ÓÜââáôï, 31 Ïêô 2026, 13:05:08
    �ñüóöáôá è�ìáôá
    [×èåò óôéò 23:11]
    [×èåò óôéò 23:07]
    áðü Markhelis
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310037
    Óýíïëï èåìÜôùí: 12401
    Online óÞìåñá: 125
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 2
    ÅðéóêÝðôåò: 78
    ÓõíïëéêÜ: 80
    Óôõë åìöÜíéóçò
    Óåëßäåò: [1]     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: Ã�óêÞóåéò ðôÞóçò ãéá F4C GR ,ARF  (Áíáãíþóôçêå 3433 öïñÝò)
    GiannisX
    Ìçíýìáôá: 1.518
    « óôéò: ÄåõôÝñá, 23 Ìáñ 2009, 21:58:16 »
     KáëçóðÃ�ñá óå üëïõò.
    Èá Þèåëá íá ñùôÞóù ó÷åôéêÜ ìå ôï ðôçôéêü êïììÜôé
    ôçò scale êáôçãïñßáò.
    ÕðÜñ÷åé ìßá õðï÷ñåùôéêÞ Üóêçóç óôï ðñüãñáììá ðïõ ë�ãåôáé "åõèåßá ðôÞóç"
    Ìðïñåß êÜðïéïò íá ìïõ åîçãÞóåé ôçí äéáöïñÜ áõôÞò ôçò Üóêçóçò
    ìå ôçí Üóêçóç åðéëïãÞò "flight in a straight line in a constant height" Huh?
    ÊáôáãñÜöçêå
    Aeolus-Rc
    GiannisX
    Ìçíýìáôá: 1.518
    « ÁðÜíôçóç #1 óôéò: ÐÝìðôç, 26 Ìáñ 2009, 15:42:06 »
    ÄçëáäÞ ìðïñþ íá åêôåë�óù ôçí ßäéá áêñéâþò Üóêçóç óôï ðñüãñáììá.
    Ã�÷ïõí êáé äéáöïñåôéêü Ê factor  Grin  Grin
    KÜðïéïò åðß ôïõ è�ìáôïò?
    ÊáôáãñÜöçêå
    Aeolus-Rc
    DINOS BALANOS
    Ìçíýìáôá: 194
    « ÁðÜíôçóç #2 óôéò: ÐÝìðôç, 26 Ìáñ 2009, 17:25:08 »
    HEY GiannisX,
    ''FLIGHT IN A STRAIGHT LINE AND CONSTANT HEIGHT(MAXIMUM 6m)''
    MODEL AIRCRAFT APPROACHES IN STRAIGHT FLIGHT AT A CONSTANT HEIGHT NOT EXCEEDING 6 METRES
    FOR A MAXIMUM DISTANCE 100 METRES, THEN CLIMBS AWAY.THIS IS AN EFFECT � LOW FLYPAST.
    ERRORS:
    1.NOT A STRAIGHT COURSE(SLIGHT CORRECTIONS ACCEPTABLE WITH LIGHT AIRCRAFT).
    2.NOT CONSTANT HEIGHT.
    3.NOT 6 METRES OR BELOW.
    4.NOT PASS OVER THE LANDING AREA
    5.NOT CENTERED ON JUDGES'  POSITION.
    6.NOT PARALLEL WITH THE JUDGES' LINE.
    7.TOO SHORT DISTANCE(TOO LONG IS NOT AN ERROR).
    8.MODEL AIRCRAFT FLIGHT PATH NOT STEADY.
    9.TOO FAR AWAY/TOO CLOSE/TOO HIGH/TOO LOW.
    Ô� ��Ñ����Ù �Ñ�ÊÕ�Ô�Õ�Å ��� Ô�� SPORTING CODE TOY 2006 ��Õ Å×Ù ÓÔ� ×ÅÑÉ� Ì�Õ!
    �ÉÈ��ÙÓ Ê�ÔÉ �� Å×ÅÉ �ËË�ÎÅÉ ��� Ô�ÔÅ!!!
    Å�� Ó×ÇÌ�Ô�ÊÉ ÂÅÂ�ÉÙÓ, È� ÓÅ ÄÉÅÕÊ�ËÕ�Å �Ê�ÌÇ �ÅÑÑÉÓ�ÔÅÑ�!
    ÅË�ÉÆÙ �� Â�ÇÈÇÓ�...
    ÊáôáãñÜöçêå
    ×�ÉÑÅÔÉÓÌ�ÕÓ, DINOS
    THE FLYING FARMER!
    DINOS BALANOS
    Ìçíýìáôá: 194
    « ÁðÜíôçóç #3 óôéò: ÐÝìðôç, 26 Ìáñ 2009, 17:32:39 »
    Å×Ù ÔÇ� Å�ÔÕ�ÙÓÇ �ÙÓ Ç ÓÕÃÊÅÊÑÉÌÅ�Ç �ÓÊÇÓÇ ��ÇÊÅÉ
    ÓÔÉÓ �Ñ��ÉÑÅÔÉÊÅÓ! Å×ÅÉ �ËË�ÎÅÉ Ê�ÔÉ;
    ×�ÉÑÅÔÉÓÌ�ÕÓ...
    ÊáôáãñÜöçêå
    ×�ÉÑÅÔÉÓÌ�ÕÓ, DINOS
    THE FLYING FARMER!
    DINOS BALANOS
    Ìçíýìáôá: 194
    « ÁðÜíôçóç #4 óôéò: ÐÝìðôç, 26 Ìáñ 2009, 20:11:06 »
    ÔÙÑ� ÉÓÙÓ Ê�ËÕÔÅÑ�!
    http://www.cobra.org.br/modalidades/arquivos/SC4_Vol_F4_Scale_08.pdf
    ÊáôáãñÜöçêå
    ×�ÉÑÅÔÉÓÌ�ÕÓ, DINOS
    THE FLYING FARMER!
    GiannisX
    Ìçíýìáôá: 1.518
    « ÁðÜíôçóç #5 óôéò: ÐÝìðôç, 26 Ìáñ 2009, 21:27:49 »
     Nôßíï åõ÷áñéóôþ ãéá ôçí áíôáðüêñéóç áëëÜ ç áðïñßá ìïõ äåí ëýèçêå
    Ôïõò êáíïíéóìïýò ôïõò äéáâÜæù áðü ôçí ÅëÜï êáé íïìßæù üôé éó÷ýïõí.
    Åßíáé Üóêçóç åðéëïãÞò üðùò áí�öåñá óôï ðñþôï ðïóô , ç Üóêçóç ðïõ ðåñéãñÜöåéò ðùò ãßíåôáé.
     Ã™Ã±Ã¡ÃŸÃ¡ äéáâÜóáìå ðùò åêôåëåßôáé áõôÞ ç Üóêçóç.... ôþñá ìðïñïýìå íá ìÜèïõìå,
    ðùò åêôåëåßôáé êáé ç õðï÷ñåùôéêÞ Üóêçóç "åõèåßá ðôÞóç" êáé áí �÷åé äéáöïñ�ò ìå áõôÞí ôçò åðéëïãÞò?
    ÊáôáãñÜöçêå
    Aeolus-Rc
    Êþóôáò Êùóôüðïõëïò
    Ìçíýìáôá: 2.879
    « ÁðÜíôçóç #6 óôéò: ÐáñáóêåõÞ, 27 Ìáñ 2009, 07:51:56 »
    ÃéÜííç äåò ôï í�ï êáíïíéóìü F4 2009 áðü ôï site ôçò FAI.
    Åýëïãç ç áðïñßá óïõ, ç äéáöïñÜ åßíáé óôï ýøïò, ç ðñïáéñåôéêÞ Üóêçóç (ôï ãñÜöåé êáé óôá åëëçíéêÜ) �÷åé ýøïò ðôÞóçò �ùò ôï ðïëý 6m, äçëáäÞ óôçí ïõóßá åßíáé ÷áìçëü ð�ñáóìá.
    �ðü ôïí í�ï êáíïíéóìü 2009
    6C.3.6.2. Straight Flight:
    Model aircraft should make a straight and level flight of at least 100 metres length centred on the judges’ position.
    Errors:
    1. Not a straight course (slight corrections are acceptable with a light aircraft)
    2. Not constant height.
    3. Not pass over the landing area.
    4. Not centred on judges’ position.
    5. Not parallel with the judges’ line.
    6. Too short a distance (too long is not an error).
    7. Model aircraft flight path not smooth and steady.
    8. Too far away, too close, too high, too low.
    T Flight in a Straight Line at Constant Height (Maximum 6 m):
    Model aircraft approaches in straight flight at a constant height not exceeding 6 metres for a minimum distance of 100 metres, then climbs away. This is in effect a low flypast.
    Errors:
    1. Not a straight course (slight corrections acceptable with light aircraft).
    3. Not 6 metres or below.
    4. Not pass over the landing area.
    5. Not centred on judges’ position.
    6. Not parallel with the judges’ line.
    7. Too short distance (too long is not an error).
    8. Model aircraft flight path not steady.
    9. Too far away/too close/too high/too low.
    Åëðßæù íá ìçí ðáñåîçãçèþ, êñéôÞò F3A Ã�÷ù êÜíåé, ü÷é scale.  Óôñéöïãýñéóìá ìáôéþí
    ÊáôáãñÜöçêå
    �ñéí êÜíåôå åñþôçóç: ØÜîáôå óôï Aeromodelling GR Þ óôï Âéâëßï ôïõ jkon;
    Ìçí êÜíåôå ÷áñáêôçñéóìïýò êáé Üó÷çìá ó÷üëéá, áí ìç ôé Üëëï, óõãêñáôçèåßôå ãéá ôï êáëü ôïõ ÷üìðõ ìáò.
    GiannisX
    Ìçíýìáôá: 1.518
    « ÁðÜíôçóç #7 óôéò: ÐáñáóêåõÞ, 27 Ìáñ 2009, 10:25:26 »
     ÃŠÃ¡Ã«Ã§Ã¬Ã�ñá.
    ÄçëáäÞ óôçí õðï÷ñåùôéêÞ Üóêçóç äåí õðÜñ÷åé ðåñéïñéóìüò ýøïõò...
    ðáñüëáôáõôá ìðïñåßò íá ðåôÜîåéò åðßóçò êÜôù áðü ôá 6 ì�ôñá êáé íá êÜíåéò 2 ßäéåò áóêÞóåéò.
    Åõ÷áñéóôþ
    ÊáôáãñÜöçêå
    Aeolus-Rc
    Êþóôáò Êùóôüðïõëïò
    Ìçíýìáôá: 2.879
    « ÁðÜíôçóç #8 óôéò: ÐáñáóêåõÞ, 27 Ìáñ 2009, 22:39:19 »
    Äåí íïìßæù ïôé ç õðï÷ñåùôéêÞ åõèåßá ïñéæïíôßá åßíáé óùóôü íá åßíáé ÷áìçëÞ, ðñ�ðåé í' áíôéóôïé÷åß óôïí ôýðï ôïõ ðñáãìáôéêïý áåñïóêÜöïõò êáé íá "ä�íåé" ìå ôéò êïíôéí�ò. Åðßóçò ç åðéëïãÞ ôùí ðñïáéñåôéêþí áóêÞóåùí ðñ�ðåé í' áíôéóôïé÷åß ìå ôéò äõíáôüôçôåò êáé ôçí ÷ñÞóç ôïõ ðñáãìáôéêïý.
    ÊáôáãñÜöçêå
    Óåëßäåò: [1]     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Ã�åñïìïíôÃ�ëá õðü êëßìáêá (scale)  |  Êëßìáêïò (scale) F4C êáé semi scale (ÓõíôïíéóôÞò: ArgyrisGiannetakis)  |  ÈÝìá: Ã�óêÞóåéò ðôÞóçò ãéá F4C GR ,ARF
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.057 äåõôåñüëåðôá. 24 åñùôÞìáôá.
