Τετάρτη, 16 Σεπ 2026, 21:13:06
    [Σήμερα στις 14:04]
    [Χθες στις 11:08]
    [Τρίτη, 8 Σεπ 2026, 18:11:18]
    Σύνολο μηνυμάτων: 309978
    Online σήμερα: 105
    Επισκέπτες: 48
    Συνολικά: 49
    Αποστολέας Θέμα: Kopilot Lite flight controller with gps 50 euro  (Αναγνώστηκε 1748 φορές)
    georgeeeee
    « στις: Δευτέρα, 29 Νοε 2021, 14:25:59 »
    γνώμες για το συγκεκριμένο flight controller ?
    έχετε να προτείνετε κα πιο άλλο φτηνό για ενα foam που ετοιμάζω
    ZOHD Kopilot Lite Autopilot System Flight Controller with GPS Module Return Home Stabilization Gyro for FPV RC Airplanes Fixed-wing
    KOPILOT Lite is ZOHD's first Autopilot System. Designed for the fixed-wing RC pilot (FPV and LOS) will give you peace of mind and a feature-rich unit in a very small and light-weight package.
    Picture this:
    You're about to maiden your very expensive EDF jet or super-scale Warbird. You know your nerves can bite you in the rear and have a bad time. KOPILOT Lite will make that maiden way smoother taking care of part of the flying until you get the feel of your new bird, giving you the change to switch it off and have a full manual experience of you beloved machine.
    You're new to FPV and overwhelmed with iNAV settings, bulk files, and hundreds and hundreds of pages of How to's and user manuals. Forget all of that. KOPILOT Lite will give you a super easy setup (literally 10 minutes) and you're off to the field. More time flying, less time researching.
    You're an experienced FPV pilot bugged by clustered OSD'S with a lot of less info and unreliable software. KOPILOT Lite will put at your commond, the basic functions for bringing your plane safely back home without getting in the way o flying. You will know KOPILOT Lite is there, only when you need it.
    Description:
    Brand: ZOHD
    Item name: Kopilot Lite Autopilot System
    Usage: For FPV RC Airplanes Fixed Wing Model
    Kopilot unit weight: 12 grams
    GPS module weights: 8 grams
    Package Weight: 83g
    Package Size (L x W x H):113 x 84 x 29mm
    Features:
    * Easy installation, minimal wiring. Super easy setup.
    * Powerful stabilization and RTH algorithm.
    * Return to Home (RTH) Fence (RAD) and Stabilization modes on a 3 position switch.
    * Supports T-Tail, V-Tail and Flying Wing/ Delta configurations.
    * Mini-size GPS unit for ultra-light setups.
    * Fast SAT lock.
    * Adjustment board removable for a light-weight setup.
    * Launch assistant and motor blocking for no SAT fix.
    * AIL, ELE, THR, RUD + AUX to control your servs. Landing gear and flaps go straight to RX.
    * Computer-free programming.
    * Easy to transfer between planes.
    * Completely transparent. Switch it off and use it as a mixing board only.
    Package Included:
    1 X Kopilot Mainboard
    1 X Mounting Support
    1 X GPS
    1 X Adjustment Board
    1 X Double-side Tape
    1 X Screw Driver
    1 X Manual
    www.timologic.gr  Πρόγραμμα ηλεκτρονικής τιμολόγησης
    https://lavo.gr/
    « Απάντηση #1 στις: Δευτέρα, 29 Νοε 2021, 19:33:31 »
    Ωραίο φαίνεται δεν ήξερα ότι υπήρχε κάτι τέτοιο.
    Βέβαια είναι plug and play και χώρις osd και καμιά παραμετροποίηση.  Καλό κακό δεν ξέρω.😬
    Σίγουρα θα γλυτώσεις πολύ χρόνο.
    Το 99% που γνωρίζω χρησιμοποιεί inav με κάποιο matek wing controller .Γενικά το fpv είναι ένας άλλος κόσμος θέλει πολύ διάβασα και YouTube μέχρι να πετάξεις.
    cosmic
    « Απάντηση #2 στις: Δευτέρα, 29 Νοε 2021, 23:55:50 »
    κανει ακριβως οτι λεει! Πολυ τιμιο για τα λεφτα του και πολυ ευκολο σεταρισμα!
    Δεν περιμενα να ειναι τοσο καλο!!!
    RTH κανεις και με χασιμο επικοινωνιας πομπου-δεκτη με failsafe στον διακοπτη που εχεις τα modes (στην θεση του RTH φυσικα)
    cosmic
    « Απάντηση #3 στις: Τρίτη, 30 Νοε 2021, 00:00:38 »
    παραμετροποιεις το gain , τον τυπο του αεροπλανου (Vtail, Ttail, Delta) , την τηλεκατευθυνση σου και τα τριμς και την οριζοντιωση του πτηνου. Απο εκει και περα εχεις 3 Modes - manual, stabilize, RTH.
    To θεμα osd το λυνεις με ενα αυτονομο osd συνδεμενο κανονικα στον πομπο σου βιντεο και στο esc ( το kopilot δεν συνδεεται με το esc, οποτε και μπορεις να συνδεσεις εκει τον αντιστοιχο σενσορα για να παρει την τηλεμετρια - ρευματα)
    ΙΚΑΡΟΣ
    Εκεί που ισιώνει ο αετός , οι γλάροι δεν πετάνε .
    « Απάντηση #4 στις: Τρίτη, 30 Νοε 2021, 13:30:39 »
     Για να θυμούνται οι παλιοί , και να μαθαίνουν οι νέοι
      AVIOMODELLI  CALYPSO
      F3A WORLD CHAMPION
       ΔΙΑΓΡΑΦΗ ΕΓΙΝΕ ΛΑΘΟΣ
    * aviomodelli-calypso_1_9b926326390ee4470f4461d65e204d69.jpg (35.35 KB, 400x300 - εμφανίστηκε 390 φορές.)
    Εκει που ισιωνει ο αετος, οι γλαροι δεν πετανε .
    christos139
    « Απάντηση #5 στις: Τετάρτη, 1 Δεκ 2021, 11:06:48 »
    επισης επειδη το εχω το συγκεκριμμενο σε αεροπλανο fpv μπορεις αντι για rth να βαλεις fence δλδ οταν θα πηγαινεις αν θυμαμαι καλα πανω απο 300 μετρα δεν θα σε αφηνει και θα γυρναει μεσα στο "φραχτη"...εγω ειμαι παρα πολυ ευχαριστημενος και με το gps δουλευει αψογα.
    Aeromodelling GR  |  Forum  |  Αεροπλάνα R/C - Ηλεκτρικά  |  Κινητήρες - Ρυθμιστές - Μπαταρίες  |  Θέμα: Kopilot Lite flight controller with gps 50 euro
