Δευτέρα, 12 Οκτ 2026, 17:20:55
    [Σήμερα στις 13:52]
    Online σήμερα: 45
    Επισκέπτες: 31
    Συνολικά: 33
    Σελίδες: 1 ... 17 18 19 [20]     Κάτω
    Αποστολέας Θέμα: Samos Model center  (Αναγνώστηκε 207887 φορές)
    samosrc
    « Απάντηση #285 στις: Σάββατο, 19 Ιουλ 2014, 10:17:12 »
    ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
       ΝΕΑ ΠΡΟΙΟΝΤΑ
    nano-tech 2500mAh 3S1P 5~10C Transmitter Lipo Pack Typically reserved for high amp draw performance applications Turnigy nano-tech batteries represe…
    21.00€
    Turnigy nano-tech 1500mAh 2S1P 20~40C Receiver Pack Typically reserved for high amp draw performance applications Turnigy nano-tech batteries represe…
    13.00€
    TURNIGY TRUST 55A SBEC Brushless Speed Controller Turnigy® TRUST SBEC ESC 's have a very flexible and broadly capable MCU, able to run all typ…
    33.00€
    HobbyKing 60A BlueSeries Brushless Speed Controller Its no “Mystery” where these ESC s are made, now they are available to you at HobbyKi…
    39.00€
    On-Board LED RX Voltage Display This tiny, bright and lightweight unit gives you an accurate RX voltage reading and can be plugged into either your…
    5.00€
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΣΕ ΟΛΗ ΤΗΝ ΕΛΛΑΔΑ ΑΝΩ ΤΩΝ   50€
    http://www.rcmodelshop.gr/index.php?main_page=products_new
    rcmodelshop.gr
    samosrc
    « Απάντηση #286 στις: Παρασκευή, 8 Αυγ 2014, 10:23:29 »
    MINTOR & SEBART
    Joysway Super Mono X B/less 2.4GHz ARTR Take a high performance mono hull design and equip it with a water-cooled 2212-2950kV out-runner brushless m…
    110.00€
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΑΝΩ ΤΩΝ 50Ε  ΣΕ ΟΛΗ  ΤΗΝ ΕΛΛΑΔΑ
    rcmodelshop.gr
    samosrc
    « Απάντηση #287 στις: Παρασκευή, 12 Σεπ 2014, 10:46:26 »
    MINTOR & SEBART
    Grip Cyanoacrylate - Thick (50g)
    Grip Cyanoacrylate - Thick (50g) Grip Cyanoacrylate, or 'Super Glue' is a high performance instant setting adhesive that forms lightweight, strong jo…
    9.00€
    Cirrjavascript:void(0);us 3CSX 3Ch Steerwheel 40MHz Combo
    Cirrus 3CSX 3Ch Steerwheel 40MHz Combo • Rubber steering wheel • Servo Reversing • Adjustable Steering ATV • Button controlle…
    26.00€
    Hi-Energy Extreme 3S 3200mAh 30C Li-Po
    Hi-Energy Extreme 3S 3200mAh 30C Li-Po Hi-Energy Extreme batteries are designed to offer great performance in sports applications and amazing value…
    29.00€
    Hi-Energy Extreme 3S 2200mAh 30C Li-Po
    Hi-Energy Extreme 3S 2200mAh 30C Li-Po Hi-Energy Extreme 3S 2200mAh 30C Li-Po Hi-Energy Extreme batteries are designed to offer great performance in…
    19.00€
    Ripmax Glowstart w/Chgr - 2100mAh
    Ripmax Glowstart w/Chgr - 2100mAh A basic 2100mA glowstart. Supplied with appropriate AC charger.
    16.00€
    Udi U839 Nano Quad 2.4GHz Orange RTF
    Udi U839 Nano Quad 2.4GHz Orange RTF UDI have taken the proven technology of their larger quadcopters and shrunk it down into this Nano U839 drone q…
    37.00€
    ZIPPY Flightmax 1300mAh 3S1P 20C
    ZIPPY Flightmax 1300mAh 3S1P 20CZ13003S20C Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries i…
    11.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #288 στις: Τρίτη, 16 Σεπ 2014, 19:02:18 »
    MINTOR & SEBART
    Easy Star II Το νέο Easy Star II είναι πραγματικότητα . Με εμφανείς βελτιώσεις τόσο στην άτρακτο όσο και στα φτερά του. Πιο συγκεκριμένα η άτρακτος έ…
    79.00€
    r
    Solius Glider Specification Wingspan: 2160 mm Overall lengh: 1100 mm All-up weight, glider version: from 1250 g All-up weight, electric version: from…
    122.00€
    Nine Eagles Sky Runner S-FHSS RTF The perfect model to start out in radio control flying without breaking the bank! It has been purpose desi…
    [url=http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=2217][/url]
    95.00€
    EASY STAR (white  edition        EasyStar – the modern path for your first steps in model flying  EasyStar - the model with the innovative desi…
    59.00€
    HXT900 9g / 1.6kg / .12sec Micro Servo HXT900, one of the most famous and the best value micro servos available. Used by tens of thousands of hobbyies…
    3.90€
    23.00€
    Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec   Weight: 13.4g Dimension: 22.8*12.2*28.5mm Stall torque: 1.8kg/cm (4.8V) - 2.2kg/cm (6.0V…
    7.00€
    Turnigy nano-tech 1700mAh 2S1P 20~40C LiFePo4 Receiver Pack Typically reserved for high amp draw performance applications Turnigy nano-tech batterie…
    16.00€
    Turnigy TG9e 9g / 1.5kg / 0.10sec Eco Micro Servo   THE WORLDS LOWEST COST (RELIABLE) SERVO   The TG9e boasts the same …
    3.00€
    ZIPPY Flightmax 2200mAh 3S1P 25C Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the hobb…
    16.00€
    « Τελευταία τροποποίηση: Τρίτη, 16 Σεπ 2014, 19:13:30 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #289 στις: Πέμπτη, 9 Οκτ 2014, 13:05:04 »
    MINTOR & SEBART
    Futaba R7008SB Receiver (S-Bus) (HV) 2.4GHz The R7000SB is a FASSTest telemetry enabled receiver, a high-voltage design that operates up to …
    106.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #290 στις: Παρασκευή, 28 Νοε 2014, 10:10:53 »
    MINTOR & SEBART
    ΝΕΑ  ΠΡΟΙΟΝΤΑ
    Ripmax Dingo 1/18th Truggy EP
    Ripmax Dingo 1/18th Truggy EP They say that good things come in small packages and the Ripmax Dingo is certainly a case in point. At 1/18th scale si…
    79.00€
    Hi-Energy Extreme 3S 1300mAh 30C Li-Po
    Hi-Energy Extreme 3S 1300mAh 30C Li-Po Hi-Energy Extreme batteries are designed to offer great performance in sports applications and amazing value…
    12.00€
    Joysway Super Mono X V2 Brushless 2.4GHz ARTR
    Joysway Super Mono X V2 Brushless 2.4GHz ARTR Take a high performance mono hull design and equip it with a water-cooled 2812-2950kv out-runner brushl…
    119.00€
    TT YAK 54 3D Kit - 55" with OBL Motor
    TT YAK 54 3D Kit - 55" with OBL Motor A great e-powered 3D fun-flyer to attack any aerobatics and 3D manoeuvres ranging from Knife Edge, Hover…
    139.00€
    TT YAK 54 3D Kit - 55" Wingspan - Red/White
    TT YAK 54 3D Kit - 55" Wingspan - Red/White A great e-powered 3D fun-flyer to attack any aerobatics and 3D manoeuvres ranging from Knife Edge,…
    99.00€
    [/center]
    rcmodelshop.gr
    samosrc
    « Απάντηση #291 στις: Παρασκευή, 28 Νοε 2014, 19:53:26 »
    MINTOR & SEBART
    ΝΕΑ  ΠΡΟΙΟΝΤΑ
    19.00€
    GWS EP Propeller (DD-4540 114x102mm) (6pcs/set) All GWS EP Propellers Stocked! GWS EP Propeller (DD-4540 114x102mm) Colours vary. Not always orange &n…
    6.00€
    Turnigy Accucel-8 150W 7A Balancer/Charger
    Turnigy Accucel-8 150W 7A Balancer/Charger The Accucel-8150 is a Lipoly/LiFe battery charging workhorse. Capable of handling up to 8S, 7A or a …
    [ur]=http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1307[/url]
    64.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #292 στις: Πέμπτη, 17 Δεκ 2015, 13:38:30 »
                              SEBART
    Hi-Energy 2S 5000mAh 40C Car Li-P This battery and other Hi-Energy Ultra Li-Po battery packs are designed to offer great value for money yet still d…
    46.00€
    17.00€
    Turnigy nano-tech 2000mAh 2S1P 20~40C LiFePo4 Transmit Typically reserved for high amp draw performance applications Turnigy nano-tech batteries repr…
    22.00€
    The Cerberus B6 Balance Charger utilises quality FETs and resistors to accurately balance and charge Lithium Polymer and NiMH batteries. The Cerberus…
    39.00€
    Gens ACE Lipo 3s-11.1V Spec. - Product Type:lipo battery pack - Capacity: 2200mAh - Voltage: 11.1V - Max Continuous Discharge: 25C (55A) - Max Burst …
    29.00€
    Ripmax Coyote 1/18th Buggy EP At 1/18th scale size, the Coyote is capable of being used both outdoors in the rough and indoors on carpets. Don't be …
    94.00€
    Ripmax Micro Short Course EP RTR 2.4GHz This stunning micro Short Course car features a clever moving chassis suspension system keeping weight/cost…
    43.00€
    Turnigy 1300mAh 2S 20C Li Turnigy batteries are known the world over for performance, reliability and price. It’s no surprise to us that Turnigy Lipo…
    12.00€
    Turnigy 2200mAh 3S 25C Lipo Pack Turnigy 2200mAh 3S 25C Lipo Pack   The new number one in performance and price! The new Tur…
    19.00€
    Turnigy 3000mAh 2S 40C L Turnigy batteries are known the world over for performance, reliability and price. It’s no surprise to us that Turnigy Lipol…
    27.00€
    Turnigy 3300mAh 2S 30C Lipo Pack   The new number one in performance and price! The new Turnigy Lipoly packs deliver full cap…
    27.00€
    Turnigy 4000mAh 2S 30C Hardcase Pack (ROAR APPROVED Now officialy approved by  ROAR  for race use! Turnigy batteries are known the world over fo…
    32.00€
    RIO BRAVO T732
    126.00€
    rcmodelshop.gr
    Σελίδες: 1 ... 17 18 19 [20]     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: Samos Model center
