Δευτέρα, 12 Οκτ 2026, 19:42:25
    [Σήμερα στις 13:52]
    Online σήμερα: 45
    Επισκέπτες: 34
    Συνολικά: 36
    Σελίδες: 1 ... 18 19 20 [21] 22 23 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 206954 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #300 στις: Πέμπτη, 23 Ιουν 2022, 18:38:28 »
    « Απάντηση #301 στις: Παρασκευή, 22 Ιουλ 2022, 19:06:06 »
    « Απάντηση #302 στις: Τετάρτη, 3 Αυγ 2022, 13:16:59 »
    Νέες Παραλαβές σε αεροπλάνα και αξεσουάρ 2 Αυγούστου 2022 από www.Diamond-Models.gr
    Freewing Hawker Sea Fury wingspan:1200mm PNP
    Technical specifification:
    Wing span: 120 cm
    Length: 108 cm
    Weight: 1550 without battery g
    Assembly level: Engine installed, Servos installed, Semi assembled structure covered or painted
    Radiocontrol: 6-8CH (not included)
    60A ESC with XT60 connector (included)
    Electric Motorization
    Motor: 3748-580Kv Brushless Outrunner (included)
    Servos: (included)
    Material: EPO
    Comes with: Servos, Electric motor, Variator, Retract gears
    Battery: 4S 14.8V 2200-4200mAh LiPo with XT60 connector (not included)
    Battery charger: (not included)
    Manual :manual in English (included)
    FREEWING MIRAGE 2000C V" TIGER MEET 80MM EDF-PnP
    Features:
    12 Blade factory balanced EDF with metal housing combined with 3530-1750KV brushless outrunner motor produces realistic jet turbine sound and an incredible 6 lbs of thrust
    Composite fan blades combined with metal EDF housing make the Mirage 2000 AMA compliant (the fan blades themselves are NOT metal, so there are no flying restrictions)
    Super scale details include hand painted, scale-sized pilots, full instrument panel, refueling probe, scale drop tanks, airfoil panel lines, and complete French Air Force graphics package
    80 Amp Hobbywing ESC with 5A BEC
    Electronic retractable landing gear with all metal shock-absorbing struts
    Steerable, shock absorbing nose gear for enhanced ground maneuverability
    Spring operated nose gear door
    Carbon spars and EPO foam construction provide the perfect balance between strength and flexibility
    Nylon hinges on all control surfaces (superior to foam hinges)
    Outrunner motor, servos, ESC and EDF come pre-installed for your convenience
    Removable magnetic nose cone, and removable wings and vertical stabilizer for convenient transport
    Includes:
    Freewing 80mm 12-Blade Metal EDF Mirage 2000C-5 - PNP
    « Απάντηση #303 στις: Τετάρτη, 3 Αυγ 2022, 13:45:04 »
    « Απάντηση #304 στις: Τετάρτη, 3 Αυγ 2022, 18:45:06 »
    E-flite Commander mPd 1.4m VERSION 2 PNP
    More Information
    Wingspan 140 cm
    Length 114 cm
    Weight 1770 without battery g
    Assembly level Engine installed, Servos installed, Ready to fly, Semi assembled structure covered or painted
    Radiocontrol 5+ CH (not included)
    Spektrum Avian 45A ESC with IC3 / EC3 connector (included)
    Motor Brushless outrunner 3720-850Kv 14 poles (included)
    Servos 6 submicro MG (included)
    Material EPO
    Comes with Servos, Electric motor, Variator
    Battery 3S / 4S 2200–3200mAh LiPo with EC3 / IC3 connector (not included)
    Needed to Complete
    • 5 + ch radio control plus receiver
    • Battery 3 • 4S 2200/3200 mah with EC3 / IC3 connector
    • Battery charger
    What's in the box?
    • Foam fuselage, wings and tail surfaces, painted as in the photo
    • Brushless outrunner 3720 850Kv 14 poles motor
    • Spektrum AVIAN 45A brushless controller with EC5 / IC5 connector
    • 6 MG submicro servos
    • Propeller
    • Cockpit and pilot
    • Manual
    « Απάντηση #305 στις: Τρίτη, 9 Αυγ 2022, 19:08:51 »
    Phoenix Models Tucano MKII.91/15cc Wingspan:1730mm with Electric retract set
    Phoenix Model TUCANO is a beautiful semi-reproduction of the famous Brazilian training aircraft. Acrobatic 90% ready to fly
    Structure completely in wood, ribs and trim, with wide use of balsa and first quality plywood.
    The covering is entirely in ORACOVER.
    Wide range of accessories. The manual is step by step photographic.
    Specifications:
    - Designed for both electric and petrol engines.
    - Covered in ORACOVER®
    - Plastic missiles included
    - Wing in two parts to facilitate transport
    - Removable hood for easy access to the radio system
    - Light but robust construction
    - Made of balsa and high quality plywood
    - All quality accessories included
    - mechanical reach trucks
    Specifications:
    Wingspan 173 cm
    Length 145 cm
    Wing Area 46.6 dm²
    Weight 4200-4800 g
    Assembly level Semi-assembled structure covered or painted
    2200 W electric motor
    Electric Motor, Burst
    6 CH radio remote control (not included)
    Variator (ESC) (not included)
    Standard 8 servos (not included)
    2200W Electric Motor - Burst .60-.91 (not included)
    Wood Material
    Electric Retractable system (included)
    Battery (not included)
    Charger (not included)
    English Instructions
    « Απάντηση #306 στις: Παρασκευή, 16 Σεπ 2022, 18:44:48 »
    « Απάντηση #307 στις: Πέμπτη, 22 Σεπ 2022, 11:11:08 »
    « Απάντηση #308 στις: Τετάρτη, 2 Νοε 2022, 20:03:19 »
    Νέα Παραλαβή Νοεμβρίου από www.Diamond-Models.gr 2/11/2022
    AFX180 Single-Rotor Helicopter 4-channel 6G RTF 2,4Ghz
    Technical specifications:
    Body length: 330mm
    Hull width: 65mm
    Body height: 100mm
    Rotor diameter: 320mm
    Main material: plastic
    Weight ready to fly: 131g
    Remote control: 2.4GHz handheld transmitter
    Flybarless System: 3D/6G Gyro
    Motor: 8520 hollow cup
    Servos: 2x Micro Digital 4.3g
    Battery: LiPo 2S 7.4V 700mAh, 20C, BEC connector, 55x21x15mm, 34g
    Balancers: XH
    Flight time: 12-15min
    Charger: USB charging cable
    Charging time: 70-90min
    Mini Piper Cub with 3D / 6G gyro wingspan:650mm RTF -2,4Ghz
    Features:
    Highly efficient brushless motor
    3D / 6G Gyro System
    Robust, very light EP material
    Two requirement levels (beginner 6G / advanced 3D)
    Length: 460mm
    Span: 650mm
    Take-off weight: 170g
    Battery: LiIon 2S 7.4V 500mAh BEC connector, 60 x 17 x 14mm, weight: 29g
    Flight time: approx. 6 minutes
    Charging time: approx. 60 minutes
    Range: approx. 200 meters
    Scope of delivery:
    Prefabricated airplane model
    2.4GHz transmitter
    Battery 7.4V LiPo 500mAh BEC
    USB charging cable 500mAh output power
    Replacement propeller
    Operating instructions D / Eng
    Required accessories:
    4x 1.5V Mignon battery
    AMX Racing HV7246MG Digital Servo Standard size, 47,8KG, 0,10sec/60° ALU case
    Description:
    This revolutionary competition standard HV servo from the AMX racing servo series is extremely reliable, powerful and very durable.
    The robust steel gear, the milled aluminum housing and the low price speak for themselves.
    Technical Specifications:
    Working frequency: 1520 / 330hz
    Speed (6.0V): 0.12sec/60°
    Speed (8.4V): 0.10sec/60°
    Forcε (6.0V): 38.6kg/cm
    Actuating force (8.4V): 47.8kg/cm
    Dimensions: 40.5 x 20.3 x 36mm
    Weight: 72g
    Connection cable length: 265mm
    Ball bearing: 2BB
    Gear: metal
    Housing: full aluminum
    SCOPE OF DELIVERY:
    servo
    servo arms
    fastening material
    « Απάντηση #309 στις: Τετάρτη, 9 Νοε 2022, 19:33:55 »
    Νέες Παραλαβές σε mini Αεροπλάνα από www.diamond-Models.gr
    Volantex RC Spitfire with Xpilot One Key Aerobatic Stabilization System RTF
    KEY FEATURES
    Built-in gyroscope
    3-level flight control assistant
    Easily perform acrobatics with the "One Key" function
    Propeller securing system
    Model in 4-channel version
    Volantex RC Sport Cub 500 4CH Aircraft Glider with Built In Gyro RTF
    INTEGRATED GYRO EASY TO CONTROL: 6-axis gyro ultra stable self stabilization of gyro system. Powerful over-grade motor system and 4 channel allow easy controlling to do aerobatic flying.
    BEGINNERS' FIRST RC AIRPLANE TRAINER: 3-level flight control assists (Beginner level with full assist/ Intermediate with partial assist/ Expert for manual control) help beginners learn to fly step by step.
    GREAT AIRPLANE FOR OUTDOOR ADVENTURE: 2.4Ghz Radio Control distance of over 1312 ft, the strong anti jamming capability allows to hold a small flight club party between you and your friends.
    ONE-KEY AEROBATIC: This function includes “flip” and “roll”, means that the airplane can do aerobatic automatically in two direction if you control it in beginner mode, just need to click the aerobatic button and then turn the right stick up to max position or down to min position. Everyone could enjoy the aerobatic flight even if he/she is a new pilots.
    FULLY ASSEMBLY READY TO FLY: Fully assembly to get the plane take off within 1 minutes out of box. Portable package to go with you everywhere.
    « Απάντηση #310 στις: Κυριακή, 18 Δεκ 2022, 15:10:32 »
    « Απάντηση #311 στις: Πέμπτη, 12 Ιαν 2023, 17:45:37 »
    « Απάντηση #312 στις: Δευτέρα, 23 Ιαν 2023, 17:52:21 »
    « Απάντηση #313 στις: Πέμπτη, 9 Φεβ 2023, 17:36:00 »
    « Απάντηση #314 στις: Παρασκευή, 3 Μαρ 2023, 19:54:37 »
    Σελίδες: 1 ... 18 19 20 [21] 22 23 24     Πάνω
    Δημιουργία σελίδας σε 0.065 δευτερόλεπτα. 25 ερωτήματα.
