310.077 μηνύματα σε 12.405 θέματα από 6.301 Μέλη / Τελευταίο μέλος: Clubdim
Δευτέρα, 16 Νοε 2026, 14:17:53
    [Σήμερα στις 13:28]
    [Σήμερα στις 10:39]
    [Χθες στις 12:41]
    Σύνολο μηνυμάτων: 310077
    Επισκέπτες: 94
    Συνολικά: 97
    Αποστολή θέματος Εκτύπωση
    Αποστολέας Θέμα: Kingkong 210GT 210MM F3 FPV Racer Quad RTF with 700TVL CCD Cam 600mW VTX Flysky  (Αναγνώστηκε 865 φορές)
    rcfans88.com
    « στις: Πέμπτη, 28 Ιουλ 2016, 05:54:20 »
    Kingkong 210GT 210MM F3 FPV Racer Quad RTF with 700TVL CCD Cam 600mW VTX Flysky i6 Mode 2 Transmitter
    Features
    Kingkong 210GT 210MM FPV Racer Quadcopter RTF with F3 Camera 5.8G 600mW VTX Flysky i6 Transmitter
    -3mm carbon frame body,strong,light-weight frame
    -20A 2S-4S Opto BLHeli Speed controllers
    -Powerful KINGKONG 2300kv motors
    -Pre-tuned micro CC3D flight control system
    -CCD camera has good effect at night flight.
    -Standard camera holders, the vertical angle is adjustable
    -High brightness multicolor rear LED with lampshade
    Product Details
    Brand Name: Kingkong
    Item Name: 210GT RTF
    Thickness of Upper Plate: 1.5±0.2mm
    Thickness of Bottom Plate: 3±0.2mm
    Flight Controller: Micro F3
    Propeller: 5040
    Motor: 2205 2300KV(2-4s)
    ESC: BLHELI 20A 2-4s
    VTX: 600mW 5.8G
    Antenna: RHCP, SMA
    Remote Control System: Flysky FS-i6
    Battery: 3S 1300mAh 25C Battery
    Frame Weight: 306g
    20A ESC
    Processor: MEGA88A(16Mhz)
    Rated Voltage: 2S-4S LiPo
    Continuous Current: 20A
    Instantaneous Currents: 25A(Max. 5 seconds)
    BEC: No
    Aluminium Radiator Fin: No
    Size: 25 x 12 x 3mm
    Net Weight: 4g
    700TVL CCD Camera
    Format: PAL,NTSC
    View Angle:115°
    Lens Type: F2.0/2.8MM
    Voltage: DC8V-18V
    Weight: 16.4g
    5.8G 600mW 32CH VTX
    Video Format: NTSC/PAL
    Voltage: 5v
    Transmitting Power: 600mW
    FS-i6 Specifications:
    Channels: 6 Channels
    Model Type: Glider/Heli/Airplane
    RF Range: 2.40-2.48GHz
    Bandwidth: 500KHz
    Band: 142
    RF Power: Less Than 20dBm
    2.4ghz System: AFHDS 2A and AFHDS
    Code Type: GFSK
    Sensitivity: 1024
    Low Voltage Warning: less than 4.2V
    DSC Port: PS2;Output:PPM
    Charger Port: No
    ANT length: 26mm*2(dual antenna)
    Weight:392g
    Power: 6V 1.5AA*4
    Display mode: Transflective STN positive type, 128*64 dot matrix VA73*39mm,white backlight.
    On-line update:yes
    Color: Black
    Certificate: CE0678,FCC
    Model Memories: 20
    Channel Order: Aileron-CH1, Elevator-CH2, Throttle-CH3, Rudder-CH4,Ch 5 & 6 open to assignment to other functions.
    FS-iA6 Specifications:
    Model Type: Fixed-wing/Glider/Airplane
    Bandwidth: 500KHz
    Band: 142
    RF power:less than 20dBm
    RF.receiver sensitivity:-105dBm
    Code Type: GFSK
    ANT length: 26mm
    Weight:6.4g
    Power:4.0-6.5V
    Color: Black
    Certificate: CE,FCC
    i-BUS port: NO
    Item Packing
    1 x 210MM Frame Kit
    4 x 2300KV Motor
    4 x 20A ESC
    20 x 5040 Propeller
    1 x 600mW 5.8G VTX
    1 x 700TVL CCD Camera
    1 x SMA RHCP 5.8G Antenna
    1 x 3S 1300mAh Battery
    1 x Battery Charger
    1 x Flysky i6 Transmitter
    1 x Flysky iA6 Receiver
    Detailed Images
    * 210KIT.jpg (41.55 KB, 500x500 - εμφανίστηκε 216 φορές.)
    * KK210GT 1.jpg (38.97 KB, 500x318 - εμφανίστηκε 208 φορές.)
    * KK210GT 2.jpg (50.74 KB, 500x341 - εμφανίστηκε 198 φορές.)
    * KK210GT 3.jpg (44.92 KB, 500x336 - εμφανίστηκε 216 φορές.)
    Αναφορά στον συντονιστή   Καταγράφηκε
    Aeromodelling GR  |  Forum  |  Αερομοντελλισμός στο Aeromodelling GR  |  Aeromodelling GR Café International (Συντονιστής: Γιώργος Κανδυλάκης)  |  Θέμα: Kingkong 210GT 210MM F3 FPV Racer Quad RTF with 700TVL CCD Cam 600mW VTX Flysky
    Δημιουργία σελίδας σε 0.064 δευτερόλεπτα. 27 ερωτήματα.
