Σάββατο, 14 Νοε 2026, 10:09:31
    Επισκέπτες: 82
    Συνολικά: 84
    Αποστολέας Θέμα: Τηλεμετρία στις Futabes Μας  (Αναγνώστηκε 8159 φορές)
    « στις: Παρασκευή, 21 Οκτ 2011, 03:10:25 »
    Επιτελους κατα το καλοκαιράκι θα έχουμε τηλεμετρία..! Σε καποιες θα εχουμε την τηλεμετρια στην τηλεκατ και σε κάποιες άλλες θα την έχουμε εξωτερικά..!
    Πως και πως την περιμένω τώρα με το φωτογραφικο Απο τα καλύτερα νέα που άκουσα τον τελευταίο καιρό
    http://www.robbe.de/content_global/images/robbe-erleben/newsletter/Newsletter_Telemetrie_2011.pdf
    With the new radio system in T18MZ
    Fall 2011 robbe-Futaba in the home
    Telemetry are finding their way. Based on the
    FASST system, the bidirectional
    comprehensive test ™ - system for the transmission of tele-
    metriedaten the models developed for the transmitter.
    The new system is called comprehensive test ™, where "est"
    for "Advanced Telemetry System" is.
    A radio link for control and telemetry data.
    The high-end radio gear to control the sending T18MZ
    Model 16 +2 and 32 channels can be up to telemetry channels
    received. The telemetry data will not only display
    displayed, but also acoustically or via voice
    printed output. An optional vibration alarm in the
    Transmitters are activated.
    At the transmitter, the telemetry data are also available in digital
    Form and are available via a wireless or
    Bluetooth module to a smartphone or a laptop
    transferred. This opens up for the greatest-model pilot
    flexibility of display and output options.
    Other features of T18MZ
    The brilliant 6 "HVGA display with touchscreen, LED back-
    backlight and contrast is enhanced in bright
    Sunlight readable well. Was greatly accelerated the
    Reaction time of the touch screen by using a super-
    fast microprocessor. The increase in operating time
    was on a long operating day reduction achieved by
    the power consumption while increasing the battery
    capacity at 3500 mA. The battery charging process management in
    output assumes the transmitter electronics.
    The internal memory is such that images of
    Models can be stored in internal memory. The
    integrated 0.3 megapixel camera allows the uncomplicated
    graced creation of model photos to the then
    allocate appropriate memory model. In addition to the
    known storage on SD card, a USB stick as
    Storage medium used and the data via USB
    Cable in the PC are stored. Via the USB port
    can alternatively keyboard and mouse for menu control
    be used.
    At the transmitter, a connector is to
    Programming of S-BUS servos and registration of
    Telemetry sensors on the system. The best menu setup
    tion of the T-14 was around the menus for S-BUS-power,
    S-BUS-gyro, camera and telemetry display expanded.
    The new, extremely precise joystick use
    Industriepotis, characterized by a lifetime of more
    characterized as one million cycles.
    Page 2
    Sensors
    Other sensors, such as a simple sensor for Vario
    Small models, a pro-Vario-resolution sensor with precise
    by Vario and height and a GPS sensor for altitude and
    Speed ​​measurement, in addition to other current
    and voltage sensors, sensors for Restkraftstoffanzei-
    GE, flow, temperature, individual cell voltage, the
    Telemetry sensors offer robbe / Futaba round.
    What's new with remote control and telemetry equipment?
    R7008SB comprehensive test ™
    The heart of the comprehensive test ™ system is the
    R7008SB new receiver with integrated
    Telemetry transmitters.
    It is designed for connecting up to eight standard PWM
    Servos (analog or digital) designed. With two receivers
    Up to 16 channels can be received. On S-BUS
    All output channels are also available in digital form-
    tion. There, right up to 18 servos or via S-BUS
    Be connected with an adapter and standard PWM servo.
    Automatically when connecting the receiver, the
    important data such as telemetry receiver battery voltage,
    an external voltage (60 V) and the Antennensig-
    nalstärke transferred to the transmitter. On S-BUS 2 - Input
    the telemetry sensors and / or bidirectional
    working-RC components connected.
    The S-BUS 2 - port receive these RC components
    th their control and send signals over the same line
    Telemetry data to the transmitter. A receiver for all
    No further
    Additional equipment required on the receiver!
    Impressive are the small size of
    47.3 x 24.9 x 14.3 mm and only 13 grams. Perfect both
    for narrow hulls and large sailing competition models.
    Roxxy BL-control knobs (S-BUS2)
    A part of this new S-BUS 2-RC components are
    new S-BUS Roxxy BL-control knobs. You will be after
    Registration and automatically port on the S-BUS2
    Telemetry data speed, current and voltage to the transmitter
    . transmit This will almost sensorless digital future
    Reality without additional sensors and wires and without
    Additional costs.
    After the launch of the fall of 2011 T18MZ
    little by little, all FASST transmitter as T8FG,
    FX-20, T12FG, FX-30, etc. gradually to the new
    comprehensive test ™ system changed. The new facilities would
    both the FASST system and the FHSS system
    Modulation provide. This is to-
    ensure that existing FASST receiver in addition
    be operated with the RC system with telemetry
    can. The telemetry data is displayed on the display,
    or alternatively and sound output, and probably
    Lich and voice output via the headphone jack
    issued. This feature is of course only in the
    Modulation comprehensive test available.
    Figure example
    Page 3
    Wi-Fi, Bluetooth phone, laptop and telemetry
    As a universal telemetry unit, the output
    Smart-phone use. The data are transmitted via wireless
    Bluetooth module or transferred to the smartphone, the
    Voice and tone, vibrating alert and a display
    possesses. The smartphone is the optimal output
    unit for telemetry data. Thus, the telemetry data
    gleichzeitigt output on various devices (eg
    Helpers, announcer, timekeeper, etc.)
    Wlan or Bluetoooth can Telemetriedeaten
    also to a laptop / notebook will be sent with the
    necessary software, which telemetry data to
    the monitor displays a large area. For events and
    Competitions, the telemetry values ​​as RGB or
    HDMI port on the netbook / laptop through a large
    Flat panel monitor or display to the spectators
    be.
    How does the conversion on telemetry at
    existing FASST systems?
    Existing systems can FASST with a new
    Recipient (R7008SBHybrid), the control signals FASST
    receives the telemetry data as a comprehensive test-signal ™
    Telemetry receiver box to send. In principle this is similar
    The receiver R70008SB (as described above), is
    However, as FASST / comprehensive test-signal hybrid-combination
    designed.
    Telemetry box
    For the reception of telemetry data, the telemetry box
    offered, equipped with a receiver and lithium
    Battery. The telemetry data received at the display
    and displayed either by sound or voice output
    issued.
    By means of the telemetry receiver and R7008SBHybrid
    autaken the telemetry box, all existing
    FASST transmitter and RASST and plants with FASST or
    RASST modules are converted to telemetry.
    robbe model sports team in June 2011
    FlyingDoctor
    Βασιλης
    « Απάντηση #1 στις: Παρασκευή, 21 Οκτ 2011, 13:12:49 »
    http://www.robbe.de/content_global/images/news/2011-10-09-Telemetrie-Update/Telemetrie2011_Update.pdf
    extenge
    Nikos
    « Απάντηση #2 στις: Παρασκευή, 21 Οκτ 2011, 21:50:44 »
    Ωραια ρε παιδια αυτα αλλα απ οτι καταλαβαινω για να εχεις τηλεμετρια σε Futaba πρεπει να σου περισσευουν πολλα ευρώ..........
    « Απάντηση #3 στις: Παρασκευή, 21 Οκτ 2011, 21:54:06 »
    θα δείξει ας μην βιαζόμαστε..! ίσως σε καποιες γινει με ενα δωρεαν update και σε καποιες άλλες με ολοκληρο hardware..
    FlyingDoctor
    Βασιλης
    « Απάντηση #4 στις: Παρασκευή, 21 Οκτ 2011, 22:00:02 »
    Ουσιαστικα το καντραν θελει που ειναι και δεκτης ταυτοχρονα.Βεβαια τι τιμη θα εχει αυτο....?Δεν πιστευω ομως να την συμφερει να εχει υψηλες τιμες στα περιφεριακα. ηδη οι δεκτες της ειναι τσιμπημενοι.
    « Απάντηση #5 στις: Παρασκευή, 21 Οκτ 2011, 22:09:23 »
    Τηλεμετρια στις Futaba ΜΑΣ δεν ειναι, ειναι τηλεμετρια στις Futaba ΤΟΥΣ.
    Ειχα διαβασει πριν λιγο καιρο με την ελευση της Futaba 8FG Super (οι διαφορες της απλης με την Super einai οτι εχει απο τον κατασκευαστη λογισμικο για τα 12 κανναλια, εχει λιγα χιλιοστα μακρυτερα sliders και εχει σταμπα στην προσοψη για 12 κανναλια και οχι για 8, τελος γραφει καπου και την λεξη Super) οτι ισως η Super να μπορεσει να δεχθει τηλεμετρια. Υπαρχει δηλαδη υποψια οτι εχουν κανει και αλλαγες στο hardware εσωτερικα.
    Εαν βαλουν τηλεμετρια εχει νοημα σε ενα μεσαιο μοντελο οπως η 8FG.
    Τηλεμετρια με αναβαθμιση δεν γινεται για τον απλουστατο λογο οτι καπου μεσα στην TK πρεπει να υπαρχει κυκλωμα που να δεχεται την ακτινοβολια απο τον δεκτη (τον δεκτη που βαζουμε στο αεροπλανο).
    FlyingDoctor
    Βασιλης
    « Απάντηση #6 στις: Παρασκευή, 21 Οκτ 2011, 22:12:23 »
    Το καντρανακι ειναι και δεκτης των πληροφοριων απο το δεκτη.
    « Απάντηση #7 στις: Παρασκευή, 21 Οκτ 2011, 22:35:33 »
    Σε όλες θα υπάρξει..! απλα σε καποιες θα ειναι εξωτερικη σε καποιες που την δέχονται εσωτερικά..!Οσο για την 8fg σιουρα δέχετε αμφιδρομη επικοινωνια..! Ειτε η σουπερ ειτε η απλη..! Ετσι φενεται να γινεται και με την 12Fg..! Οι άλλες απλα θα εχουν ενα εξωτερικο κουτακι.>! Άρα θα είναι για όλες..!
    « Απάντηση #8 στις: Παρασκευή, 21 Οκτ 2011, 22:42:38 »
    Πολυ ενδιαφερον αυτο που λες σχετικα με την αμφιδρομη επικοινωνια στην 8FG. Που θα βρω περισσοτερες πληροφοριες για αυτο; Η εξωτερικη τηλεμετρια ειναι μια λυση αναγκης. Η σωστη τηλεμετρια δειχνει τα στοιχεια στην ηδη υπαρχουσα οθονη της ΤΚ και με ηχο.
    « Απάντηση #9 στις: Παρασκευή, 21 Οκτ 2011, 22:52:52 »
    Δν μπορείς να βρεις στοιχεία έυκολα..! το παραπάνω κείμενο σου λεει οτι η 8fg kai η 12FG μαζι με 2 αλλες θα ειναι αυτές που θα γίνουν με αναβάθμιση..!
    Παλαιότερα ειχα βρει κάπου στο FB της Futaba pου ελεγε οτι υποστηριζει αμφιδρομη επικοινωνια..! Διαβασε παραπάνω κατι βγαινει αλλα δν ειναι ξεκάθαρο 100%
    FlyingDoctor
    Βασιλης
    « Απάντηση #10 στις: Πέμπτη, 27 Οκτ 2011, 18:35:32 »
    http://shop.lindinger.at/pdf/93114a.pdf
    FlyingDoctor
    Βασιλης
    « Απάντηση #11 στις: Σάββατο, 19 Νοε 2011, 22:35:44 »
    http://www.robbe.de/content_global/pdf/News/2011-11-13-Interview-Telemetrie/AV_1211_Interview_robbe_Telemetrie.pdf
    Aviator: Μπορώ να κατανοήσει επίσης παλιό πομπό μου στο νέο
    Σύστημα τηλεμετρίας εκ των υστέρων εξοπλισμού;
    Frank Schwartz: Η τροποποίηση του FASST πομπό,
    έτσι ώστε τα δεδομένα τηλεμετρίας που περιήλθε στο πομπό
    και μπορεί να εμφανίζεται στην οθόνη του πομπού
    δεν έχουν παρασχεθεί προηγουμένως. Έχουμε, ωστόσο, με την
    Τηλεμετρίας και WIFI κουτί δύο πολύ καλές ευκαιρίες
    σε, ακόμη και με τις υπάρχουσες ραδιοτηλεοπτικούς φορείς τα πλεονεκτήματα της FASST
    Robbe / Futaba-τηλεμετρίας για χρήση χωρίς περιορισμούς.
    Το κουτί έχει ένα ενσωματωμένο δέκτη τηλεμετρίας για
    τα δεδομένα τηλεμετρίας και ένα ξεχωριστό τροφοδοτικό. έτσι
    Το κιβώτιο είναι εντελώς ανεξάρτητο από το τηλεχειριστηρίου
    και ευέλικτο. Το πακέτο περιλαμβάνει δύο
    Περιλαμβάνεται προσαρμογέας. Έτσι, είναι πιθανό, το πλαίσιο για την
    Λαβή μεταφοράς του πομπού ή στη βάση των αχρησιμοποίητων
    Συνδέστε το 35-megahertz κεραία. Το Κουτί Τηλεμετρίας
    μπορεί να καθοριστεί με μια λαβή. βρίσκει
    για παράδειγμα, απλά μια θέση στο
    Τσέπη. Η Robbe / Futaba κουτί Τηλεμετρίας υποδεικνύει την
    Δεδομένα τηλεμετρίας όπως: Εμφάνιση, ήχος ή
    Έξοδος φωνής μέσω ακουστικών και η δόνηση.
    Πάνω από τη θύρα USB είναι δυνατό να ενημερώσεις λογισμικού
    που ισχύουν για τη συσκευή.
    Σε ποιον ανήκει ένα smartphone μπορεί να χρησιμοποιεί το Robbe /
    Futaba WIFI κουτί μπορεί να μεταδώσει δεδομένα με ασύρματο τρόπο.
    Τα δεδομένα τηλεμετρίας εμφανίζεται στην οθόνη, ήχο
    και η παραγωγή φωνής και η δόνηση, είναι επίσης διαθέσιμα.
    Για να ενεργοποιήσετε το WiFi κουτί
    Αυτή είναι μόνο η υποδοχή εκπαιδευτής σε πομπό σας
    συνδεθεί. Το app για το iPhone και το τηλέφωνο Android
    θα είναι διαθέσιμη σύντομα.
    η μεταφραση ειναι λιγο για πεταμα............αλλα πανω κατω βγαζεις συμπερασμα.
    « Απάντηση #12 στις: Κυριακή, 15 Ιαν 2012, 21:41:07 »
    Υπαρχει καμια εξαλιξη στο θεμα η μας κοροιδευει η Robbe-Futaba;
    « Απάντηση #13 στις: Κυριακή, 15 Ιαν 2012, 21:49:32 »
    Εχουν πει καλοκαιρακι..!!
    FlyingDoctor
    Βασιλης
    « Απάντηση #14 στις: Κυριακή, 15 Ιαν 2012, 21:54:07 »
    Καποιες τιμες εχουν ανακοινωθει στο tower hobbies,αλλα πιστευω απο τελος γεναρη που θα ξεκινηση η διαθεση της 18ΜΖ να ξεκαθαρισει το τοπιο.
    Ισως ο Pant να ειναι πιο ενημερωμενος!
    Aeromodelling GR  |  Forum  |  Το αερομοντελιστικό εργαστήρι  |  Η τηλεκατεύθυνση και τα αξεσουάρ (Συντονιστές: DEPRON MANIAC, kolotoympas)  |  Θέμα: Τηλεμετρία στις Futabes Μας
