Παρασκευή, 16 Οκτ 2026, 03:00:44
    [Χθες στις 13:50]
    Επισκέπτες: 36
    Συνολικά: 36
    Σελίδες: 1 ... 11 12 13 [14] 15 16 17 ... 20     Κάτω
    Αποστολέας Θέμα: Samos Model center  (Αναγνώστηκε 208285 φορές)
    samosrc
    « Απάντηση #195 στις: Παρασκευή, 22 Ιουλ 2011, 10:38:49 »
    ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
    ΤΕΤΡΑΗΜΕΡΗ ΠΡΟΣΦΟΡΑ 10%- ΣΕ ΟΛΑ ΤΑ ΑΕΡΟΠΛΑΝΑ ΑΝΩ ΤΩΝ 79€
    http://www.rcmodelshop.gr/index.php?main_page=index&cPath=1_89
    http://www.rcmodelshop.gr/index.php?main_page=index&cPath=1_7
    rcmodelshop.gr
    samosrc
    « Απάντηση #196 στις: Δευτέρα, 1 Αυγ 2011, 09:39:16 »
    MINTOR & SEBART
    CALMATO 40 SPORTS blue
    SKY BLUE No.11215BL   ARF Kit □Available : 30 Oct 2004 The perfect introduction to low-wing flight. You’ll enjoy the ideal 40-s…
    109.00€
    CALMATO 40 SPORTS red
    CALMATO 40 SPORTS The perfect introduction to low-wing flight. You’ll enjoy the ideal 40-size flight performance. Delivers the excellent stability and…
    109.00€
    CALMATO 40 SPORTS yellow
    109.00€
    OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
    OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver   Compatible with Futaba FASST receivers: TM7, TM8, TM10, TM14 + more. Th…
    33.00€
    Sukhoi 29S 50E V2 Red/Blue
    Sebart Planes  NEW - Sukhoi 29S 50E V2NEW - Sukhoi 29S 50E V2 Yellow/Black Version - Red/Blue Version Nuova versione "V2", acrobatic…
    257.00€
    ZIPPY Flightmax 2200mAh 3S1P 20C
    ZIPPY Flightmax 2200mAh 3S1P 20C Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the ho…
    13.00€
    http://www.rcmodelshop.gr/index.php?main_page=index&cPath=73
    rcmodelshop.gr
    samosrc
    « Απάντηση #197 στις: Πέμπτη, 11 Αυγ 2011, 07:41:26 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    4ch Rx 2.4GHz FHSS
    4ch Rx 2.4GHz FHSS Able to function in both FHSS and S-FHSS modes, this new and low cost four channel received can be used with a wid…
    39.00€
    3ch Combo 2.4G FHSS (Dry) R203GF
    Utilising Futaba’s new FHSS 2.4Gz transmission system, this new 3 channel steerwheel system incorporates an internal transmitter aeri…
    65.00€
    12ch Combo 2.4GHz M2 R6014HS
    799.00€
    Pro-Peak Watt Meter
    Pro-Peak Watt Meter
    Pro-Peak Watt Meter At last, a heavy duty watt meter that can monitor the power consumption of your motor/load source and ‘freeze’ re…
    36.00€
    Black Horse Edge 540V3 EP…
    Black Horse Edge 540V3 EP ARTF
    Black Horse Edge 540V3 EP ARTF Sharing the same design as the large-scale model above, the smaller EP version of the Edge 540V3 is perfect for smal…
    138.00€
    Futaba Servo Arm Set
    7.00€
    CNC 6CM Alloy Servo Arm E…
    CNC 6CM Alloy Servo Arm Extra Long (Futaba)
    6.00€
    CNC Alloy Servo Arm Short…
    CNC Alloy Servo Arm Short (Futaba)
    6.00€
    CNC Alloy Servo Arm Long …
    CNC Alloy Servo Arm Long (Futaba)
    6.00€
    Turnigy 3639 Brushless Mo…
    Turnigy 3639 Brushless Motor 1100kv
    Turnigy 3639 Brushless Motor 1100kv   Dimension: 43mm x 37mm, 62mm(with shaft) Weight: 136g  (kv 750) (not including connecto…
    33.00€
    Turnigy Park480 Brushless…
    Turnigy Park480 Brushless Outrunner 1020kv
    Turnigy Park480 Brushless Outrunner 1020kv Turnigy Park480 Brushless Outrunner 1020kv   Designed to provide reliable and…
    24.00€
    Turnigy Park450 Brushless…
    Turnigy Park450 Brushless Outrunner 890kv
    Turnigy Park450 Brushless Outrunner 890kv Turnigy Park450 Brushless Outrunner 890kv   Designed to provide reliable a…
    18.00€
    Turnigy L3010B-1300 Brush…
    Turnigy L3010B-1300 Brushless Motor (420w)
    Turnigy L3010B-1300 Brushless Motor (420w) Turnigy L3010B-1300 Brushless Motor (420w)     Turnigy L3010B-1300 Brushless M…
    22.00€
    Turnigy L2210C-1200 Brush…
    Turnigy L2210C-1200 Brushless Motor (150w)
    Turnigy L2210C-1200 Brushless Motor (150w) Turnigy L2210C-1200 Brushless Motor (150w)   Turnigy L2210C-1200 Brushless…
    18.00€
    Turnigy L2210A-1650 Brush…
    Turnigy L2210A-1650 Brushless Motor (180w)
    Turnigy L2210A-1650 B Turnigy L2210A-1650 Brushless Motor (180w)   Turnigy L2210A-1650 Brushless Motor (180w)   Specification…
    17.00€
    Turnigy G15 Brushless Out…
    Turnigy G15 Brushless Outrunner 950kv
    Turnigy G15 Brushless Outrunner 950kv   Designed to be a direct swap out for your 15 size glow engine. This brushless outr…
    27.00€
    http://www.rcmodelshop.gr/index.php?main_page=products_new
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΑΝΩ ΤΩΝ 50Ε  ΣΕ ΟΛΗ  ΤΗΝ ΕΛΛΑΔΑ
    rcmodelshop.gr
    samosrc
    « Απάντηση #198 στις: Κυριακή, 21 Αυγ 2011, 21:00:24 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    EXTRA 260 FERTIGMODELL 1,78M GELB ARFM-L   BRAND: PLANET-HOBBY MANUFACTURER ITEM NUMBER: EX260-70"YELLOW CATALOGUE …
    229.00€
    YAK 54 2,2M FERTIGMODELL BLAU PILOT-RC BRAND: PILOT-RC MANUFACTURER ITEM NUMBER: YAK54-87"-0…
    549.00€
    S-AKKU ENELOOP 2000/9,6V FUTABA FX14/18TECHNICAL DESCRIPTION:Kapazität2000 mAhSpannung:9,6 VMarkeSanyoEinzelzelleENELOOP 2000Für SenderFX14/…
    34.00€
    CATALINA FORMSCHAUMMODELL ROT/WEISS PICHTECHNICAL DESCRIPTION:Spannweite:1380 mmGewicht:ca.780 gempf.Motor:2xBrushless-MotorSteuerung:H,S,Q,MHerstelle…
    158.00€
    piper pa-18 super cub DESCRIPTIF: Envergure: 3330 mm Poids: environ 13000 g (vol) Motorisation .Motor: environ 50 cc Contrôle: Prof, Direction, A…
    599.00€
    GENERATION 3 CX LIPO 240MAH/3,7V 25/45CTECHNICAL DESCRIPTION:Spannung:3,7 VFormEinzelzelleGewicht6,5 gTypeLipolyKapazität240 mAhmax.Dauerstrom25/…
    4.00€
    PILATUS PORTER "PATROUILLE SWISS" 1,58M
    169.00€
    S-AKKU ENELOOP 2000/9,6V FF-7/10 FUTABA
    33.00€
    POWER PEAK TRIPLE EQUALIZER BID 12V LADE
    Item Description RB8541 - Power Peak Triple EQ-BID Check out Robbe's latest high end 3 output charger...   Compact TRIPL3 charge-discharge stat…
    189.00€
    DUALSKY XPOWER EX G5 LIPO 7,4V/400MAH TECHNICAL DESCRIPTION:Spannung:7,4 VForm2er-PackGewicht30 gTypeLipolyKapazität400 mAhmax.Dauerstrom30CL/B/H…
    7.00€
    GENERATION 3 CX LIPO 450MAH/7,4V 25/45C
    GENERATION 3 CX LIPO 450MAH/7,4V 25/45CSpannung:7,4 VForm2er-PackGewicht29 gTypeLipolyKapazität450 mAhmax.Dauerstrom25/45CL/B/H mm57/32/12
    11.00€
    LRP LiPo Safe - 18 x 22cm
    LRP 65846 LiPo Safe - 18 x 22cm
    16.00€
     GX46  kyosho
    112.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #199 στις: Πέμπτη, 25 Αυγ 2011, 09:26:08 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    http://www.rcmodelshop.gr/bmz_cache/d/d2c1f57b2903ad741ba8060c166de2cc.image.100x73.jpg[/img]
    6.00€]
    6.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1622
    HXT900 9g / 1.6kg / .12sec Micro Servo
    HXT900 9g / 1.6kg / .12sec Micro Servo HXT900, one of the most famous and the best value micro servos available. Used by tens of thousands of hobbyies…
    4.00€
    T-REX 450 Pro Super Combo
    T-REX 450 Pro Super Combo Focus Shot1(High precision main rotor assembly) Focus Shot2(High precision bearing mixing arms) Focus Shot3(Single piec…
    358.00€
    Turnigy 2213 22turn 924kv 17A Outrunner Turnigy 2213 22turn 924k
    Turnigy 2213 22turn 924kv 17A Outrunner Spec. Kv: 924rpm/v Operating Current: 6A ~ 14A Peak Current: 17A Suggested prop: 11x5.5 E-prop Suggested Batte…
    21.00€
    Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec
    Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec Weight: 13.4g Dimension: 22.8*12.2*28.5mm Stall torque: 1.8kg/cm (4.8V) - 2.2kg/cm (6.0V…
    7.00€
    Turnigy nano-tech 1000mah 2S 25~50C Lipo Pack
    Turnigy nano-tech 1000mah 2S 25~50C Lipo Pack   More than just a fancy name. TURNIGY nano-tech lithium polymer batteries are b…
    9.00€
    DUALSKY XPOWER ES LIPO 250MAH/7,4V 20C
    DUALSKY XPOWER ES LIPO 250MAH/7,4V 20CGENERAL DESCRIPTION: DUALSKY Lipo Akkupacks mit hoher Leistung und hervorragendem Preis/Leistungsverhältnis…
    6.00€
    Fazer McLaren F1 GTR RTR
    GP touring cars provide the real taste of motor racing excitement and the FAZER brings this intensity within easy reach. KYOSHO`s design expertise fo…
    219.00€
    Futaba R617FS FASST 2.4Ghz receiver
    Futaba R617FS FASST 2.4Ghz receiver FEATURES: High sensitivity receiver weighs only .25oz (7g) without case yet is a full range system for all aircraf…
    59.00€
    KYOSHO 1:10 GP 4WD Fazer Arta NSX 2007
    FAZER What is the FAZER series? Simply the ideal beginner GP touring car machine! FAZER performance lets you relive GT racing. GP touring cars provid…
    219.00€
    SERVO S3001 BULK 3,0 kg
    4.8V or 6.0V Dimension 40.4 mm x 19.8 mm x 36.0 mm Weight 45.1 g Operating Speed 0.22 sec/60° Output torque 3.0 kg-cm
    13.00€
    ULTRA MODEL MPX Funjet ELAPOR
    BRAND: MULTIPLEX MANUFACTURER ITEM NUMBER: 214 246 CATALOGUE PAGE: 082 ITEM DESCRIPTION: After all, some like it hotter Even the "normal&q…
    103.00€
    « Τελευταία τροποποίηση: Πέμπτη, 25 Αυγ 2011, 09:53:03 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #200 στις: Τρίτη, 30 Αυγ 2011, 18:15:28 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ[/size]
    Futaba® 8FG Super 2.4GHz FASS
    395.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #201 στις: Τρίτη, 6 Σεπ 2011, 18:52:59 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    MOSQUITO PLUG AND PLAY Specification Wingspan 1355mm Length 950mm Weight  1700g ESC 2x 30A Brushless Servo 8x 9g Motor 2x Brushless
    240.00€
    CESSNA 182 EPO 500 CLASS PNP (NO TX/RX
    CESSNA 182 EPO 500 CLASS PNP (NO TX/RX/BAT OR CHG) (RED) Coming in at 1030mm long and with its enormous wingspan of 1290mm, this is one of the most st…
    189.00€
    Max Thrust MX2
    Max Thrust MX2 Wing Span: 1400mmTotal Length: 1290mmFlying Weight: 1900g Outrunner Brushless Motor45 Amp Electronic Speed Controller2 x 9g Servo (Aile…
    145.00€
    Turnigy 2200mAh 3S 25C Lipo Pack Turnigy 2200mAh 3S 25C Lipo Pack   The new number one in performance and price! The new Tur…
    13.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #202 στις: Πέμπτη, 8 Σεπ 2011, 19:52:51 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    12.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=368
    rcmodelshop.gr
    samosrc
    « Απάντηση #203 στις: Δευτέρα, 12 Σεπ 2011, 08:14:59 »
    MINTOR & SEBART
    DIAMOND 2500 GLIDER PNP (NO TX/RX/BAT OR CHG)
    189.00€
    This model is made from EPO Foam giving it robustness and strength to perform those aerial manuevers time and time again. Propelled by a massive 4 cell Li-Po battery and out-runner motor, this beauty will have no trouble climbing to the clouds and with a 2560mm wingspan visibility won't be an issue.
    The Diamond comes with all electronics pre-fitted including 2.4GHz Transmitter and receiver and has a seperate servo for each of it's control surfaces, including the flaps on the wings.
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1364&zenid=72e819372a712468101cf461085590bd
    rcmodelshop.gr
    samosrc
    « Απάντηση #204 στις: Τετάρτη, 14 Σεπ 2011, 22:26:03 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    Mini Moa Art Tech
    158.00€
    The MiniMoa is one of the classic glider shapes of all time, its design dates back to 1935 and you can see the influence of the birds within its features in both wing shape and gull wing dihedral. The full size glider established several world records, including an altitude record of 6687 metres in 1938, and then went on to win the world championships in two consecutive years. There are now only four full size aircraft left flying, one of which is based in the UK.
    Our model has taken all of these classic features and reproduced them down to the last detail in EPOFLEXY, rather than wood, making it highly detailed, light and very strong. We have also added an electric motor so you can fly this model anywhere, any time, to whatever height record you want to set. And when high enough, you can shut the throttle and the propeller folds away to give you the best streamlined glider shape for soaring.
    Art Tech Mini Moa
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1357&zenid=eb9afae7341db199f3e6632282785c79
    rcmodelshop.gr
    samosrc
    « Απάντηση #205 στις: Παρασκευή, 16 Σεπ 2011, 21:13:19 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    MINTOR 33cc New
    299.00€
    The first of a new line of powerful and reliable engines... At the right price!!
    Engine 33cc, barrill, spacers, ignition, NGK plug
    Engine weight = 910 grams
    Ignition weigth = 105 grams
    Barrill weight = 58 grams
    With barrill, prop Mejzlik 19x8 = 7.700 rpm
    Peso Motore = 910 g.
    Peso Iniezione = 105 g.
    Peso scarico barilotto = 58 g.
    Elica Mejzlik 19x8 = 7.700 giri/m.
    con scarico barilotto
    Mintor srl, was born as a workshop of high precision mechanics working.
    Our decades-long activity in high level working in many different industrial sectors and especially our great passion for engines and model aircraft construction, hasdriven us, in these last few years, to dedicate part of our activity to the design of engines specific for model aircraft. It has always been our firm belief that, anyone who dedicate time and resources for the model aircraft, must have the chance to find high quality and reliable products on the market.
    Following this inspiration, our products are designed and manufactured with the main aim of high performances and reliability.
    Actually, we are the only firm, all over the world, to design, produce and assemble all the mechanical components of the enigne here in our premises with manufacture engineering inspired to the best italian motor design and engineering traditions.
    The search of the best structural stiffness and weight reduction, has given reason for the realization from a solid block of each particular of the engine using the best alloys, no details are made from fusion!
    This technique, surely much more expensive than the traditional ones used by any other manufacturer, added to the use of the most sophisticated CNC machinery, allow to optimize to the highest levels the weight and functionality of any single component in order to obtain a very high level whole.
    Anyone who choose a Mintor engine, owns a product made with the attention and meticulousness dedicated to competitions, and above all is sure to have always at his disposal the support of a serious, motivate and competent firm.
    rcmodelshop.gr
    samosrc
    « Απάντηση #206 στις: Τετάρτη, 21 Σεπ 2011, 20:21:52 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    JU 87B-2 STUKAS
    JU 87B-2 STUKAS
    JU 87B-2 STUKAS Περιγραφή Προϊόντος  Specification  Wing  Span(mm / in.)34”(863.6mm) Length(mm / in.)28.43”(722mm) Wing Area(sq. dm² / …
    64.00€
    SUKHOI 3D PROFILE BRUSHLESS MOTOR
    SUKHOI 3D PROFILE BRUSHLESS MOTOR SUKHOI 3D PROFILE BRUSHLESS MOTOR TT 4347K21 Γρήγορη Επισκόπηση Ένα οικονομικό 3D αεροπλάνο που συνδυάζει τόσο …
    89.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #207 στις: Παρασκευή, 7 Οκτ 2011, 09:40:52 »
    MINTOR & SEBART
    Su26M EP ARTF Black Horse
    Su26M EP ARTF       Black Horse   Designed and built in the U.S.S.R. and taking its maiden flight in 1984, the SU-26 is a single…
    149.00€
    Edge ARTF Black Horse
    Edge ARTF        Black Horse           Get ready to be impressed by the new Black Horse Edge ARTF. Just like the full-size, this …
    184.00€
    Extra 330L ARTF Black Horse
    Extra 330L ARTF Black Horse A classic shape with performance and quality to match. Sometimes, you just want a reliable, general …
    188.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #208 στις: Παρασκευή, 14 Οκτ 2011, 12:09:55 »
    MINTOR & SEBART
    A30-10 XL
    A30-10 XL V2 Technische Daten: Leistungsbereich max. 650W (15 sec.) Leerlaufstrom bei 8,4V 1,9A Innenwiderstand 0,024 Ohm Leerlaufdreh…
    79.00€
    JETImodel MAX BEC
    JETImodel MAX BEC  MAX BEC can be supplied either by NiXX or LiXX cells, recommended is 2 LiXX cells or 5-6 NiXX cells. Input voltage is indicat…
    35.00€
    MINTOR 33cc New
    New MINTOR 33cc The first of a new line of powerful and reliable engines... At the right price!! Engine 33cc, barrill, spacers, ignition, NGK plug E…
    295.00€
    SAVÖX SC-1256TG
    Beschreibung: Digitalservo der neuen Generation mit neu entwickeltem Glockenanker-Motor, Gehäuse teilweise aus Alu, Titanium-Getriebe, 2 x Kug…
    62.00€
    X-Pro-USB-Interface
    X-Pro-USB-Interface V2, geeignet für die X-Pro Reglerserie inkl. Win7 64bit
    13.00€
    6ch Combo 2.4GHz (N-Tx) M2 R617FS
    The 6EXP is Futaba's entry-level 2.4GHz aircraft/helicopter system and utilises the highly advanced FASST (Futaba Advanced Spread Spectrum Technolog…
    149.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #209 στις: Κυριακή, 16 Οκτ 2011, 21:19:07 »
    MINTOR & SEBART
    MINTOR 38cc New
    316.00€
    rcmodelshop.gr
    Σελίδες: 1 ... 11 12 13 [14] 15 16 17 ... 20     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: Samos Model center
    Δημιουργία σελίδας σε 0.051 δευτερόλεπτα. 28 ερωτήματα.
