310.035 ìçíýìáôá óå 12.400 èÝìáôá áðü 6.301 ÌÝëç / Ôåëåõôáßï ìÝëïò: Clubdim
ÐáñáóêåõÞ, 30 Ïêô 2026, 16:07:48
    �ñüóöáôá è�ìáôá
    áðü Markhelis
    áðü spirost
    [ÊõñéáêÞ, 25 Ïêô 2026, 14:50:50]
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    [ÐáñáóêåõÞ, 4 Óåð 2026, 16:34:37]
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310035
    Óýíïëï èåìÜôùí: 12400
    Online óÞìåñá: 105
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 1
    ÅðéóêÝðôåò: 54
    ÓõíïëéêÜ: 55
    Óôõë åìöÜíéóçò
    Óåëßäåò: [1]     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: Lx f4u  (Áíáãíþóôçêå 2754 öïñÝò)
    john_p51d
    Ìçíýìáôá: 47
    « óôéò: Ôñßôç, 24 Ìáñ 2020, 22:20:34 »
    ¸÷ù ôåëåéþóåé ìå áõôü ôï Corsair ,êáé óôï íá ðñïãñáììáôßóù ôá Control throws .
    Äõóôõ÷þò óôéò ïäçãßåò äåí õðÜñ÷ïõí ñõèìßóåéò. ¸÷ù âñåé óôï äéáäýêôéï ôéò ðáñáêÜôù:
    CONTROL SURFACE THROWS
    We recommend the following control surface throws. (Throws are measured at the widest part of the elevators, rudder and ailerons.)
    ELEVATOR: 11/16" up, 5/8" down (High Rate)
    1/2" up, 7/16" down (Low Rate)
    RUDDER: 2-3/8" right, 2-3/8" left (High Rate)
    1-3/8" right, 1-3/8" left (Low Rate)
    AILERONS: 1/2" up, 1/2" down (High Rate)
    3/8" up, 3/8" down (Low Rate)
    FLAPS: At low point of middle flap,
    1-3/8" down
    NOTE: If your radio does not have “dual rates,�
    then set up the control surfaces to move midway
    between the recommended high and low rates.
    ÃŽÃ�ñåé êÜðïéïò óå  mm  ðùò åßíáé; Ã�õôü ðïõ ìå ìðåñäåýåé åßíáé  ôï RUDDER: 2-3/8" right, 2-3/8" left (High Rate)
    ÊáôáãñÜöçêå
    john_p51d
    Ìçíýìáôá: 47
    « ÁðÜíôçóç #1 óôéò: Ôñßôç, 24 Ìáñ 2020, 22:21:56 »
    Foto
    * D3C03C00-8548-4CF3-8B7A-A4255D39A479.jpeg (87.31 KB, 640x384 - åìöáíßóôçêå 500 öïñÝò.)
    ÊáôáãñÜöçêå
    falcon67
    Ìçíýìáôá: 16
    « ÁðÜíôçóç #2 óôéò: Ôñßôç, 24 Ìáñ 2020, 22:45:34 »
    ÂÜóåé ôïõ ôýðïõ  mm= in/0,039370 Ã�÷ïõìå:
    Ãéá ôï Rudder:
    2-3/8 =60,33 mm
    1-3/8 =34,93 mm
    Êáë�ò ðôÞóåéò
    ÊáôáãñÜöçêå
    john_p51d
    Ìçíýìáôá: 47
    « ÁðÜíôçóç #3 óôéò: ÔåôÜñôç, 25 Ìáñ 2020, 10:58:35 »
    6cm ìå 3.4cm ôï âë�ðù ëßãï äýóêïëï!!!
    ÊáôáãñÜöçêå
    cptnassos
    Ìçíýìáôá: 1.129
    « ÁðÜíôçóç #4 óôéò: ÔåôÜñôç, 25 Ìáñ 2020, 13:36:44 »
    Ãéá ðïéï ëüãï??
    ELEVATOR: 11/16" (17.4mm) up, 5/8" (15.8mm) down (High Rate)
    1/2" (12.7mm) up, 7/16" (11.1mm) down (Low Rate)
    RUDDER: 2-3/8" (60.3mm) right, 2-3/8" (60.3mm) left (High Rate)
    1-3/8" (34.9mm) right, 1-3/8" (34.9mm) left (Low Rate)
    AILERONS: 1/2" (12.7mm) up, 1/2" (12.7mm) down (High Rate)
    3/8" (9.5mm)  up, 3/8" (9.5mm) down (Low Rate)
    1-3/8" (34.9mm) down
    ÓÇÌÅÉÙÓÇ: ÅÜí ç ôçëåêáôåõèçíóç óáò äåí �÷åé \"äéðë�ò ôéì�ò ñýèìéóçò\",
    óôç óõí�÷åéá, ñõèìßóôå ôéò åðéöÜíåéåò åë�ã÷ïõ ãéá íá ìåôáêéíçèåßôå óôç ì�óç
    ìåôáîý ôùí óõíéóôþìåíùí õøçëþí êáé ÷áìçëþí ôéìþí êßíçóçò.
    « Ôåëåõôáßá ôñïðïðïßçóç: ÔåôÜñôç, 25 Ìáñ 2020, 14:37:17 áðü cpt_nassos » ÊáôáãñÜöçêå
    john_p51d
    Ìçíýìáôá: 47
    « ÁðÜíôçóç #5 óôéò: ÔåôÜñôç, 25 Ìáñ 2020, 14:38:06 »
    �ðëá ôá servo äåí öôÜíïõí áõô�ò ôéò áðïóôÜóåéò óôï ruder.
    Ôá õðüëïéðá ôá �÷ù êáé åãþ �ôóé õðïëïãßóåé
    ÊáôáãñÜöçêå
    cptnassos
    Ìçíýìáôá: 1.129
    « ÁðÜíôçóç #6 óôéò: ÔåôÜñôç, 25 Ìáñ 2020, 14:43:19 »
    Êáíå áëëáãÞ óôá horn ôùí servo ìå ìåãáëýôåñá (ìáêñýôåñá).
    https://www.aeromodelling.gr/ForumS/index.php?topic=56812.0
    ÊáôáãñÜöçêå
    john_p51d
    Ìçíýìáôá: 47
    « ÁðÜíôçóç #7 óôéò: ÔåôÜñôç, 25 Ìáñ 2020, 15:21:30 »
    Èá ôï êïéôÜîù áëëÜ ìÜëëïí äýóêïëá èá âñù Üëëá íá ôáéñéÜæïõí!
    ÊáôáãñÜöçêå
    cptnassos
    Ìçíýìáôá: 1.129
    « ÁðÜíôçóç #8 óôéò: ÔåôÜñôç, 25 Ìáñ 2020, 15:22:35 »
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 2.386
    « ÁðÜíôçóç #9 óôéò: ÔåôÜñôç, 25 Ìáñ 2020, 16:39:47 »
    Ãéá ìÃ�ãéóôç êßíçóç åíüò ðéäáëéïõ âÜæåéò ôçí åîùôåñéêÞ ôñýðá óôï Servo êáé áðü ôçí ìåñéÜ ôïõ ruder ôçí åóùôåñéêÞ.
    Äïêßìáóå ôï.  Êáé íá ìçí öôÜóåéò ôï íïýìåñï ðïõ ëÃ�åé ôï Manual äåí õðÜñ÷åé ðñüâëçìá.  Ã�ýôå ôï íïýìåñï ôïõ Low rates äåí öôÜíåéò?
    ÊáôáãñÜöçêå
    ¹ �óôï÷ßá Õëéêïý ¹ Ì…êéá Ôå÷íéêïý!
    john_p51d
    Ìçíýìáôá: 47
    « ÁðÜíôçóç #10 óôéò: ÐÝìðôç, 26 Ìáñ 2020, 15:47:42 »
    �áé ðÜåé ì�÷ñé 60mm, ôï âñßóêù üìùò õðåñâïëéêü.
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 2.386
    « ÁðÜíôçóç #11 óôéò: ÐÝìðôç, 26 Ìáñ 2020, 16:46:18 »
    Ìçí ôñåëáßíåóáé êáé 3 åßíáé êáëÜ.
    ÊáôáãñÜöçêå
    Óåëßäåò: [1]     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Ã�åñïðëÜíá R/C - ÇëåêôñéêÜ  |  Sport - Ã�êñïâáôéêÜ - 3D (ÓõíôïíéóôÝò: 3DJunk, stavros, andreas)  |  ÈÝìá: Lx f4u
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.041 äåõôåñüëåðôá. 24 åñùôÞìáôá.
