ÄåõôÝñá, 2 Íïå 2026, 02:12:22
    �ñüóöáôá è�ìáôá
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:11:29]
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:07:37]
    áðü Markhelis
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310037
    Óýíïëï èåìÜôùí: 12401
    Online óÞìåñá: 39
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 0
    ÅðéóêÝðôåò: 36
    ÓõíïëéêÜ: 36
    Óôõë åìöÜíéóçò
    Óåëßäåò: [1] 2 3  ¼ëïé     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: Ìðáôáñéá Lipo  (Áíáãíþóôçêå 13523 öïñÝò)
    Ìçíýìáôá: 4.887
    « óôéò: Ôñßôç, 27 Óåð 2005, 17:52:11 »
    Ãíùñéæåé êáðïéïò ðïõ ìðïñù íá âñù ìðáôáñéá lipo ôçò ALIGN åêôïò áðï ôï êáôáóôçìá Êïõôóïò ôï ïðïéï äåí å÷åé áõôï ôïí êáéñï.
    Äåí èåëù íá êáíù äéáöçìéóç áðëá ç óõãêåêñéìåíç ìðáôáñéá (1800mah 11.1v 12c) ìå âïëåõåé ëïãï ó÷çìáôïò 95×30×22. Ã�í ãíùñéæåôáé  êáðïéá áëëç áîéïðéóôç ìáñêá óå áõôåò ôéò äéáóôáóåéò (åêôïò no name) èá  çèåëá íá ìáèù êáé ðïõ ìðïñù íá ôçí âñù
    ÊáôáãñÜöçêå
    ...êáôé ðô�ñõãåò êáé ðïëý óáâïýñá
    ÄÇÌÇÔÑÇÓ
    ÅðéóêÝðôç
    « ÁðÜíôçóç #1 óôéò: ÔåôÜñôç, 28 Óåð 2005, 14:22:16 »
    Ilia ï Êùóôáò ï �áðáäïðïõëïò(HMS) ìïëéò ðáñåëáâå êáéíïõñéåò 15C ðïõ åéíáé óå êïíôéíåò äéáóôáóåéò.Äåí èõìáìáé áð åîù ôç äéåõèõíóç ôï ôçë.åéíáé 2108235405.
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 4.887
    « ÁðÜíôçóç #2 óôéò: ÔåôÜñôç, 28 Óåð 2005, 16:47:10 »
    Åõ÷áñéóôù Äçìçôñç. �õôåò ðïõ åéíáé 15c ôéò å÷åéò ÷ñçóéìïðïéçóåé? áí íáé ôé åíôõðùóåéò å÷åéò? (ð.÷. õðåñèåñìáíóç áíôï÷ç )
    ÊáôáãñÜöçêå
    Êþóôáò Æáðáíôéþôçò
    Ìçíýìáôá: 631
    « ÁðÜíôçóç #3 óôéò: ÐáñáóêåõÞ, 10 Öåâ 2006, 20:46:45 »
    �ãüñáóá áõôÞ ôç ìðáôáñéÜ(11,1V óôá 1300mah) ôá ðáñáêÜôù ÷áñáêôçñéóôéêÜ
    This is a GWS 3 cell 11.1 volt 1300mAh Lithium Polymer Battery Pack. FEATURES: Lithium Polymer design JST 2 pin male connector INCLUDES: One battery pack REQUIRES: Charging with the Triton GPMM3150, PolyCharge GPMM3010, Polycharge 4 GPMM3015, or any other charger specifically designed for LiPo cells. Do not use a charger designed for NiCd NiMH or any other battery chemistry. SPECS: Length: 2.6" (67mm) Height: 1.4" (35mm) Thickness: 0.8" (19.8mm) Voltage: 11.1v Capacity: 1300mAh Weihgt : 3.1oz (88gr) COMMENTS: Lithium Polymer batteries require particularly careful handling. Mishandling these batteries may lead to explosions, fire, smoke and a risk of poisoning. Do NOT series or parallel connect battery packs since the cell capacities and the charging condition may be too different. GWS LiPo batteries can be charged at a maximum rate of 1.5C and should be charged within a temperature range of 0° to 50°C. GWS LiPo batteries can be discharged at continous currents of around 6C (with 85%-95% capacity). High discharging current may reduce the discharging capacity or cause overheating. This battery should be discharged within a temperature range of -10° to 60°C.
     ÃªÃ¡Ã© Ã�÷ù ôïí PRO-PEAK PRODIGY II ãéá öïñôéóôÞ.Ìå ôé mah íá ôç öïñôßóù óôçí áñ÷Þ?êáé ìå ðüóá ãéá íá ìïõ æÞóåé ðåñéóóüôåñï?
    * makethumb.php.jpg (9.91 KB, 184x184 - åìöáíßóôçêå 608 öïñÝò.)
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 3.333
    « ÁðÜíôçóç #4 óôéò: ÐáñáóêåõÞ, 10 Öåâ 2006, 21:00:17 »
    Eãù èá ôç öïñôéæá ìå 1C äçëáäç 1.3� áí êáé ï êáôáóêåõáóôçò ëååé 1.5C áëëá ìç ôï êáíåéò êáôá ôç ãíùìç ìïõ ãéá íá å÷åéò ôï êåöáëáêé óïõ çóõ÷ï. �éèáíïôáôá èá áêïõóåéò êáé áëëåò áðïøåéò êáôá ôéò ïðïéåò ç öïñôéóç ðñåðåé íá ãéíåôáé êáôù áðï 1C, ðéóôåõù ïôé åéíáé ëéãï ÷áóéìï ÷ñïíïõ åéäéêá ïôáí èåëåéò íá ðåôáîåéò. Êïéôáîå åðéóçò íá ñõèìéóåéò ôïí öïñôéóôç ãéá 3 óôïé÷åéá åêôïò êé áí åéíáé áõôïìáôïò.
    �éêïò
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 4.887
    « ÁðÜíôçóç #5 óôéò: ÓÜââáôï, 11 Öåâ 2006, 09:40:38 »
    �ðï ïóï îåñù ìðïñåéò íá öïñôéóåéò ìéá ìðáôáñéá ìå÷ñé ôá mah ðïõ åéíáé äçëáäç 800 ç ìðáôáñéá 800 êáé ï öïñôéóôçò.
    Åãù ðñïóùðéêá ïôáí åéìáé óðéôé ôçí âáæù óôá ëéãïôåñá mah ôïõ öïñôéóôç ãéáôé åôóé äåí ðéåæåôáé ç ìðáôáñéá áëëá óôï áõôïêéíçôï êáôé ëéãïôåñï áðï 1C
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 3.333
    « ÁðÜíôçóç #6 óôéò: ÓÜââáôï, 11 Öåâ 2006, 10:53:24 »
    Êïéôáîå åðéóçò êáé ôé ñåõìá åêöïñôéóçò å÷åéò, óõìöùíá ìå ôïí êáôááêåõáóôç äå ðñåðåé íá îåðåñáóåéò ôá 6C=6x1.3=7.8A óå óõíå÷ç ëåéôïõñãåéá. �í îåðåñáóåéò áõôï ôï ïñéï ãéá ìåãáëï ÷ñïíéêï äéáóôçìá ôïôå ç ìðáôáñéá äå ðñïêåéôáé íá æçóåé ðïëõ ãéáôé èá æåóôáèåé ëïãéêá. �õôï åéíáé ðïõ ðñåðåé íá óå áðáó÷ïëçóåé âáóéêá êáé åîáñôáôáé áðï äéáöïñïõò ðáñáãïíôåò ïðùò ìïôåñ êáé ðñïðåëá.
    �éêïò
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 3.434
    Ö�ñå ÅÓÕ ôçí áëëáãÞ ðïõ èÜ 'èåëåò íá Äåßò
    « ÁðÜíôçóç #7 óôéò: ÓÜââáôï, 11 Öåâ 2006, 21:20:34 »
    Óõìöùíþ ìå ôïí �ßêï .
    Çëßá ðñüóåîå óå ôß êáôáíÜëùóç èá ôç âÜëåéò ... Åßíáé ðñïçãïýìåíçò ãåíéÜò ìå ÷áìçëÞ Åêöüñôéóç ...
    Ä�í åßìáé áêüìç åõ÷áñéóôçì�íïò ìå ôéò LiPoly .
    Ç ôå÷íïëïãßá ôïõò åßíáé áêüìç óå �çðéáêü óôÜäéï êáôÜ ôç ãíþìç ìïõ ... ÌåôÜ áðï 30-40 êýêëïõò 'Ìïíôåëéóôéêïýò' ÷Üíïõí áñêåôÜ ôç äýíáìÞ ôïõò Üí ä�í ðñïó�îåéò ðïëý ...
    Êáðïéïò ìïõ åß÷å ðåß ðùò ï ÄçìÞôñçò �âáæå äýï ìéêñ�ò �áñÜëëçëá óôá Depron 3D's áíôß ìßáò ìåãÜëçò ... (ð.÷. äýï 700Üñåò) .
    Óùóôüò ...  Thumbs up   Thumbs up
    ÄçìÞôñç áëçèåýåé ??
    ÊáôáãñÜöçêå
    Åðéôõ÷ßá óôç ÆùÞ= ��öôù "í" öïñ�ò, Îáíáóçêþíïìáé "í+1" öïñ�ò. ÂïÞèá ôïõò ¸ëëçíåò åðáããåëìáôßåò.
    Ìçíýìáôá: 4.887
    « ÁðÜíôçóç #8 óôéò: ÊõñéáêÞ, 12 Öåâ 2006, 09:09:02 »
    êáé êáôé áëëï ðáñáëëçëá ìå áõôï ðïõ óõçæçôáìå.
    ïôáí äåí êáíù ÷ñçóç ãéá ðïëõ êáéñï ôçò ìðáôáñéáò èá ðñåðåé íá åéíáé öïñôçóìåíç öïõë ìåôá ôçí ôåëåõôáéá ÷ñçóç?
    ÊáôáãñÜöçêå
    ÃéÜííçò ÊùíóôáíôáêÜôïò
    Ìçíýìáôá: 6.297
    AKA "jkon" Þ "èåßïò ÃéÜííçò"
    « ÁðÜíôçóç #9 óôéò: ÊõñéáêÞ, 12 Öåâ 2006, 20:30:06 »
    ÕðÜñ÷ïõí ïé áðáíôÞóåéò óôá åñùôÞìáôÜ óïõ óôï http://jkon.aeromodelling.gr/ninter-073e.htm
    jkon
    ÊáôáãñÜöçêå
    �ñüåäñïò Å.�.�.
    DINOS
    Ìçíýìáôá: 57
    « ÁðÜíôçóç #10 óôéò: ÄåõôÝñá, 8 ÌáÀ 2006, 16:40:21 »
    Ôþñá áãïñá ôï 3D ìïõ êáé åß÷å ìÃ�óá ôçí Li-po ìáæß ìå ôïí öùñôéóôÞ ôçò.Ôéò äáãêÜíåò óå ôé ìðáôáñßá íá ôéò âÜëù ãéá íá öïñôßóù, áõôïêéíÞôïõ;; Ã�ñþôç öïñÜ áó÷ïëïýìáé êáé äåí  îÃ�ñù, áí ãíùñßæåôáé ðåóôå ìïõ! Thumbs up Thumbs up
    * Li-po.jpg (109.61 KB, 394x299 - åìöáíßóôçêå 570 öïñÝò.)
    « Ôåëåõôáßá ôñïðïðïßçóç: ÄåõôÝñá, 8 ÌáÀ 2006, 16:47:43 áðü DINOS » ÊáôáãñÜöçêå
    �Üíôá øçëÜ êé' üëï øçëüôåñá!
    VAG
    Ìçíýìáôá: 159
    « ÁðÜíôçóç #11 óôéò: ÄåõôÝñá, 8 ÌáÀ 2006, 17:01:30 »
    Ößëå �ôßíï,
    ÅÜí êñßíù áðü ôçí öùôïãñáößá ðïõ �÷åéò óôåßëåé ç ìðáôáñßá áõôïêéíÞôïõ èá óïõ êÜíåé. Ãéá íá êÜíåéò üìùò ôçí æùÞ óïõ ðéï åýêïëÞ êáé áóöáëÞ ðñïðÜíôùí èá óïõ ðñüôåéíá íá áãïñÜóåéò ôñïöïäïôéêü áðü  Laptop. �õôÜ �÷ïõí áñêåôÜ ampere (åßíáé óôáèåñïðïéçì�íá êáé ñõèìéæüìåíá) þóôå íá êáëýøïõí ôéò áíÜãêåò ôïõ ìéêñïý öïñôéóôÞ óïõ (12volt 1-1.5ampere maximum). Ô�ôïéá èá âñåéò ó÷åôéêÜ åýêïëÜ óå áðëÜ ìáãáæéÜ çëåêôñïíéêþí. Óçìáóßá �÷åé íá äßíåé 12- 13.5volt �îïäï. Ô�ôïéï ÷ñçóéìïðïéþ ãéá ôï TRex ìïõ Thumbs up.
    ÖéëéêÜ,
    Âáãã�ëçò
    ÊáôáãñÜöçêå
    Èá óôáìáôÞóåé åðéô�ëïõò íá öõóÜåé???
    v_tolias
    Ìçíýìáôá: 1.367
    « ÁðÜíôçóç #12 óôéò: ÄåõôÝñá, 8 ÌáÀ 2006, 17:39:35 »
    Äåò ðïóá volt óôï input óïõ ëååé ï öïñôéóôçò.Ëïãéêá èá åéíáé 12 äçë.óõíäååéò óå ìðáôáñéá áõôïêéíçôïõ Þ ôñïöïäïôéêï!!!
    ÊáôáãñÜöçêå
    Êáí�íá äåí �ìåéíå åê�é ðÜíù...
    kosmasleiletzoglou
    ÅðéóêÝðôç
    « ÁðÜíôçóç #13 óôéò: Ôñßôç, 9 ÌáÀ 2006, 13:38:24 »
    �áé åßíáé ãéá ìðáôáñéá ìïëýâäïõ 12 âïëô. Åßôå öïñçôÞ åßôå áõôïêéíÞôïõ.
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 4.887
    « ÁðÜíôçóç #14 óôéò: ÐáñáóêåõÞ, 29 Óåð 2006, 18:28:32 »
    Ìðïñåé íá ìïõ ðåé êáðïéïò ôé åéíáé êáëõôåñï óôï åîçò åñùôçìá:
    Åóôù ïôé èåëïõìå íá êáíïõìå ÷ñçóç lipo ìðáôáñéáò,
    ôé çôáí êáëõôåñï (áðïäïóç äéáñêåéá ìáêñïæùéá) íá ÷ñçóéìïðïéçóïõìå 2 ìðáôáñéåò ìå 3 óôïé÷åéá êáé 1800 ma ç êáèå ìéá óå ðáñáëëçëç äéáôáîç ðïõ èá ìáò âãáëïõí 3600ma óõíïëï Þ 1 ìðáôáñéá ìå 3 óôïé÷åéá êáé 3600mA? Huh Huh
    Èåùñïõìå ïôé åéíáé óôá éäéá C åêöïñôéóçò êáé ôï âáñïõò ôïõò óå êáèå ðåñéðôùóç åéíáé ôï éäéï
    ôï êïóôïò ôï áöçíïõìå áðï åîù
    ÊáôáãñÜöçêå
    Óåëßäåò: [1] 2 3  ¼ëïé     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Ã�åñïðëÜíá R/C - ÇëåêôñéêÜ  |  ÊéíçôÞñåò - ÑõèìéóôÃ�ò - Ìðáôáñßåò  |  ÈÝìá: Ìðáôáñéá Lipo
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.038 äåõôåñüëåðôá. 24 åñùôÞìáôá.
