Τετάρτη, 14 Οκτ 2026, 03:36:32
    Online σήμερα: 24
    Επισκέπτες: 25
    Συνολικά: 25
    Σελίδες: 1 ... 15 16 17 [18] 19 20 21 ... 23     Κάτω
    Αποστολέας Θέμα: MODELLSPORT - ΠΡΟΣΦΟΡΕΣ  (Αναγνώστηκε 248704 φορές)
    MODELLSPORT
    « Απάντηση #255 στις: Σάββατο, 15 Σεπ 2012, 10:17:19 »
    Hubsan FPV Lynx Fixed Pitch RC Helicopter with 2.4Ghz Radio System
    Hubsan FPV Lynx Features:
        Balance Charger & Lipo Battery
        Auto rudder trimming
        4-Channel, Fixed Pitch, Single Rotor
        Tail Rotor Gyro
        Durable Alloy Construction
        CNC Machined Metal Rotor Head
        Direct-Drive Tail Rotor
        Includes 5 Megapixel Camera Installed Below Mainframe
        2.4GHz Transmitter with 3.5" LCD Color Monitor
        Selectable Flight Control Sensitivity for Beginner or Expert
    Spec Check:
        Size (mm): 342 x 124 x 63 (250 size)
        Weight: 197g
        Main Rotor: 338mm
        Tail Rotor: 64mm
        Power System
        180 Main Motor
        N30 Tail Motor
        Control Distance: 100m-300m
        Mix Controller: 4 in 1 mix controller w/ gyro, mixer, ESC, receiver
        Servo: 3.7g 0.12sec/60°
        Live Video Distance: 50-100m
    MODELLSPORT ΜΟΝΤΕΛΙΣΜΟΣ - ΤΗΛΕΚΑΤΕΥΘΥΝΟΜΕΝΑ
    ΑΠΟΚΛΕΙΣΤΙΚΟΣ ΑΝΤΙΠΡΟΣΩΠΟΣ
    BYRON FUELS
    HOBAO RACING
    FTX - FASTRAX - ETRONIX
    CML
    J PERKINS
    ΕΠΙΣΗΜΗ ΔΙΑΘΕΣΗ
    TEAM ASSOCIATED
    MODELLSPORT
    « Απάντηση #256 στις: Σάββατο, 15 Σεπ 2012, 18:43:47 »
    Axial EXO RTR - Electric 4WD Terra Buggy Kit
    Axial EXO RTR Features:
        AX-3 2.4GHz Radio System
        Robust Molded Roll Cage Design
        Quick Release Battery Mount
        Realistic Scale Details
        Brushless Powered
        Standard 32 Pitch Gearing
        4mm Aluminum Chassis
        Three Oil-filled Differentials
        Durable Driveline Components
        2.2/3.0 Raceline Renegade Wheels
        Hankook Dynapro MT Tyres
        Adjustable Suspension
        Tuned Shock Springs
        Protective Skid Plate Bumpers
        Waterproof Receiver Box
    Spec Check:
        Wheelbase: 334mm
        Length: 482.6mm
        Width: 295.3mm
        Height: 228.6mm
        Ground Clearance: 50mm
        Weight (no electronics): 2.25kg (4.95 lbs)
        Motor: Vanguard 2900Kv Brushless Motor (Developed by Castle)
        Servos: AS-4 Standard Servo
        ESC: Vanguard ESC, 3S LiPo, 8 NiCELL, Forward / Reverse, Waterproof
    MODELLSPORT
    « Απάντηση #257 στις: Κυριακή, 16 Σεπ 2012, 10:37:36 »
    Τηλεκατευθυνόμενα Ελικόπτερα Hubsan FPV Lynx Co-axial RC Helicopter με 2.4Ghz Τηλεκατεύθυνση - Κάμερα
        Tail Rotor Gyro
    Spec Check:
        Weight: 197g
        Main Rotor: 338mm
        Tail Rotor: 64mm
        Power System
        180 Main Motor x 2
    HUBSAN >>>
    MODELLSPORT - ΤΗΛΕΚΑΤΕΥΘΥΝΟΜΕΝΑ ΕΛΙΚΟΠΤΕΡΑ >>>
    MODELLSPORT
    « Απάντηση #258 στις: Δευτέρα, 17 Σεπ 2012, 17:08:30 »
    Dynam Mini Vortex 3.5 Channel Infra-Red, Micro RC Helicopter
    www.modellsport.gr
    MODELLSPORT
    « Απάντηση #259 στις: Τρίτη, 18 Σεπ 2012, 14:27:56 »
    RC Buggy, HoBao Hyper 7 TQ2 RTR Hyper 21 3-Port Edition
    Hyper 7 TQ2 Features:
        New cab forward body styling
        New strenghened front and rear shock tower designs
        New design radio box
        New low profile dual stage air filter assembly
        New front anti-roll bar assembly
        New turnbuckles for steering and servo linkage
        2.4ghz Hobao radio system
        Factory fitted SAVOX high performance servos
        HoBao Hyper 21 3-port pull start engine
        14mm big bore shock absorbers
        Black dish wheels
        Black wing
    Spec Check:
        Length: 460mm
        Width: 300mm
        Height: 140mm
        Wheelbase: 322mm
        Front Track: 305mm
        Rear Track: 308mm
        Weight: 330g
    MODELLSPORT - ΑΠΟΚΛΕΙΣΤΙΚΟΣ ΑΝΤΙΠΡΟΣΩΠΟΣ HOBAO >>>
    MODELLSPORT
    « Απάντηση #260 στις: Τετάρτη, 19 Σεπ 2012, 15:54:12 »
    HoBao Hyper 7 TQ2 RTR Mach 28 Edition, 1/8 Off-Road RC Buggy
        HoBao branded FUTABA servos
        HoBao Mach 28 Pull start engine
        White dish wheels
        White wing
    Spec Check:
        Length: 460mm
        Width: 300mm
        Height: 140mm
        Wheelbase: 322mm
        Front Track: 305mm
        Rear Track: 308mm
        Weight: 330g
    MODELLSPORT
    « Απάντηση #261 στις: Πέμπτη, 20 Σεπ 2012, 09:04:04 »
    Turnigy GTX3 AFHDS 2.4ghz 3 Channel Radio System
    www.modellsport.gr
    MODELLSPORT
    « Απάντηση #262 στις: Πέμπτη, 20 Σεπ 2012, 20:22:44 »
    Hubsan X4 Mini Quad Copter RTF 2.4Ghz
    Specification and features
    2.4gHz 4-channel radio
    Adjustable normal or expert sensitivity modes
    3.7v 240mAh LiPo battery
    4 Coreless motors
    Latest 6-axis flight control system with adjustable gyro sensitivity
    USB charge cable
    Lightweight moulded airframe for added protection
    Super stable flight performance
    Weight 38gram (including battery)
    Σύντομα στο Modellsport με τιμή περίπου στα 45 Ευρώ.
    MODELLSPORT
    « Απάντηση #263 στις: Παρασκευή, 21 Σεπ 2012, 13:37:29 »
    Dynam PBY Catalina 1470mm ARTF Twin Engine RC Seaplane w/o TX/RX/Battery - Blue/Yellow
    Dynam PBY Catalina Features:
        High quality scale detail and a nice large 1.4m winspan make this an attention grabbing model.
        Plenty of power is provided by the twin 1100KV motors.
        Made from a high strength EPO-foam for added durability.
        Powered by a pair of high powered 1100KV electric brushless motors
        Makes a great gift since almost everything needed to fly comes in one box.
    Tech Spec:
        Wingspan - 1470mm
        Overall length - 940mm
        Servo - Installed 9g x 4
        ESC - 30 Amp x 2
        Motor - Brushless Outrunner x 2
    MODELLSPORT- ΤΗΛΕΚΑΤΕΥΘΥΝΟΜΕΝΑ ΑΕΡΟΠΛΑΝΑ, ΗΛΕΚΤΡΙΚΑ >>>
    MODELLSPORT
    « Απάντηση #264 στις: Παρασκευή, 21 Σεπ 2012, 20:19:39 »
    Micro RC Helicopter, Hubsan Invader Fixed Pitch BASIC
    Spec Check:
        Flying Weight: 60g
        Flying Time: Around 8 minutes
        Power system: N30 main motor,N20 tail rotor
        Transmitter: 4 Channels 2.4Ghz
        Servo: Super micro size 2.0g 0.12sec/60
        Helicopter battery: 3.7V 450mAh LiPo battery with safety PCB
        Transmitter battery: 4 x AAA(not included)
    Features:
        450mAH 15C LiPo Battery
        4 in 1 controller (receiver, flight control system, gyro, mixer)
        Durable CNC Alloy Chassis
        4 channel 2.4GHz Transmitter
        Selectable Flight Control Sensitivity expert mode 40-100%/beginner mode 20-80%,
        servo reverse
        Micro 2g servos
        USB Charger
    HUBSAN >>>
    ΤΗΛΕΚΑΤΕΥΘΥΝΟΜΕΝΑ ΕΛΙΚΟΠΤΕΡΑ - ΗΛΕΚΤΡΙΚΑ >>>
    MODELLSPORT
    « Απάντηση #265 στις: Παρασκευή, 21 Σεπ 2012, 20:36:45 »
    Hubsan EC145 Fixed Pitch Micro RC Helicopter BASIC
    Spec Check:
        Flying Weight: 60g
    Features:
        servo reverse
        Micro 2g servos
        USB Charger
    HUBSAN >>>
    MODELLSPORT
    « Απάντηση #266 στις: Σάββατο, 22 Σεπ 2012, 08:13:32 »
    Dynam Messerschmitt BF109 ARTF 1270mm RC Aircraft
    Dynam Messerschmitt BF109 Features
        Large canopy access hatch to the battery and receiver area
        Worm drive retracts
        Larger ailerons
        Stiff wing with simple attachment
        Fixed empennage
        Steering tail wheel
        1 piece 3 Blade propeller 13x7 (includes spare)
        3 Navigation lights (LED)
        Scale spinner with central screw
        Retracts - 2 x Worm Drive Electronic
    Tech Spec
        Wingspan - 1270mm
        Overall length - 1163mm
        ESC - Heavy duty 40 Amp
        Motor - Brushless 500KV
        Flying weight - 1400g
    MODELLSPORT
    « Απάντηση #267 στις: Σάββατο, 22 Σεπ 2012, 17:15:52 »
    Dynam Waco F Series ARTF RC Bi-Plane, Τηλεκατευθυνόμενο Διπλάνο
    Spec Check:
        Tech Spec
        Wingspan: 1270mm
        Length: 983mm
        Servo: 9g x4
        Motor Brushless: 650kv
        ESC: 40Amp
    www.modellsport.gr
    MODELLSPORT
    « Απάντηση #268 στις: Κυριακή, 23 Σεπ 2012, 08:35:55 »
    Etronix Powerpal 80w AC/DC Performance Charger/Discharger
    Powerpal AC Specifications:
        Battery Type: 1-6 Li-Po, Li-Ion, Li-Fe, 1-15 NiCd, NiMH, 1-6 Lead-Acid
        Charge Rate: 0.1A-5.0A (Max 80W)
        Discharge Rate: 0.1A-1A (Max 5W)
        Cycle Charge/Discharge: 1-5 Cycles (charge>discharge, discharge>charge)
        Balancer: Built-in individual voltage balancer for Lithium batteries 300mAh/cell current drain
        Fast/Storage Mode: Charge Lithium batteries for special purposes. 'Fast' reduces charge time, while 'Storage' controls final voltage for long time storage
        Charge Safety: Delta Peak
    • Sensitivity voltage detection (NiCd/NiMH) Auto-Charge current limit useful for small capacity NiMH, Auto-Charge current limit useful for small capacity NiMH, Capacity limit charge, Temperature limit charge, Time limit charge
        Battery Data: 5 model memory
    Includes:
        1 x Charge leads for Receiver batteries,
        1 x Receiver batteries JST plug,
        1 x Glow stick,
        1 x Deans connector,
        1 x Crocodile Universal clip,
        1 x JST XH Balance Board.
    ΦΟΡΤΙΣΤΕΣ, ΤΡΟΦΟΔΟΤΙΚΑ - MODELLSPORT.GR
    MODELLSPORT
    « Απάντηση #269 στις: Κυριακή, 23 Σεπ 2012, 14:15:38 »
    Hubsan Lynx Co-axial RTF RC Helicopter
    Spec Check:
        Weight: 197g
        Main Rotor: 338mm
        Tail Rotor: 66mm
        Power System
        180 Main Motor x 1
        N30 Tail Motor x 1
        7.4v 650mAH LiPo
    Features:
        Tail Rotor Gyro
        2.4GHz Transmitter
    www.modellsport.gr
    Σελίδες: 1 ... 15 16 17 [18] 19 20 21 ... 23     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: MODELLSPORT - ΠΡΟΣΦΟΡΕΣ
