Κυριακή, 18 Οκτ 2026, 02:56:28
    [Χθες στις 16:17]
    Online σήμερα: 25
    Επισκέπτες: 25
    Συνολικά: 25
    Σελίδες: 1 2 3 4 [5] 6 7 8 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 207488 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #60 στις: Τετάρτη, 5 Νοε 2014, 21:20:31 »
    High Grade Aluminium Alloy Electric Retract SET (3 PCS) For Planes 5Kg-7Kg
    Dimensions:    80mm*22mm*27mm
    Axles Diameter:    10mm
    Thickness:    3mm
    Weight:    67g
    Retract Controller:    1 with doors controler
    Wire Length:     300mm
    Motor:1215 brush motor
    Alu Electric Retract with Alu Strut and Electric Brake wheels Set of 3 for 5Kg-7Kg jet
    Type:    RLB-1
    Eletric Retract:    Three Units
    Length:    191.36mm
    Oleo Strut:    Three Units
    front wheel:    Singe/Double
    Totally Weight:    500g
    Electric Brake wheel:    Two Units
    Jet Type:    5kg to 7kg Jet
    Contorller:1*Retract Contorller and 1*Brake Wheel Contorller
    Alu Oleo Strut set with two wheel nose strut D=10MM
    Type:    Oleo Strut
    Size of Front Wheel:    40mm
    Diameter:    10mm    \
    Size of Main Wheel:    50mm to 65mm
    Length:    153mm
    Weight:    121g
    Το Hobby σας είναι η δουλειά μας
    « Απάντηση #61 στις: Τετάρτη, 5 Νοε 2014, 21:43:59 »
    J3 Cub EPO span 1400mm PnP by MaxThrust
    With its large 1400mm (55.1“) wingspan, superb flight performance and durable EPOFLEXY construction, this J3 Cub is for the connoisseur! Optimised for use with 4S Li-Po batteries, the powerful brushless motor provides sufficient power for take-offs from the shortest flying strips.
    Featuring pre-installed servos, factory applied decals with oodles of scale detail and a choice of two authentic colour schemes.
    Assembled in a few hours, it makes a perfect sport-scale choice for the novice, but will be equally popular with experienced pilots seeking a realistic aircraft that’s not too demanding to fly.
    Whats Included
    The Plug and Play version of the Cub includes 4 servos (4x 9g), a brushless ESC and a brushless motor all pre-installed.
    To have this model ready for flight you will need a transmitter and receiver (4 channels or more) a Li-Po flight battery (14.8v 2250mAh) and a compatible charger.
    Features
    Decals Pre-Applied
    Durable EPOFLEXY Construction
    Powerful Brushless Motor
    Brushless ESC
    Scale Detailing
    Plug and Play
    This model comes complete just requiring your own transmitter, receiver, battery and charger.
    Wingspan    1400mm (55.1")
    Length    950mm (37.4")
    Weight    1800g (16.6oz)
    Servos    9g x 4
    Recommended Battery    2250mAh 14.8v Li-Po
    STOL 500 class PnP
    Overview
    The Art-Tech STOL is part of the next generation of models from this famous brand. Now manufactured with top quality electronics including HobbyWing ESC's you can rely on top performance all the way.
    The STOL is a unique aircraft and is named after its main purpose Short Take-Off and Landing. This is achieved through advanced aerodynamics and the ability to change the wing section for landing and take-off. It achieves this through a bit of ingenious design, the flaps and leading edge slats are interconnected so as to provide incredible lift at low speeds. Once airborne you can set these back to normal for sports aerobatics and then back again for slow short landings.
    Features
    The STOL has been designed as a parachute drop aircraft or toffee bomber to add even more flying fun and pleasure, try some parachute spot landing it's much harder and more fun than you can imagine!
        30A Brushless ESC
        Leading Edge Slats
        Trailing Edge Flaps
        Drop Bay for Optional Parachuting Figure
        Large Tyres for Rough Ground or Grass
        Tough, Coloured EPOFLEXY Construction
    What's Included
    This Plug and Play kit contains 7 x 9g servos, 1x Brushless Motor, 1x 30A Brushless ESC and 1x 500 Class STOL Airframe.
    To make this model flight ready, you will require:
    1x 11.1v 1800mAh Li-Po flight battery, 1x 5 (or more) Channel Receiver and Transmitter.
    Specification
    Wingspan    1254mm (49.4")
    Length    988mm (38.9")
    Weight    1440g (50.8oz)
    Servos    7 x 9g
    Recommended Battery    11.1v 1800mAh Li-Po
    « Απάντηση #62 στις: Τετάρτη, 5 Νοε 2014, 21:50:21 »
    PC6 Turbo Porter 600 class PnP
    Overview
    The PC6 is a classic work horse of the sky at many airfields around the world, with its fantastic climb and descent abilities it is perfect for getting skydivers up to height and then back down on to the ground in the shortest possible time. Also very well suited to glider tugging the PC6 is a very versatile aircraft.
    Art-Tech along with Century UK have developed the 1.7 metre model to imitate the full size aircraft. With ample power you can tow up a 3 metre R/C model glider and with the included tug release system let them go when up to height.
    It's a bit different but then that's its appeal.
    Features
    The model can climb near vertical on full power and also descend vertically with full flaps deployed to a walking speed landing. Never before has such all round performance been available in a sport aircraft of the type.
        40A Brushless ESC
        Trailing Edge Flaps
        Electronic Tow Hook
        Wingtip LED Lighting
        Tough EPOFLEXY Construction
    Specification
    Wingspan    1700mm (66.9")
    Length    1252mm (49.3")
    Weight    1900g (67oz)
    Servos    1 x 9g, 6 x 17g
    Recommended Battery    14.8v 3000mAh Li-Po
    « Απάντηση #63 στις: Τετάρτη, 5 Νοε 2014, 22:06:14 »
    ΝΕΟ!!!! CX20 Auto Pathfinder 350 QUADCOPTER με GPS ,Altitude hold RTF = 318€
    [url=https://www.youtube.com/watch?feature=player_detailpage&v=Vx6AHmhoHq4]
    The CX20 Auto Pathfinder is the ultimate in next generation Quadcopter.
    The model comes fitted with GPS, an electronic compass and altitude sensors and features a GPS hold system. The GPS hold system allows you to fly a position of your choice and then with the flick of a switch the onboard electronics hold the model there. The failsafe and Return To Home functions allow the model to return back to its take-off point on it's own either when you choose, or when the radio signal is lost or interrupted. These systems combined with the super stable flight dynamics make for an incredibly easy to use model that is also a joy to fly.
    Features
    Fixed Position Hover
    Using a combination of a GPS receiver capable of reading from up to 12 satellites at once, an electronic compass to keep its heading locked and altitude sensors to maintain height, flick a switch and the CX20 will hover on the spot.
    Altitude Hold
    The CX20 has a unique altitude lock feature, using altitude sensors, in altitude hold mode, it maintains a steady height, allowing you to get those great panning shots without needing to worry about controlling the height.
    Return To Home
    At the touch of a button, the CX20 will fly straight along to above the spot it took off from, then gently descend until it touches down at your feet. Perfect for those moments when you've lost orientation or have your hands a little full and need to bring it back safely.
    This feature also works if you lose radio contact to the model. On sensing that radio signal has been lost, the CX20 will automatically return to the take-off position.
    Auto Landing Failsafe
    When your battery starts getting low, the CX20 will automatically begin descending to land in a safe and controlled manner.
    Intelligent Orientation Control (IOC)
    Using the onboard electronic compass and GPS sensors, the CX20 has a switchable IOC function. With the IOC function enabled, the model will always fly in the direction you push the controls, which means you don’t need to worry about which way the model is facing and can concentrate on bringing it back to base or getting that perfect camera shot.
    Throttle Lock
    Before any flight, the CX20 automatically locks it's throttle system to prevent accidental start-up and possible damage, allowing you to make any fine adjustments to your camera system (if fitted) without having to worry about getting near those blades. Once everything is set and ready, a small flick of the rudder and everything is live. Don't worry if it's not quite right, as re-locking the throttle is just as easy!
    GoPro Hero 3 and Hero3+ Compatible Camera Mount (Optional Extra)
    With the addition of a GoPro Hero3 and Hero3+ compatible camera mount for your CX20 Quadcopter, you can film your flight and get a true birds eye of your flying site.
    Specifications
    Rotor Diameter    570mm (22.44")
    Rotor Blade Length    206mm (8.11")
    Battery    11.1v 2700mAh Li-Po
    Length    300mm
    Width    300mm
    Height    200mm
    Approx. Flight Time    10 minutes
    Number of Channels    8
    [/url]
    « Τελευταία τροποποίηση: Τετάρτη, 5 Νοε 2014, 22:35:59 από DIAMOND » Καταγράφηκε
    « Απάντηση #64 στις: Δευτέρα, 10 Νοε 2014, 21:05:14 »
    PHOENIX MODEL TUCANO size .61-.91 or 15cc SCALE 1:6 ½ ARF Wingspan:1720mm
    Introducing
        A great airplane! Its Semi symmetrical airfoil and long tail moment deliver precise aerobatic performance for experienced pilots, yet the Tucano's superb stability and ultralight wing loading make it an ideal first low–wing model. This ARF has been designed to keep building time to a minimum; it's 90% pre-built, with premium covering. The better you get the more fun it gives you!
    Technical data
    - Wingspan: 1730mm (68.1in)
    - Length: 1450mm (57.1 in)
    - Flying weight: 4.2 - 4.8 kg
    - Wing area: 46.6 dm2
    - Wing loading: 80g/dm2
    - Wing type: Naca airfoils
    - Covering type: Genuine ORACOVER®
    - Retract gear type: Air-retract With CNC Suspension Metal Struts (included)
    - Spinner size: Plastic 70mm (included)
    - Radio: 6 channel minimum (not included)
    - Servo: 7 standard servo: 2 aileron; 1 elevator; 1 rudder; 1 steering nose; 1 retract; 1 throttle (not included)
    - Recommended receiver battery: 4,8-6.0V 1200-2000mAh NiMH (not included)
    - Servo mount: 21mm x 42 mm
    - Propeller: suit with your engine
    - Engine: .61-.91 / 2-stroke or .91 / 4 stroke glow engine (not included)
    - Motor: brushless outrunner 1800-2000 W, 500 KV (not included)
    - Gravity CG: 100 mm (7 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 8mm up/down, 10% expo; High: 10mm up/down, 10% expo
    - Control throw Elevators: Low: 8mm up/down, 12% expo; High: 10mm up/down, 12% expo
    - Control throw Rudder: Low: 30mm right/left, 15% expo; High: 40mm right/left, 15% expo
    - Experience level: Intermediate
    RECOMMENDED MOTOR AND BATTERY SET UP
    - Motor: Rimfire.60 (not included)
    - Propeller: 15x6- 15x8 E APC (not included)
    - Lipo cell: 6 cells / 4000 – 5500mAh (not included)
    - Esc: 60-100A (not included)
    Feature
    - Designed for compatibility with both GP and EP flight
    - Covered in genuine ORACOVER®
    - Top quality balsa/light plywood construction
    - Air-retract With CNC Suspension Metal Struts included
    - Full-depth cockpit and instrument panel and pilot included
    - Scale plastic rocket included
    - Bolt-on two-piece wing for easy transport and setup at the field
    - Removable canopy for easy change lipo battery and set up radio
    - Strong Light Weight Construction
    - Superb flying characteristics, plus an accurate scale outline
    - High-quality hardware package included
    Colour chart
    •  Light green    (# 21042)
    •  Blue                (# 21050)
    •  Cub Yellow    (# 21030)
    •  White              (# 21010)
    •  Black               (# 21071)
    « Απάντηση #65 στις: Δευτέρα, 10 Νοε 2014, 21:25:18 »
    Νέες Παραλαβές 10-11-2014
    SANWA 94813 (Micro 18g) Digital servo
    APC 10x6 4-blade propeller
    Aluminium Servo Arm Double-arm Futaba 98mm
    Aluminium Servo Arm Double-arm for Futaba 111mm
    Q-Model Knife edge body hole reamer
    Aluminium Long Servo Arm (Futaba) Double-arm
    « Απάντηση #66 στις: Πέμπτη, 20 Νοε 2014, 13:43:20 »
    Black Horse Sky Jet EP ARTF
    Inspired by a classic jet trainer aircraft the Sky Jet is a simply beautiful model. Built from quality balsa and ply using the latest in CAD design and CNC construction techniques, weight is kept to a minimum.
    The Sky Jet is designed to suit 90mm electric ducted fan units such as Wemotec 90mm Midi Fan Evo. That combined with an HET 650-68-2000 motor, 120A ESC and a 6S 22.2v 6,700mAh Li-Po (2x 6S 3,350mAh in parallel). It would also suit turbine conversions (no turbine information is supplied).
    • Includes metal oleo main and nose struts
    • Suits an electric retract set capable of 5kg weight
    • Balsa & Ply construction using CAD design
    • Covered in Oracover
    • Detailed cockpit
    • Tip tanks included
    Specification
    Wingspan:    1,400mm (55.12")
    Length:    1,350mm (53.15")
    Weight:    4,000g (8.8 lb)
    Servos:    8 Mini (Req.)
    Radio System:    8 Channel (Req.)
    Electric Motor:    HET 650-68-2000 (Rec.)
    EDF Fan Diameter:    90mm (Req.)
    Speed Controller:    120A (Req.)
    LiPo:    2x 6S 22.2v 3350mAh (Req.)
    « Απάντηση #67 στις: Πέμπτη, 20 Νοε 2014, 13:50:58 »
    Νέες Παραλαβές Νοεμβρίου
    Hi-Flow Filler Valve Glo/Petrol/Jet
    Ripmax Dagger EP ARTF
    Developed with one thing in mind... performance! Small enough to transport easily, this one-piece delta is the most exciting thing we’ve flown this year.
    The wings, fuselage and fins are supplied pre-covered in this dramatic film scheme, ready for rapid final assembly before installation of your choice of brushless motor and three channel R/C. Designed for mini servos (we used Ripmax SD200s on the prototypes) and a choice of 3 or 4S Li-Pos, the Dagger has a fantastic turn of speed, yet is almost impossible to stall. A vice-free performer, the Dagger is simple to launch with handy finger grips on the underside.
    • CNC balsa construction
    • Attractive colour scheme
    • Metal backplate spinner
    • Amazing roll rate
    Specification
    Wingspan:    850mm (34.5")
    Length:    710mm (28")
    Weight:    920g (32.5oz)
    Radio System:    3 Channel with Delta Mixing (Req.)
    Electric Motor:    Quantum II 20 Speed (Rec.)
    LiPo:    3-4S 2200mAh 30C (Req.)
    Speed Controller:    Quantum 60A (Rec.)
    Deluxe Materials Model Lite Lightweight Filler (Balsa)
    EUROKIT New Pair of rubber wheels , aluminium rim mm 100
    EUROKIT Large retractable L/G
    « Απάντηση #68 στις: Παρασκευή, 28 Νοε 2014, 18:51:05 »
    Jamara Servo AQUA7 MG
    Operating Temperature 0 ~ 60
    Operating voltage 5 - 6 V
    Operating time (5 V) 0.14 sec. / 60 °
    Operating time (6 V) 0.12 sec. / 60 °
    Force in kg (5 V) 6
    Force in kg (6 V) 7
    Dimensions in mm 40.5 x 20 x 39.3
    Weight in g 54.7
    Our proven Q7-purpose servo is now also available with ball-bearing full metal gearbox in a waterproof version.
    In addition to the fast response time of 0.12 sec and a force of 7 kg,
    it also has 3 rubber seals in the ground, cover and splined shaft. And all this at a weight of only 54 grams.
    ECO Power Box 8-16 incl. Main Switch (5 - 12V systeem)
    Power distribution system including power switch.
    8 receiver channels in and 16 servo channels out.
    Optimized for use with LiFe (A123) and LiPo batteries. See LiFe (A123) 2600mAh 6.6V battery.
    Also suitable for LiPo with an additional BEC.
    Note: Receiver voltage is equal to battery voltage
    Specification:
        8 Inputs (A,B,C,D,E,F,G,H)
        16 Buffered/Filtered and amplified outputs (A,A,B,B,C,C,D,D,E,E,F,F,G,G,H,H)
        Including overall power switch.
        Robust design, the receiver and servo's will  be power with a malfunction of the power switch.
        Optimized for use with 2 cell LiFe (A123) and 2S LiPo battery. Can be used without a BEC.
        Can be used with 4/5 cell NiCd or NiMh battery
        Optimized for 6V and HV servos
        No seperate Radio battery needed
        Mounting receiver at the middle of the power box
        Dual Battery Inputs - Auto Load sharing and
        Failsafe switch over between batteries
        Includes rubber grommets , Deans connectors and screws
        30Amp power bus
        Deans Input Connections
        Includes 8 leads for connection to receiver, additional leads can be purchased seperately
        Works with PPM , PCM, 2.4Ghz systems
        Suitable for both analog as well as digital servos
        5 volt Minimum input is required (preferred regulated) - 12.6 Volt Max Input
    « Απάντηση #69 στις: Κυριακή, 7 Δεκ 2014, 11:08:34 »
    DLE55RA gas engine with rear exhaust (55cc, 5.5hp, 1570gr)
    DLE 50cc takes performance to a new level with the rear exhaust DLE-55RA.
    Everything about this engine screams performance from the piston skirt - designed to be lightweight for quick throttle response and tons of power - to the rear exhaust
    That lets you easily install a tuned pipe in your aircraft.
    The 55RA biedt 100 rpm more than the standard DLE-55.
    It includes engines standoffs, electronic ignition, spark plug and Pitts style muffler.
      Technical Specification:
      Cylinder Capacity 55.6 ccm
      Power 5.5 hp  4.0 kW
      RPM 1350 - 8500 r / min
      Propeller 22x8 - 23x10 inches
      Electronic ignition voltage 4.8 to 8.4 volts
      Fuel ratio 30: 1 petrol: oil
      weight:  Engine 1330 grams  Exhaust 90 gram  Inflammation 145 grams
      documentation:  User Manual User Manual DLE55RA
    NGH GF38 4-stroke gas engine (38cc, 3.6hp, 1310gr)
     Displacement
    (Cylinder Inhoud)     38 ccm
     Output Power             3.6hp/ 2.7 kW
     Carburetor  Walbro WT1022
     Speed Range     1800 - 8300 rpm
     Propeller     18x8-10 - 20x8     inch
     Ignition power supply  4.8 - 6     Volt
     Spinner bout diameter     9.5      mm
     Gas/Oil mix ratio            (Brandstof verhouding)     35 : 1     gas : oil
     Weight:
     Engine     1295     gram
     Muffler     15     gram
     Ignition     120     gram
     Documentation:
     User Manual   NGH GF38 User Manual
     Afstellen Ontsteking Walbro Manual     Wallbro WT Series Manual
    « Τελευταία τροποποίηση: Κυριακή, 7 Δεκ 2014, 11:19:10 από DIAMOND » Καταγράφηκε
    « Απάντηση #70 στις: Κυριακή, 7 Δεκ 2014, 11:32:37 »
    KARATE BLACK BELT AC/DC 100W 7A
    Technical data
    Input voltage:    100-240 V (AC); 11-18 V (DC)
    Charging power:    max. 100 W
    Discharging power:    max. 5 W
    Charging current:    0,1-7,0 A
    Discharging current:    0,1-1,0 A
    Balancing current:    300 mA/Zelle
    Cell count:    1-15 Nickel; 1-6 Lithium
    Pb voltage:    2-20 V
    Fan:    vorhanden
    Temperature sensor connection:    vorhanden
    Dimensions:    111 x 135 x 60 mm
    Weight:    390 g
    « Απάντηση #71 στις: Κυριακή, 7 Δεκ 2014, 11:41:54 »
    Νέες Παραλαβές σε Ελικες Fiala 2-3-4-5 Blades Natural-Coloured
    « Απάντηση #72 στις: Τρίτη, 9 Δεκ 2014, 20:27:46 »
    Aeronaut TL-32 Typhoon ARF wingspan:1170mm
    Description
    This kit produces a semi-scale model of the TL32 Typhoon ultralight aircraft.The model can be ready for the air in a relatively short
    time thanks to the lightweight GRP fuselage and factory-assembled built-up wings (ARC version) / pre-covered wings (ARF version).
    The Typhoon is capable of ground take-off, and its appearance in the air is extremely close to that of its full-size counterpart. The
    model kit contains: Detailed plan and building instructions, white pigmented GRP fuselage with factory-installed wing mounting,
    ready-made built-up wing panels with servo wells installed and machined ailerons (ARC version) / film-covered ailerons (ARF version),
    CFRP wing joiner, balsa tailplane and fin, vacuum-moulded canopy, tricycle spring steel undercarriage with wheels, decal sheet and
    many small items
    Wing loading [g/dm²]   38
    Weight [g]   850-900
    Length [mm]   830
    Wingspan [mm]   1170
    Wing area [dm²]   22,84
    RC functions    elevator, ailerons, rudder, motor control
    « Απάντηση #73 στις: Τρίτη, 9 Δεκ 2014, 20:32:36 »
    Νέες Παραλαβές σε Aeronaut CAM-Carb-Blades μεγέθη απο 14"  έως 16"
    « Απάντηση #74 στις: Κυριακή, 21 Δεκ 2014, 12:18:20 »
    Udi U816 UFO/Drone - 2.4GHz RC Micro Quadcopter RTR
    This new UFO Quadcopter is something to get very exctied about! Featuring an inbuilt 6 axis gyro it comes complete with a quality 4 Channel 2.4GHz transmitter. Its included 1S, 250mAh Li-Po gives flight times of at least 7 minutes. All the features and manoeuvrability of a larger quadcopter but at a fraction of the price! Moulded foam blade cover helps prevent damage from the inevitable knocks but easily removable for those who would prefer the increase in flight agility and speed. Perfect for beginners and experts alike!
    • 6 Axis Gyro Stabilisation
    • Interchangable Body
    • Fast and manouverable
    • Easy to Fly!
    • Only 4 'AA' style batteries needed to complete
    • Dual Output Charger
    Specification
    Charge Time:    60 Minutes (2 Batteries)
    Flight Time:    7-9 Minutes
    Length:    160mm (Inc. Guard)
    Weight:    38.9g
    Radio System:    4 Channels (Inc.)
    LiPo:    1S 3.7V 240mAh (Inc.)
    Width:    160mm (Inc. Guard)
    Rotor Diameter:    57mm (Each)
    Gyro:    6-Axis (Inc.)
    GRAUPNER Giant Starlet wingspan: 2.4m
    Description
    The STARLET 2400 model is an enlargement of the model from 1982 with a wingspan of about 1525 mm. The original was offered by the company Stolp in the USA as a kit in the experimental class for amateur aircraft builders. The one-seater aircraft with the parasol design was assembled using composite construction techniques. As propulsion system, it is possible to install anything from a VW car engine to a 60-hp Continental. The docile flying characteristics make the STARLET 2400 ideal as a starting point in the area of large model flying and switching to aileron-controlled motorised models. Both internal combustion and electric motors can be used for propulsion. Simple aerobatics are possible with types of propulsion system. With the OS GT 33, vertical climbs are possible. However, the docile flight behavior means that very slow overflights can also be done. To change the drive battery inthe electric version, a large opening has been provided in the the fuselage in the area of the cockpit. The two detachable wings and the two halves of the tailplane can be removed for transport.
        ARTF model (almost ready to fly)
        Complete balsa/plywood design
        Ideal for switching to large aileron-controlled models
        Fuselage, wings, and tailplane pre-covered with multicolored foil
        Wheels, small parts, and accessories for rudder linkage
        Parts included for electric installation
        Protective bags for wing and tailplane halves and vertical stabiliser
    spare parts
    Information
        ARTF(Almost Ready to Fly)
        Aerobatic trainer
        Wings and tailplane halves can be removed for transport
    RC functions
    Rudder linked to tailwheel
    Elevators
    Ailerons
    Speed controller
    Specification
    Wing area : 76 dm²
    All-up weight, approx.: 6500 g
    Total surface area, approx. : 91 dm²
    Hull length, approx. : 1540 mm
    Tailplane area : 15 dm²
    Wingspan approx.: 2400 mm
    PHOENIX MODEL PC21 PILATUS .120 SCALE 1:5 ARF
    Introducing
        From November 1997, Pilatus flew a modified PC-7 Mk.II to test various improvements for a next generation turboprop trainer. In November 1998, Pilatus decided to privately fund the development of the PC-21 training system. Full-scale development was launched in January 1999. Extensive wind tunnel tests were performed to validate the CAD/CAM design. A PC-7 MK.II was converted into a proof of concept aircraft to test higher wing loadings, spoilers, the 1600 shp engine and power management system. Roll out of the first PC-21 prototype was on 30 April 2002 at the Stans factory. The aircraft will be certified in 2004, with first deliveries possible from late that year, it was said at the roll out.
        Now you can experience the spirit of the PILATUS in this giant-scale dream, PHOENIX MODEL's 1.20 sized replica of he real thing. The PILATUS PC21 ARF, based on the most recent version of the PC21, is an easy-to-assemble, easy -to-fly blast for any pilot interested in large-scale flight. Functioning scale flaps make takeoffs and landings a breeze. Factory-created scale detail like the canopy, control surfaces. Its authentic ORACOVER covering supplies a superior sheen. The PILATUS PC21 ARF is part of PHOENIX MODEL's complete line of top-quality aircraft and accessories.
    Technical data
    - Wingspan: 1772mm (69.72in)
    - Length: 2019mm (79.5 in)
    - Flying weight: 6.4 - 7.2 kg
    - Wing area: 57.6 dm2
    - Wing loading: 113g/dm2
    - Spinner size: 90mm (included)
    - Servo: 10 standard servo: 2 aileron;2 flap; 2 elevator; 1 rudder; 1 steering nose; 1 retract; 1 throttle (not included)
    - Recommended receiver battery: 4,8-6.0V 2000mAh NiMH (not included)
    - Engine: 1.20/ 2-stroke or 1.40/4-stroke glow engine or 20-30cc gas engine (not included)
    - Motor: brushless outrunner 1600-2200 W, 450 KV (not included)
    - Gravity CG: 166 mm (6.5 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 10mm up/down, 10% expo; High: 12mm up/down, 10% expo
    - Control throw Elevators: Low: 10mm up/down, 12% expo; High: 12mm up/down, 12% expo
    - Control throw Flaps: Mid: 25mm down; Landing: 35mm down
    - Plane type: Scale Military
    - Motor: RIMFIRE .120 (not included)
    - Lipo cell: 5-6 cells / 5500 – 6000mAh (not included)
    - Esc: 120-160A (not included)
    Feature
    Ευχόμαστε Ολόψυχα σε Όλους Καλά Χριστούγεννα
    και
    Χαρούμενο  2015 !!!
    Σελίδες: 1 2 3 4 [5] 6 7 8 ... 24     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: www.Diamond-Models.gr
    Δημιουργία σελίδας σε 0.065 δευτερόλεπτα. 26 ερωτήματα.
