of crash only single parts are required
        Frame and arms in carbon-fibre
        Carbon fibre of the highest quality construction with aluminium spacers
        Highly accurate flight control
        Integrated flight control into the receiver. Software made in Germany
        Very direct and precise flight, eliminating additional transmission paths
        All settings possible via HoTT transmitter
        2300Kv brushless outrunner motors with windings carried by hand and special optimized multi-winding for cooling
        Simplified access to FPV Racing attitude mode or FPV Racing professional rate mode
        Simplified appearance, with double deck to install the controllers and cables
        Voltage module with timely warning for a safe landing.
        Tilt the motor to avoid turbulence of the rear propellers.
        Self-tightening propeller adapters
        LED lighting
        Propellers stiffer with extremely high efficiency and flight characteristics optimized for FPV Racing
        Universal construction to use the FPV camera with and without Action Cam
        Smart design for optimum mounting of components
    Dimensions
    Axles distance: 22x28 cm;
    Motors height: 6 cm;
    Frame height: 7 cm
    Frame: 5.6 x 22.5 x 5.5 cm (thickness 2 mm);
    Arms: 10x3 cm (thickness 3 mm)
    Weight without battery: 357g
    Package content
        Quad Copter ALPHA 250 RACE ready assembled
        2 ULTRA BRUSHLESS Motors 2804 clockwise
        2 ULTRA BRUSHLESS Motors 2804 counterclockwise
        2 Propellers red (R/L)
        2 Propellers white (R/L)
        4 ULTRA BRUSHLESS Regulators
        GR-18 with Coptersoftware already installed
        Voltage Module (EH)
        Assembly material
    « Απάντηση #111 στις: Σάββατο, 3 Οκτ 2015, 14:45:22 »
    SC150 3D 6 Channel Heli Aquirel BodyRTF with LCD Transmitter 2.4 GHz
    Light, agile and powerful Flybarless helicopter. For indoor and Outdoor suitable. By The Button
    on the remote control it can by professional 3D Flight mode on the high-precision 6-axis gyro
    be switched. Therefore, the SC150 also suitable for aerobatics beginners,
    since in this mode, a high Flight stability is ensured. in The LCD display of high-quality 2.4 GHz radio control
    can be very clear all flight-related Data read. All rudders and Gas adjustment can be the SC150
    digital trim. Nor can the rowing rashes by simply pressing a button by the pilot
    Set. The powerful brushless motor provides an outstanding performance in all flight attitudes.
    Another highlight of the SC150 is the quality rotor head made of metal.
    Length: 275mm
    Height: 80mm
    Weight incl. Battery: 78g
    Propeller length: 276mm
    3D flight mode by pressing a button
    switchable to 6-axis gyro
    Battery: 500mAh 3.7V 25C
    Flight time: 5-7 minutes
    Motor: Brushless, 1106
    Heck Motor: coreless 8520
    Remote Control: 2.4 GHz, with LCD display
    Mode 1 -. 4 adjustable, including trimming function
    Flybarless, 3D aerobatic
    AMEWI SC150 3D helicopter
    2 x Battery 500mAh 3.7V 25C
    USB charging cable
    Charger with 2 battery slots
    3 x spare blades (main rotor)
    1 x Tail Rotor
    1 x Spare main gear
    1 x Screwdriver
    1 x Allen wrench
    Detailed operating instructions (Dt., Engl., Fra.)
    « Απάντηση #112 στις: Σάββατο, 3 Οκτ 2015, 15:02:10 »
    FLYMODEL Lancair 360 MKII 1.20 wingspan:1.80m
    Top quality wood construction with fiberglass fuselage.
    Detachable 2-piece main wing. with ailerons and flaps.
    Detachable stabilizer, All hardware and Accessories included.
    Optional pneumatic or electric retractable landing gear.
    Wing Span: 71 in / 1800mm
    Wing Area: 760 sq in / 49 sq dm
    Flying Weight: 9.50 lb / 4320g
    Fuselage Length: 58.5 in / 1495 mm
    Engine Required: 2c 1.20
    Radio Required: 6 channels 8 servos
    « Απάντηση #113 στις: Δευτέρα, 26 Οκτ 2015, 15:45:46 »
    Νέα Παραλαβή από www.Diamond-Models.gr
    BlackHorse Mig-29 Fighter Jet
    « Απάντηση #114 στις: Παρασκευή, 13 Νοε 2015, 16:33:06 »
    Νέες Παραλαβές Νοεμβρίου 2015 από www,Diamond-Models.gr
    « Απάντηση #115 στις: Πέμπτη, 3 Δεκ 2015, 14:59:05 »
    Udi U846 Tiny UFO Hex 6-Axis RTF
    Looking for a durable, easy to fly quadcopter to learn how to fly?
    Then the new "INTELLIGENT" 2.4Ghz 4 Channel 6 AXIS Headless Tiny UFO, is for you...
    Intelligent Orientation Control (IOC) system
    The UDI U846 has the Intelligent Orientation Control (IOC) function. Usually, the forward direction of a flying multi-rotor is the same as the nose direction. By using IOC, the forward direction has nothing to do with nose direction. This lessens the steepness of the learning curve and allows the pilot to enjoy flight while slowly learning each specific orientation of the quadcopter.
    6 Axis Gyro
    Equipped with the latest 6-axis flight control systems, 3D lock, More scheduled flight,
    operating more to the force!
    360° Eversion
    One key 360° roll, continuous roll for perfect action and wonderful performance.
    2.4GHz Radio Control
    Fly at long distance with multiple copters at the same time with minimal interference.
    This new radio technology consumes small amount of power and delivers rapid response.
    • With 6 speed motors as the driving force,
    • Also equipped with 180mA 3.7V Lipo Battery,
    • LED lights.
    • High wind resistance makes it suitable for outdoor flight.
    • Smooth, precise positioning, with rise and fall, left and right rotating, tumbling stunt and high/low.
    Included in the Box:
    • 1 x UDI U846
    • 1 x Remote Control
    • 1 x USB Cable
    • 6 x Replacement Propellers
    • 1 x LiPo Battery
    • 1 x Instructions
    Specification
    Charge Time:    40 min (Approx)
    Flight Time:    6 - 8 min (Approx)
    Range:    30m
    Length:    100mm
    Width:    100mm
    Height:    26.6mm
    Weight:    22.5g
    Radio System:    4 x 'AA' (Not Included)
    Frequency:    2.4GHz
    LiPo:    3.7V 180mAh (Inc.)
    Charger:    USB (Inc.)
    Size:    100 x 100 x 26.6mm
    Rotor Diameter:    32mm
    « Απάντηση #116 στις: Πέμπτη, 3 Δεκ 2015, 15:05:20 »
    ST Model Seawind EP PnP Wingspan:1450mm
    The ARTF Seawind from ST Model is a scale model of the full size kit aircraft and includes a wide array of features as standard.
    Just like the full-size counterpart the ST Seawind is a fully amphibious, and capable of being flown from paved surfaces, grass field and off of water. The high mounted motor keeps the propeller well and truly out of harm's way from catching grass or water splashes. Not only do the main wheels retract, there is also a retractable steerable water rudder for amazing water handling.
    Moulded from EPO foam the Seawind is light and tough, and using the latest in moulding techniques the finish is smooth and sleek. ST Model have really gone the extra mile with this model, for example all the control surfaces on the wing have plastic hinges to give the bets range of movement including fowler flaps! The moulded clear canopy is in hinges and can even lock up in the scale open position to give you both easy access to the battery compartment. The cockpit also features a full set of lightweight foam moulded seats, an instrument panel including yokes.
    The Seawind is supplied with 7 servos, a powerful brushless outrunner motor, electronic speed controller, retracts and LED lighting already pre-installed making assembly a breeze. Just add your choice of Tx/Rx combo, battery and charger to get airborne.
    Each wingtip has a moulded plastic tip light section, in each tip there are bright LED landing lights, flashing LED strobe lights and coloured LED navigations lights.
    The Seawind design is a very forgiving yet capable airframe and with the brushless power system included it is a perfect match. There is plenty of punch and control authority for aerobatics such as loops, rolls, stall turns, inverted flight and steep climb outs. Just back off the throttle and the Seawind has great slow speed handling thanks to its high mounted wing and low wing loading, making it perfect for cruising about just over the water admiring the reflection.
    Finished in a bright ocean inspired blue scheme, we think this will stand out at any flying field or lake.
    • EPO moulded airframe
    • Moulded plastic
    • Scale fowler flaps
    • Powerful brushless motor and ESC pre-installed
    • High mounted motor to keep the propeller clear of obstructions
    • Rx-Ready with servos pre-installed
    • Opening canopy with cockpit detail
    • Retracting metal arm main wheels
    • Retracting steerable nose wheel with doors
    • Retracting steerable water rudder
    • Easily removable wings with simple locking mechanism
    • Bright colour scheme
    • Great water handling
    • Superb flight charactistics
    Specification
    Lights:    LED Wingtip (Inc.)
    Propeller:    11 x 8 (Inc.)
    Wingspan:    1450mm
    Length:    1123mm
    Height:    430mm
    Weight:    1.82Kg
    Servos:    7 (Inc.)
    Radio System:    6 Channel (Req.)
    Electric Motor:    Brushless (Inc.)
    Retracts:    Included
    LiPo:    3S1P 11.1v 2100-2500mAh 30C (Req.)
    Speed Controller:    Brushless (Inc.)
    « Απάντηση #117 στις: Τρίτη, 15 Δεκ 2015, 11:34:45 »
    Νέες Παραλαβές Δεκεμβρίου
    RCGF 20cc BM gas engine (20cc, 2.9hp, 940gr)
    Technical Specification:
    Displacement 20ccm
    Output Power 2.9hp = 2.1kW
    Bore x Stroke 32x26 mm
    Speed Range 1500 - 9800rpm
    Propeller 15x6 - 18x8inch
    Ignition power supply 4.8 - 6 Volt
    Gas/Oil mix ratio 30 : 1 gas : oil
    Weight:
    Engine 740 gram
    Muffler 80 gram
    Ignition 120 gram
    « Απάντηση #118 στις: Τρίτη, 15 Δεκ 2015, 11:44:00 »
    NGH GF38 4-stroke gas engine (38cc, 3.6hp, 1310gr)
    Displacement 38 ccm
    Output Power 3.6 hp ,2.7 kW
    Carburetor Walbro WT1022
    Speed Range 1800 - 8300 rpm
    Propeller 18x8-10 - 20x8 inch
    Spinner bout diameter 9.5 mm
    Gas/Oil mix ratio 35 : 1 gas : oil
    Weight: Engine 1295 gram
    « Απάντηση #119 στις: Πέμπτη, 24 Δεκ 2015, 17:48:07 »
    Ευχόμαστε Ολόψυχα σε Όλους
    Υγεία Χαρά και Ευτυχία
    Καλά Χριστούγεννα !!!
    Σελίδες: 1 ... 5 6 7 [8] 9 10 11 ... 24     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: www.Diamond-Models.gr
