Δευτέρα, 12 Οκτ 2026, 14:11:34
    [Σήμερα στις 13:52]
    Online σήμερα: 45
    Επισκέπτες: 45
    Συνολικά: 46
    Σελίδες: 1 ... 3 4 5 [6] 7 8 9 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 206940 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #75 στις: Κυριακή, 18 Ιαν 2015, 18:11:56 »
    Joysway Eaglet Seaplane Brushless RTF 2.4GHz
    The Joysway Eaglet is designed as the perfect first float plane. Weighing in at only 145g and with a compact size (620mm wingspan) it is especially suited to smaller flying sites. The EPO construction gives a nice smooth surface finish whilst remaining tough and lightweight.
    Assembly takes minimal time thanks to the pre-installed brushless outrunner motor, 8amp ESC, 2S 7.4v 400mAh Li-Po battery, 3x 2.5g micro servos. This Ready-To-Fly configuration also includes a Joysway 2.4GHz transmitter and receiver.
    • Brushless power!
    • Tough EPO foam
    • Spare propeller & flexible mount
    • Pre-installed electronics
    Specification
    Wingspan:    620mm
    Length:    538mm
    Weight:    145g
    Servos:    3x 2.5g (Inc.)
    Radio System:    4 Channel 2.4Ghz (Inc.)
    Electric Motor:    Brushless (Inc.)
    LiPo:    2S 7.4v 400mAh (Inc.)
    Speed Controller:    8A Brushless (Inc.)
    Το Hobby σας είναι η δουλειά μας
    « Απάντηση #76 στις: Κυριακή, 18 Ιαν 2015, 18:19:34 »
    Black Horse Spitfire IX ARTF 33cc
    The unmistakable lines of the MK IX Spitfire - originally designed to counter the increasing threat of German Focke Wulf 190s during 1942 - have been skillfully captured by Black Horse in this large scale model. Factory assembled using CNC machined balsa and ply components and then superbly covered in printed film. Supplied complete with air up/down retracts and oleos, the model is designed for 33cc petrol engines and radio with a minimum of 7 channels and high torque servos.
    • Includes Air Retracts with Oleos
    • All balsa and ply CNC construction
    • Covered in heat shrink film
    Specification
    Wingspan:    2,000mm (78.74")
    Length:    1,760mm (69.29")
    Weight:    6.8 kg (14.96 lb)
    Servos:    9 (Req.)
    Radio System:    7 Channel (Req.)
    Petrol Engine:    33cc (Rec.)
    « Τελευταία τροποποίηση: Κυριακή, 18 Ιαν 2015, 18:50:17 από DIAMOND » Καταγράφηκε
    « Απάντηση #77 στις: Κυριακή, 18 Ιαν 2015, 19:00:09 »
    PHOENIX MODEL P51- MUSTANG 60CC SCALE 1:5 1/4 ARF
    Introducing
        The P-51 Mustang was a solution to the clear need for an effective bomber escort. The Mustang was at least as simple as other aircraft of its era. It used a common, reliable engine and had internal space for a huge fuel load. With external fuel tanks, it could accompany the bombers all the way to Germany and back. Enough P-51s became available to the 8th and 9th Air Forces in the winter of 1943–44.
         For the ultimate, realistic flight experience, the P-51 comes with all-metal mechanical spring-loaded strut assemblies. The P-51 comes out of the box with all kinds of details that have been finished for the consumer, including a factory-painted fiberglass cowl, scale antenna, scale-shaped spinner, aluminum wheel hubs and much more. For a high-quality outer surface and realistic appearance, the P-51 is dressed with Oracover.
    Technical data
    - Wingspan: 2190mm (86.2 in)
    - Length: 1907mm (75 in)
    - Flying weight: 9-12 kg
    - Wing area: 92 dm2
    - Wing loading: 98g/dm2
    - Wing type: Naca airfoils
    - Covering type: Genuine ORACOVER®
    - Retract gear type: Air-retract With CNC Suspension Metal Struts (included)
    - Spinner size: P51 Mustang type, aluminum plate 115mm (included)
    - Radio: 6 channel minimum (not included)
    - Servo: 9 standard hi-torque servo: 2 aileron; 2 flap; 2 elevator; 1 rudder;1 retract; 1 throttle (not included)
    - Recommended receiver battery: 6.0V 2400/2600mAh NiMH (2) (not included)
    - Servo mount: 21mm x 42 mm
    - Propeller: suit with your engine
    - Engine: 50-60 CC gas engine (two stroke) (not included)
    - Motor: brushless outrunner 2600-3000 W, 190 KV (not included)
    - Gravity CG: 190 mm (7,48 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 15mm up/down, 10% expo; High: 20mm up/down, 10% expo
    - Control throw Elevators: Low: 15mm up/down, 12% expo; High: 20mm up/down, 12% expo
    - Control throw Rudder: Low: 40mm right/left, 15% expo; High: 60mm right/left, 15% expo
    - Control throw Flaps: Mid: 25mm down; Landing: 35mm down
    - Experience level: Intermediate
    - Plane type: Scale Military
    RECOMMENDED MOTOR AND BATTERY SET UP
    - Motor: hacker brushless A60 (not included)
    - Propeller: 22x12 APC E (not included)
    - Lipo cell: 12 cells / 5000 – 6000mAh (not included)
    - Esc: 120-160A / HV (not included)
    Feature
    - Designed for compatibility with both GP and EP flight
    - Covered in genuine ORACOVER®
    - Air-retract With CNC Suspension Metal Struts included
    - Retractable Tail Wheel with Gear Doors included
    - Full-depth cockpit and instrument panel and pilot included
    - Scale plastic bomb included
    - Bolt-on two-piece wing for easy transport and setup at the field
    - Removable canopy for easy change lipo battery and set up radio
    - Strong Light Weight Construction
    - Superb flying characteristics, plus an accurate scale outline
    - High-quality hardware package included
    Colour chart
    -   White             (# 21010)
    -   Blue                (# 21050)
    -   Black              (# 21071)
    -   Silver              (# 21091)
    « Απάντηση #78 στις: Κυριακή, 18 Ιαν 2015, 19:19:13 »
    JP 105mm Alu CNC EDF Unit 12 Blade with motor(12S) 7.4kg Thrust New
    Running detail is 12S / 118A / 7.4kg(thrust)
    EDF-TURBINE Thrust Testing Stand -45Kg All Alu CNC
    Unit Selection:
      Press “UNIT” key to select the unit. The unit could be selectable among: kg,Lb,Jin,OZ,Lb:OZ
    Range of Testing:64mm to 120mm EDF/Turbin Engine
    Range of Weight:   0.000g to 45kg
    Working Voltage:  2.4~3.5V  (2*AAA Battery)
    Opration Temperatuer:10℃ to 40℃
    Tatolly Weight: 2.5kg
    « Απάντηση #79 στις: Τρίτη, 20 Ιαν 2015, 11:07:17 »
    Black Horse Corsair 50/62cc ARTF
    The world of 1/5th scale warbirds has suddenly become very affordable with the launch of the new, big, Black Horse Corsair. At 90 inch span this is a serious size model, but by careful use of laser cut, balsa and ply components, weight has been kept down to an amazing 18 1/2lbs. This low weight allows the use of affordable 50cc engines that are becoming so popular now. Fit a 62cc engine an you have real performance in the vertical.
    The outline has been kept as close to scale as possible to keep the classic look 'all Corsair' as she grooves around the sky in a manner that only big models like this can. Black Horse made sure that the gull wing angle was correct as the easy option was never a consideration.
    Not only are the multi-section flaps true to the original, there are air operated, twist and turn retracts included complete with functioning oleo legs. These are items that are nearly always a major additional cost in many models of this size, not so with Black Horse, they're there as standard!! An air tank must be purchased separately and we recommend the SkyRC 300ml unit (Z-SKYRE0307) in this application.
    For easy of transpotation, the individual wing sides can be easily removed.
    The whole model is clothed in duarble Oracover covering, so she will retain her looks for many years to come. The use of Oracover means that damaged covering is easily and exactly matched by a visit to your local model shop.
    Flying is so predictable and easy that you could even make her your first warbird. The stall is benign and she handles predictably and stabiliy at all speeds.
    Go on, you know you want to!!!
    Specification
    Wingspan: 2310mm (90.04in)
    Length:1750mm (68.90in)
    Weight:8.4kg (18.52lbs_
    Servos:9 Servos (8kg min on elevator/aileron)
    Radio System: 6/7 Channel
    IC Engine:    50 -62cc Petrol
    « Τελευταία τροποποίηση: Τρίτη, 20 Ιαν 2015, 11:40:25 από DIAMOND » Καταγράφηκε
    « Απάντηση #80 στις: Τρίτη, 20 Ιαν 2015, 11:28:43 »
    Joysway Offshore Infinity Brushless w/o Tx-Rx
    • Self-righting hull design
    • Two blade nylon propeller
    • CNC aluminum alloy rudder
    • Stainless steel turn fin
    Specification
    Hull Length:550mm
    Hull Material:Fiberglass
    Length:610mm
    Servos:1x 9g Metal Geared (Inc.)
    Radio System:2 Channel 2.4Ghz (Required.)
    Electric Motor:B2850 Water Cooled (Inc.)
    Speed:60 kph
    Speed Controller:60A Water Cooled (Inc.)
    LiPo:   3S 11.1v 2200mAh 25C (Rec.)
    Beam:165mm
    « Απάντηση #81 στις: Τετάρτη, 4 Φεβ 2015, 10:18:20 »
    FLYMODEL T6 Texan 140 wingspan:2100mm
    Top quality balsa and plywood construction
    All wood constructions with fiberglass fuselage and the middle part of wings
    Trimmed and painted cowling by fuel proof paint
    Hand iron-on color covering
    Wing Span: 82 in / 2100 mm
    Wing Area: 975 sq in / 65 sq dm
    Flying Weight: 12lbs / 5500g
    Fuselage Length: 55 in / 1400mm
    Radio Required: 4-5channels, 5-6 servos
    Engine Required: 2C:1.40
    « Απάντηση #82 στις: Τετάρτη, 4 Φεβ 2015, 10:39:07 »
    X-Teamrc All Alu EDF 120mm 12 Blade 7kg-9.0kg thrust
    Electric Ducted Fan X-team rc 120MM
    Manufacturer X-team rc
    Fan Swept Area 88.4 sq.cm
    Static Thrust (g ) 12S/7600-9000g
    Max Efficiency 80%
    Max Rpm 72,000
    Anti -flying out Shroud Diameter 134mm
    Inside Diameter 117.5mm
    Shroud Length 85mm
    EDF Material CNC alu alloy T7009
    Rotor Type/Material 12 blade metal alu alloy
    Ducted Fan Weight 280g (without motor)
    Motor Diameter 58mm
    Motor Shaft 8mm
    « Απάντηση #83 στις: Τετάρτη, 4 Φεβ 2015, 10:47:21 »
    X-Team Digital Servo XTD-5515MG 15KG High Precision Metal Gear
    FEATURE:
    -- High performance digital standard servo
    -- High-precision Taiwan-made metal gears
    -- High quality brushed motor
    -- Dual ball bearings
    SPECIFICATIONS:
    Dead band: 2μsl
    Working frequence: 1520μs / 330hz
    Operating Voltage:  DC4.8~6.0 V
    Operating Speed (4.8V): 0.18 sec/60 degrees
    Operating Speed (6V): 0.16 sec/60 degrees
    Stall Torque (4.8V): 14.25 kg.cm (197.93 oz/in)
    Stall Torque (6V):  15.32 kg。cm (212.79 oz/in)
    Dimensions: 40.5X20.2X38mm /1.59 X0.80X49 in
    Weight:  55.6 g (1.96oz)
    Connector Wire Length: JR  265 mm (10.43in)
    Bearing: 2BB
    « Απάντηση #84 στις: Τετάρτη, 4 Φεβ 2015, 10:58:59 »
    X-Teamrc All Alu EDF 80mm 12 Blade 2.37kg-3.35kg thrust
    Electric Ducted Fan X-team rc 80MM
    Static Thrust (g ) 2.35kg-3.350kg
    Max Efficiency 80%
    Max Rpm 76,600
    Anti -flying out Shroud Diameter 89mm
    Inside Diameter 78.15mm
    Shroud Length 55mm
    Ducted Fan Weight 98g (without motor)
    Motor Diameter 29mm
    Motor Shaft 4mm
    « Απάντηση #85 στις: Τετάρτη, 4 Φεβ 2015, 11:14:55 »
    X-Team XTI-57113 Series 4-Poles Inrunner Brushless Motor for 1/5 cars,1800mm Boat,120mm EDFs
    Product introduction
    Available for class 750 - 1/5th scale vehicles, 1800mm boat and 120mm EDF
    Number of stator slot: 12G 4Poll
    Sensored or sensorless: Sensorless
    Diameter of shaft:Φ8mm
    motor size: Diameter Φ57 /113mm
    Stator diameter: Φ51.3mm
    Max volt:44,4 volt
    Nomimal power:7600 watt
    Rpm/volt: 850KV
    Weight: 1160g
    Technique:
    • Hand-wound for maximum copper fill.
    • Precision-balanced rotor will boost the efficiency and
       power performance of the motor.
    • Nickel-plated sintered neodymium rotor for maximum
       motor acceleration, braking power and performance
       in high-temperature conditions.
    « Απάντηση #86 στις: Τετάρτη, 4 Φεβ 2015, 11:23:32 »
    FLYMODEL Embraer 312F-120
    All wood constructions with fiberglass parts
    Comes with all hardware and accessories
    Wing Span: 1780 mm
    Wing Area: 662 sq in / 43 sq dm
    Flying Weight: 9.25lb / 4200 g
    Fuselage Length: 59 in / 1530 mm
    Engine Required: 4 C: 1.20 cu in
    Radio Reqired: 5channels ; 8 - 9 servos
    « Απάντηση #87 στις: Πέμπτη, 12 Φεβ 2015, 13:39:53 »
    PHOENIX MODEL Pilatus PC9 .61-.91/15-20cc ARF plane with Air retracts
       Designed for compability with both GP and EP flight
        Fully scale panel cockpit and scale pilot included
        Lightweight balsa-and-plywood construction
        95% factory built, covered and painted
        1 full set heavy duty air retract included
        All hardware included
    Colour chart:
        White (21-010)
        Ferrari Red (21-023)
        Blue (21-050)
    Requires:
        Engine: 2-stroke .61-.91 cu in (9.99 - 14.91 cm3) or 15-20cc gas engine
        6 channel radio with compatible receiver
        7 Servos
    Manufacturer stock No. TPM07
    Technical data
    Length:    1580 mm
    Wingspan:    1730 mm
    Weight:    4400 - 4700 g
    « Απάντηση #88 στις: Πέμπτη, 12 Φεβ 2015, 14:15:06 »
    Hurricane PNP With Retracts Wingspan:1000mm
    Overview
    The Art-Tech Hurricane captures the very essence of one of the most beautiful and most influential warbirds of WWll. It shares many of the characteristics that made the full size aircraft a pilots favourite. The Hurricane is smooth, highly responsive and exciting model to fly.
    The brushless motor and ESC combination gives ample power enabling you to fly this warbird how it deserves to be flown, fast low passes before breaking to the left and up in to a barrel roll ready to attack the next adversary.
    Airframe
    This superb scale model features electronic retracts fitted as standard so that once in flight you can streamline the model and start to beat up the strip.
    Moulded in 'EPOFLEXY' the scale detailing on this model will impress even the most skilled scratch builder and you can be up and flying with the model in under an hour, spend time flying rather than building.
    Featuring:
    Length    780mm (30.7")
    Wingspan    1000mm (39.4")
    Weight    680g (24oz)
    Servos    4 x 9g
    Recommended Battery    11.1v Li-Po 1300mAh
    Electronic Retracts Pre-Installed
    Wingtip Lights
    Tough EPOFLEXY Construction
    3 Bladed Prop
    Brushless ESC and Motor Pre-Installed
    4 x 9g Servos Pre-Installed
    « Απάντηση #89 στις: Πέμπτη, 12 Φεβ 2015, 14:18:47 »
    PHOENIX MODEL Tucano .46-.55 ARF 1:7 scale plane
    Tucano ARF is a great scale airplane for anyone who likes scale flying. Extreme good looks, reputation for speed, scale outline, ease of assembly, and competitive price. This is one of those models I just had to begin as soon as I got it, and I’m sure it will have the same effect on you. The Tucano is a top-quality ARF that ought to be on your buy list. You will not be disappointed and you will be the envy at your flying field.
    Features:
        Quality materials and genuine ORACOVER covering
        Accurately-etched panel lines and factory-applied paint scheme
        Fully detailed, factory-installed cockpit, pilot and canopy
        Extremely lightweight laser-cut all-wood construction
        True-to-scale artworkScale outline is enhanced by the lightweight fiberglass cowl
        Can be converted for electric flight
        Flies with a wide variety of engines
    Colour chart:
        White           (21-010)
        Black            (21-071)
    Requires:
        Engine: 2-stroke .40-.46 cu in (6.55 - 7.53 cm3)
        4~9 channel radio with compatible receiver
        5 Servos
    Manufacturer stock No. PH042
    Technical data
    Length:    1359
    Wingspan:    1578 mm
    Weight:    2,9 - 3,2 kg
    Wing area:    39,4 dm2
    Wing loading:    80 g/dm2
    Σελίδες: 1 ... 3 4 5 [6] 7 8 9 ... 24     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: www.Diamond-Models.gr
    Δημιουργία σελίδας σε 0.042 δευτερόλεπτα. 26 ερωτήματα.
