Πέμπτη, 15 Οκτ 2026, 19:16:06
    [Σήμερα στις 13:50]
    Επισκέπτες: 40
    Συνολικά: 43
    Σελίδες: 1 ... 17 18 19 [20] 21 22 23 24     Κάτω
    Αποστολέας Θέμα: www.Diamond-Models.gr  (Αναγνώστηκε 207335 φορές)
    Diamond-Models Ι. Γεωγιάδης
    « Απάντηση #285 στις: Τετάρτη, 29 Δεκ 2021, 18:37:49 »
    Graupner SJ MZ-16 HoTT 16ch Only Transmitter
    Software:
    32 proportional channels
    999 Model memory
    2 Receiver binding 10ms or 20ms frame rate
    Model, group or global binding modes
    Model types: Airplane, Helicopter, Multirotor, Vehicle, Boat
    8 selectable flight modes
    8 wing types, 6 delta wing types, 3 tail types
    Multi engine control (4)
    6 user designable widgets dashboards (model specific or global)
    Context sensitive help text
    Text to speech with VDF editor
    Servo balancer & synchronization
    6 phase dependent assignable trim settings and 5 trim types
    4 phase dependent configurable timers (Start/Stop, Lap, Lap Trigger, Lap Toggle)
    4 phase dependent quad rate and expo settings
    12 phase dependent multi point user mixers
    4 dual differential mixers
    3 channel sequencers
    3 channel ring limiters
    16 user assignable digital switches
    6 assignable combination switches
    8 assignable logical switches
    8 assignable control switches
    4 snap roll mixes
    4 direct adjust
    8 wing and tail mixers and crow/butterfly function
    9 user assignable and configurable system voice notifications
    12 user assignable and configurable user voice notifications
    10 user assignable and configurable control voice notifications
    8 user assignable and configurable voice notifications
    8 sensor activated switches
    4 direct adjust for value/curve point adustment by a control
    Dedicated vario and control menu with dead zone control
    Wireless setup of receivers, telemetry and flight controllers
    Integrated file manager
    « Απάντηση #286 στις: Παρασκευή, 21 Ιαν 2022, 10:49:37 »
    Νέες Παραλαβές Ιανουαρίου 2022 απο www.Diamond-Models.gr
    PHOENIX MODEL P51 MUSTANG GP/EP Size 15-20CC SCALE 1:7 ¼ ARF with electric retracts
    Technical data:
    - Wingspan: 1572mm (61.9in)
    - Length: 1356mm (53.4 in)
    - Flying weight: 4500- 4600g
    - Wing area: 47dm2
    - Wing loading: 91g/dm2
    - Wing type: Naca airfoils
    - Gear type: Electric Retract Gear (included) with controller box (included).
    - Spinner size: P51 Mustang type 80mm (included)
    - Radio: 6 channel minimum (not included)
    - Servo: 7 standard servo: 2 aileron; 2 flap; 1 elevator; 1 rudder; 1 throttle (not included)
    - Recommended receiver battery: 6.0V 2000mAh NiMH (not included)
    - Servo mount: 21mm x 42 mm
    - Propeller: suit with your engine
    - Engine: .91/ 2-stroke glow or 15-20CC gas engine (not included)
    - Motor: brushless outrunner 1800-2000 W, 500 KV (not included)
    - Experience level: Intermediate
    - Plane type: Scale Military
    RECOMMENDED MOTOR AND BATTERY SET UP
    - Motor: Quantum II 55 (not included)
    - Propeller: 15x6- 15x8 E (not included)
    - Lipo cell: 6 cells / 5000 – 6000mAh (not included)
    - Esc: Quantum 80A SBEC (not included)
    Feature
    - Designed for compatibility with both GP and EP flight
    - Top quality balsa/light plywood construction
    - Electric Retract Gear With CNC Suspension Metal Struts included
    - Electric Controller Gear Box With Multi Function included
    - Full-depth cockpit and instrument panel and pilot included
    - Removable hatch for easy change lipo battery and set up radio
    - Strong Light Weight Construction
    - Superb flying characteristics, plus an accurate scale outline
    - High-quality hardware package included
    Colour chart
    - Blue (# 21050)
    - Black (# 21071)
    - Silver (# 21091)
    Packing
    BOX DIMENSION
    -1079mm X 425mm X 218mm (L x W x H)
    « Απάντηση #287 στις: Τρίτη, 8 Φεβ 2022, 19:31:35 »
    « Απάντηση #288 στις: Σάββατο, 12 Φεβ 2022, 11:50:56 »
    « Απάντηση #289 στις: Πέμπτη, 3 Μαρ 2022, 12:07:09 »
    Νέες Παραλαβές απο www.Diamond-Models.gr
    Black Horse Viper Jet Turbine wingspann: 2000 mm /8Kg Turbine
    The original is the Viper Jet is a sports aircraft designed and built by Viper Aircraft Corporation, which is supplied by the manufacturer in kits. It is a conventional low-wing aircraft with seats arranged one behind the other. The jet engine is housed in the fuselage and the nose wheel landing gear is retractable. The aircraft is made entirely of fiber composites. Our Viper Jet is a prototypical replica of the original and made of wood. The model is designed for kerosene turbines with 8kg thrust. It impresses with great flight performance and fantastic detailed solutions.
    Delivery including electric retractable landing gear including brakes worth € 500.
    Product features
    * ARF finished model in modern wood construction (laser cut)
    * Fully covered as shown
    * Sensationally developed cockpit as shown (standard)
    * Functional landing flaps
    * Electric retractable landing gear and scale landing gear legs included
    * Electronic landing gear brakes
    * Extensive accessories, richly illustrated instructions
    Technical specifications:
    Span = 2000mm
    Length = 1820mm
    Take-off weight = 9.8 - 10.5kg
    Area = 62.2dm²
    Wing loading = 157.5g / dm²
    R / C functions = rudder, elevator, ailerons, landing flaps, motor controller, retractable landing gear
    Channels = 8 channels / 8 servos
    Special accessories (recommended)
    Kerosene turbine with 8kg thrust
    MASTER Servo DS3615 x 8pcs
    « Απάντηση #290 στις: Τετάρτη, 9 Μαρ 2022, 19:17:19 »
    Νέες Παραλαβές Μαρτίου 2022 απο www.Diamond-Models.gr
    Sopwith Camel ARF Wingspan: 1200mm
    The Sopwith Camel is a biplane and is considered the most successful British fighter aircraft of the First World War.
    The man-carrying original was designed and built by the Sopwith Aviation Company.
    When converting the model, attention was paid to an appearance that was as true to the original as possible and to the best flight characteristics.
    Beautiful scale details perfectly round off the overall picture of this fantastic flight model.
    product features:
    * Completely covered as shown
    * Highest degree of prefabrication
    * Multi-part wings with stable connection
    * Semi Scale Landing Gear and Wheels
    * Painted hood
    * Great scale details
    * Accessory for R/C installation
    * Wheels, linkages, small parts, illustrated instructions
    Span = 1200mm
    Length = 830mm
    Weight = 1400g
    R/C functions = rudder, elevator, aileron, motor
    Channels = 4 channels / 4 servos[/color]
    « Απάντηση #291 στις: Τετάρτη, 9 Μαρ 2022, 19:23:18 »
    « Απάντηση #292 στις: Σάββατο, 2 Απρ 2022, 12:51:18 »
    « Απάντηση #293 στις: Σάββατο, 9 Απρ 2022, 11:54:45 »
    « Απάντηση #294 στις: Σάββατο, 23 Απρ 2022, 13:55:42 »
    « Απάντηση #295 στις: Σάββατο, 23 Απρ 2022, 13:59:45 »
    Θερμές Ευχές για Καλή Ανάσταση και Χαρούμενο Πάσχα.
    « Απάντηση #296 στις: Πέμπτη, 19 Μαΐ 2022, 11:32:58 »
    Διαθέσιμο από 31-5-2022 στο www.Diamond-Models.gr
    Albatros L-39 Jet Plane wingspan:1720 mm (Preorder)
    Product features
    Span = 1720mm
    Length = 2163mm
    Take-off weight = 9.6 - 10.5kg
    Area = 60.7dm²
    Wing loading = 158g / dm²
    for Kerosene turbine with 8kg thrust
    « Απάντηση #297 στις: Πέμπτη, 26 Μαΐ 2022, 15:16:23 »
    Νέες Παραλαβές 25 Μαίου 2022 από www.Diamond-Models.gr
    Arrows Husky 1800mm electric motor high-decker PUP ARTF
    Specifications
    Wingspan 1800mm (71in)
    Length 1200mm (47in)
    Flying Weight Around 2100g
    CG (Center of Gravity) 80-90mm from leading edge
    Power System 3541-kv750
    Electronic Speed Control 45A
    Propeller / EDF 13 x 7.5 2-blade
    Servos 17gram servo x 6
    Landing Gear Fixed
    Required Battery 14.8V 2200-2600mAh 35C
    Required Radio 6 Channel transmitter and receiver required
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Yes
    MODSTER Trip electric motor glider model wingspan: 1800 PNP
    Product information :
    Our MODSTER trip is not only suitable for beginners, but also convinces advanced sailors.
    High stability and excellent gliding characteristics characterize this modern electric glider. This is guaranteed by the V-shaped wing.
    The wings are divided and connected via a 9mm thick aluminum tube.
    The T-tail is also much more robust during landings and an integrated central landing wheel protects the fuselage during landings.
    Scope of delivery:
    • MODSTER Trip 1800mm PUP
    • incl. BL motor C2415-1150KV and 40A BL controller
    • incl. 4 pieces 9g servos
    • Instructions in German/English
    A 4-channel remote control with receiver, LiPo 3S 11.1V 2200mAh
    Sport Cub S2 high-wing RTF 500mm incl. 6-axis flight attitude stabilization
    Specifications:
    INTEGRATED GYRO EASY TO CONTROL: 6-axis gyro ultra stable self stabilization of gyro system. Powerful over-grade motor system and 4 channel allow easy controlling to do aerobatic flying.
    BEGINNERS' FIRST RC AIRPLANE TRAINER: 3-level flight control assists (Beginner level with full assist/ Intermediate with partial assist/ Expert for manual control) help beginners learn to fly step by step.
    GREAT AIRPLANE FOR OUTDOOR ADVENTURE: 2.4Ghz Radio Control distance of over 1312 ft, the strong anti jamming capability allows to hold a small flight club party between you and your friends.
    ONE-KEY AEROBATIC: This function includes “flip” and “roll”, means that the airplane can do aerobatic automatically in two direction if you control it in beginner mode, just need to click the aerobatic button and then turn the right stick up to max position or down to min position. Everyone could enjoy the aerobatic flight even if he/she is a new pilots.
    FULLY ASSEMBLY READY TO FLY: Fully assembly to get the plane take off within 1 minutes out of box. Portable package to go with you everywhere
    « Απάντηση #298 στις: Τετάρτη, 15 Ιουν 2022, 16:39:33 »
    Νέες Παραλαβές 15 Ιουνίου 2022 από www.Diamond-Models.gr
    TOP RC Hobby BLAZER 2 in 1 1200/1280mm - KIT - dual Wing included
    Wing Span:
    (1)Trainer version: 1280mm/50.40in;
    (2) Sports version: 1200mm/47.25in
    Length: 942mm/37.09in
    Weight: 1152g
    PIPER PA-18 Super Cub 1700mm PNP + Gyro FMS REFLEX V2 with Wheels and Floats
    The plane is in the PNP version, the set includes the landing gear model (wheels + floats), engine, regulator, servos and Gyro FMS REFLEX V2.
    You need to buy a battery, charger, transmitter and receiver on your own.
    Features:
    1. Powerful 3541- 750KV Outrunner motor with Predator 45A ESC provides adequate thrust for any situation.
    2. CNC metal landing gear structure for less-than-perfect landings.
    3. 6.25-inch oversized balloon tires for all-terrain operations.
    4. STOL capable (Takes off in less than 3m/10ft)
    5. Pre-installed navigation and landing lights
    6.Two-piece wing and horizontal stabilizer for easy transportation
    7. High-strength carbon fiber wing spars
    8.Integrated servo connectors
    9. Screw-together assembly
    10.Large battery bay
    11.Ball-linked pushrods for increased precision
    12.Tough two bladed Nylon propellers
    13. Functional flaps
    14. Floats and stainless-steel struts
    15.Gyro FMS REFLEX V2
    SkyRC BD250 Battery Discharger & Analyser For LiPo LiFe LiHV NiCd NiMH Pb Battery 250W / 35A
    Specifications
    Size and Weight
    Dimension: 136.6x104.8x107mm
    Weight: 879g
    Power
    Accepted Voltage Range: 5.40-35.00V
    Low Voltage Alert: <5.2V
    High Voltage Alert: >35V Max.
    Discharge Power: 250W
    Discharge
    Discharge Current Range: 0.01A-35.00A
    Display
    Current Consumption in Sleep Mode: <100uA
    Capacity Display Accuracy: ±3%
    Current Display Accuracy:
    0.01-10.00A ±60mA
    10.00-35.00A ±3%
    Voltage Display Accuracy:
    5.4-10V <80mV
    10-20V <120mV
    20-35V <160mV
    « Απάντηση #299 στις: Τετάρτη, 22 Ιουν 2022, 17:29:46 »
    Σελίδες: 1 ... 17 18 19 [20] 21 22 23 24     Πάνω
    Δημιουργία σελίδας σε 0.048 δευτερόλεπτα. 25 ερωτήματα.
