Τρίτη, 13 Οκτ 2026, 14:56:55
    Επισκέπτες: 28
    Συνολικά: 29
    Σελίδες: 1 [2] 3 4 5 ... 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 207051 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #15 στις: Πέμπτη, 21 Αυγ 2014, 19:03:17 »
    PHOENIX MODEL P-40 Kittyhawk .61-.91/15cc Wingspan: 1615mm (63.5in) ARF plane
    Rotating retracking air system with struts included
    Introducing
    The P-40 Warhawk was an American single-engine, single-seat, all-metal fighter and ground attack aircraft that first flew in 1938. The P-40 design was a modification of the previous Curtiss P-36 which reduced development time and enabled a rapid entry into production and operational service. The Warhawk was used by most Allied powers during World War II, and remained in front line service until the end of the war. It was the third most-produced American fighter, after the P51 and  P47
    Technical data
    - Wingspan: 1615mm (63.5in)
    - Length: 1425mm (56.1 in)
    - Flying weight: 3700-4500 g
    - Wing area: 47.6 dm2
    - Wing loading: 85g/dm2
    - Wing type: Naca airfoils
    - Retract gear type: Rotary Air-retract 90 degree With CNC Suspension Metal Struts (included)
    - Spinner size: 95mm (included)
    - Pressure for air tank retract: 7 bar (100 PSI)
    - Radio: 6-channel radio system minimum. 7 standard hi-torque servo: 2 aileron;
    1 elevator; 1 rudder; 1 throttle; 1 air valve (not included)
    - Engine: .61-.91 two stroke (not included)
    - Motor: brushless outrunner 1800-2000 W, 500 KV (not included)
    - Recommended receiver battery: 6.0V 2400/2600mAh NiMH (not included)
    - Propeller: suit with your engine
    - Gravity CG: 95-100 mm (3.7-3.9 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 10mm up/down, 10% expo; High: 12mm up/down, 10% expo
    - Control throw Elevators: Low: 10mm up/down, 12% expo; High: 12mm up/down, 12% expo
    - Control throw Rudder: Low: 20mm right/left, 15% expo; High: 35mm right/left, 15% expo
    - Experience level: Intermediate
    - Plane type: scale military
    RECOMMENDED MOTOR AND BATTERY SET UP
    - Motor: RIMFIRE .60-.80 (not included)
    - Lipo cell: 6 cells / 4500 – 5500mAh (not included)
    - Esc: 80-100A (not included)
    Feature
    - Designed for compatibility with both GP and EP flight
    - Top quality balsa/light plywood construction
    - Air-retract With CNC Suspension Metal Struts included
    - Full-depth cockpit and instrument panel and pilot included
    - Scale plastic bomb included
    - Bolt-on two-piece wing for easy transport and setup at the field
    - Removable canopy for easy change lipo battery and set up radio
    - Strong Light Weight Construction
    - Superb flying characteristics, plus an accurate scale outline
    - High-quality hardware package included
    « Απάντηση #16 στις: Πέμπτη, 21 Αυγ 2014, 19:25:04 »
    Black Horse Wyvern S4 50cc ARTF with scale air retracts sytem
    scale air retracts sytem included
    Now here's a model that you don't see every day. In fact it's probably the firts R/C ARTF model of the Wyvern anywhere in the world! The Westland Wyvern was one of the very last, single propeller aircraft to enter service with the Royal Navy for strike purposes. She was big, powerful and packed a huge punch. Only one survives today and that was the prototype. Ok, the Black Horse Wyvern does not have the contra rotating scale propellers, although there are some big electric systems on the market that would do the job, so she needs a powerful 50- 55cc petrol engine like the O.S. GT-55 to do her justice and deliver performance. Actually, most of the GT-55 and silencer get swallowed up by the cowl, making a very scale nose area. Flaps are not scale in shape, but are highly effective during landing. They are capable of big lift and drag, consequently they need strong servo power to operate. The all wood construction is laser-cut, jig-assembled and then clothed in durable, printed vinyl in a real scale scheme. It's a big model, so the wings, tailplanes and fin are designed to be removable for transport, making the Wyvern a very practical model to carry in a regular estate car of bigger hatchback. A full set of completely new, all-metal, air retracts are included and the legs are the sprung oleo type. Scale inner wheel well doors are actuated by the wheels as they retract, making a very clean underside when in flight. The tailwheel is fixed but sprung and quite scale looking. The scale pilot and detailed cockpit are all new and in keeping with all the detail that has been lavished on this model. You even get some external weapons to hang on the wing underside. The Black Horse Wyvern is a bold statement of 'doing something different' and will certainly turn a lot of heads on your club patch!!
    Specification
    Wingspan: 2240mm (88.19")
    Length: 2050mm (80.71")
    Weight: 9.3Kg (20.46 lb)
    Servos: 9 x High Torque, 1 x Std
    Required Radio System: 6/7 Channel
    (Req.) IC Engine: 50 - 55cc
    « Απάντηση #17 στις: Παρασκευή, 22 Αυγ 2014, 09:33:33 »
    ESM F-4U Corsair Wing span: 1885mm(74.2”)
    also available Morepower 3-Blade Alu Hub Carbon Blades 16"x10" with Variable pitchl
    Specifications:
    Length: 1470mm(57.9”)
    Wing area: 62.13sq.dm(6.7sq.ft)
    Wing loading: 107.8g/sq.dm (35.3oz/sq.ft)
    Flying weight: 6.7kg(14.7lbs)
    Radio: 6ch & 8servos
    Engine: 120 4-cycle
    Feature:
    Fiberglass fuse and balsa built -up wing
    Wing Covering Material: Covering, painted, decals applied and clear coated. The aircraft has a beautiful flat, non-glossy finish. This is superior to glossy covering materials. The covering material is a brand name covering which has a special paint adherant layer. The covering goes on clear, and is then primed and painted, then clearcoated.
    Optional:
    Rotating Retract with oleo struts, alloy wheels. The retracts are generation 5 Air up/air down retracts, and incorporate all of the latest design improvements.
    History:
    The Corsair started as a USN requirement for a carrier aircraft that could perform with the best land based aircraft of its day. It was harnessed to a 2000hp Pratt and Whitney 2800 double wasp engine, which allowed it to exceed 400mph in level flight, becoming the first US production aircraft to do so. Other carrier aircraft of its time were considerably overbuilt to withstand the repeated stresses of carrier landings. Early carrier trials produced mediocre results, and the Navy released the aircraft for the Marine Corps who desperately needed a decent replacement for the obsolete F4F Wildcats. Two navy units were supplied with the Corsair, but one later gave its aircraft to the marines and the other (VF-12) was removed from its carrier, the USS Bunker Hill, but continued to operate from land bases in the Rabaul area.
    The Marines were very happy with their new aircraft, and it saw combat from February 1943 on from bases in Guadalcanal and the Solomon Island chain, it became a very potent aircraft and produced its first ace by May of 1943, 2nd Lieutenant Kenneth A. Walsh, who ended the war with 21 kills.
    As the war progressed the F4U Corsair developed itself into a close support aircraft, providing marines with precision strikes in support of amphibious landings. The Navy also adopted several squadrons as they needed more combat aircraft to combat the increasing threat of kamikaze attacks.
    By the end of the war, US pilots had flown 64051 sorties and scored 2140 kills against enemy aircraft for only 189 losses; a kill ratio of over 11:1. It also ped close to 70% of the total bombs ped by fighter-bombers during the war, an important statistic to the Marines on the beaches of Okinawa or Iwo Jima. It also saw WWII service with the Royal Navy in both theatres, and with the RNZAF and other commonwealth nations.
    Upon the conclusion of the Second World War, the Corsair continued to see service around the world. The advent of jet fighters such as the Mig-15 and F-86 Sabre made them obsolete as fighters, but the corsair continued to be a popular ground attack aircraft, and saw extensive combat in Korea. They served faithfully with the French navy during the 50's, seeing combat in French Indochina against the Vietcong, and also against the Eqyptians during the Suez crisis and continued to serve until 1964.
    The Corsair last saw combat in 1969, when surplus Corsairs, operated by the airforces of Honduras and El Salvador faced each other in the Football War.
    « Απάντηση #18 στις: Σάββατο, 23 Αυγ 2014, 13:39:07 »
    PHOENIX MODEL EDGE 540 .46-.55 SCALE 1:5 1/4 ARF
    Introducing
        The Edge 540 is the most common aircraft used in the Red Bull Air race World Series , in fact all champions of the World Series have flown this aircraft.
        Phoenix’s Edge 540 is naturally slower but is engineered to perform equally thrilling maneuvers! scale-like model able to perform flat spin, knife edge and many other difficult aerobatics. The Edge 540 is expertly handcrafted from balsa and plywood using only epoxy and CA glues. You can fly this plane after few hours of installation. All the hardware are included (servo wire, fuel tank, wheel/landing gear, etc). You only need to separately purchase the nitro engine and radio system.
    Technical data
    - Wingspan: 1407mm (55.3 in)
    - Length: 1353mm (53.2 in)
    - Flying weight: 2800-3200 gr
    - Wing area: 35.3 dm2
    - Wing loading: 80g/dm2
    - Covering type: Genuine ORACOVER®
    - Gear type: Aluminum Hi-grade for main gear and spring wire for tail gear (included)
    - Spinner size: Plastic 58mm (included)
    - Radio: 4 channel minimum (not included)
    - Servo: 5 standard servo: 2 aileron; 1 elevator; 1 rudder; 1 throttle (not included)
    - Recommended receiver battery: 4.8-6V / 800-1200mAh NiMH (not included)
    - Servo mount: 21mm x 42 mm
    - Engine: .46-.55 / 2-stroke or .52/4-stroke glow engine (not included)
    - Motor: brushless outrunner 1000-1400 W, 480 KV (not included)
    - Gravity CG: 80-85 mm (3.1-3.3 in) Back from  the leading edge of the wing, at the fuselage
    - Control throw Ailerons: Low: 8mm up/down, 10% expo; High: 10mm up/down, 10% expo
    - Control throw Elevators: Low: 8mm up/down, 12% expo; High: 10mm up/down, 12% expo
    - Control throw Rudder: Low: 25mm right/left, 15% expo; High: 40mm right/left, 15% expo
    - Plane type: Scale Aerobatic
    - Motor: RIMFIRE .46-.55 (not included)
    - Lipo cell: 6 cells / 4000 – 5500mAh (not included)
    - Esc: 50-80A (not included)
    Feature
    - Covered in genuine ORACOVER®
    « Απάντηση #19 στις: Σάββατο, 23 Αυγ 2014, 14:02:08 »
    PHOENIX MODEL YAK54 YAKOVLEV .120 SCALE 1:4 ¾ ARF
    Introducing
        The new Yak54 is enhanced with design and structural upgrades that boast a fresh, progressive look and make them extreme aerobatic performers to be reckoned with. This plane allows pilots to achieve unlimited potential for sport and 3D flight - harriers, blenders, knife-edge, torque rolls and more. The Yak54 offers lightweight balsa and light plywood construction dressed in genuine ORA COVER for a vibrant look. Also in the kit is a complete hardware package, an instruction manual, stick-on decals. Hardware items include aluminum landing gear, wheels, engine mount, fuel tank, control horns, clevises, and control rods. This Yak54 is the best choice for you.
    Technical data
    - Wingspan: 1672mm (65.83 in)
    - Length: 1620mm (63.8 in)
    - Flying weight: 4.7- 5.2 kg
    - Radio: 4 channel . 5 standard hi torque servo: 2 aileron; 2 elevator; 1 rudder; 1 standard servo throttle (not included)
    - Engine: .120 / 2-stroke – glow engine - 20/22 cc gas engine (not included)
    - Propeller: 18x6; 18x8 (2 blade) (not included)
    - Plane type: Scale aerobatic
    - Motor: rimfire 120 (not included)
    - Lipo cell: 12 cells / 5500 – 6000mAh (not included)
    - Esc: 120-160A HV (not included)
    Feature
    - Capable of both precise and extreme 3D aerobatics
    - Genuine Oracover covering
    - Extremely lightweight laser-cut all-wood construction
    - Durable factory-painted fiberglass cowl
    - Prepainted pilot figure, preinstalled in cockpit
    - All hardware included
    « Απάντηση #20 στις: Τρίτη, 26 Αυγ 2014, 17:43:11 »
    GRAUPNER WP STARLET 2400 MM
    Description
    The STARLET 2400 model is an enlargement of the model from 1982 with a wingspan of about 1525 mm. The original was offered by the company Stolp in the USA as a kit in the experimental class for amateur aircraft builders. The one-seater aircraft with the parasol design was assembled using composite construction techniques. As propulsion system, it is possible to install anything from a VW car engine to a 60-hp Continental. The docile flying characteristics make the STARLET 2400 ideal as a starting point in the area of large model flying and switching to aileron-controlled motorised models. Both internal combustion and electric motors can be used for propulsion. Simple aerobatics are possible with types of propulsion system. With the OS GT 33, vertical climbs are possible. However, the docile flight behavior means that very slow overflights can also be done. To change the drive battery inthe electric version, a large opening has been provided in the the fuselage in the area of the cockpit. The two detachable wings and the two halves of the tailplane can be removed for transport.
        ARTF model (almost ready to fly)
        Complete balsa/plywood design
        Ideal for switching to large aileron-controlled models
        Fuselage, wings, and tailplane pre-covered with multicolored foil
        Wheels, small parts, and accessories for rudder linkage
        Parts included for electric installation
        Protective bags for wing and tailplane halves and vertical stabiliser
    spare parts
    Information
        ARTF(Almost Ready to Fly)
        Aerobatic trainer
        Wings and tailplane halves can be removed for transport
    RC functions
    Rudder linked to tailwheel
    Elevators
    Ailerons
    Speed controller
    Specification
    Wing area : 76 dm²
    All-up weight, approx.: 6500 g
    Total surface area, approx. : 91 dm²
    Hull length, approx. : 1540 mm
    Tailplane area : 15 dm²
    Wingspan approx.: 2400 mm
    « Απάντηση #21 στις: Πέμπτη, 28 Αυγ 2014, 20:33:43 »
    Graupner MZ-18, 9 channel HoTT radio control with Telemetry
    Description
    Graupner/SJ mz-18 HoTT 2.4GHz 9 Channel transmitteris designed with Graupner/SJ's unique telemetry technology that support Bi-directional data transmission gives user the real-time information. The use of up to 75 frequency hopping channels ensures extreme operating reliability and immunity to external interference. mz-18 has 30 model memories and it is suitable for any aircraft, Aditionally, with up to 9 available channels, built-in telemetry with data logging capabilities and 3.5" large TFT LCD with specialized touch pannel, mz-18 is the obvious choice for anyone who needs a high quality 9 channel radio.
    Features:
        HoTT (HOPPING TELEMETRY TRANSMISSION) bi-directional 2.4 GHz technology
        3.5" clolor TFT LCD with specialized touch pannel and user friendly interface
        Smart voice announcement system (Speaker and Earphone) for warnings and alarms at real time
        Real-time data analysis with optional sensor (GPS, Fuel status, Temperature, Voltage, Current) and sensor board (General air module, General engine module)
        Real-time telemetry analysis for Brushless Control Telemetry ESC such as RPM, consumption current, voltage, ESC temperature, Warning'
        Advanced HoTT wired/wireless trainer system
        Multi binding receiver system that 2 receivers can be connected in paralleled to use additional servos
        High-precision quad ball bearing gimbals (total 8ea) lead the smooth and comfortable stick feeling
        Standard micro SD Memory cards to sharemodel setup, expand model memeory
        30 model memories
        Model copy function for model memories
        Staying up to date with the latest Graupner/SJ Firmware
        Programming options:
        30 model memories(Available to expand model memory, using SD card)
        6 Q.link functions
        3 Model types(Helicopter, Airplane, Glider)
        Helicopter Function
        Q.link function x 6
        6 swash plate types (1 Servo, 2 Servo 180, 3 Servo 120, 3 Servo 140, 3 Servo(Elevator), 4 Servo 90)
        Pitch Curves (7-point)
        Throttle Curves(7-point)
        Pitch, Throttle Trim function x 6
        Swash Limit function
        Swash Limit mix function
        Program mixing x 8(Liner Program mixing x 5, Curve mixing x 3)
        Throttle mixing function(AILE>>THRO, ELEV>>THRO, RUDD>>THRO)
        Airplane Function
        Q.link function x 6
        8 wing type(Delta wing included)
        3 tail type
        Wing mixing(RUDD>>AILE, AILE>>RUDD, RUDD>>ELEV)
        Snap roll function
        Aileron Diff function
        Flap sett function
        Airbrake function
        Idle Low function
        Glider Function
        Q.link function x 6
        3 tail type
        Flap MIX function(FLAP, AILE>>FLAP, ELEV>>FLAP, FLAP>>ELEV)
        Flap sett function
        Butterfly function
    Specification
    Control function: 9
    Temperature range : -10...+55 °C
    Aerial length: 120 mm
    All-up weight, approx.: 840 g
    Frequency : 2400...2483,5 MHz
    Range approx. : 4000 m
    Dimensions (LxWxH): 194 x 287 x 112 mm
    Modulation: FHSS
    Charging rate : 510 mA
    Operating voltage : 3,4...6,0 V
    « Απάντηση #22 στις: Πέμπτη, 28 Αυγ 2014, 20:43:13 »
    Νέες Παραλαβές σε SERVO και Brushless Motors απο PowerHD (πλήρη σειρά)
    « Τελευταία τροποποίηση: Παρασκευή, 29 Αυγ 2014, 11:25:05 από DIAMOND » Καταγράφηκε
    « Απάντηση #23 στις: Παρασκευή, 29 Αυγ 2014, 11:22:37 »
    Elektric Brake system with 55mm Double Ballraced Inflateble Alu wheels (2pcs)
    JP lectromagnetic control aircraft brake system is replacing and reshaping the traditional pneumatic and server remote control aircraft braking system.
    This will enable the players an easier installation mode and a better control on distance when landing without adding extra flying weight.
    JP applies high grade aluminum machined brake Wheel frame , Built inside magnetic coil, high intensity hub with strong axle and adopting replaceable advanced hollow rubber tires skin.
    Feature:
    1: Completely control by electricity , no more trouble from air brake air leaking.
    2:Strong CNC machined wheel frame and inflatable true soft rubber tire.
    3.The controller will shut down the brake after 1 minute automatically , The controller will smartly detect it if you the brake stop for 1 minutes, and automatically reset it to its normal function.
    Brake Using illustration:
    1.Voltage input :7.2V-30V Can tap directly on aircraft batteries Or use an external battery 7.2V-30V
    2.Signal input : Connect remote control receiver, set an action
    3.Capacity control: adjustment clockwise will increase the power, or counter clockwise to reduce power
    4.Brake wheel: Connect the power input line on the battery.Set come with two main wheels and brake controller.
    Specifications:
    1.Main Wheel Diameter:50mm-65mm
    2.Axle Screw Diameter: 4mm
    3.Total Weight: 4.37 oz/ 135g
    Instruction
    Step 1: Install the magnetic wheels with your wheel strut.
    Step 2: Connect two brake wheels’ wire into PC-board, and the signal wire into the receiver :
    Step 3: Set an action “ON/OFF” on your transmitter:
    Notice :The signal wire must connect into the working receiver,otherwise it will consume all the battery.
    Voltage input:
    7.2V-30V can tap directly on aircraft battery or use an external battery 7.2V-30V.
    Brake force control:
    The transmitter only support ON/OFF, thus there is not making proportional brake, or you can use currency trim button to control the brake force.The controller shut down the brake after 1 minute. The controller will smartly detect it,shut down the current to brake system and automatically reset it to its normal function.
    This ‘auto-shut down’ is designed to protect the magnetic coil and conserve your battery power.
    Thanks and Have a great Landing on
    « Απάντηση #24 στις: Παρασκευή, 29 Αυγ 2014, 11:51:00 »
    BRAINERGY LiPo 6s1p 22,2V 5.200mAh 45C
    Τιμή: €88.90
    Technical data
    Configuration:    6s1p
    Nominal voltage:    22,2 V
    Rated capacitance:    5.200 mAh
    Charge rate (maximum):    2C (10,4 A)
    Discharge rate (continuous):    45C (234 A)
    Dimensions:    137 x 43 x 60 mm
    Weight:    715 g
    Connection cable:    Silikon
    Connection:    kompatibel mit Deans Ultra Plug (T-Plug)
    Balancer cable:    Silikon
    Balancer:    kompatibel mit JST XH
    « Απάντηση #25 στις: Δευτέρα, 1 Σεπ 2014, 21:53:22 »
    Nicesky F4U-1A Corsair PnP
    Η Τιμή μας: €102.90
    Technical Data
        Scale: 1:18,5
        Wingspan: 680 mm
        Length: 555 mm
        Material: EPS
        Weight: 270g
        Servos: 3 x 9 g (installed)
        Motor: BL Outrunner (installed) 2.000 U/min/V (KV)
        Controller: BL ESC (installed) 12 A
    Pilot-operated
        Elevator
        Rudder
        Ailerons
        Motor
    Scope of Delivery
        Fuselage (decorated)
        Wings (decorated)
        Manual (German/English)
    « Απάντηση #26 στις: Πέμπτη, 4 Σεπ 2014, 20:58:57 »
    ESM PC-9
    Length:             1936mm(76")
    Wing span:       2024mm(80")
    Wing area:        64sq.dm(6.9sq.ft)
    Wing loading:  106.3g/sq.dm                (34.9oz/sq.ft)
    Flying weight:   6.8kg(17.3bs)
    Engine:             120 4-cycle
                             30cc gasoline engine
    History:
    Feature: Fiberglass fuse and balsa built -up wing
    Wing Covering Material: Special Fabric Covered, painted, decals applied and clear coated. The aircraft has a beautiful flat, glossy finish.
    « Απάντηση #27 στις: Παρασκευή, 5 Σεπ 2014, 07:41:28 »
    Πολύ όμορφο μοντέλο  Thumbs up
    « Τελευταία τροποποίηση: Σάββατο, 6 Σεπ 2014, 07:03:09 από w1ndsurfer » Καταγράφηκε
    « Απάντηση #28 στις: Παρασκευή, 5 Σεπ 2014, 13:01:10 »
    Σε ελεύθερη μετάφραση μέσο Google!!
    Το αεροσκάφος έχει μια όμορφη επίπεδη, γυαλιστερό φινίρισμα.
    Μάλλον είναι σωστό όπως το έχει!!!  Wink
    « Απάντηση #29 στις: Παρασκευή, 5 Σεπ 2014, 13:45:21 »
    (edit)
    « Τελευταία τροποποίηση: Σάββατο, 6 Σεπ 2014, 07:02:30 από w1ndsurfer » Καταγράφηκε
    Σελίδες: 1 [2] 3 4 5 ... 24     Πάνω
