Τετάρτη, 18 Νοε 2026, 04:09:42
    [Χθες στις 12:57]
    Σύνολο μηνυμάτων: 310087
    Σύνολο θεμάτων: 12405
    Online σήμερα: 98
    Επισκέπτες: 83
    Συνολικά: 83
    Σελίδες: 1 ... 5 6 7 [8] 9     Κάτω
    Αποστολέας Θέμα: Focke Wulf 190 d9 1/4 scale.  (Αναγνώστηκε 39935 φορές)
    fokke
    « Απάντηση #105 στις: Κυριακή, 7 Φεβ 2016, 20:26:40 »
    What's happened with the model,  who build it now Huh
    « Απάντηση #106 στις: Τρίτη, 9 Φεβ 2016, 07:15:05 »
    Hi Rumen,
    I am in no hurry to jump into it, I am the patient type of builder that collects information from other people's projects and avoid "discovery of the wheel" as much as I can.
    I will write notes / instructions before I start to make sure I haven't missed anything, and edit those when I do the physical build.
    If you do a revised kit I might be interested in some corrected parts.
    Apart from Demire on RCSB, is anyone else documenting their build in detail?
    http://www.rcscalebuilder.com/forum/forum_posts.asp?TID=23811&PN=1&TPN=35
    fokke
    « Απάντηση #107 στις: Τρίτη, 9 Φεβ 2016, 10:00:26 »
    Hello
    Yes Charles made one of this models. All changes wich he made on the models are his opinion , any who build the models can make and write any what he want , anyone is free to make changes, sometime are good , some times are not . To this moment, 21 kits, from 1/4 scale are sold in all over the World, but some are not start as projects yet , some do not like to write about his work . Yes, I have information for other guys who work in the Anton, some will start work on the kits to , so we will watch many different method of work on my kits:)
    Here you can see the work on 1/4 scale Anton , the wings are the same like Dora: http://www.rcuniverse.com/forum/rc-warbirds-warplanes-200/11571397-fw-190-d9-1-5-fokkerc-com-21.html
    HEree  you can see any  updates,  and any work on the other  models :  https://www.facebook.com/fokkerc.chakarov
    So I think when you start work on the model to write me with any questions  about the method and changes  on the model
    Now we work on Manual  for A8 and D9
    Best regards from Sofia
    « Απάντηση #108 στις: Τρίτη, 9 Φεβ 2016, 21:33:19 »
    Hi Rumen,
    Δηλαδή σε απλά Ελληνικά θες να μας πεις πως το έχεις εσύ;;;;;; Δηλαδή έχεις το κιτ, έχεις τα σχέδια του Jeff, έχεις και χρόνο να το μελετήσεις και να το τελειοποιήσεις οπότε είσαι έτοιμος να μας τρελάνεις τελείως όταν το ξεκινήσεις;;;;!!!!!   idiot2 idiot2 idiot2 idiot2 idiot2
    « Απάντηση #109 στις: Τετάρτη, 10 Φεβ 2016, 07:19:27 »
    Thanks Rumen,
    sign me up for a D9 manual when ready
    « Απάντηση #110 στις: Τετάρτη, 10 Φεβ 2016, 07:26:12 »
    Ναι το πήρα από τον φίλο Μιχάλη ο οποίος είχε ξεκινήσει την κατασκευή της ατράκτου.
    Αλλά όπως ξέρεις πολύ καλά Παναγιώτη το Dora έχει συγκεκριμένα σημεία που θέλουν ιδιαίτερη ενίσχυση, και σε κλίμακα 1/4 γίνονται ακόμα πιο κρίσιμα.
    Γι'αυτό περιμένω να πετάξουν αυτά που κατασκευάζονται, και να φτιάξω την έκδοση 2 με τις όποιες διορθώσεις / βελτιώσεις.
    Υπάρχει και η σκέψη πριν το 1/4 να φτιάξω στο 1/5 ... όρεξη νά'χουμε
    « Απάντηση #111 στις: Τετάρτη, 10 Φεβ 2016, 09:41:41 »
    Αναμένουμε με ανυπομονησία!
    Μας έχει μπριζώσει όλους ο Rumen!!!! Cheesy
    Ειδικά άν ετοιμάσει και το glass skin τότε θα γλυτώσεις και την περισσότερη δουλειά!
    Άσε που σχεδιάζει ο Rumen να κατασκευάσει στο μέλλον και ένα Ju-87 Stuka....!!
    Καλή συνέχεια!!!
    « Απάντηση #112 στις: Τετάρτη, 10 Φεβ 2016, 17:15:41 »
    Μα τι εννοείς δεν σε καταλαβαίνω;;;;;
    « Απάντηση #113 στις: Τετάρτη, 10 Φεβ 2016, 17:24:50 »
    εεεεε...μα ούτε εγώ καταλαβαίνω τι θέλει να πεί ο ποιητής..;;;;;
    « Απάντηση #114 στις: Πέμπτη, 11 Φεβ 2016, 07:27:09 »
    Ο νοών νοείτω
    fokke
    « Απάντηση #115 στις: Δευτέρα, 11 Απρ 2016, 08:53:34 »
    Thanks Rumen,
    I will make manyal
    Man, you do not need any manual, the all model is made like a puzzle , like LEGO ....... The changes of Charles are hes opinion , do not watch hes changes , any modeler can make any changes on the model, The model is easy to build , an usual modeller can build it easy and fast and correct !
    The changes of Charles are hes changes he is american , thay work with american plans who are not correct, all plans of Dora are with mistakes .Do you think that my skills to project and build my models are not so good ? Can you imagine how can I start to sell models before I am not sure that everything is perfect? The main plans who I use for my work is FACTORY drawings and plans from Luft archive , no other , no american plans , no some dubious plans from internet !
    So you can be sure that the plans are correct and my solutions in the plans are better !
    Best regads
    Rumen Wink
    Καλή συνέχεια!!!
    Dimitri , after BF 109 E4 1/4  I will start  1/4 Stuka , that;s my plans
    All best guys , Great forum  you have there !
    Cheers
    ALPHA KILO
    « Απάντηση #116 στις: Δευτέρα, 11 Απρ 2016, 09:11:51 »
    Παναζία μου! Cheesy Cheesy Cheesy
    Τρελαθήκατε όλοι σας, και θα μας τρελάνετε και εμάς!
    Δεν πάμε κατευθείαν στο 1 προς 1 να τελειώνουμε, αφού το λέει η καρδούλα μας!
    Άρης police
    « Απάντηση #117 στις: Δευτέρα, 11 Απρ 2016, 10:45:05 »
    Best regads
    Rumen Wink
    Rumen,
    The Fw-190 wing airfoils are from the factory plans scaled to 1/4?
    fokke
    « Απάντηση #118 στις: Τετάρτη, 13 Απρ 2016, 09:48:26 »
    Yep, I made the airfoils of original wings in the root NACA 23015 and NACA 23009 in the tip of wing
    15 % airfoil for the model in this scale is  OK
    Also I made  wishout  of the wing , so the landing will be  slower
    fokke
    « Απάντηση #119 στις: Τετάρτη, 9 Αυγ 2017, 14:29:06 »
    Hi guys , I am back on FW-190 A8 1/4 aluminium plug
    Today I finish the canopy frame , and it is ready for molding
    Σελίδες: 1 ... 5 6 7 [8] 9     Πάνω
    Aeromodelling GR  |  Forum  |  Αεροπλάνα R/C - Καύσιμο  |  Γιγαντιαία, υπό κλίμακα και με βενζίνη (Συντονιστής: ArgyrisGiannetakis)  |  Θέμα: Focke Wulf 190 d9 1/4 scale.
    Δημιουργία σελίδας σε 0.034 δευτερόλεπτα. 28 ερωτήματα.
