Τετάρτη, 14 Οκτ 2026, 10:27:43
    Online σήμερα: 87
    Επισκέπτες: 73
    Συνολικά: 75
    Σελίδες: 1 2 3 [4] 5 6 7 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 207176 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #45 στις: Κυριακή, 5 Οκτ 2014, 12:53:15 »
    ]Νέα Παραλαβή Οκτωμβρίου
    Black Horse L-39 Albatros 90mm EDF ARTF
    The L-39 is the most widely used jet trainer in the world and has served with over 30 air forces. In addition to performing basic and advanced pilot training, it has also flown combat missions in a light-attack role.
    Black Horse has managed to faithfully recreate this iconic jet using the clever lightweight CNC construction techniques they have become well known for. The fuselage features a hinged opening canopy and removable cockpit interior allowing a large access hatch for easy battery access. Black Horse paid extra attention to this cockpit on this model and used hand painted vac-form components to reproduce a very detailed cockpit area. The wing and tailplane halves plug in to the fuselage on an aluminium spar and are removable for easy transportation.
    Supplied complete with mechanical retract units and tough CNC machined oleo legs. The sprung oleos help with ground handling and she copes well with grass surfaces.
    The L-39 is designed to suit higher end 90mm electric ducted fan units and 8S battery setups. A good example would be a Wemotec 90mm Midi Fan Evo, HET 650-68-1500 motor, 120A HV ESC and a 8S 29.6v 6,000mAh Li-Po. It would also suit turbine conversions (no turbine information is supplied).
    • Mechanical retracts, oleos and wheels included
    • Detailed cockpit and pilot
    • Balsa/Ply construction using advanced CNC techniques
    • Covered with high quality Oracover film
    Specification
    Wingspan:    1,450mm
    Length:    1,860mm
    Weight:    4.3 - 4.6 kg
    Servos:    8 (+3 Retract) (Req.)
    Radio System:    8 Channel (Req.)
    Electric Motor:    from 1000kv-2000kv (Req.)
    EDF Fan Diameter:    90mm (Req.)
    Speed Controller:    85-HV--120A-6s (Rec.)
    LiPo:    6s-10S  5,000-6,000mAh (Req.)
    « Απάντηση #46 στις: Σάββατο, 11 Οκτ 2014, 11:18:49 »
    Saturn X6 6 Channel Combo 2.4GHz FHSS
    A revised version of the 6 channel high performance Saturn 2.4GHz radio system at an incredibly low price! Perfect for receiver-ready models as it is supplied without servos. A new full-range, even smaller six channel receiver is supplied as standard.
     Interference-Free 2.4GHz Technology
     4 Channel Digital Proportional Radio with two extra switched channels.
     Servo Reversing on main channels
     Battery Condition LEDs
     Lightweight 6 Channel Receiver Included!
    Specification
    Modulation:    Saturn X 2.4GHz
    Channels:    6
    « Απάντηση #47 στις: Σάββατο, 11 Οκτ 2014, 11:25:03 »
    JOYSWAY electric "BULLET" model RTR
    Shooting across the water, the new Bullet Speedboat will certainly leave its mark. Supplied with 2.4GHz radio gear, a 30A water-cooled brushless ESC w/ BEC mated to a powerful 2815 out-runner brushless motor, tough 37g steering servo and CNC aluminium rudder, it just requires an 11.1V 2200mAh 20C LiPo pack, balance charger plus 8 'AA' batteries for the transmitter to complete.
    Specification
    Hull Material:    One Piece Blow Moulded
    Length:    729mm (28.7")
    Weight:    1.25kg (2.75lb)
    Servos:    1x 37g (Inc.)
    Radio System:    3 Channel 2.4GHz (Inc.)
    Electric Motor:    Water Cooled 2815 Outrunner (Inc.)
    Speed Controller:    30A Water Coolled (Inc.)
    LiPo:    11.1v 2200mAh 20C (Req.)
    Beam:    180mm (7.1")
    « Απάντηση #48 στις: Σάββατο, 11 Οκτ 2014, 11:40:56 »
    Zenoah G450PU Air και Zenoah G380PU Air
    « Απάντηση #49 στις: Σάββατο, 11 Οκτ 2014, 11:57:54 »
    Νέες Παραλαβές σε Μπαταρίες
    Ripmax 6.0v 2500mAh Eneloop Rx Pack Hump
    Ripmax Vanquish 7.2v 3000mAh Ni-MH Battery with Tamiya Connector
    Hi-Energy 6.0v 1600mAh "A" Ni-MH Rx Pk Flat
    Hi-Energy 4.8V 2200mAh Ni-MH Rx Pk Square
    Hi-Energy 6.0v 2200mAh Ni-MH Rx Pk Flat
    Intellect 2S 240mAh 25C Li-Po
    UDI U9/10/21  Battery
    Ripmax Li-Po Battery 3.7v 1100mah
    « Απάντηση #50 στις: Πέμπτη, 16 Οκτ 2014, 10:52:07 »
    PHOENIX MODEL P51- MUSTANG 60CC SCALE 1:5 1/4 ARF
    Introducing
        The P-51 Mustang was a solution to the clear need for an effective bomber escort. The Mustang was at least as simple as other aircraft of its era. It used a common, reliable engine and had internal space for a huge fuel load. With external fuel tanks, it could accompany the bombers all the way to Germany and back. Enough P-51s became available to the 8th and 9th Air Forces in the winter of 1943–44.
         For the ultimate, realistic flight experience, the P-51 comes with all-metal mechanical spring-loaded strut assemblies. The P-51 comes out of the box with all kinds of details that have been finished for the consumer, including a factory-painted fiberglass cowl, scale antenna, scale-shaped spinner, aluminum wheel hubs and much more. For a high-quality outer surface and realistic appearance, the P-51 is dressed with Oracover.
    Technical data
    - Wingspan: 2190mm (86.2 in)
    - Length: 1907mm (75 in)
    - Flying weight: 9-12 kg
    - Wing area: 92 dm2
    - Wing loading: 98g/dm2
    - Wing type: Naca airfoils
    - Covering type: Genuine ORACOVER®
    - Retract gear type: Air-retract With CNC Suspension Metal Struts (included)
    - Spinner size: P51 Mustang type, aluminum plate 115mm (included)
    - Radio: 6 channel minimum (not included)
    - Servo: 9 standard hi-torque servo: 2 aileron; 2 flap; 2 elevator; 1 rudder;1 retract; 1 throttle (not included)
    - Recommended receiver battery: 6.0V 2400/2600mAh NiMH (2) (not included)
    - Servo mount: 21mm x 42 mm
    - Propeller: suit with your engine
    - Engine: 50-60 CC gas engine (two stroke) (not included)
    - Motor: brushless outrunner 2600-3000 W, 190 KV (not included)
    - Gravity CG: 190 mm (7,48 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 15mm up/down, 10% expo; High: 20mm up/down, 10% expo
    - Control throw Elevators: Low: 15mm up/down, 12% expo; High: 20mm up/down, 12% expo
    - Control throw Rudder: Low: 40mm right/left, 15% expo; High: 60mm right/left, 15% expo
    - Control throw Flaps: Mid: 25mm down; Landing: 35mm down
    - Experience level: Intermediate
    - Plane type: Scale Military
    RECOMMENDED MOTOR AND BATTERY SET UP
    - Motor: hacker brushless A60 (not included)
    - Propeller: 22x12 APC E (not included)
    - Lipo cell: 12 cells / 5000 – 6000mAh (not included)
    - Esc: 120-160A / HV (not included)
    Feature
    - Designed for compatibility with both GP and EP flight
    - Covered in genuine ORACOVER®
    - Air-retract With CNC Suspension Metal Struts included
    - Retractable Tail Wheel with Gear Doors included
    - Full-depth cockpit and instrument panel and pilot included
    - Scale plastic bomb included
    - Bolt-on two-piece wing for easy transport and setup at the field
    - Removable canopy for easy change lipo battery and set up radio
    - Strong Light Weight Construction
    - Superb flying characteristics, plus an accurate scale outline
    - High-quality hardware package included
    Colour chart
    -   White             (# 21010)
    -   Blue                (# 21050)
    -   Black              (# 21071)
    -   Silver              (# 21091)
    Packing
    -   Dimension (mm)
        * Box                 :  1539 x 595 x 283
        * Cover carton :  1555 x 605 x 280
    « Τελευταία τροποποίηση: Πέμπτη, 16 Οκτ 2014, 11:02:36 από DIAMOND » Καταγράφηκε
    « Απάντηση #51 στις: Πέμπτη, 16 Οκτ 2014, 11:01:20 »
    Νέες Παραλαβές Οκτώβριος 2014
    PHOENIX MODEL Giant VOLCANO 60CC SCALE 1:4 1/4 ARF
    Introducing
        A real beauty aircraft. Anyone who likes the war birds is bound to love this airplane. It has a large wing and very strong construction. Control surface size and the right tail moment promise great flying characteristics, wide speed range, slow landings and precise aerobatics. An impressive scale Landing gear is also included with the kit. It is designed exclusively for this aircraft. It is a piece of engineering of its own. The Volcano is an easy-to-assemble, easy -to-fly blast for any pilot interested in large-scale flight. Functioning scale flaps make takeoffs and landings a breeze. Factory-created scale detail like the canopy, cockpit, pilot, control surfaces... Its authentic ORACOVER covering supplies a superior sheen. The VOLCANO ARF is part of PHOENIX MODEL's complete line of top-quality aircraft and accessories.
    Technical data
    - Wingspan: 2567mm (101in)
    - Length: 2190mm (86.2 in)
    - Flying weight: 11-13 kg
    - Wing area: 101 dm2
    - Wing loading: 99g/dm2
    - Spinner size: 115mm (included)
    - Servo: 10 standard hi-torque servo: 2 aileron; 2 flap; 2 elevator; 1 rudder;1 retract; 1 throttle; 1 steering nose. (not included)
    - Engine: 50- 60 CC gas engine (two stroke) (not included)
    - Gravity CG: 141 mm (5.5 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 12mm up/down, 10% expo; High: 15mm up/down, 10% expo
    - Control throw Elevators: Low: 12mm up/down, 12% expo; High: 15mm up/down, 12% expo
    - Control throw Rudder: Low: 30mm right/left, 15% expo; High: 45mm right/left, 15% expo
    - Motor: Hacker A60 (not included)
    - Propeller: 22x10 E; 22x12 E APC (not included)
    - Lipo cell: 12 cells / 5500 – 6000mAh (not included)
    Feature
    - Separate fuselage and wing structure allows compact transportation
    - Extremely lightweight laser-cut all-wood construction
    Colour chart
    •  Light green    (# 21042)
    •  Blue                (# 21050)
    •  Cub Yellow    (# 21030)
    •  White              (# 21010)
    •  Black               (# 21071)
    Packing
    BOX DIMENSION
       - 1244mm X 650mm X 388mm (L x W x H)
    « Απάντηση #52 στις: Πέμπτη, 16 Οκτ 2014, 11:05:16 »
    PHOENIX MODEL GENESIS .46-.55 SCALE 1:8 ARF
    Introducing
        The most successful aircraft in air racing history. Phoenix proudly introduces the Genesis .46-.55 a quick to assemble, sport scale version for 50 sized power plants that is ready for high speeds and good flight performance.
    Technical data
    - Wingspan: 1533mm (60.35in)
    - Length: 1310mm (51.57 in)
    - Flying weight: 2.8-3.2 kg
    - Wing area: 29 dm2
    - Wing loading: 105g/dm2
    - Gear type: Mechanic retract With CNC Suspension Metal Struts and spring tail gear (included)
    - Spinner size: Plastic 70mm (included)
    - Servo: 5 standard servo: 2 aileron; 1 elevator; 1 rudder; 1 throttle and 2 servo retract Futaba S3170G (not included)
    - Recommended receiver battery: 4.8-6V / 800-1200mAh NiMH (not included)
    - Engine: .46-.55 / 2-stroke or .52/4-stroke glow engine (not included)
    - Motor: brushless outrunner 1000-1400 W, 480 KV (not included)
    - Gravity CG: 65mm (2.6 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 8mm up/down, 10% expo; High: 10mm up/down, 10% expo
    - Control throw Elevators: Low: 8mm up/down, 12% expo; High: 10mm up/down, 12% expo
    - Control throw Rudder: Low: 20mm right/left, 15% expo; High: 30mm right/left, 15% expo
    - Plane type: Scale Civilian
    - Motor: RIMFIRE .46-.55 (not included)
    - Lipo cell: 4- 6 cells / 4000 – 5500mAh (not included)
    - Esc: 50-80A (not included)
    Feature
    - Designed for compability with both GP and EP flight
    - Super Finishing Fiber Glass Cowl
    - Attractive Scale Colour Scheme
    - Mechanical retract With CNC Suspension Metal Struts included
    - Standard Installation For Engines With Muffler
    - Removable Top Hatch Makes Flight Battery Installation Easy for Electric Power Option
    - Factory Painted and Detailed Canopy
    - Plug in Wings for Convenient Transportation and Storage
    Colour chart
    -  White                 (# 21010)
    -  Blue                   (# 21050)
    -  Cub Yellow       (# 21030)
    -  Corsair Blue    (# 21019)
    « Απάντηση #53 στις: Σάββατο, 18 Οκτ 2014, 11:10:41 »
    Graupner Flybarless system receiver GR-18+3xG+3A + Vario HoTT
    Description
    With the GRAUPNER HoTT 2.4 GHz technology, the receiver has a new Hopping Telemetry Transmission high-frequency unit with state-of-the-art components and software. For reception, a hardware-aerial diversity system always switches to the better aerial signal and for transmission always uses the aerial that was last used for reception. This ensures that the return channel data are sent via the better positioned aerial. Without add-on sensors, the parameters receiver voltage and temperature, as well as signal strength are transmitted.
    3-axis gyro + 3-axis acceleration sensors + Vario:
        Stabilization of the model aircraft in difficult wind conditions for up to 3 axes
        Natural flight behaviour thanks to proportional gyro offset adjustment
        Very good stabilization for tight flight figures
        Thanks to the 3-axis gyro, even aerobatic models that are difficult to master can be flown very comfortably; simplifying aerobatic flight extremely
        Flight figures can be flown very tightly
        Simple adjustment of gyro assignment
        Adjustment of the parameters via the HoTT telemetry
        Altitude sensor for vario-function and altitude
        Flybarless system for helicopters
        I2C interface for future addition of functions
    Specification
    Temperature range : - 15...+70 °C
    Aerial length: 2 x Draht 145 (Antenne 30) mm
    All-up weight, approx.: 14 g
    Frequency : 2400 ... 2483.5 MHz
    Range approx. : 4000 m
    Dimensions (LxWxH): 46 x 21 x 14 mm
    Modulation: 2.4 GHz FHSS
    Charging rate : 70 mA
    Operating voltage : (2,5) 3,6 ... 8,4 V
    Warnhinweis: Warnhinweis_14+_EN
    « Τελευταία τροποποίηση: Σάββατο, 18 Οκτ 2014, 11:38:50 από DIAMOND » Καταγράφηκε
    « Απάντηση #54 στις: Σάββατο, 18 Οκτ 2014, 11:39:39 »
    Graupner Ultra DC Quad Charger 4 x 80 Watt 1-6s Li-po
    Overview:
    Graupner/SJ "ULTRA DC QUAD" is a computer-controlled four-port balancer charger that features a high-performance microprocessor. The advanced software allows you to charge four batteries of varying types and numbers of cells simultaneously.
    The charger provides multiple charge programs and a balancer connection for up to 6 cells.
    Age recommended by manufacturer: 14 years and up
    Characteristics:
        Optimised operating software
        One display and one input keyboard per charger output
        Integrated balancer
        Balanced discharge
        Charge/discharge capability for LiPo/LiFe/LiIon, NiMH, NC, PB batteries
        Normal, fast and storage charge programs
        Automatic error detection and shut-off
        delta peak cut-off
        10 x 4 programmable battery memories
    The Set contains:
        ULTRA DC QUAD charger
        EH to XH 6S Adapter Board and 6S Cable x 4
        DC input cable
        Temp Sensor x 2
        charge Cable(R, BK)
        Alligator Clip(R, BK)
        Manual
    Specification
    Dimensions (LxWxH)    225 x 170 x 40     mm
    Socket type    DC Eingang XT-60
    Artikelbild 1    S2007_Ultra_DC_Quad_01
    Artikelbild 2    S2007_Ultra_DC_Quad_02
    Artikelnummer    S2007
    Operating voltage    DC: 11 ... 15     V
    Balancer socket    1-14 NiCd,NiMH/1-6 Lixx/1-6 Pb
    All-up weight, approx.    1012     g
    Input voltage    External DC Power Supply 11-15     V
    Discharge current    4x(max.5W) 0,1 ... 1     A
    Capacity    4x 10 ... 9900     mAh
    Charge current    4 x (max.80 W) 0.1 ... 7     A
    WarengruppenNr    72
    « Απάντηση #55 στις: Παρασκευή, 31 Οκτ 2014, 13:16:36 »
    Mirage 2000 PNP gray - FlyFly Hobby Jet (+EDF 7B +Alu gear set +engine1500kv)
    Mirage 2000 PNP gray- FlyFly Hobby Jet
    Set includes:
        EDF
        gear
        engine bRUSHLESS MOTOR 3660 1500KV
    Requires (not included):
        4x micro servo
        6 channel Radio 2.4 GHz
        Li-Po Battery (6 cells)
        ESC
    Numer producenta: FF-D001C-G
    Technical data
    Length:    1350 mm
    Wingspan:    955 mm
    Weight:    1900 g
    Wing area:    39 dm2
    Material:    Styrofoam (EPS)
    « Απάντηση #56 στις: Παρασκευή, 31 Οκτ 2014, 13:23:14 »
    R-PLANES PIONEER 2,4 GHz RTF Mode 2 wingspan:1400mm
    Model glider PIONEER's R-​​Planes.
    Pioneer glider entirely built with extremely high-impact EPP foam. In the middle of the hull, turret placed pusher propeller model - thanks to this solution, it will not be damaged in the event that in. Failed landings. Model designed for both beginners and intermediate modelers.
    RTF version - complete with a comprehensive set of aircraft equipment.
    The RTF kit includes the following elements:
         Hull (with mounted: brushless motor, speed controller, propeller hub, metal cap, 2 bowdenami, 2 servos, and a lockable cockpit magnets)
         The wings (each wing has a built-in 2 servos with thrusters)
         rudder
         elevator
         4-channel 2.4GHz transmitter in MODE 2 (gas left) along with 6-channel receiver 2.4GHz
         Bayonet coupling carbon wing
         LiPo power model: 1300 mAh, 11,1V 20C (equivalent Redox 11,1V 1300 mAh 20C)
         Charger 12V 800 mA for 2-3S lipo packages (7.4 - 11,1V) with the adapter "Jack - Alligator Clip"
         The pusher propeller 5x8 "
         Set of small accessories:
             Cord - splitter servo type "Y"
             2 x T-bar lift pasted
             2 x Complete mount bowden
             1 x set of velcro (1 x large, 2 x small)
         Manual in Polish
         Colorful box with information about the model in Polish
    Characteristics:
         Wingspan: 1400mm
         Hull length: 925 mm
         Wing area: 26 dm2
         Load wings: 25 g / dm 2
         Starting Weight: 650 g
         Approximate flight time: approx. 15-30 min.
         Level of play - for beginners and intermediate modelers
    Components necessary to run the model:
         Adhesive foam EPP
         Basic tools (eg. A screwdriver)
         8 x alkaline battery R6 or AA battery to power the transmitter (eg. Graupner Graupner Mignon alkaline battery LR6 AA 1.5V)
    Notes: The apparatus version MODE II - rod gas left.
    « Απάντηση #57 στις: Παρασκευή, 31 Οκτ 2014, 13:27:38 »
    Redox BETA COMBO Charger with 230V power supply
    Redox Beta is a small and universal charger with built-in Lithium cell balancer. Thanks to included Redox 12V/5A Power Supply it can be powered by 12V or 230V!
    Specifications (Redox Beta charger):
        Dimensions: 113 x 65 x 23 mm
        Operating voltage: DC 11.0~18.0 V or AC/DC Adapter 230V 5A (included)
        Circuit power:
            Max. charge Power 50W
            Max. discharge power 5W
        Charge current range: 0.1~5.0A
        Discharge current range: 0.1~1.0A
        Balancing current: 300 mAh/cell
        NiCD/NiMH battery cell count: 1~15 cell
        Li-Po/Fe/Ion cell count: 1~6 cell
        Pb battery voltage: 2~20V
        Weight: 195 g
    Specifications (Redox 12V/5A Power Supply):
        Dimensions: 125 x 57 x 31,5 mm
        Input voltage: 100~265V / 47/60 Hz AC
        Output voltage: stabilized 12V
        Output current: constant 5A
        Weight: 313 g
    Set includes:
        Redox Beta charger
        Redox 12V/5A Power supply
        Balancer adapter for 2-6 lithium cell
        Power cord 12V DC (Jack - Aligator clips)
        1 x DEANS socket - Aligator clips adapter
        1 x DEANS socket - BEC socket adapter
        1 x DEANS socket - Futaba type servo socket (compatible with JR servo plugs)
        1 x DEANS socket - Glow clip charging adapter
        Manual
    FEATURES:
        Optimized operating software
        Internal independent lithium battery balancer
        Discharger
        Adaptable to various type of lithium battery
        Fast charge and storage mode for lithium battery
        Maximum safety
        Automatic charging current limit
        Capacity limit
        Temperature treshold (optional)
        Processing time limit
        Input power monitoring
        Data recording and loading
    « Απάντηση #58 στις: Παρασκευή, 31 Οκτ 2014, 13:33:00 »
    Electric-retracts XL main for 10kg 2 pcs
    Electric retract set for airplanes and helicopters
    - The all in one system retract system require no complex linkages nor extra servo
    - The retracts are operated as a servo and connected to the receiver.
    - The 5th channel of the transmitter switches in or out the retracts.
    - The design allows an easy installation in almost every model.
    - The main retracts (2) and the steerable front retract (1) are sold separately.
    - The support blocks are made out of strong aluminium.
    - You will be surprised how good your airplane flies with its landing gear retracted.
    Type XL Front Nose Wheel set
    Size L - W - H 92,2mm x 51,0mm x 30,6mm
    Weight 102g
    Speed 4.8v (s/60°) 6
    Speed 6.0v (s/60°) 5
    Torque 4.8v 15,5kg*cm
    Torque 6v 18,6kg*cm
    Gears Metal
    Axle diameter 5mm
    Output Angle 90°
    Airplane weight up to 10kg
    « Απάντηση #59 στις: Παρασκευή, 31 Οκτ 2014, 13:35:37 »
    GREAT PLANES - Gas Engine Ignition Kill Switch
    Σελίδες: 1 2 3 [4] 5 6 7 ... 24     Πάνω
    Δημιουργία σελίδας σε 0.069 δευτερόλεπτα. 25 ερωτήματα.
