ÓÜââáôï, 31 Ïêô 2026, 05:56:36
    Ðñüóöáôá èÝìáôá
    [×èåò óôéò 23:11]
    [×èåò óôéò 23:07]
    áðü Markhelis
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310037
    Óýíïëï èåìÜôùí: 12401
    Online óÞìåñá: 54
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 0
    ÅðéóêÝðôåò: 48
    ÓõíïëéêÜ: 48
    Óôõë åìöÜíéóçò
    Ìçí áíïßãåôå åäþ èÝìáôá ðïõ äåí Ý÷ïõí êáììßá ó÷Ýóç ìå áåñïìïíôåëéóìü. Ôï ðéèáíüôåñï åßíáé ïôé èá äéáãñáöïýí ãéáôß åßíáé åêôüò áíôéêåéìÝíïõ ôïõ Aeromodelling GR.
    Óåëßäåò: 1 ... 8 9 10 [11] 12 13 14 ... 37     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: FPV Systems  (Áíáãíþóôçêå 130881 öïñÝò)
    karian
    Ìçíýìáôá: 41
    « ÁðÜíôçóç #150 óôéò: ÄåõôÝñá, 12 Áðñ 2010, 01:42:42 »
    Ðáéäéá êáëçóðåñá êáé åõ÷áñéóôù ãéá ôéò áðáíôçóåéò!
    Eâáëá ôñéðëï äéáêïðôç óôï aux êáé ïëá êáëá, áëëá óôï FBW mode ïôáí ôï âáæù äåí áêïõåé ôï ruder ìçðùò îåñåé êáíåéò ãéáôé?
    ôï å÷ù óõíäåóåé óôï rvocd óôçí åéóïäï aileron êáé ç åéóïäïò ruder åéíáé êåíç, ãéá íá ìðïñù íá ôï ðåôáù ìå ôï äåîéï stick.
    Öéëå canopus ðïëõ ùñáéï ôï ìïíôåëï óïõ êáé ôï âéíôåáêé åðéóçò.Ìðïñåéò íá ìïõ ðåéò ôé âáñïò óïõ å÷åé âãåé êáé ìå ôé ìðáôáñéåò?
    Ôåëéêá ïé ir sensor ìðïñïõí íá ñõèìéóôïõí åí ðôçóç? áí íáé ðùò?
    Áõôá ðñïò ôï ðáñïí, áõñéï èá êáíù ôçí ðñùôç ðôçóç êáé åëðéæù ïôáí åíåñãïðïéçóù ôï auto pilot íá ìçí áñ÷éóç ôï ìïíôåëï íá êáíåé ôéðïôá ôñåëá !!!
    Èá ðïóôáñù âéíôåï ðáíôùò .
    Êáëçíõ÷ôá!!!
    ÊáôáãñÜöçêå
    kordi
    Ìçíýìáôá: 28
    « ÁðÜíôçóç #151 óôéò: ÄåõôÝñá, 12 Áðñ 2010, 02:49:06 »
    Ößëå Canopus ìå ðïéá êÜìåñá åßíáé ç ðáñáêÜôù ðôÞóç óïõ; Ý÷åé áðßóôåõôá êáèáñÞ åéêüíá
    (RVOSD AUTOPILOT TEST)
    http://www.youtube.com/watch?v=UpGdNijChc4
    ÊáôáãñÜöçêå
    Theory is when you know everything, but nothing works. Practice is when everything works but nobody knows why. In our case theory and practice are combined. Nothing works and nobody knows why.
    ÓùêñÜôçò ÄáìïõëÜêçò
    Ìçíýìáôá: 573
    AKA canopus
    « ÁðÜíôçóç #152 óôéò: ÄåõôÝñá, 12 Áðñ 2010, 08:55:42 »
    Êáëçíõ÷ôá!!!
    Êáëùò çñèåò óôïí FPV êïóìï.. WinkÁí äåí áêïõåé ôï Ruder sto FBW ìÜëëïí ðñåðåé íá êáíåéò áíáâáèìçóç ìå PICkit 2 USB programmer áëëá ðñïóï÷ç åäù ..ìðåò óôï http://www.rangevideo.com/forum/showthread.php?t=383 êáé äéáâáóå ðñïóåêôéêá ðùò èá êáíåéò ôçí áíáâáèìçóç..Ôï âáñïò öéëå ìïõ åéíáé óôï êéëï êáé å÷ù ðåñéðïõ 45 ëåðôá ðôçóç ìå 2200 ìáç ìðáôáñéá..1 âáæù..ïé ir sensors ìðïñïõí íá calibraristoun åí ðôçóç ìïíï óôï íá åõèçãñáìéóôïõí ïé 2 ìðáñåò óôï êåíôñï ôçò ïèïíçò óïõ...ç äéáäéêáóéá íá êáíåéò ôï êáëéìðñáñéóìá óôï åäáöïò åéíáé êáëõôåñç..ìðáéíåéò óôï autopilot menou êáé... IR sensors equalization: Before starting it, make sure that you are in a location with unobstructed view to the sky. When this option is initialized, the OSD will display the steps and actions you need to do. First it will ask to get the plane leveled, during this stage the system it’s checking the Z sensors values and storing the biggest value detected. Second it will ask for keep the plane nose down, during this stage the system is checking the pitch aligned sensors maximum (if value is greater than 127) or minimum (if value is less than 127) and storing it to make the appropriate XY to Z on. After this the system should improve if you had sensors mismatch. If you are not satisfied with this correction and the AHI is working worst after the calibration (make sure to test this while flying). You can go to the menu “IR XY head position” and try to change it with your transmitter, It will not change because it is not allowed to be changed by the transmitter, but still will eliminate any change done by the AHI equalization.
     Ôùñá ðñïóï÷ç óôéò ðñùôåò ðôçóåéò ..
     ìçí åíåñãïðïéçò ôïí áõôïìáôï ðéëïôï óå ÷áìçëï õøïò êáëõôåñá óå ìåãáëï õøïò 200 ìåôñá åéíáé êáëá ãéáôé ÷áìçëá äåí èá ðñïëáâåéò íá åðáíáöåñåéò..âáëå êáëá óåñâï êáé UBEC ãéá íá ìçí å÷åéò ðñïâëçìá ôáóçò óôïí äåêôç óïõ..ìçí ðåôáò ìáêñõá óôçí áñ÷ç èá ÷áèåéò ..ôï speed control ìáêñõá áðï gps èá ôï ôñåëáíåé..
    Åëðéæù íá óå âïçèçóá ..Óùêñáôçò
    « Ôåëåõôáßá ôñïðïðïßçóç: ÄåõôÝñá, 12 Áðñ 2010, 09:12:07 áðü canopus » ÊáôáãñÜöçêå
    ÔÑÅËÏÓ ÃÉÁ ÁÅÑÏÂÉÍÔÅÏÓÊÏÐÇÓÇ...
    ÓùêñÜôçò ÄáìïõëÜêçò
    Ìçíýìáôá: 573
    AKA canopus
    « ÁðÜíôçóç #153 óôéò: ÄåõôÝñá, 12 Áðñ 2010, 08:58:25 »
    Åéíáé ç KX191 color and night mode CCD camera áëëá êáíå ëéãï õðïìïíç ..ðåñéìåíù ìéá êáéíïõñéá ç ïðïéá ç ôéìç ôçò ìå ôá ìåôáöïñéêá åéíáé 40 åõñù ..êáé áí åéíáé ïðùò ðåñéãñáöïõí èá åéíáé ôåëåéá..ôï ìõóôéêï âåâáéá åéíáé êáé ìå ôé óõóêåõç êáôáãñáöåéò ôá âéíôåï..åãù å÷ù ìéá Sony mini dv êáìåñá ìå Video in êáé å÷ù óùèåé...
    ÊáôáãñÜöçêå
    contravago
    Ìçíýìáôá: 583
    « ÁðÜíôçóç #154 óôéò: Ôñßôç, 13 Áðñ 2010, 18:53:00 »
    ÊáôáãñÜöçêå
    contravago
    Ìçíýìáôá: 583
    « ÁðÜíôçóç #155 óôéò: Ôñßôç, 13 Áðñ 2010, 18:53:33 »
    Ïôáí åñèåé ãñáøå åíôõðùóåéò Þ êáé êáðïéï âéíôåï ãéáôé áí áîéæåé èá ðáñù êáé åãù ìéá.
    ÊáôáãñÜöçêå
    ÓùêñÜôçò ÄáìïõëÜêçò
    Ìçíýìáôá: 573
    AKA canopus
    « ÁðÜíôçóç #156 óôéò: Ôñßôç, 13 Áðñ 2010, 23:20:42 »
    http://vimeo.com/10894511
    ÊáôáãñÜöçêå
    ÓùêñÜôçò ÄáìïõëÜêçò
    Ìçíýìáôá: 573
    AKA canopus
    « ÁðÜíôçóç #157 óôéò: Ôñßôç, 13 Áðñ 2010, 23:24:10 »
    http://vimeo.com/10898112
    ÊáôáãñÜöçêå
    studiopetros
    Ìçíýìáôá: 125
    « ÁðÜíôçóç #158 óôéò: Ôñßôç, 13 Áðñ 2010, 23:43:46 »
     Thumbs up Thumbs up Thumbs up Thumbs up Thumbs up
    ÊáôáãñÜöçêå
    Dimitris76
    Ìçíýìáôá: 98
    « ÁðÜíôçóç #159 óôéò: ÔåôÜñôç, 14 Áðñ 2010, 00:44:04 »
    http://vimeo.com/1798459
    ÊáôáãñÜöçêå
    Dimitris76
    Ìçíýìáôá: 98
    « ÁðÜíôçóç #160 óôéò: ÔåôÜñôç, 14 Áðñ 2010, 00:45:30 »
    http://vimeo.com/6723767
    ÊáôáãñÜöçêå
    karian
    Ìçíýìáôá: 41
    « ÁðÜíôçóç #161 óôéò: ÔåôÜñôç, 14 Áðñ 2010, 00:46:03 »
    Óùêñáôç ðïëõ ùñáéá ôá âéíôåáêéá!
    Ôåëéêá å÷ôåò êáôáöåñá êáé ðåôáîá ìéá ÷áñá áëëá äõóôõ÷ùò äåí ìðïñåóá íá ãñáøù âéíôåï ãéáôé ãñáöù óå mini dv êáé ìåôá áðï ðïëõ ôáëáéðùñéá êáôáëáâá ïôé äåí ãñáöåé
    ãéáôé ç êáìåñá óôï ìïíôåëï çôáí ntsc, êáé ï÷é pal.
    Óôçí ðôçóç äåí ìðïñåóá äõóôõ÷ùò íá âáëù auto pilot êáíåíá mode ãéáôé åéäá ïôé åêáíå áíáðïäåò êéíçóåéò óôï elevator êáé êáôáëáâá ïôé êáðïéá ñõèìéóç èá åéíáé,
    áëëá ëïãù ôïõ ïôé ëïéðù óå ìéá åâäïìáäá èá óõíå÷éóù îáíá ðõñåôùäùò. Áëëá ðáñáôçñçóá ïôé ïôáí ãõñíáãá ôï ìïíôåëï áíáðïäá ïé êéíçóåéò óôï elevator çôáí ïê.(o ïñèéïò sensor åéíáé åíôáîåé....íïìéæù )
    Áõôï ðïõ èåëù íá ñùôçóù åéíáé ïôáí ìå ôïí ôñéðëï äéáêïðôç  ôçò ôçëåêáôåõèõíóçò ìðáéíïõìå óôï ìåíïõ êáé ìå ôï äåîéï stick ðáìå ðáíù êáôù, ìå ðïéï stick êáíïõìå åðéëïãç?HuhHuh?
    Êáé êáôé áëëï ãéá ôïí canopus ìéáò êáé å÷ïõìå ôï éäéï ìïíôåëï...Áðï ôï receiver ðåñíåéò áðï ôï êáíáëé aileron ìðáéíåéò óôï ruder in ôïõ rvocd êáé âãáéíïíôáò áðï ôï ruder out ðáò óôï óåñâï
    ôïõ ruder óôï Easy star? Káé ïé õðïäï÷ç aileron in êáé out óôï rvocd ìåíåé êåíç?
    Áõôá!!!!!!
    Êáëçíõ÷ôá êáé êáëåò ðñïóãåéùóåéò!
    ÊáôáãñÜöçêå
    ÓùêñÜôçò ÄáìïõëÜêçò
    Ìçíýìáôá: 573
    AKA canopus
    « ÁðÜíôçóç #162 óôéò: ÔåôÜñôç, 14 Áðñ 2010, 00:53:36 »
    Áõôá!!!!!!
    Ëïéðïí ..äåí åôñåîåò ôïí wizard ðïõ å÷åé óôï ìåíïõ ...âãáëå ôçí ðñïðåëá êáé áêïëïõèçóå ôïí áäçãï áõôïí ..ãé áõôï óïõ êáíåé áíáðïäåò êéíçóåéò...åðéëïãç êáíåéò ìå ôï stick ðáëé ôï äåîéï áëëá ìå äåîéá êéíçóç óáí íá èåëåéò íá óôñéøåéò äåîéá..
    (Áðï ôï receiver ðåñíåéò áðï ôï êáíáëé aileron ìðáéíåéò óôï ruder in ôïõ rvocd êáé âãáéíïíôáò áðï ôï ruder out ðáò óôï óåñâï
    ?) áêñéâùò åôóé å÷ù ôá êáíáëéá..óùóôá ôï åéðåò..
    êáëï âñáäõ êáé óå óåíá !!
    ÊáôáãñÜöçêå
    karian
    Ìçíýìáôá: 41
    « ÁðÜíôçóç #163 óôéò: ÔåôÜñôç, 14 Áðñ 2010, 01:43:41 »
    Áõôá!!!!!!
    Ëïéðïí ôïí wizard ôïí åôñåîá êáé áñêåôåò öïñåò ìáëéóôá (éóùò íá ôï îáíáêáíù ðïéï ðñïóåêôéêá)
    Êáé ãéá ôçí åðéëïãç ìå ôï stick äåîéá ôï åêáíá óõíå÷åéá áëëá äåí áêïõãå ìå ôéðïôá êáé ãéáõôï åêáíá ôçí åñùôçóç. Ìçðùò åðåéäç ôï aileron ôï ðçãáéíù óôï aileron in ôïõ ocd?
    Åõ÷áñéóôù ðáíôùò ãéá ôçí ãñçãïñç áðáíôçóç...
    ÊáôáãñÜöçêå
    karian
    Ìçíýìáôá: 41
    « ÁðÜíôçóç #164 óôéò: ÔåôÜñôç, 14 Áðñ 2010, 07:53:53 »
    Ëéãï ðñéí ôçí ðôçóç óôçí ôåëéêç ôïõ ìïñöç.(Ïóï ãéá ôïí ðïìðï ôïõ video äåí å÷áóå óçìá ðïõèåíá)
    * fpv_easystar_1.jpg (34.29 KB, 1000x750 - åìöáíßóôçêå 384 öïñÝò.)
    * fpv_easystar_2.jpg (43.09 KB, 1000x750 - åìöáíßóôçêå 403 öïñÝò.)
    ÊáôáãñÜöçêå
    Óåëßäåò: 1 ... 8 9 10 [11] 12 13 14 ... 37     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Áåñïìïíôåëëéóìüò óôï Aeromodelling GR  |  Aeromodelling GR - ãåíéêÝò óõæçôÞóåéò (ÓõíôïíéóôÞò: ArgyrisGiannetakis)  |  ÈÝìá: FPV Systems
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.12 äåõôåñüëåðôá. 23 åñùôÞìáôá.
