Τετάρτη, 14 Οκτ 2026, 16:30:41
    Online σήμερα: 87
    Επισκέπτες: 36
    Συνολικά: 37
    Σελίδες: 1 2 [3] 4 5 6 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 207214 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #30 στις: Σάββατο, 6 Σεπ 2014, 08:05:02 »
    SkyRC GPS Meter
    Stop wondering how fast your RC car can run and how high your RC Airplane or helicopter can
    fly. Now all these data come at your finger with the GPS SPEED METER by SkyRC.
    The popularity of GPS devices inspired SkyRC to design this gadget at about 41g. The Speed
    Meter is the result of SkyRC’s ongoing development efforts, boasting an ultra compact GPS
    module with hidden antenna design, the high-sensitivity GPS receiver chip can do quick
    positioning, a robust controller IC to keep recording speed and altitude in real time.
    This gadget is ideal for RC racing/flying and casual biking, driving and long journey. User could
    easily view the screen while working out data such as speed, altitude total mileage/kilometer,
    longitude/latitude.
    The gadget records the top speed and top altitude for instant recall after the running. It will help
    RC fans much to fine-tune their RC gadgets to achieve better performance.
    • Compact and easy to carry
    • Speed meter with top speed memory
    • Top altitude
    • GPS Coordinator
    • Built-in 4M flash (recording time: 6 hours)
    • UTC timestamp logged for each track point
    • Built-in rechargeable, LiPo bettery 200mAh (Operating time: 150 minutes)
    • Support both Metric and Imperial system of measurements
    • PC link for data logging & google map
    • Firmware upgradable
    • 32 parallel satellite searching channels
    • Receiver: L1, 1575.42 MHZ
    • Frequency: 1.023 MHZ
    • Update frequency: 1 Hz.
    • Antenna type: Built-in
    • Satellite signal reception sensitivity: -159dBm
    • Operating temperature: 0? to +50?
    • Storage temperature: -10? to +60?
    • Operating humidety: 5% to 90%
    GPSLOGGER SOFTWARE
    You can use SkyRC application software “GpsLogger”to transfer the log data to PC and easily
    export the log data to “Google Earth” Please visit Google Earth website
    http://earth.google.com for more information.
    • Transfer the log data to PC and show the track data on Google Earth
    • Save the log data to PC
    • Select the language between English and Chinese
    • Change Metric and Imperial system of measurement
    • GPS update rate selection
    • Firmware upgrade
    Download Software & Upgrade
    Specification
    Weight:    41g
    Dimensions:    65.7 x 39.6 x 20.8mm
    « Απάντηση #31 στις: Σάββατο, 6 Σεπ 2014, 08:13:51 »
    Udi U839 Nano Quad 2.4GHz Red-Green RTF
    UDI have taken the proven technology of their larger quadcopters and shrunk it down into this Nano U839 drone quad. When set in advanced mode the U839 is incredibly nimble yet in the novice setting it is suitable for beginner to learn with thanks to the stability provided by the inbuilt 6 axis gyro. The battery is easily removable allowing you to have a spare and keep flying after you have used the first one. With all the features and manoeuvrability of a larger quadcopters but at a fraction of the price you really can't go wrong with the Nano U839.
    A compact 4 Channel 2.4GHz transmitter is included that uses the same battery as the quad itself allowing quick recharging and long life. The included USB charger can charge both the quad flight battery and transmitter battery meaning you really have everything included in box.
    • Fully Assembled and ready to fly
    • Three separate control settings (Novice, Intermediate & Advance)
    • Rechargeable transmitter battery
    • Easy to replace flight battery
    • Flips in four different directions
    • Plastic propeller guard
    • LED lights
    Note: Both Tx and Quad require charging before use.
    Specification
    Length:    88mm
    Height:    28mm
    Radio System:    4 Channel 2.4GHz (Inc.)
    Electric Motor:    4x Brushled (Inc.)
    LiPo:    1S 3.7v 150mah (Inc.)
    Charger:    USB (Inc.)
    Width:    88mm
    Rotor Diameter:    36mm (Each)
    « Απάντηση #32 στις: Σάββατο, 6 Σεπ 2014, 21:25:34 »
    JOYSWAY electric BULLET model ARTR with 2.4Tx
    Shooting across the water, the new Bullet Speedboat will certainly leave its mark. Supplied with 2.4GHz radio gear, a 30A water-cooled brushless ESC w/ BEC mated to a powerful 2815 out-runner brushless motor, tough 37g steering servo and CNC aluminium rudder, it just requires an 11.1V 2200mAh 20C LiPo pack, balance charger plus 8 'AA' batteries for the transmitter to complete.
    Specification
    Hull Material:    One Piece Blow Moulded
    Length:    729mm (28.7")
    Weight:    1.25kg (2.75lb)
    Servos:    1x 37g (Inc.)
    Radio System:    3 Channel 2.4GHz (Inc.)
    Electric Motor:    Water Cooled 2815 Outrunner (Inc.)
    Speed Controller:    30A Water Coolled (Inc.)
    LiPo:    11.1v 2200mAh 20C (Req.)
    Beam:    180mm (7.1")
    « Απάντηση #33 στις: Σάββατο, 6 Σεπ 2014, 21:36:51 »
    Joysway Magic Cat RTR 2.4GHz
     Despite its diminutive size, the brilliant Magic Cat reaches a high speed of 20km/h with its powerful water cooled 180 size motor! Offering Includes an AC Charger ( for 7.2V Power Pack) and a 9V Dry Battery ( for Transmitter). Outstanding value for money. Buy two and enjoy some exciting pond racing with a friend!
    Included:
    • 2.4GHz 2Ch Digital Proportional R/C System
    • 5A Electronic Speed Controller
    • 9g Rudder Servo
    • 6V 260mAh Power Pack
    • AC Charger (for 6v Power Pack)
    • 9V Dry Battery (For Transmitter)
    Specifications
    Length:    265mm
    Weight:    135g
    Servos:    1x 9g Rudder (Inc.)
    Radio System:    2 Channel 2.4GHz
    Electric Motor:    Brushed (Inc.)
    Speed Controller:    5A (Inc.)
    NiCad/Ni-MH:    6V NiMH (Inc.)
    Beam:    72mm
    « Απάντηση #34 στις: Τετάρτη, 10 Σεπ 2014, 19:36:22 »
    ESM MIG-3 Color F 80" Wingspan (2032 mm) Model ARF
    Wing Span:    80" (2032 mm)
    Length:    66" (1676 mm)
    Wing area:    7.7sq. ft (71 sq dm)
    Wing Loading:    40 oz/sq. ft (123 g/sq. dm)
    Flying Weight:    19 lbs (8.7 kg)
    Radio:    6ch & 7 servos
    Engine:    35cc gasoline engine
    « Απάντηση #35 στις: Τετάρτη, 10 Σεπ 2014, 19:58:03 »
    FLYMODEL CESSNA 421 twin engine
    Top quality wood construction with fiberglass fuselage
    Comes with all hardware and accessories
    Wing span: 1800 mm / 71 in
    Fuselage length: 1590 mm / 62.6 in
    Flying weight: 5000 g / 11 lbs
    Wing area : 763 sq in / 49.5 sq.dm
    Engine Required: 2c 0.40x2
    Radio Required: 6ch ; 10-11 Servos
    « Απάντηση #36 στις: Παρασκευή, 12 Σεπ 2014, 21:17:18 »
    Electron electric retracts set (3 pcs+controler) for 15KG model
    Technical data
    Control electronics:    Digital
    Gearing:    Metall
    Operating voltage:    5,0-9,0 V
    Dimensions:    103,0 x 24,0 x 32,5 mm
    « Απάντηση #37 στις: Σάββατο, 13 Σεπ 2014, 11:15:23 »
    BRAINERGY LiPo 3s1p 11,1V 2.200mAh 45C T-PLUG
    Τιμή: €24.99
    Technical data
    Configuration:    3s1p
    Nominal voltage:    11,1 V
    Rated capacitance:    2.200 mAh
    Charge rate (maximum):    2C (4,4 A)
    Discharge rate (continuous):    45C (99 A)
    Dimensions:    101 x 33,5 x 21 mm
    Weight:    154 g
    Connection:    YUKIKING T-Plug
    « Τελευταία τροποποίηση: Σάββατο, 13 Σεπ 2014, 11:25:26 από DIAMOND » Καταγράφηκε
    « Απάντηση #38 στις: Κυριακή, 21 Σεπ 2014, 09:36:37 »
    FLYMODEL P-47D .120 wingspan=1800mm
      Product Name: P-47D Thunderbolt
     Wing span: 71 in / 1800mm
    Wing area: 806 sq in / 52 sq dm
     Flying weight:  9.2 lb / 4200g
     Fuselage length: 56 in / 1420 mm
     Engine Required: 2c 0.91cu in    4c1.20 cu in
     Radio Required:   6channels,7 servos
    « Απάντηση #39 στις: Πέμπτη, 25 Σεπ 2014, 08:00:30 »
    Saito FG- 84R3 3-Cylinder Gas Radial Engine
        Gasoline version of the 450 3-cylinder radial
        Larger displacement than the glow version
        2S Li-Po battery compatible ignition without a regulator provides easy starts and reliable performance
        Engine heat sink for better cooling and performance through an aerobatic routine
        4-stroke sound Saito™ engines are famous for
        Complete with electronic ignition, mufflers and engine standoffs
    Overview
    The Saito™ FG-84R3 engine is the gas/petrol version of the existing FA-450R3 glow engine. This engine is designed specifically for large models and performance airframes. Above and beyond the advantages of a 4-stroke gas engine, this is the engine for those who like to run clean and efficient engines. Accompanied by the Saito power and precision craftsmanship, the distinguished look and sweet sound, this is the engine many of you have been waiting for. This engine delivers a larger displacement than the older 450 3-cylinder radial engine, and provides easy starts and reliable performance due to the 2S LiPo-compatible electronic ignition. The designed Walbro carburetor features a rotating barrel specially made for 4-stroke engines, ensuring reliable fuel feed and outstanding performance at any attitude. Engine heat sink provides better cooling and performance through an aerobatic routine. Complete with mufflers, engine mount, and electronic ignition.
    As an expert in reliable 4-stroke engines, Saito engineers spent years developing the best-built 4-stroke gas engine. The power-to-weight ratio of a Saito engine creates a one-of-a-kind flying experience. For serious modelers, the long awaited arrival of the 450R3 gas version is here with the same quality, sound and precision craftsmanship Saito is known for.
    Specs
    Benchmark Prop:    24 x 10 @ 6,300 rpm
    Bore:    36.0mm (1.42 in) x 3
    Carb Type:    Walbro
    Crankshaft Threads:    M10 x 1.25
    Crankshaft Type:    Threaded
    Cylinder Type:    Ringed
    Displacement:    5.14 cu. in. (84.28 cc)
    Engine (Only) Weight:    6.7 lb (3.1 kg)
    Ignition Weight:    8.8 oz (250 g)
    Muffler Threads:    M14
    Muffler Type:    Flex tube
    Muffler Weight:    5.5 oz (157 g)
    Oil Type & Content:    20:1 gas/oil ratio
    Plug Type:    CM-6
    Prop Range:    23 x 10 – 24 x 10
    RPM Range:    1,400 – 6,500 on ground
    Recommended Fuel:    87-92 octane gasoline
    Stroke:    27.6mm (1.09 in) x 3
    Total Weight:    7.8 lb (3.5 kg) (includes engine, muffler, and ignition where appropriate)
    Type:    4-stroke Airplane
    Cylinders:    Radial
    Fuel Type:    Gas
    « Απάντηση #40 στις: Πέμπτη, 25 Σεπ 2014, 15:59:21 »
    FlyFly Hobby Condor Glider wingspan:3000mm
    FlyFly Hobby - Condor Glider.The hull laminate, wing design (balsa) covered with foil.
    Recommended accessories (not included) required to run the model:
         6 channel 2.4GHz Radio
         Li-Po 1800 mAh 7.4V 20C + BEC voltage stabilizer
         5x micro servo 9g + 1x 45g standard servo
    Specifications
    Wingspan: 3000 mm
    Hull length: 1270 mm
    Height: 280 mm
    Weight (ready to fly): 1900-2100 g
    Wing area: 50.4 dm2
    « Απάντηση #41 στις: Πέμπτη, 25 Σεπ 2014, 16:13:28 »
    Νέες Παραλαβές Σεπτεμβρίου απο www.Diamond-Models.gr
    « Απάντηση #42 στις: Κυριακή, 28 Σεπ 2014, 20:38:46 »
    Νέα Παραλαβή Σεπτεμβρίου σε HiFei Speed controlers απο www.Diamond-Models.gr
    Hifei Swordfish ProII 240A HV 12s water proof
    Hifei ESC 160A-GII-12S
    Hifei ESC 180A-GII-6S
    καθώς επίσης και την πλήρη σειρά από HiFei ESC και Hifei Capacitor Banks
    « Απάντηση #43 στις: Σάββατο, 4 Οκτ 2014, 14:49:43 »
    Νέα Παραλαβή
    Roban UH60 700 class 4 blade heads+Mechanics
    Body length:    1700mm
    Length incl. rotors:    1850mm
    Width:    665mm
    Height:    445mm
    Main rotor diameter    1560mm
    Main blade length:    750mm
    Tail rotor diameter:    280mm
    Tail blade length:    45mm
    Main shaft diameter:    12mm
    Tail shaft diameter:    5mm
    Spindle diameter:    8mm
    Main blade count:    4
    Tail blade count:    4
    Drive gear ratio:    1:13.8:4.7
    Motor:*    1x 750MX 450KV brushless outrunner , 12S capable
    Speed controller:*    1x 120A brushless, 12S capable
    Servo:*    3x metal gear cyclic, 1x metal gear tail servo
    Battery:*    44.4V 5000mAh 35C
    Flight time:    5 minutes
    Takeoff weight:    8000g
    Flight Stabilization:*    3 axis flybarless gyro
    Radio Control:*    min. 6 channel with pitch and throttle curves
    This scale helicopter comes with a complete scale mechanic! Only electronic components are needed!
        12S 5000mAh Lipo battery, 30C +
        700 size standard cyclic and tail metal geared servos, not HV equipment needed
        Align 750MX 450KV Motor HML75M02 (or same size and KV class, no lower KV recommended, main shaft needs to be equally long!)
        3 Axis Gyro suitable for scale helicopters (e.g. Skookum 720, Bavarian Demon X)
        7 channel RC system (electric retract system is included and requires aux channel for control)
        120A HV ESC (govenor recommended but not necessary)
    Description:
    Robans new 700 size UH-60 is now available. It‘s the sixth product in our Super Scale series.
    Our new True Scale Design locates the cockpit exactly at the right spot, unlike on most canopies based on 3D mechanics. The compact mechanic is built into the engine compartment, just like on a real helicopter. Therefore it allows space for front to back scale cockpit seats. The position light system programmable with 9 different patterns is preinstalled.
    The fuselage of the UH-60 stands out through the detailed crafted surface details and the overall correctly scaled down shape. This unique scale look and details stun and make it hard to see the difference to a real helicopter.
    The helicopter comes with a detailed instruction manual. The setup is simple and quick, the mechanics are completely preassembled. Only screw drivers and allen keys are required to make it airborne.
    Features:
    • Quad Blade Rotorhead and scale carbon fiber rotor blades included
    • Quat Tail Blade and scale carbon fiber tail blades included
    • Extremely detailed surface details, a realism unknown in this size class
    • Complete seven seated scale cockpit
    • Complete built in / preinstalled position lighting system (controllable via aux channel)
    • Special CCPM mechanics built in the top section, as on a real helicopter
    • Use of 750MX standard equipment (12S battery, 450KV motor), fly with your existing parts
    • Take off weight of 9kg (about the double than a 700 3D helicopter)
    • 1700mm long, exact 1/ scale
    • Product comes preassembled and requires very few work to mobilize it
    « Απάντηση #44 στις: Σάββατο, 4 Οκτ 2014, 14:53:24 »
    Graupner WP Hott Deluxe PnP
    Specification
    Wing area : 21,0 dm²
    All-up weight, approx.: 1000 g
    Total surface area, approx. : 25,0 dm²
    Tailplane area : 4,0 dm²
    Overall length, approx.: 955 mm
    Wingspan approx.: 1240 mm
    Wing loading : 40,0 g/dm²
    Σελίδες: 1 2 [3] 4 5 6 ... 24     Πάνω
    Δημιουργία σελίδας σε 0.046 δευτερόλεπτα. 25 ερωτήματα.
