ÊõñéáêÞ, 1 Íïå 2026, 04:41:02
    �ñüóöáôá è�ìáôá
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:11:29]
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:07:37]
    áðü Markhelis
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310037
    Óýíïëï èåìÜôùí: 12401
    Online óÞìåñá: 52
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 0
    ÅðéóêÝðôåò: 43
    ÓõíïëéêÜ: 43
    Óôõë åìöÜíéóçò
    Óåëßäåò: [1]     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: Óõíäåóç çëåêôñïëïãéêùí  (Áíáãíþóôçêå 1292 öïñÝò)
    akissofronas
    Ìçíýìáôá: 46
    « óôéò: ÐÝìðôç, 11 Éáí 2024, 15:09:43 »
    êáëçóðåñá óáò. ðñïóöáôá óå ìéá áëëáãç åëéêáò åêáëá ëáèïò íïõìåñï êáé ôï ìïíôåëï ðçñå öùôéá óôïí áåñá. êáçêå ìïôåñ speedcontrol êáé åé÷á ðôùóç ãéáôé å÷áóá ôá ðçäáëéá.
    ç åñùôçóç ìïõ åéíáé ç åîçò .
     Ã°Ã¹Ã² ìðïñù íá óõíäåóù îå÷ùñéóôá ôïí ðïìðï ùóèå óå ðáñïìïéá ðåñéðôùóç íá ìðïñåóù íá êáôåâù ôï ìïíôåëï?
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 697
    ... �ÅÔ�Ù ÃÉ�ÔÉÉÉ,...Â�ÑÅÈÇÊ� ÅÄÙ Ê�ÔÙ...!!!
    « ÁðÜíôçóç #1 óôéò: ÐÝìðôç, 11 Éáí 2024, 15:29:30 »
      ÃƒÃ¥Ã©Ã¡ óïõ ÓôÃ�öáíå...
    ..., îå÷ùñéóôÞ ìðáôáñéá ãéá ôïí äÃ�êôç-ðçäÜëéá... ççç ñßîå ìéá ìáôéÜ  Ã³Ã´Ã¯Ã­ ðéï êÜôù óýíäåóìï..., ôï êüêêéíï (+) îåóýíäåóå áðï ôï ESC...
    1. The LiPo is connected directly to the power leads on the ESC.
    2. The 3-wire lead from the ESC to the receiver has it's red wire (the +5v supply) disabled by pulling its pin out of the plug -- use the point of a hobby knife blade to pry up the little plastic tang that holds it in place, then pull the wire out and tie it back on itself with insulating tape so it can't touch anything.
    3. The LiFe battery (2-cell probably) can then be connected directly or, better still, via an on/off switch, to any free channel in your receiver. If it's not specifically designed as an Rx pack you may need to crimp on a standard servo plug, taking care to ensure that the +ve wire (red) goes to the middle pin of the plug.
     https://forums.modelflying.co.uk/index.php?/topic/43229-using-separate-battery-for-servos-and-motor-and-how-to-connect-them-to-rx/
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 7.730
    �ñïó�÷ïõìå ãéá íá �÷ïõìå!!!
    « ÁðÜíôçóç #2 óôéò: ÐÝìðôç, 11 Éáí 2024, 20:06:12 »
    Ç äåýôåñç ëýóç åßíáé íá �÷åéò ôçí ßäéá ìðáôáñßá êáé íá âÜëåéò UBec åîùôåñéêü,
    âãÜæïíôáò üðùò êáé óôçí ðñþôç ëýóç ôï + áðü ôï Esk!!!
    ÊáôáãñÜöçêå
    akissofronas
    Ìçíýìáôá: 46
    « ÁðÜíôçóç #3 óôéò: ÐÝìðôç, 11 Éáí 2024, 21:42:48 »
    Óáò åõ÷áñéóôù èá ôï ìåëåôçóù.
    Ôùñá ôï öôéáîá êáé êïëëçóå ç íôéæá áðï åíá óåñâï.
    Ìïõ öáéíåôáé èá ôï âáëù öùôéá ìïíïò ìïõ êáôù óôï õðïãåéï ïðùò åéíáé! Grin
    ÊáôáãñÜöçêå
    Óåëßäåò: [1]     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Ã�åñïðëÜíá R/C - ÇëåêôñéêÜ  |  ÊéíçôÞñåò - ÑõèìéóôÃ�ò - Ìðáôáñßåò  |  ÈÝìá: Óõíäåóç çëåêôñïëïãéêùí
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.043 äåõôåñüëåðôá. 24 åñùôÞìáôá.
