Παρασκευή, 16 Οκτ 2026, 00:15:46
    [Χθες στις 13:50]
    Επισκέπτες: 32
    Συνολικά: 33
    Σελίδες: 1 ... 6 7 8 [9] 10 11 12 ... 20     Κάτω
    Αποστολέας Θέμα: Samos Model center  (Αναγνώστηκε 208268 φορές)
    samosrc
    « Απάντηση #120 στις: Παρασκευή, 10 Σεπ 2010, 10:03:43 »
    ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
    6ch Combo 2.4GHz (N-Tx) M2 R617FS
    149.00€
    The 6EXP is Futaba's entry-level 2.4GHz aircraft/helicopter system and utilises the highly advanced FASST (Futaba Advanced Spread Spectrum Technology) system to give the ultimate in performance and control. Allowing switch on and go operation, and with amazing interference rejection, this set is the standard by which all others are measured. With this set there will be no more waiting for a frequency to become clear, and fellow fliers cannot accidentally shoot you down by mistakenly switching their set on when it is on the same frequency, significantly increasing safety and allowing more flying time at popular flying sites. With the operating frequency changing every two milliseconds, the 2.4GHz FASST system is virtually invulnerable to interference, unlike other less advanced systems that operate on one or two fixed frequencies. Dual antenna diversity selects the best signal from the two receiver aerials, so there is a solid RF link, no matter what the attitude of the model. The tiny R617FS receiver weighs only 9.8 grams (7 grams without case), but is a full range receiver that works every bit as well in normal or giant scale models, allowing simple swaps between models. Unlike other systems there is no separate aerial module that has to be installed, increasing weight and taking up more space. Other features include Pre-Vision Packet Screening Technology that scans the incoming data, and applies sophisticated error correction techniques as well as the Easy Link system which incorporates a unique ID code in the transmitter, which when linked with the R617FS receiver, ensures that only this particular receiver will accept commands from its "paired" transmitter.
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΣΕ ΟΛΗ ΤΗΝ ΕΛΛΑΔΑ
    rcmodelshop.gr
    samosrc
    « Απάντηση #121 στις: Σάββατο, 11 Σεπ 2010, 08:21:52 »
    MINTOR & SEBART
    FOX FERTIGMODELL
    229.00€
    PLANET-HOBBY
    Spannweite:   2620 mm
    Gewicht:   2700g (leer)
    Profil:   RITZ1-30-10
    Steuerung:   H,S,Q,M
    Hersteller:   Planet-Hobby
    Rumpf:   GFK
    Flächen:   Styro/Balsa
    Ausführung:   Fertigmodell
    Flug / Bau:   22
    [/center]
    rcmodelshop.gr
    su 29
    « Απάντηση #122 στις: Τρίτη, 21 Σεπ 2010, 19:22:29 »
    μια και ανοιξα το θεμα το συγχαρητηρίων σε καποιο αλλο θέμα θα ήθελα να πω ενα μεγαλο ευχαριστώ στον ιδιοκτήτη του καταστήματος απο τον οποίο πηρα ενα Sebart Sukhoi 29S 2.2m το οποίο με ντροπή θα πω οτι μετα την πολή μεγαλη εκπτωση μου εκανε βγήκε μονο 80 ευρω ποι ακριβα απο το προηγουμενο no name yak 54.και μαζι με το αεροπλανο πηρα και δωρα αξιας ανω τον 50 ευρω και το βασικοτερο ολα αυτα χωρις δικια μου απαιτηση ουτε στο ψαλιδισμα τις τιμης ουτε απαιτηση για δωρα.αυτο δειχνει σε εμενα εναν ανθρωπο με μερακια και βασικα ΕΠΑΓΓΕΛΜΑΤΙΑ.
    ευχαριστω πολη για ολα.
    Pitts Model 12 15e e-flite
    Fun jet Multiplex
    TREX 550E
    samosrc
    « Απάντηση #123 στις: Πέμπτη, 23 Σεπ 2010, 10:01:36 »
    MINTOR & SEBART
    Futaba Aero Team Transmitter Case Single
    43.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=487&zenid=df2c8fec629e0d39db5195d73bea4c5b
    rcmodelshop.gr
    billiano
    « Απάντηση #124 στις: Πέμπτη, 23 Σεπ 2010, 10:27:07 »
    Η βαλιτσα ειναι τρομερη και σε ποιοτητα και σε τιμη και σε μεταφορικα...
    samosrc
    « Απάντηση #125 στις: Κυριακή, 26 Σεπ 2010, 20:27:16 »
    MINTOR & SEBART
    ΠΡΟΣΦΟΡΑ 4 ΗΜΕΡΩΝ
    HANGAR-9 Piper J-3 Cub 40 ARF
    234.00€  199.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=509&zenid=df2c8fec629e0d39db5195d73bea4c5b
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΣΕ ΟΛΗ ΤΗΝ ΕΛΛΑΔΑ[/color]
    rcmodelshop.gr
    samosrc
    « Απάντηση #126 στις: Τρίτη, 28 Σεπ 2010, 07:07:23 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Acromaster
    119.00€
    CESSNA-177 60 KIT
    121.00€
    ready 40
    72.00€
    FLOATS For Thunder Tiger Cessna 177 Cardinal 3025/1
    45.00€
    EASY GLIDER PRO
    85.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #127 στις: Κυριακή, 3 Οκτ 2010, 21:11:54 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    WOT 4 Foam-E Mk2 ARTF
    149.00€
    This is not just any foam model! It’s a very clever WOT 4 that can be flight ready in under 30 minutes! The beautiful EPO mouldings hide an innovative internal structure that adds strength where needed and locks all the components together. The impressive specification includes a carbon main spar, carbon fuselage spine, shock resistant engine mount, simple battery access and battery retaining moulding, with further carbon reinforcement for the tailplane and ailerons. The four servos, brushless motor and 30A ESC are all pre-installed. Just add a receiver and a 3 cell 2100~2500mAh battery of your choice then let the fun begin!
    http://www.youtube.com/watch?v=Bshw6t-wjhY&feature=player_embedded#!
    rcmodelshop.gr
    samosrc
    « Απάντηση #128 στις: Δευτέρα, 4 Οκτ 2010, 08:50:04 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Black Horse Piper Cub 120 ARTF
    299.00€
    Massive 96.5" wingspan makes this an eye cathcing aircraft even before it takes to the air!!
    The Piper J-3 Cub was a small, simple, light aircraft that was built between 1937 and 1947 by Piper Aircraft. With tandem (fore and aft) seating, it was intended for light training but became one of the most popular and best known light aircraft of all time. For many it was the 'Model T' of the air bringing flight to a whole new generation of people.
    The largest wingspan model in the Black Horse range makes a big presence at the flying field! With a 96.5in span yet only 5kg of weight ensures a really low wing loading for ultra-slow flying and STOL performance.
    With scale wing struts, simulated scale undercarriage and a dummy scale engine, this big Cub needs just a 1.20 four stroke engine to power her but using her as a glider tug may need a little more.
    Construction is conventional balsa/ply covered in Oracover and she dismantles into convenient size parts for transport.
    Recommended EP Conversion:
    • Motor: KMS Quantum 4130/09
    • ESC: KMS Sentry 60
    • Battery: Impulse 6S 4000mAh LiPo
    Specification
    Wingspan:    2450mm (96.46in)
    Length:    1450mm (60.63in)
    Weight:    5kg (11 lbs)
    Radio System:    5 Channel witth 5 servos
    IC Engine:    1.20 Four Stroke / .91 Two Stroke
    rcmodelshop.gr
    samosrc
    « Απάντηση #129 στις: Πέμπτη, 7 Οκτ 2010, 09:26:09 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Black Horse Yak-54 ARTF
    119.00€
    Black Horse Katana 60 ARTF
    139.00€
    ST Model Discovery RTF Trainer 2.4
    199.00€
    http://www.rcmodelshop.gr/index.php?main_page=products_new&zenid=df2c8fec629e0d39db5195d73bea4c5b
    rcmodelshop.gr
    samosrc
    « Απάντηση #130 στις: Πέμπτη, 7 Οκτ 2010, 13:54:37 »
    MINTOR & SEBART
    Futaba Aero Team Transmitter Case Single[/size]
    43.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=487&zenid=df2c829e0d39db5195d73bea4c5bfec6
    rcmodelshop.gr
    samosrc
    « Απάντηση #131 στις: Πέμπτη, 7 Οκτ 2010, 22:09:34 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Futaba R617FS FASST 2.4Ghz receiver
    89.00€ 59.00€
    Έκπτωση: 35%
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=401
    FEATURES: High sensitivity receiver weighs only .25oz (7g) without case
    yet is a full range system for all aircraft from giant scale to
    park flyer applications-no need to buy separate receiver for
    specific aircraft
    Simple one-touch binding - no plugs to mess with or lose
    Dual Antenna Diversity allows 2.4GHz FASST Futaba transmitter to
    select the best reception between the two receiver antennas with no
    signal loss
    Rubber grommets installed where antennas exit to eliminate stress
    and fraying of the two antenna wires
    SPECS: Size: 1.6 x 1.1 x .35" (40 x 27 x 9mm)
    Power Requirement: 4.8 - 6V
    Current Drain: 80mA (at no signal)
    Weight .25oz (7g) without case
    rcmodelshop.gr
    samosrc
    « Απάντηση #132 στις: Σάββατο, 9 Οκτ 2010, 07:17:24 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Freewing F-16 EDF VT ARTF-Grey Camo
    199.00€
    It's all in the detail....and no-one gives you more high level scale detail than Freewing! Accurately moulded from robust EPS foam, the stunning F-16 has an amazing specification. It includes a dual axis 360° vectored thrust unit, factory fitted servos for all flight controls, high performance brushless motor, 70 mm fan, ESC, and a superb factory applied colour scheme with accurate decals. Simply add your choice of Tx, Rx and 4S 2200mAh 20C Li-Po.
    • 360° vectored thrust unit
    • 2750KV brushless motor
    • Factory applied colour scheme
    • ESC and servos included
    Specification
    Wingspan:    800mm
    Length:    1150g
    Weight:    900g
    Servos:    7 x 9g (Inc.)
    Speed Controller:    45A (Inc.)
    LiPo Recommended:    O-IT4S1P250025A
    KV RPM:    2750KV
    EDF Fan Diameter:    70mm
    LiPo:    4S 2200mAh 20C
    Vectored Thrust:    Dual Axis
    Channels:    6
    rcmodelshop.gr
    samosrc
    « Απάντηση #133 στις: Παρασκευή, 15 Οκτ 2010, 09:54:14 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    SUKHOI SU 31 120
    Product Description ARTF SPORT from Balsa wood, Άνοιγμα Φτερών/Wing Span:1790, Βάρος/Weight:4800, SPORT ΑΕΡΟΜΟΝΤΕΛΟ, ΣΧΕΔΟΝ ΕΤΟΙΜΟ ΝΑ ΠΕΤΑΞΕΙ (ART…
    265.00€
    FUTURE 40 3D
    Product Description 3D ARTF from wood balsa, Άνοιγμα Φτερών/Wing Span:1260, Βάρος/Weight:2100, 3D ΑΕΡΟΜΟΝΤΕΛΟ, ΣΧΕΔΟΝ ΕΤΟΙΜΟ ΝΑ ΠΕΤΑΞΕΙ (ARTF) ΚΑΤ…
    130.00€
    PILATUS PC21
    Product Description Aerobatic ARTF from wood balsa, Άνοιγμα Φτερών/Wing Span:1740, Βάρος/Weight:4600 ΑΚΡΟΒΑΤΙΚΟ ΑΕΡΟΜΟΝΤΕΛΟ, ΣΧΕΔΟΝ ΕΤΟΙΜΟ ΝΑ ΠΕΤΑ…
    320.00€
    POWER DRIVE FUN CUB
    117.00€
    POWER DRIVE MENTOR
    POWER DRIVE MENTOR MULl 332641 Γράψτε πρώτος μια αξιολόγηση για αυτό το προϊόν Πρόσθεση στα Επιθυμητά| Πρόσθεση στην Σύγκριση Γρήγορη Επισκόπη…
    165.00€
    FUNCUB
    Περισσοτερες Οψεις FUNCUB MUL 214243 Γράψτε πρώτος μια αξιολόγηση για αυτό το προϊόν Πρόσθεση στα Επιθυμητά| Πρόσθεση στην Σύγκριση …
    109.00€
    Multiplex Mentor
     MENTOR    The ldial forty-size trainer (for a .40 (6.5 cc) glow motor) is still the worlds most popular type of model aircraft. …
    131.00€
    SPITFIRE 60
    Semi scale ARTF from wood balsa, Άνοιγμα Φτερών/Wing Span:1550, Βάρος/Weight:3200 ,ΑΕΡΟΜΟΝΤΕΛΟ ΚΛΙΜΑΚΑΣ ΤΟΥ ΠΡΑΓΜΑΤΙΚΟΥ, ΣΧΕΔΟΝ ΕΤΟΙΜΟ ΝΑ ΠΕΤΑΞΕΙ (AR…
    160.00€
    YAK 54 120
    Product Description Aerobatic ARTF from wood balsa For 120 - engine 4 channel 6 servos Additional Information ΚΩΔΙΚΟΣ ΠΡΟΪΟΝΤΟΣ PH084 ΕΠΙΠΕ…
    265.00€
    YAK 54 40
    Product Description Semi scale ARTF from wood balsa, Άνοιγμα Φτερών/Wing Span:1440, Βάρος/Weight:2600, ΑΕΡΟΜΟΝΤΕΛΟ ΚΛΙΜΑΚΑΣ ΤΟΥ ΠΡΑΓΜΑΤΙΚΟΥ, ΣΧΕΔΟ…
    145.00€
    Aluminium Field Box
    High quality, super-strong aluminium tote box with heavy duty construction and large enough to carry one or two transmitters and …
    34.00€
    Black Horse Spitfire ARTF
    Black Horse Spitfire ARTF A-BH013 Even though it's been designed as a semi-scale model, the Black Horse Spitfire is remarkably close to the true …
    119.00€
    SkyRC IMAX Quattro B6 Charger
    Fed up of being unable to charge more than one or two batteries? What about being unable to charge totally different capacities and chemistries …
    149.00€
    Και πολλά άλλα σας περιμένουν στις χαηλότερες τιμές της αγοράς.
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΓΙΑ ΟΛΗ ΤΗΝ ΕΛΛΑΔΑ
    « Τελευταία τροποποίηση: Σάββατο, 16 Οκτ 2010, 10:31:38 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #134 στις: Τετάρτη, 20 Οκτ 2010, 09:48:04 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    SEBART
    Wind S 50E Yellow/Black V…
    Wind S 50E Yellow/Black Version
    Wind S 50E Yellow/Black Version - White/Blue Version Acrobatico elettrico 3D outdoor, pronto al volo, completo di tutti gli accessori. Outdoor…
    239.00€
    Sukhoi 29S 2.2m New Red/B…
    Sukhoi 29S 2.2m New Red/Blue
    Wing Span: cm 218 Lenght w. spinner: cm 212 Wing Area: 92 dm2 Weight: 8.5 Kg RTF dry Recommended power set up: Engine: 50/60 cc Gasoline Recommen…
    749.00€
    Sebart Planes : NEW - Suk…
    Sebart Planes : NEW - Sukhoi 29S 50E V2 Red/Blue
    Sebart Planes  NEW - Sukhoi 29S 50E V2NEW - Sukhoi 29S 50E V2 Yellow/Black Version - Red/Blue Version Nuova versione "V2", acrobatic…
    229.00€
    Sebart Planes : NEW - Sukhoi 29S 50E V2 Yellow/Black
    229.00€
    Katana S 50E V2 Red/Blue…
    Katana S 50E V2 Red/Blue Version
    Katana S 50E V2 Yellow/Black Version - Red/Blue Version Nuova versione "V2", acrobatico elettrico 3D outdoor, pronto al volo, completo di t…
    219.00€
    Sebach 30E White/Blue Ver…
    Sebach 30E White/Blue Version
     Sebach 30E - NEW! White/Blue Version - Yellow/Black Version Acrobatico elettrico 3D outdoor, pronto al volo, completo di tutti gli accessor…
    199.00€
    « Τελευταία τροποποίηση: Σάββατο, 23 Οκτ 2010, 09:35:49 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    Σελίδες: 1 ... 6 7 8 [9] 10 11 12 ... 20     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: Samos Model center
    Δημιουργία σελίδας σε 0.032 δευτερόλεπτα. 27 ερωτήματα.
