Δευτέρα, 19 Οκτ 2026, 08:29:02
    Online σήμερα: 46
    Επισκέπτες: 41
    Συνολικά: 43
    Σελίδες: 1 ... 13 14 15 [16] 17 18 19 20     Κάτω
    Αποστολέας Θέμα: Samos Model center  (Αναγνώστηκε 208537 φορές)
    samosrc
    « Απάντηση #225 στις: Τετάρτη, 29 Φεβ 2012, 11:21:49 »
    ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
    TopFuel LiPo 20C-ECO 900mAh 3S
    Discription: The new TopFuel ECO 20C Series. High quality and a lot of power for a fair price. Technical Datas: Cellcount   3 Capac…
    13.00€
    JETImodel SP06
    JETImodel SP06   This switch is suitable for switching on – off auxliary functions, e.g. lights...
       23.00€
    JETImodel SPS 20
    JETImodel SPS 20   magnetic switch for power circuits (RX Battery, Ignition Battery ... ) , no voltage regulator   Parameters Di…
    38.00€
    JETImodel DPS 40
    JETImodel DPS 40   magnetic switch for two power circuits, no voltage regulator   Parameters: Dimensions [mm] 46 x 45 x 6.5 P…
    39.00€
    T5692 Turnigy Pro Comp Brushless Inrunner Motor 1000kv
    When you need serious power for your large scale perfomance boat or 1/5 scale RC car, look no further than the Turnigy Pro Comp series inrunners. The…
    110.00€
    3 Way Air Retract Landing-gear System (Trike-X Large)
    Complete air up/down Tricycle landing gear system that features adjustable retract speed for both up and down operation and sprung under-carriage leg…
    127.00€
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΑΝΩ ΤΩΝ 50Ε  ΣΕ ΟΛΗ  ΤΗΝ ΕΛΛΑΔΑ
    rcmodelshop.gr
    samosrc
    « Απάντηση #226 στις: Τετάρτη, 7 Μαρ 2012, 09:58:04 »
    MINTOR & SEBART
    Spinner 77mm for 110/120/140-size SebArt-Airplanes Yellow
    Item no.:  22421255 Spinner 77mm for 110/120/140-size SebArt-Airplanes Yellow
    14.00€
    TopFuel LiPo 20C 2100mAh 4S
    Beschreibung: Unsere TopFuel Akkus sind in dem jeweiligen Anwendungsbereich heiß begehrt und zeichnen sich durch extreme Leis…
    27.00€
    Aeronaut CAM Carbon 12 X 6,5
    Aeronaut CAM Carbon 12 X 6,5 Aeronaut CAM Carbon 12 X 6,5 CCCN 95030039
    9.00€
    A30-10 XL V2
    A30-10 XL V2 Item no.:  15716231 Description: A30-10XL V2 Specifications: Powerange max. 650W (15 se…
    96.00€
    A30-14 L V2
    A30-14 L V2 Item no.:  15716901 Description: A30-14L V2 Specifications: Powerange max. 500W (15 sec.…
    86.00€
    A10-15S
    A10-15S Item no.:  97100008 Description: The A10 motors are smalle outrunner of our series and provid…
    37.00€
    Carbon Strip 1x6x750mm
    Carbon Strip Specs: Length: 750mm Width: 6mm Thickness: 1mm
    1.00€
    Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin)
    Glass Fiber Cloth 100% woven glass fiber sheet. Excellent for repairing or forming your own canopy, cowl or pretty much anything. Use epoxy resin, …
    2.00€
    Turnigy nano-tech 5300mah 2S2P 30~60C Hardcase
    Turnigy nano-tec More than just a fancy name. TURNIGY nano-tech lithium polymer batteries are built with an LiCo  nano-technology substrate complex …
    41.00€
    ZIPPY Flightmax 4000mAh 2S1P 30C hardcase pack
    Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today! Hardcase packs a…
    28.00€
    A30-16 M V2
    Description: A30-16M V2 Specifications: Powerange max. 350W (15 sec.) Idle Current @ 8,4V 1,6A Resis…
    79.00€
    A20-20 L EVO
    A20-20 L EVO Description: A20-20 L EVO Specifications: Powerange max. 200W (15 sec.) Idle Current @ 8,4…
    65.00€
    Para-RC ARF Trike Set - Gold/White/Black
    Para-RC ARF Trike Set - Gold/White/Black Discription: A new dimension of scale RC-Paragliders incl. the complete Moto…
    689.00€
    TopFuel LiPo 3400mAh 3S 30C-LIGHT
    TopFuel LiPo 30C-LIGHT 34 Discription: The new TopFuel LIGHT 30C Series. High capacity with low weight, the best cells for every model. Technical …
    56.00€
    Twisted 60CM Servo Lead Extention (Futaba) 22AWG
    Twisted 60CM Servo Lead Extention Twisted 60CM Servo Lead Extention (Futaba) 22AWG (Futaba) 22AWG
    1.50€
    rcmodelshop.gr
    samosrc
    « Απάντηση #227 στις: Πέμπτη, 8 Μαρ 2012, 20:10:54 »
    MINTOR & SEBART
    Easy Star II
    Easy Star II Το νέο Easy Star II είναι πραγματικότητα . Με εμφανείς βελτιώσεις τόσο στην άτρακτο όσο και στα φτερά του. Πιο συγκεκριμένα η άτρακτος έ…
    76.00€
    EASY GLIDER PRO
    The EasyGlider PRO is an updated model based on the popular and proven EasyGlider and EasyGlider electric. Just like the larger Cularis the Easy Glid…
    78.00€
    PARK MASTER MUL 214232
    PARK MASTER MUL 214232PARK MASTER MUL 214232 Γρήγορη Επισκόπηση  With the ParkMaster 3D you can now fly aerobatics outdoors just like you do indoors! …
    96.00€
    Hacker-Model Extra 330 SC - Yellow
    Hacker-Model Extra 330 SC - Yellow < h1=""> Hacker-Model Extra 330 SC - Yellow recommended Setup: 3S Setup Hacker A20-26M EvoHacker…
    76.00€
    JETImodel MAX BEC
    JETImodel MAX BEC  MAX BEC can be supplied either by NiXX or LiXX cells, recommended is 2 LiXX cells or 5-6 NiXX cells. Input voltage is indicat…
    39.00€
    SAVÖX SC-1256TG
    Beschreibung: Digitalservo der neuen Generation mit neu entwickeltem Glockenanker-Motor, Gehäuse teilweise aus Alu, Titanium-Getriebe, 2 x Kug…
    62.00€
       http://www.rcmodelshop.gr/index.php?main_page=index&cPath=73
    « Τελευταία τροποποίηση: Παρασκευή, 9 Μαρ 2012, 19:14:40 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #228 στις: Τετάρτη, 21 Μαρ 2012, 09:09:33 »
    MINTOR & SEBART
    GX40  KYOSHO
    69.00€
    Τιμή:62.10€
    CALMATO With GX40 Engine GOLDEN YELLOW
    KYOSHO 40 TRAINER CALMATO With GX40 Engine GOLDEN YELLOWLength 1,300mm Width 1,600mm Weight 2,400 - 2,500g (approx.) Wing Area 43d…
    165.00€
    Τιμή:148.50€
    KYOSHO 40 TRAINER CALMATO yellow
    KYOSHO 40 TRAINER CALM   An absolute and authentic trainer. Factory finished down to fine details. This plane is concentrated on learning to fly.…
    109.00€
    Τιμή:98.10€
    CALMATO EP 1400 The famous Calmato beginner-friendly performance now realized in electric power. Lightweight balsa structure is pre-covered in film fo…
    126.00€
    Τιμή:113.40€
    rcmodelshop.gr
    samosrc
    « Απάντηση #229 στις: Τετάρτη, 28 Μαρ 2012, 12:02:57 »
    MINTOR & SEBART
    [/color]
    Power Supply 13.8v 8.5A 115W (Euro)
    Power Supply 13.8v 8.5A 115W (EurThis brand new 13.8v, 8.5A Power Supply is suitable for use with almost all 12v input chargers available today. Despi…
    26.00€
    Τιμή:23.40€
    9.6V 2700mAh Tx Pk Ni-MH Flat
    33.00€
    Τιμή:29.70€
    Nine Eagles Sky 500 RTF
    Nine Eagles Sky 500 R The Sky 500 is the smallest of the Nine Eagles line of "Powered Glider" RTF Trainers. It's convenient size allows…
    65.00€
    Τιμή:58.50€
    Nine Eagles Sky Surfer RTF
    Nine Eagles Sky Surfer RTF With its compact size, the Nine Eagles Sky Surfer is the perfect park flyer. Supplied complete with r…
    93.00€
    Τιμή:83.70€
    FAIRWIND III FRP Hull, Readyset
    FAIRWIND III FRP Hull, ReadysetEnjoy reading wind shifts and trimming the sails with real yacht-like control. Sail this world renowned yacht enhanced …
    439.00€
    Τιμή:395.10€
    rcmodelshop.gr
    samosrc
    « Απάντηση #230 στις: Τρίτη, 10 Απρ 2012, 11:16:24 »
    MINTOR & SEBART
    4mm Gold connectors. Package contains 10 PAIRS of connectors.
    5.00€
    Τιμή:4.50€
    HXT UBEC 5/6v output, 5.5~23v Input
    HXT UBEC 5/6v output, 5.5~23v InputhexTronik UBEC. Will supply a solid 5v or 6v to your reciever with a  2 to 5S Lipoly pack. Specifications; Output: …
    11.00€
    Τιμή:9.90€
    HXT900 9g / 1.6kg / .12sec Micro Servo
    HXT900 9g / 1.6kg / .12sec Micro Servo HXT900, one of the most famous and the best value micro servos available. Used by tens of thousands of hobbyies…
    4.00€
    Τιμή:3.60€
    Mr JIG - Soldering Aid
    Mr JIG - Soldering Aid Mr JIG - Soldering Aid (and all round nice guy) This handy little gizmo makes soldering plugs a breeze! The clamp features …
    13.00€
    Τιμή:11.70€
    TURNIGY 8-15A UBEC for Lipoly
    TURNIGY 8-15A UBEC for Lipoly Power your receiver and servos with the baddest of UBEC power solutions. The all new Turnigy 15  is an advanced switch…
    21.00€
    Τιμή:18.90€
    XT60 Connectors Male/Female (5 pairs)
    XT60 Connectors Male/Female (5 pairs) Excellent W.S. Deans T-connector replacements. Made from high-temp Nylon and gold plated spring connectors, both…
    6.00€
    Τιμή:5.40€
    TURNIGY Plush 40amp Speed Controller
    TURNIGY Plush 40amp Speed Controller Plush 40A Brushless Speed Controller The Plush series ESC are a very good quality controller. They have a broad…
    26.00€
    Τιμή:23.40€
    FLOATS KIT FOR EASY CAB
    39.00€
    Τιμή:35.10€
    floats kit white e.g.for MiniM
    floats kit white e.g.for MiniM MUL 733069 Γράψτε πρώτος μια αξιολόγηση για αυτό το προϊόν Γρήγορη Επισκόπηση Πλωτήρες απο Elapor κατάλληλοι για το M…
    39.00€
    Τιμή:35.10€
    JU 87B-2 STUKAS
    JU 87B-2 STUKAS Περιγραφή Προϊόντος  Specification  Wing  Span(mm / in.)34”(863.6mm) Length(mm / in.)28.43”(722mm) Wing Area(sq. dm² / …
    64.00€
    Τιμή:57.60€
    SUKHOI 3D PROFILE BRUSHLESS MOTOR
    SUKHOI 3D PROFILE BRUSHLESS MOTOR SUKHOI 3D PROFILE BRUSHLESS MOTOR TT 4347K21 Γρήγορη Επισκόπηση Ένα οικονομικό 3D αεροπλάνο που συνδυάζει τόσο …
    76.00€
    Τιμή:68.40€
    Compass Cutter w/6 x Spare Blades
    The Compass Cutter allows you to cut circles in soft materials from 1~15mm diameter.
    5.00€
    Τιμή:4.50€
    Multi Function Charge lead
    Ever wanted to charge a battery and found that you do not have the right lead or have lost it? Well, here’s the answer! This single lead has mos…
    8.00€
    Τιμή:7.20€
    Power Supply 240>13.8v20A AutoEur
    The ProPeak 13.8v power supply is a high quality switch mode power supply with a particularly smooth output current, making it su…
    48.00€
    Τιμή:43.20€
    SkyRC IMAX Quattro B6 Charger
    Fed up of being unable to charge more than one or two batteries? What about being unable to charge totally different capacities and chemistries …
    149.00€
    Τιμή:134.10€
    Inferno Ve race spec + spektrum DX3S
      Advanced chassis design is equipped with a newly developed 2.4GHz R/C system to produce the strongest electric buggy Readyset around! World …
    466.00€
    Τιμή:419.40€
    rcmodelshop.gr
    samosrc
    « Απάντηση #231 στις: Δευτέρα, 21 Μαΐ 2012, 09:15:06 »
    MINTOR & SEBART
    Beaver idro arf
    TT 4593k20 Beaver idro arf Product code: TT 4593k20 Email to a Friend Be the first to review this product Quick Overview To Beaver idro είναι…
    Τιμή:200.70€
    OrangeRx R610 Spektrum DSM2 6Ch 2.4Ghz Receiver (w/ Sat Port)
    OrangeRx R610 Spektrum DSM2 6Ch 2. Compatible with all Spektrum DSM2 Air transmitters. OrangeRx receivers are built using original components and…
    11.00€
    Linkage Stopper M3x2xL11.2mm (10pcs/set)
    Linkage Stopper M3x2     Linkage Stopper M3x2xL11.2mm (10pcs/set) Unit has a grub screw on the top. xL11.2mm (10pcs/set)
    Τιμή:2.70€
    rcmodelshop.gr
    samosrc
    « Απάντηση #232 στις: Πέμπτη, 24 Μαΐ 2012, 09:19:16 »
    MINTOR & SEBART
    Motor - Venus
    Motor - Venus High torque AT2206 1500kv, brushless outrunner motor designed especially for the Tech-One Venus 3D but would suit other…
    Τιμή:24.30€
    blades 11x 8
    Τιμή:7.20€
    Ball link
    Τιμή:4.50€
    Coupling bush
    Τιμή:0.90€
    Plastic tailskid
    Τιμή:4.50€
    Control horn
    Τιμή:2.70€
    http://www.rcmodelshop.gr/index.php?main_page=products_new
    rcmodelshop.gr
    samosrc
    « Απάντηση #233 στις: Παρασκευή, 25 Μαΐ 2012, 12:56:00 »
    MINTOR & SEBART
    SERVO S3003 BULK 3,2 kg
    4.8V or 6.0VDimension 40.4 mm x 19.8 mm x 36.0 mm Weight 37.2 g Operating Speed 0.23 sec/60° (4.8V) 0.19 sec/60° (6.0V) Output torque 3.2 kg-cm (4.8V)…
    Τιμή:11.70€
    SERVO S3010 6,5Kg/0.16sec/6v
    SERVO S3010 6,5Kg/0.16sec/6v S3010Analog servo NiCd only 6.0V only Dimension 40.0 mm x 20.0 mm x 38.1 mm Weight 41 g Operating Speed 0.16 sec/60° Outp…
    Τιμή:27.00€
    3ch Combo 2.4G FHSS (Dry) R203GF
    Utilising Futaba’s new FHSS 2.4Gz transmission system, this new 3 channel steerwheel system incorporates an internal transmitter aeri…
    75.00€
    6ch Combo 2.4GHz FHSS (D)M2 R2006GS
    6ch Combo 2.4GHz FHSS (D)M2 R2006GS This brand new 6 channel system from Futaba is probably one of the most significant new radios for some time…
    149.00€
    SERVO S3001 BULK 3,0 kg
    4.8V or 6.0V Dimension 40.4 mm x 19.8 mm x 36.0 mm Weight 45.1 g Operating Speed 0.22 sec/60° Output torque 3.0 kg-cm
    Τιμή:13.50€
    SET 2ER-R122JE-S3003/2-AM27 This is the 2ER, 2-Channel, Digital Proportional AM 2-stick Radio. Available on 27 Ideal for entry-level cars, boats and a…
    54.00€
    WOT 4 Foam-E Mk2 ARTF A-CF020     This is not just any foam model! It’s a very clever WOT 4 tha…
    Τιμή:139.50€
    BRAND: GRAUPNER MANUFACTURER ITEM NUMBER: 2322 ARTICLE DESCRIP
    BRAND: GRAUPNER MANUFACTURER ITEM NUMBER: 2322 ARTICLE DESCRIPTION: Suitable for controlling hydro racing boats and catamarans. The vertically mo…
    Τιμή:12.60€
    Cooling coil SPEED 700 GRAUPNER
    Τιμή:8.10€
    rcmodelshop.gr
    samosrc
    « Απάντηση #234 στις: Παρασκευή, 25 Μαΐ 2012, 20:31:00 »
    MINTOR & SEBART
    Τιμή:11.70€
    Τιμή:27.00€
    75.00€
    149.00€
    Τιμή:13.50€
    54.00€
    Τιμή:139.50€
    Τιμή:12.60€
    Τιμή:8.10€
    rcmodelshop.gr
    samosrc
    « Απάντηση #235 στις: Σάββατο, 9 Ιουν 2012, 10:24:11 »
    MINTOR & SEBART
    6.0v 2000mAh Eneloop Rx Pk Flat Superb charge retention - 90% after 6 months, and 85% even after a year, so no…
    26.00€
    Τιμή:23.40€
    Aluminium Cas High quality aluminium case that’s just perfect for protecting and safely transporting your transmitter and support…
    25.00€
    Τιμή:22.50€
    27.00€
    Τιμή:24.30€
    Tech-One Venus EP A A highly advanced 'profile' style 3D model that is far, far more than just the usual foam sheet. The whole model is mou…
    [ur=http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1800l][/url]
    62.00€
    Τιμή:55.80€
    Tech-One Venus EP ARTF (Yellow)   A highly advanced 'profile' style 3D model that is far, far more than just the usual foam sheet. The whole model is …
    Τιμή:55.80€
    rcmodelshop.gr
    samosrc
    « Απάντηση #236 στις: Σάββατο, 16 Ιουν 2012, 13:23:49 »
    MINTOR & SEBART
    SCHALT-NETZGERÄT 20A LCD "LINDINGER"BRAND : PSU20A Σελίδα καταλόγου : 465 ΠΕΡΙΓΡΑΦΗ ΤΟΥ ΠΡΟΪΟΝ…
    59.00€
    Τιμή:53.10€
    SEAKING 60A BEC BRUSHLESS REGLERBRAND : HOBBYWING ΚΑΤΑΣΚΕΥΑΣΤΗΣ Αριθμός αντικειμένου : 87010020 Σελίδα καταλόγου : 291 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : Η σειρά Seak…
    54.00€
    Τιμή:48.60€
    SEAKING 80A HV BRUSHLESS REGLERBRAND : HOBBYWING     ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : Η σειρά Seaking ελέγχου έχει σχεδιαστεί για χρήση σε σκάφη . Όλοι …
    88.00€
    Τιμή:79.20€
    POWER CONTROBRAND : MBL Κωδικός Κατασκευαστή ΠΡΟΪΟΝΤΟΣ : ΟΚΕ -50 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : Χαμηλού κόστους σειρά με ρυθμιστή BEC , υπό τάση χαρακτηριστικό κλ…
    24.00€
    Τιμή:21.60€
    APC 13/9
    11.00€
    Τιμή:9.90€
    ALULA EPO SAL MODELL DREAM-FLIGHTBRAND : ΠΤΗΣΗ DREAM ΚΑΤΑΣΚΕΥΑΣΤΗΣ Αριθμός αντικειμένου : ALULA ECO ΚΙΤ Σελίδα καταλόγου : 009 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : X- D…
    78.00€
    Τιμή:70.20€
    ECO BL V2 50A -4S REGBRAND : PLANET - HOBBY ΚΑΤΑΣΚΕΥΑΣΤΗΣ Αριθμός αντικειμένου : SE50A Σελίδα καταλόγου : 408 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : Ανέξοδη Σειρά ελεγκτή…
    35.00€
    Τιμή:31.50€
    ECO BL V2 35BRAND : PLANET - HOBBY ΚΑΤΑΣΚΕΥΑΣΤΗΣ Αριθμός αντικειμένου : SE35A Σελίδα καταλόγου : 408 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : Ανέξοδη Σειρά ελεγκτή για τους…
    25.00€
    Τιμή:22.50€
    DUALSKY XC2512BA 25A 2-4S BL REGLER V2 ΚΑΤΑΣΚΕΥΑΣΤΗΣ Αριθμός αντικειμένου : 45 083 Σελίδα καταλόγου : 408 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : DUALSKY " XControlle…
    26.00€
    Τιμή:23.40€
    DUALSKY XC4018BA 40A 2-6S BL REGLER V2 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : DUALSKY " XController " είναι ελεγκτές ταχύτητα για 2 -12- πόλο κινητήρες χωρίς ψή…
    42.00€
    Τιμή:37.80€
    DUALSKY XC8018BA 80A 2-6S BL REGLER V2 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : DUALSKY " XController " είναι ελεγκτές ταχύτητα για 2 -12- πόλο κινητήρες χωρίς ψή…
    85.00€
    Τιμή:76.50€
    PROGCARD DUALSKY BL REGLER
    10.00€
    Τιμή:9.00€
    PROFESSIONAL 40-3P BEC AIR BRUSHLESS RE ΚΑΤΑΣΚΕΥΑΣΤΗΣ Αριθμός αντικειμένου : 40 Α- AIR Σελίδα καταλόγου : 411 ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : Ειδικά για τα μηχανοκ…
    39.00€
    Τιμή:35.10€
    BLUE ARROW REGLER BEC 30A 3XLIPO ΚΑΤΑΣΚΕΥΑΣΤΗΣ Αριθμός : PP - 30C   ΓΕΝΙΚΗ ΠΕΡΙΓΡΑΦΗ : Πολύ καλή τιμή για την κανονική σειρά κινητήρες ελέγχου…
    20.00€
    Τιμή:18.00€
    ΑΝΑΠΤΗΡΑ SEAL ADAPTER   ΑΝΑΠΤΗΡΑ SEAL ADAPTER   Κωδικός Κατασκευαστή ΠΡΟΪΟΝΤΟΣ : 8225   ΠΕΡΙΓΡΑΦΗ ΤΟΥ ΠΡΟΪΟΝΤΟΣ : Πρακτικές προσαρμ…
    7.00€
    Τιμή:6.30€
    SPEED EPOXY 4 MINUTE 71G DELUXE"DELUXE Materials" ist führender Hersteller von Standard- und Spezialklebstoffen seit über 30 Jahre…
    9.00€
    Τιμή:8.10€
    rcmodelshop.gr
    samosrc
    « Απάντηση #237 στις: Δευτέρα, 9 Ιουλ 2012, 11:07:00 »
    MINTOR & SEBART
    SOUTHHAMPTON RC-BOOT EP 1/36 RTR BRAND: HOBBYENGINE MANUFACTURER ITEM NUMBER: 0901 CATALOGUE PAGE: 285 DESCRIPTION: Schlepper sind die Arbeitstiere un…
    168.00€
    MAX-46LA (SILVER) W/E-3030
    MAX-46LA(Silver)  For medium sized sport and trainer models Displacement 7.64cc(0.467cu.in)Output 1.2ps/15,000r.p.m. Bore 23.0mm(0.906in.)P…
    Τιμή:89.10€
    SAVÖX SC-1258TG
    Item no.:  80101001   Beschreibung: Digitalservo der neuen Generation mit neu entwickeltem Glockenanker-Motor, Gehä…
    57.00€
    DUALSKY XPOWER ES LIPO 2200MAH/11, 1V 20C Order: 80 605   <!-- document.write('<a href="http://shop.lindinger.at/i…
    Τιμή:21.60€
    50SX-H Ringed Hyper For over-the-top flying excitement, the 50SX-H Ringed Hyper engine is the clear favorite! The Hyper version weighs less than the …
    Τιμή:130.50€
    EP FAZER r/s Porsche 911
    Width: 200mm Length: 383mm Height: 120mm Wheelbase (min): 260mm Track Width: 176mm Final Drive: 5.98:1 Pre-assembled chasssis Completed pre-painted bo…
    Τιμή:168.30€
    36 Size Adjustable Motor Mount with Water Cooling
    36 Size Adjustable Motor   36 Size Adjustable Motor Mount with Water Cooling Mount with Water Cooling
    11.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #238 στις: Πέμπτη, 26 Ιουλ 2012, 10:50:14 »
    MINTOR & SEBART
    MINTOR 38cc New
      MINTOR 38cc Peso: Motore: 990 grammi Centralina: 105 grammi Scarico barilotto: 58 grammi Dimensioni: vedi schema sotto - clicca per ingrandir…
    316.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #239 στις: Σάββατο, 28 Ιουλ 2012, 09:49:57 »
    MINTOR & SEBART
    RAPTOR 50 TITAN V2 HELICOPTER Δεμενο  καινουργιο
     RAPTOR 50 TITAN V2 HELICOPTER TT 4853-K Γράψτε πρώτος μια αξιολόγηση για αυτό το προϊόν  With all the features, the Raptor 50 Titan h…
    Τιμή:171.00€
    rcmodelshop.gr
    Σελίδες: 1 ... 13 14 15 [16] 17 18 19 20     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: Samos Model center
    Δημιουργία σελίδας σε 0.095 δευτερόλεπτα. 25 ερωτήματα.
