Πέμπτη, 19 Νοε 2026, 01:21:42
    [Σήμερα στις 00:04]
    [Χθες στις 21:11]
    [Χθες στις 14:10]
    [Χθες στις 13:27]
    Σύνολο μηνυμάτων: 310091
    Σύνολο θεμάτων: 12406
    Online σήμερα: 126
    Επισκέπτες: 130
    Συνολικά: 132
    Αποστολέας Θέμα: NEA PARALABI RC4U.GR KAI NEA SELIDA !!  (Αναγνώστηκε 4401 φορές)
    RC4U
    « στις: Παρασκευή, 20 Μαρ 2009, 17:07:48 »
    ΕΠΙΣΠΕΥΤΕΙΤΕ ΤΗΝ ΝΕΑ ΜΑΣ ΣΕΛΙΔΑ
    ΚΑΙ ΑΠΟΛΑΥΣΤΕ ΤΙΣ ΜΟΝΑΔΙΚΕΣ ΠΡΟΣΦΟΡΕΣ  ΜΑΣ
    ΚΑΙ ΦΥΣΙΚΑ ΤΙΣ ΝΕΕΣ ΜΑΣ ΠΑΡΑΛΑΒΕΣ!!!
    Innovator Expert 3D 2.4 GHZ
    Κατασκευαστής: Thunder Tiger
    Κωδικός: TT 4721F05 RTF
    1. The first R/C helicopter adopted the Integrated Control System (ICS) in the world.
    2. Adapt an advanced 6Channel 2.4GHz spread spectrum radio control system ( iFHSS ).
    3. 7mm strong main shaft
    4. 90-degree MCCPM push/pull linkage design
    5. New battery tray design, easy to access battery
    6. (Option) Special type 2.4GHz Tx modules fits difference brand transmitters.
    7. (Option) Exclusive PC software can let you communicate with your heli
    Full Length (mm)   650
    Full Width (mm)   135
    Total Height (mm)   245
    Main Rotor Dia. (mm)   712
    Tail Rotor Dia. (mm)   135
    Gear Ratio   1114.95
    Full Equip. Weight (g)   820
    Rotor Blade   Wood Blade
    Stabilizer   EXP
    Motor   S2/KV3800
    Battery   3S1P 1800mAh/25C
    ESC   55A
    Default Flying Data   PCS-EXP-0001
    TIMI: 615 EURO
    Lama με τεχνολογία 2,4 Ghz RTR
    Κατασκευαστής: Ikarus
    Κωδικός: 6821002
    Lama  with modern 2.4 Ghz-technology, including 2nd battery, charger, spare rotorblades and adapter for flightsimulator ("ready for Aerofly / Easyfly")
      LAMA - ready to fly -   Complete set including transmitter and Lithium Polymer battery! The Lama is a docile flying helicopter and especially suitable for the novice helicopter pilot who wants to have success fast. The stacked twin main rotor design is responsible for the extra ordinarily stable flight characteristics. Even as this helicopter is fairly easy to fly, all usual flight maneuvers can be performed, thanks to the included 4 channel radio system. Novices will enjoy successful flights very quick and advanced pilots can improve on their existing skills. The Lama has been produced in the 70s and established an altitude world record for helicopters by flying 40,793 ft high. The Lama was used for military as well as non-military tasks and many of them are still in operation nowadays. We are wishing our hobby pilots success and lots of fun with this Lama model helicopter.
       Advantages of the Lama at a glance - Twin main rotor control for easy handling- Lithium-Polymer high performance battery- Two powerful motors for great performance- Frame design with high impact resistance Set ContentsLama model helicopter, assembled with 2,4 Ghz receiver, 2. Li-Po battery, transmitter and charger for Li-Po-Battery included.  (8 AA batteries for the transmitter sold separately; Item-Nr. 332, please order 2 x 4pcs.)   Technical Specifications
    Length    14,4 in
    Fuselage height    3.5 in
    Total height   6.7 in
    Fuselage length   13.4 in
    Weight   6.6 oz
    Battery   3,7 Volt, 1000 mAh Li-Po
    ME 2 MPATARIES STO PAKETO 145EURO
    « Τελευταία τροποποίηση: Παρασκευή, 20 Μαρ 2009, 17:23:08 από RC4U » Καταγράφηκε
    WWW.rc4u.GR
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: NEA PARALABI RC4U.GR KAI NEA SELIDA !!
    Δημιουργία σελίδας σε 0.043 δευτερόλεπτα. 24 ερωτήματα.
