Δευτέρα, 19 Οκτ 2026, 07:15:48
    Online σήμερα: 46
    Επισκέπτες: 43
    Συνολικά: 45
    Σελίδες: 1 ... 7 8 9 [10] 11 12 13 ... 20     Κάτω
    Αποστολέας Θέμα: Samos Model center  (Αναγνώστηκε 208531 φορές)
    samosrc
    « Απάντηση #135 στις: Σάββατο, 23 Οκτ 2010, 09:34:49 »
    ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    SEBART
    Hobby King L1 In-flight Voltage Logger & Health Analyzer (1-6S) The L1 in-flight voltage logger and health analyzer records and instan…
    25.00€
    Male JST-XH Female Thunderpower 6S 5cm (5pcs/bag)
    Male JST-XH <-> Female Thunderpower 6S 5cm (5pcs/bag) Male JST-XH <-> Female Thunderpower 6S (5cm) The JST-XH plug is used on…
    6.00€
    Female JST-XH Male Thunderpower 2S 5cm (5pcs/bag)
    Female JST-XH <-> Male Thunderpower 2S 5cm (5pcs/bag) Female JST-XH <-> Male Thunderpower 2S 5cm (5pcs/bag) Female JST-XH <…
    4.00€
    Turnigy nano-tech 3300mah 3S 25~50C Lipo Pack
    Turnigy nano-tech 3300mah 3S 25~50C Lipo Pack More than just a fancy name. TURNIGY nano-tech lithium polymer batteries are built with an L…
    38.00€
    Turnigy nano-tech 3300mah 6S 25~50C Lipo Pack
    Turnigy nano-tech 3300mah 6S 25~50C Lipo Pack More than just a fancy name. TURNIGY nano-tech lithium polymer batteries are built with an L…
    76.00€
    Turnigy nano-tech 460mah 3S 25~40C Lipo Pack
    Turnigy nano-tech 460mah 3S 25~40C Lipo Pack More than just a fancy name. TURNIGY nano-tech lithium polymer batteries are built with an Li…
    8.00€
    Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack
    Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack More than just a fancy name. TURNIGY nano-tech lithium polymer batteries are built with an L…
    24.00€
    Turnigy 2650mAh 4S 30C Lipo Pack
    Turnigy 2650mAh 4S 30C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sa…
    36.00€
    Turnigy 500mAh 3S 20C Lipo Pack
    Turnigy 500mAh 3S 20C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sai…
    8.00€
    Carbon Fiber servo arm 53mm (2pcs/bag)
    Carbon Fiber servo arm 53mm (2pcs/bag) Improve your control surface response with Carbon fiber servo arm extensions!  Carbon fiber serv…
    5.00€
    Carbon Fiber servo arm 40mm (2pcs/bag)
    Carbon Fiber servo arm 40mm (2pcs/bag) Improve your control surface response with Carbon fiber servo arm extensions!  Carbon fiber ser…
    5.00€
    Carbon Fiber servo arm 65mm (2pcs/bag)
    Carbon Fiber servo arm 65mm (2pcs/bag) Improve your control surface response with Carbon fiber servo arm extensions!  Carbon fiber ser…
    5.00€
    Carbon Fiber servo arm 58mm (2pcs/bag)
    Carbon Fiber servo arm 58mm (2pcs/bag) Improve your control surface response with Carbon fiber servo arm extensions!  Carbon fiber ser…
    4.00€
    Turnigy Typhoon 450H 2218H Heli Motor 3450kv (450 class)
    Turnigy Typhoon 450H 2218H Heli Motor 3450kv (450 class) Turnigy Typhoon 2218H Brushless 450-Size Heli Motor 3450kv   Specificatio…
    19.00€
    Carbon Fiber Tail Blade 95mm
    Carbon Fiber Tail Blade 95mm Carbon Fiber tail blades with balanced tip. Spec; Length: 95mm Weight: 6g each Grip : 5mm
    6.00€
    Carbon Fiber Tail Blade 68m
    5.00€
    Carbon Fiber Tail Blade 107mm Follow HobbyKingLive on Twitter C
    Carbon Fiber Tail Blade 107mm Carbon Fiber tail blades with balanced tip. Spec; Length: 107mm Weight: 8g each Grip : 5mm
    7.00€
    P-SBL251Servo Brushless - Heli 0.06s/3.8Kg
    P-SBL251Servo Brushless - Heli 0.06s/3.8Kg Supplied as standard with the superb GY611 gyro, the BLS251 is a dedicated ultra high performance tai…
    99.00€
    8ch Rx 2.4GHz (FS/HS Mode)
    This 8ch receiver from Futaba differs from all previous receivers because it can run on 2 modes. There is a "Normal Mode" where the re…
    119.00€
    4.8v 2000mAh Eneloop Rx Pk Sq
    4.8v 2000mAh Eneloop Rx Pk SqSuperb charge retention - 90% after 6 months, and 85% even after a year, so no need for regular charging to aviod permane…
    16.00€
    3/32"(2.3mm) Fl.Grn/Yel/Ora 3x750mm
    Ripmax Silicone Tube is tough, extra flexible and heat resistant. This material has great resistance to kinking and it will not h…
    3.50€
    3/32"(2.3mm Bore Silicone Blue - 1M
    A range of quality silicone tube in three internal diameters to suit the majority of engine installations. Use the coloured silic…
    1.50€
    O.S. Glowplug Type 'LC3' (Hot)
    7.00€
    O.S. Glowplug No 6 (A3) Hot
    6.00€
    O.S. Glowplug No 10 (A5)Cool
    9.00€
    Black Horse Yak-54 - 120 ARTF
    Not for the faint hearted, the all new Black Horse Yak-54 120 is all set to increase your pulse rate! Designed for popular 1.20 size engines, th…
    259.00€
    Pro-Peak AC/DC Delta 3(2/3.5/5A)Chg
    28.00€
    Power Supply 240>13.8v20A AutoEur
    The ProPeak 13.8v power supply is a high quality switch mode power supply with a particularly smooth output current, making it su…
    46.00€
    Multi Function Charge lead
    Ever wanted to charge a battery and found that you do not have the right lead or have lost it? Well, here’s the answer! This single lead has mos…
    8.00€
    Wings carryng bags 50 clas
    Wings carryng bags 30 clas
    25.00€
    http://www.rcmodelshop.gr/index.php?main_page=products_new&zenid=df2c8fec629e0d39db5195d73bea4c5b
       ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΣΕ ΟΛΗ ΤΗΝ ΕΛΛΑΔΑ
    « Τελευταία τροποποίηση: Πέμπτη, 18 Νοε 2010, 08:58:46 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #136 στις: Τετάρτη, 3 Νοε 2010, 20:33:43 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    873 Silencer 40/46SF/FX
    24.00€
    Deluxe Ball Link Pliers
    15.00€
    Compass Cutter w/6 x Spare Blades
    The Compass Cutter allows you to cut circles in soft materials from 1~15mm diameter.
    4.00€
    K&S Tubing Cutter
    If you're still rolling tube under a knife blade to cut it, try the easy way and use a K & S Tubing Cutter. Perfect for cutti…
    11.00€
    Sull. 2mm Gold-N-Rod (Flexible) 36"
    Temperature stabilised to minimise thermal expansion, easy to install and adjust, lasting the life of the model.
    9.00€
    Y-Junction Servo Lead
    This neat 'Y' lead is ideal for connecting two servos to one receiver output, such as two buggy steering servos and individual ai…
    9.00€
    9C Adaptor lead for Simulators
    Great Planes RF Transmitter Adaptor (Square): New Futaba, 9C, 4th. This is the RealFlight Airtronics Transmitter Adapter Cord For…
    11.00€
    Only one word can describe the FANTOM... Amazing!! It's a hig
    Only one word can describe the FANTOM... Amazing!! It's a high performance, lightweight foam delta that assembles quickly and has an awesome fli…
    119.00€
    Great Planes PBY Catalina EP ARTF
    Accurately recreating the look of the 1930s–era naval military/sea rescue plane, the Great Planes PBY Catalina features a lightweight hand…
    189.00€
    Freewing SU-34 EDF VT ARTF-Blu Camo
    Topping the extensive range of EDF jets from Freewing is the awesome SU-34 EDF VT. This has to be the best specified electric jet in its class! …
    328.00€
    Flying Legends M.Series - Mustang
    With all the character of the original, this lightweight model comes factory finished and almost ready to fly - with a powerful brushless motor …
    66.00€
    P-51 Mustang EP 600 ARTF
    P-51 Mustang EP 600 ARTF     e: Using the same construction and coverin…
    119.00€
    Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec
    Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec Weight: 13.4g Dimension: 22.8*12.2*28.5mm Stall torque: 1.8kg/cm (4.8V) - 2.2kg/cm …
    7.00€
    Turnigy 3600mAh 2S 30C Lipo Pack
    Turnigy 3600mAh 2S 30C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sa…
    29.00€
    Turnigy 2650mAh 2S 40C Lipo Pack
    Turnigy 2650mAh 2S 40C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sa…
    21.00€
    Turnigy 4000mAh 2S 30C hardcase pack
    Turnigy 4000mAh 2S 30C hardcase pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at th…
    25.00€
    Turnigy 1800mAh 2S 40C Lipo Pack
    Turnigy 1800mAh 2S 40C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sa…
    15.00€
    Turnigy 1600mAh 2S 20C Lipo Pack
      Turnigy 1600mAh 2S 20C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at…
    12.00€
    TopFuel LiPo 30C 3800mAh 3S
    TopFuel LiPo 30C 3800mAh 3S Artikel-Nr.:  23800351 Beschreibung: Unsere TopFuel Akkus sind in dem jeweiligen Anwendungsber…
    65.00€
    « Τελευταία τροποποίηση: Σάββατο, 20 Νοε 2010, 06:27:13 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #137 στις: Σάββατο, 20 Νοε 2010, 06:44:02 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    HK-450GT CCPM 3D Full Alloy Helicopter Kit (Align T-Rex Compat.)
    74.00€
    DLA-56 56cc Gas Engine 5.6HP/7600RPM
    389.00€
    Futaba FASST Compatible 8Ch 2.4Ghz Receiver
    34.00€
    Align Super Starter for Aircraft (HFSSTQ02T)
    Align Super Starter for Aircraft (HFSSTQ02T) View Larger Image Price: £76.99 inc. V.A.T. Quantity available: 2 Qty Add to My Wish List Produ…
    88.00€
    T-REX 550E ComboKX021005
    Focus Shot1(Newly designed aerodynamically efficient metal main blade control system) Focus Shot2(Dual section battery mount) Focus Shot3(New lig…
    689.00€
    T-REX 250 Super Combo with Gyro gp780 KX019001A)
    Focus Shot1(High precision main rotor assembly)Focus Shot2(3.5mm high density carbon steel main shaft)Focus Shot3(Center of gravity of battery tray d…
    242.00€
    T-REX 250 Combo without gyro (KX019001A)
    169.00€
    T-REX 450 PRO Combo - (KX015073)
    Focus Shot1(High precision main rotor assembly)Focus Shot2(High precision bearing mixing arms)Focus Shot3(Single piece battery mount with integrated …
    249.00€
    HPI SAVAGE 3.5 (.21) - RC MONSTER TRUCK RTR
    The new updated HPI Savage 3.5 - RC Monster Truck RTR is based on the classic Savage 21 that has proven its power, performance, durability and streng…
    310.00€
    HPI E10 Drift
    The E10 from HPI Racing is an entry level 1/10th scale electric car designed for fun driving with realistic looks and performance, all at a low price…
    160.00€
    Hpi Crawler King RTR
    HPI makes getting right into crawling simple and fun with the excellent Crawler King truck kit! With its tall Rock Grabber tyres, heavy beadlock wheel…
    285.00€
    TX 10CG R6008HS DRY (2,4G)
    10CG 10-Channel 2.4GHz Computer System The 10CG: pro-level features at a sport-system price. The 10CG is perfect for the price-conscious pilot …
    445.00€
    Turnigy 2200mAh 6S 30C Lipo Pack
    Turnigy 2200mAh 6S 30C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sa…
    39.00€
    Turnigy 2200mAh 4S 35C Li…
    Turnigy 2200mAh 4S 35C Lipo Pack
    Turnigy 2200mAh 4S 35C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sa…
    38.00€
    [/center]
    « Τελευταία τροποποίηση: Τετάρτη, 24 Νοε 2010, 20:57:16 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #138 στις: Τετάρτη, 24 Νοε 2010, 21:12:41 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    [/color]
    DOUBLE SIDE TAPE 1mm/460*75mm
    3.00€
    KYOSHO RACING TOOL BAGYKW100 Pro Line Tools LRP Tools Dynamite* Machined Hex Driver Set Metric of 4. THERMOMETER mini DEEP CAVITY PLUS-SHAPE WREN…
    16.00€
    LiPo Safe 23x30 cm
    Description: The perfect tool for your LiPo batteries. No matter if charging or storing – in the new safety bag your batteries will be in save h…
    19.00€
    GX61 4242B
    74240B-GX40 74251B-GX52 74244-GX70F 74245-GX91
    118.00€
    Zap OdorlessPT25* Zap-O Odorless / 20gram
    9.00€
    Zap Kicker Aerosol PT15 +*2 oz.(56.7gr)
    6.00€
    P-51D MUSTANG 90
    P-51D MUSTANG 90 No.11892   ARF Kit □Available : Available in Mar 2009 ※PROTOTYPE Experience the realism…
    289.00€
    ι
    SQS WARBID FOCKE WULF FW190
    FOCKE WULF 50A 50-class reproduction of the famous German fighter. Retracts and flaps accurately recreate the flight style of the original. Regarded a…
    169.00€
    CURTISS P40 WARHAWK 50
    CURTISS P40 WARHAWK 50Rotating retracts and flaps recreate the magic of the CURTISS P40 WARHAWK. Fly one of WWII’s most famous combatants with this im…
    169.00€
    P-51D MUSTANG p-51d mustang w/landi
    P-51D MUSTANG 4040 CLASS ENGINE POWERED WARBIRD SCALE AIRCRAFT The mighty P-51D fighter plane of WWII flies again as an ARF model. Lightweight finish …
    169.00€
    MESSERSCHMITT Bf109E VE29 PIP
      Discover the fascination of air flight! The ultimate in miniature scale form. Advanced technology built into a PIP set that delivers…
    159.00€
    PIPER J3 CUB VE29 Readyset
    You are here: RC MODELS | RC PLANES | aiRium aiRium Μοιράσου το στο Facebook PIPER J3 CUB VE29 Readyset Inspirational! Spectacular scale form in minia…
    169.00€
    SWING
    SWINGNow it's easy to learn sharp and dynamic flight styles. Pre-assembled high Performance hand-launch glider. The SWING proves that hand-launch glid…
    79.00€
    EP JET F-22 RAPTOR DF55 PIP
    EP JET F-22 RAPTOR DF55 PIPFly your own version of this leading edge jet fighter! PIP kit with three pre-installed micro-servos make jet flight easy! …
    139.00€
    EP JET F4 PHANTOM DF55 PIP
    EP JET F4 PHANTOM DF55 PIP Fly the jet fighter that ruled the skies across the world for a generation! PIP kit locked and loaded with 2 servos makes r…
    159.00€
    CLIPPED WING CUB M24
    CLIPPED WING CUB M24For those who want to fly scale planes from the beginning. Realistic scale form and beginner-friendly flight is a dream come true.…
    109.00€
    PIPER J3 CUB M24 ReadySet
    PIPER J3 CUB M24 ReadySetGet flight right, from the very first take-off and without any fuss with this J-3 Cub ReadySet ! Experience the simple but fa…
    109.00€
    SPREE SPORT
    SPREE SPORTIndividualistic sporty contours with a high altitude action. Optimum plane for new low-wing stunt fliers! With its slightly retro styling, …
    99.00€
    Calmato ST EP 1400
      Calmato ST EP 1400 If you're ready to step up to a low wing stunt plane, the CALMATO ST EP 1400 is the perfect choice. This optimally balanced airpl…
    119.00€
    INFERNO GT2 CORVETTE C6-R
    Μοιράσου το στο FacebookINFERNO GT2The Inferno GT that brought user-friendly 1/8 Touring Cars to the world has evolved into the GT2! Longer wheelbase…
    399.00€
    INFERNO MP7.5 Mk 4
    INFERNO MP7.5 Mk 4Readyset Ref: 31279T1-BKyosho's New Verion Inferno MP-7.5 Sports 3 Readyset shares many features with its World Championship winning…
    279.00€
    DBX 1/10 Racing Buggy
    DBX 1/10 Racing Buggy Center shaft drive 4WD low CG chassis with three differentials. Equipped with digital servos for great response. Dirt-proo…
    248.00€
    LAZER ZX 5 Readyset
    LAZER ZX 5 Readyset Readyset brings world-beating racing technology to your fingertips! Get your hands on a dominant racing machine, at an affordable …
    199€
    rcmodelshop.gr
    samosrc
    « Απάντηση #139 στις: Πέμπτη, 2 Δεκ 2010, 09:32:19 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Soldering Iron - 30w w/fitted Plug
    11.00€
    Fibreglass Cloth - 24g/0.6oz. 2MSq
    Fibreglass Cloth - 24g/0.6oz. 2MSq Glass cloth for either laminating or finishing. Specially coated for superior 'wetting out' an…
    12.00€
    Fibreglass Cloth - 34g/1oz. 1MSq
    Glass cloth for either laminating or finishing. Specially coated for superior 'wetting out' and strength, suitable for use with b…
    8.00€
    Radio Case - Futaba 2x Tx
    69.00€
    CF-Card 12Z/14MZ/FX40 (128MB) Supplied as standard with the Futaba 14MZ and FX40 systems, this 128MB Data-Pak offers great amounts fo…
    65.00€
    Crystal/CAMPac Case Made from hard black plastic with a high density foam insert, the Futaba Crystal Case is the perfect way to p…
    8.00€
    Sullivan DynaTron Starter
    108.00€
    Sullivan Alum. Fuel Tank Stopper
    Sullivan Alum. Fuel Tank Stopper All the components required to complement the Sullivan range of fuel tanks. A wider bore feed pi…
    17.00€
    Glowstart w/Chgr - 2100mAh
    Glowstart w/Chgr - 2100mAh Ripmax Glowstart w/Chgr - 2100mAh L-RMXGS2100   A basic 2100mA glowstart. Supplied with appr…
    19.00€
    Flight Box (Kit)
    Flight Box (Kit) A low cost flight box, supplied complete with adjustable models stand, a single drawer, space for a fuel bottle,…
    28.00€
    Great Planes Compact E-Box
    Great Planes Compact E-Box An easy-access compartment holds most maintenance-free 12V hobby batteries. Once the handle is install…
    27.00€
    Great Planes Ultra E-Box
    The perfect electric flight carry-all! Ready to use right out of the box. Factory-finished and prebuilt from light, strong laser-…
    59.00€
    Sullivan Genesys -R/C On/Off Switch
    69.00€
    SAVÖX SC-1258TG
    Servo SAVÖX SC-1258TG Item no.:  80101001   Beschreibung: Digitalservo der neuen Generation mit neu entwickeltem G…
    57.00€
    SAVÖX SC-0254MG
    Servo SAVÖX SC-0254MG Item no.:  80101005   Beschreibung: Digitalservo der Größe Standard, Metall-Getrie…
    28.00€
    SAVÖX SH-0254
    Servo SAVÖX SH-0254 Item no.:  80101006 RRP:3) 15,88 EUR (excl. VAT) So you save at our shop: 25 % Availability: (Deliver…
    18.00€
    TopFuel LiFe 30C 3100mAh 3S
    TopFuel LiFe 30C 3100mAh 3S Item no.:  43100351 RRP:3) 49,58 EUR (excl. VAT) So you save at our shop: 25 % Availability: (Deli…
    53.00€
    TR 35-48-C 800kv Brushless Outrunner Eq: AXi 2826
    TR 35-48-C 800kv Brushless Outrunner Eq: AXi 2826 TURNIGY AerodriveXp Model : TR35-48-B Input Voltage : 7.4V~18.5V (2~5S Li-po) Kv : 800 r…
    23.00€
    Futaba/JR Connector caps (5pcs/set)
    Futaba/JR Connector caps (5pcs/set) A great way to hold your servo plugs in place. Great for servo extensions, especially those that get …
    4.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #140 στις: Σάββατο, 4 Δεκ 2010, 06:58:27 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    6ch Combo 2.4GHz (N-Tx) M…
    6ch Combo 2.4GHz (N-Tx) M2 R617FS
    The 6EXP is Futaba's entry-level 2.4GHz aircraft/helicopter system and utilises the highly advanced FASST (Futaba Advanced Spread…
    149.00€http://www.rcmodelshop.gr/index.php?main_page=index&cPath=73&zenid=df2c8fec629e0d39db5195d73bea4c5bSERVO S3003 BULK 3,2 kg
    4.8V or 6.0VDimension
    4.8V or 6.0VDimension 40.4 mm x 19.8 mm x 36.0 mm Weight 37.2 g Operating Speed 0.23 sec/60° (4.8V) 0.19 sec/60° (6.0V) Output torque 3.2 kg-cm (4.8V)…
    11.00€
    Aluminium Field Box
    Aluminium Field Box
    High quality, super-strong aluminium tote box with heavy duty construction and large enough to carry one or two transmitters and …
    34.00€
    GLOW PLUG NO.8
    GLOW PLUG NO.8
    GLOW PLUG NO.8 The O.S. #8 glow plug is the most widely used O.S. glow plug. Recommended for most current O.S. (and other brands of) 2-stroke R/C engi…
    6.00€
    MAX-46AX(40G) W/E-3070 SI…
    MAX-46AX(40G) W/E-3070 SILENCER
    This is the O.S. Max .46AX ABL BB Model Airplane Engine with Muffler.      Ideally suited to a variety of R/C aircraft including trainer, sports     …
    [imghttp://www.rcmodelshop.gr/images/make4444thumb.jpg]http://[/img]
    125.00€
    MAX-55AX W/E-3070 SILENCE…
    MAX-55AX W/E-3070 SILENCER
    MAX-55AX W/E-3070 SILENCER MAX-55AX   For scale and sport models   Displacement 8.93cc(0.545cu.in) Output 1.7ps/16,000r.p.m. …
    138.00€
    SERVO DIGI S9254 3,4Kg/0,…
    SERVO DIGI S9254 3,4Kg/0,06sec
    SERVO DIGI S9254 3,4Kg/0,06sec S9254 High-speed servo for GY240/401/502 gyros NiCd only 4.8V only Dimension 40.0 mm x 20.0 mm x 36.6 mm Weight 49 g Op…
    85.00€ 69.00€
    Έκπτωση: 19%
    Futaba R617FS FASST 2.4Gh…
    Futaba R617FS FASST 2.4Ghz receiver
    Futaba R617FS FASST 2.4Ghz receiver FEATURES: High sensitivity receiver weighs only .25oz (7g) without case yet is a full range system for all aircraf…
    89.00€  59.00€
    Έκπτωση: 34%
    TopFuel LiPo 20C 3400mAh …
    TopFuel LiPo 20C 3400mAh 3S
    TopFuel LiPo 20C 3400mAh 3S Artikel-Nr.:  73400331 Beschreibung: Unsere TopFuel Akkus sind in dem jeweiligen Anwendungsbereich heiß bege…
    49.00€
    « Τελευταία τροποποίηση: Σάββατο, 4 Δεκ 2010, 07:16:48 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #141 στις: Δευτέρα, 6 Δεκ 2010, 17:00:20 »
    MINTOR & SEBART
    ΠΡΟΣΦΟΡΕΣ
    15%-
     ΟΛΑ ΤΑ ΗΛΕΚΤΡΗΚΑ - ΘΕΡΜΙΚΑ-ΑΕΡΟΠΛΑΝΑ
    http://www.rcmodelshop.gr/index.php?main_page=index&cPath=1_6
    http://www.rcmodelshop.gr/index.php?main_page=index&cPath=1_7
    rcmodelshop.gr
    samosrc
    « Απάντηση #142 στις: Πέμπτη, 16 Δεκ 2010, 06:53:45 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    EASY STAR W/X16 SPEED CONTROL MOTORS & SERVOS MUL 264292 Γράψτε πρώτος μια αξιολόγηση για αυτό το προϊόν Πρόσθεση στα Επιθυμητά| Πρόσθεση στ…
    119.00€
    EASYCOPTER V4 COLIBRI SHERIFF MUL 272831
    Περισσοτερες Οψεις EASYCOPTER V4 COLIBRI SHERIFF MUL 272831 Γράψτε πρώτος μια αξιολόγηση για αυτό το προϊόν Πρόσθεση στα Επιθυμητά| Πρό…
    110.00€
    Great Planes Yak-55 EP ARTF
    Huge control surfaces and all flying tail for massive 3D power! The Yak 55 3D ARF dispels the myth that an expensive brushless motor system is n…
    59.00€
    Carrera Exclusiv Le Mans Champ 20320
     Carrera Exclusiv Le Mans Champ 20320 RARITÄT!!! Rennbahn ist Neu & OVP und wir seit 2002 nicht mehr ausgeliefert, daher sehr gesucht!!! …
    199.00€
    14ch Combo 2.4GHz M2 R6014HS
    The world renowned Futaba14MZ becomes yet more appealing as it is now available in 2.4GHz format, using Futaba's highly developed FASST frequenc…
    1,890.00€
    Minium AD Piper Cherokee Readyset (Blue)
      < Readyset Contents > Fully assembled airplane 3.7V-70mAh Lithium Polymer battery pack PERFEX KT-20 2.4GHz 2-stick transmitter…
    139.00€
    Flybaby Readyset (Red)
      < Readyset Contents > Fully assembled fuselage 3.7V-70mAh Lithium Polymer battery pack Dual-purpose airplane stand with built-…
    99.00€
    Cessna 210 Centurion Readyset
      < Readyset Contents > Fully assembled fuselage 3.7V-70mAh Lithium Polymer battery pack Combination display stand with auto-cut…
    99.00€
    Extra 300-88" 2,23m - Red/White
    Extra 300-88" 2,23m - Red/White Description: Extra 300-88" 2,23m - Red/White Recommended Drives: 10S Setup A80-10MasterSPIN 125 OPTO27x12 E…
    699.00€
    Extra 300-88" 2,23m - Blue/Yellow
    Extra 300-88" 2,23m - Blue/YellBeschreibung: Extra 300-88" 2,23m - Blau/Gelb Empfohlene Antriebskombinationen: 10S Setup A80-10MasterSPIN 1…
    699.00€
    Edge 540-88" 2,23m - Red/White/Blue
    Edge 540-88" 2,23m - Red/White/Blue Description: Edge 540-88" 2,23m - Red/White/Blue Attention! Beacuse of the big size of this airplane, w…
    699.00€
    Edge 540-88" 2,23m - Blue/Yellow/Silver
    Edge 540-88" 2,23m - Blue/Yellow/Silver Item no.:  70001289   Description: Edge 540-88" 2,23m - Blue/Yellow/Silver Attention! Beacu…
    699.00€
    CNC Transmitter Stand V1 Black
    CNC Transmitter Stand V1 Black CNC Transmitter Stand V1 Black Material: aluminium 6061-T6 (anodized) Weight: 50g Applies to: Aurora 9, FF9…
    29.00€
    Turnigy 3000mAh 5S 30C Lipo Pack
    Turnigy 3000mAh 5S 30C Lipo Pack The new number one in performance and price! The new Turnigy Lipoly packs deliver full capacity at the sa…
    56.00€
    Nylon T-Connectors 10 Pairs (20pc)
    Nylon T-Connectors 10 Pairs (20pc) Nylon T-connectors. Pack includes 10 male and 10 female connectors. ALERT! These connectors are made fr…
    6.00€
    Parallel charging Board for 6 packs 2~6S
    Parallel charging Board for 6 packs 2~6S Charge SIX (2~6S) lipo packs with same capacity & cell count simultaneously with this paral…
    16.00€
    Replacement CDI Ignition for FTL Engines
    Replacement CDI Ignition for FTL Engines Replacement CDI Ignition for FTL Engines. TIP: Before suspecting your CDI ignition of being fault…
    44.00€
    MEGA-ADAPTER. Connect almost anything to anything!
    MEGA-ADAPTER. Connect almost anything to anything! Now you can connect your XT60, Traxxas, Tamiya, EC3 or Deans T-connector to any type of…
    7.00€
    HPI Savage X 4,6 (Reverse) με Oπισθεν - Hpi Racing
    Μεγαλύτερη εικόνα Μεγαλύτερη εικόνα HPI Savage X 4,6 (Reverse) με Oπισθεν - Hpi Racing Τιμή: 550.00€ Τιμή Προσφοράς : 475.00€ Έκπτωση: 14% …
    475.00€
    ST Model Discovery ARTF Trainer
       ST Model Discovery ARTF Trainer        The ST model Discovery is all about learning to fly radio control model aircraft for the very first ti…
    169.00€
    « Τελευταία τροποποίηση: Σάββατο, 18 Δεκ 2010, 22:29:09 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #143 στις: Σάββατο, 18 Δεκ 2010, 22:31:50 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    119.00€
    110.00€
    59.00€
    199.00€
    1,890.00€
    139.00€
    99.00€
    99.00€
    699.00€
    699.00€
    699.00€
    699.00€
    29.00€
    56.00€
    6.00€
    16.00€
    44.00€
    7.00€
    475.00€
    129.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #144 στις: Πέμπτη, 23 Δεκ 2010, 19:57:13 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    99.00€
    99.00€
    Merlin Expert 10% nitro 1lt
    15.00€
    13.00€
    10.00€
    P-S9157 Servo Digital-Power 0.14s/30.6Kg
    P-S9157  Servo Digital-Power 0.14s/30.6Kg Developed for large scale aircraft, this servo offers over 30Kg.cm of torque and excell…
    112.00€
    P-S9452 Servo Coreless-Digital 0.11s/9.2Kg
    P-S9452 New, high speed, high torque Futaba digital servo that replaces the popular P-S9451. With an incredible 0.11s/60° speed a…
    73.00€
    H45021 Feathering Shaft
    6.00€
    HS1132 Carbon Tail Rotor Blade Set/3K
    HS1132 HS1132 Carbon Tail Rotor Blade Set/3K
    8.00€
    H45055 Torque Tube Front …
    H45055 Torque Tube Front Drive Gear Set
    11.00€
    H45022 Main Shaft
    9.00€
    Flybar Rod/220mm HS1264
    6.00€
    HS1192 Flybar Paddle
    4.00€
    HS1271T
    4.00€
    Irvine Super Z-Bend Plier w/Nav.Pin
    18.00€
    P.H. FS 52AR-4T MOTOR
    HERSTELLERARTIKELNUMMER: PHFS52AR KATALOGSEITE: 434 ALLGEMEINE BESCHREIBUNG: "P.H." 2- und 4-Takt Motoren. Bekannte und bewährte Quali…
    129.00€
    127.00€
    110.00€
    59.00€
    199.00€
    1,890.00€
    139.00€
    « Τελευταία τροποποίηση: Πέμπτη, 23 Δεκ 2010, 20:11:32 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #145 στις: Σάββατο, 25 Δεκ 2010, 11:42:27 »
    MINTOR & SEBART
    ΧΡΟΝΙΑ ΠΟΛΛΑ  ΧΡΙΣΤΟΥΓΕΝΝΙΑΤΙΚΕΣ ΕΥΧΕΣ
     ΕΥΧΕΣ ΓΙΑ ΤΟ ΝΕΟ ΕΤΟΣ
    rcmodelshop.gr
    samosrc
    « Απάντηση #146 στις: Κυριακή, 26 Δεκ 2010, 20:33:04 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    rcmodelshop.gr
    samosrc
    « Απάντηση #147 στις: Τρίτη, 28 Δεκ 2010, 13:35:42 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    OrangeRx Spektrum DSM2 Compatible 6Ch 2.4Ghz Receiver
    11.00€
    Compatible with all Spektrum DSM2 Air transmitters.
    The new range of OrangeRx receivers are built using original components and MCUs and with state of the art SMT automation to ensure a quality product each and every time.
    All OrangeRx receivers are QC tested before leaving the factory.
    The OrangeRx will work with ANY Aircraft Spektrum DSM2 2.4Ghz transmitter
    The OrangeRx 6ch is only 3.7g in weight and 19.5x30x10mm in size. Great for small planes, helis, parkflyers or even medium sized sport planes.
    Key features.
    Super light weight 3.7g / 9.8 grams with case.
    Compatible with DSM2 aircraft radio and module systems.
    6 Channels.
    Compact design 19.5mm x 30mm x 10mm, with case 43x22x13mm.
    Short 29mm antennas for mounting in almost any location.
    Input voltage: 3.7~9.6V.
    Satellite port included.
    rcmodelshop.gr
    samosrc
    « Απάντηση #148 στις: Παρασκευή, 31 Δεκ 2010, 07:47:59 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Katana S 30E Red/Blue Ve…
    Katana S 30E Red/Blue Version
    Katana S 30E  Red/Blue Version Wing Span 125 cm (49.2") Lenght 125 cm (49.2") Weight 1000 gr (+/- 2,20 lb) Engine: Hacker A30 Download full …
    179.00€
    Katana S 30E Yellow Versi…
    Katana S 30E Yellow Version
    Katana S 30E Yellow Version Wing Span 125 cm (49.2") Lenght 125 cm (49.2") Weight 1000 gr (+/- 2,20 lb) Engine: Hacker A30 Download full PRI…
    179.00€
    Katana S 50E Wellow/Black
    Katana S 50E Wellow/Black Outdoor electric 3D acro, ready to fly, with all accessories. Wing Span 57,84 in Lenght 57,84 in Weight 79,36 oz less batt.…
    219.00€
    Sebach 30E Yellow/Black …
    Sebach 30E Yellow/Black Version
     Sebach 30E - NEW! White/Blue Version - Yellow/Black Version Acrobatico elettrico 3D outdoor, pronto al volo, completo di tutti gli accessor…
    199.00€
    Sebart Planes : NEW - Suk…
    Sebart Planes : NEW - Sukhoi 29S 50E V2 Red/Blue
    Sebart Planes  NEW - Sukhoi 29S 50E V2NEW - Sukhoi 29S 50E V2 Yellow/Black Version - Red/Blue Version Nuova versione "V2", acrobatic…
    229.00€
    Sebart Planes : NEW - Sukhoi 29S 50E V2 Yellow/Black
    229.00€
    Sebart Sukhoi 29S 140E …
    Sebart Sukhoi 29S 140E Red/Blue
    489.00€
    Shark S 30E Red/Blue
    Shark S 30E  Red/Blue Wing Span 157 cm Lenght 140 cm Wing area: 44dm2 Weight: 1.430gr. RTF without batteries 1.700gr. RTF with 3300-3S Flight Power En…
    199.00€
    Sukhoi 29S 140E Red/Gree…
    Sukhoi 29S 140E Red/Green
    Sukhoi 29S 140E  Red/Green Outdoor 3D acro, 140 class, ready to fly, with all accessories. Wing Span 194 cm Lenght 192 cm Wing area 82 dm2 Weight 4.0…
    489.00€
    Sukhoi 29S 2.2m New Red/B…
    Sukhoi 29S 2.2m New Red/Blue
    Wing Span: cm 218 Lenght w. spinner: cm 212 Wing Area: 92 dm2 Weight: 8.5 Kg RTF dry Recommended power set up: Engine: 50/60 cc Gasoline Recommen
    749.00€
    Sukhoi 29S 2.2m Yellow/Bl…
    Sukhoi 29S 2.2m Yellow/Black
    Wing Span: cm 218 Lenght w. spinner: cm 212 Wing Area: 92 dm2 Weight: 8.5 Kg RTF dry Recommended power set up: Engine: 50/60 cc Gasoline Recommen…
    749.00€
    Sukhoi 29S 30E Red/Blue
    Sukhoi 29S 30E  Red/Blue Specifications Wing Span:……….....130 cm (51,18 in.) Recommended power set up: Length:….......……
    189.00€
    Wind S 50E Yellow/Black V…
    Wind S 50E Yellow/Black Version
    Wind S 50E Yellow/Black Version - White/Blue Version Acrobatico elettrico 3D outdoor, pronto al volo, completo di tutti gli accessori. Outdoor…
    239.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #149 στις: Σάββατο, 1 Ιαν 2011, 21:49:00 »
    MINTOR & SEBART
    Καλά Χριστούγεννα και Καλή Χρονιά, με υγεία, χαρά, οικογενειακή και προσωπική ευτυχία.
    rcmodelshop.gr
    Σελίδες: 1 ... 7 8 9 [10] 11 12 13 ... 20     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: Samos Model center
    Δημιουργία σελίδας σε 0.117 δευτερόλεπτα. 28 ερωτήματα.
