Πέμπτη, 19 Νοε 2026, 14:15:23
    [Σήμερα στις 00:04]
    [Χθες στις 21:11]
    [Χθες στις 14:10]
    [Χθες στις 13:27]
    Σύνολο μηνυμάτων: 310091
    Σύνολο θεμάτων: 12406
    Online σήμερα: 141
    Επισκέπτες: 88
    Συνολικά: 91
    Αποστολέας Θέμα: new Mikado Vbar control radio  (Αναγνώστηκε 9191 φορές)
    papabill
    « στις: Παρασκευή, 21 Φεβ 2014, 17:07:43 »
    Νεα Τ/Κ από τη MIGATO με πολλες καινοτομιες!
    Απολαυστε!
    papabill
    « Απάντηση #1 στις: Παρασκευή, 21 Φεβ 2014, 17:10:40 »
    Software Highlights:
    Set up, programming and adjusting of VBar-controlled model helicopters accomplished directly via VBar Control transmitter.
    No computer, control panel or smartphone necessary.
    Instant access to almost every flight parameter from the transmitter controls, even in flight.
    Easy programming for new helicopters via the familiar VBar setup wizard.
    New ESC setup wizard for programming all types of speed controllers.
    Bank switching with three banks.
    Real time logging and real time vibration analysis readable from the transmitter.
    Several telemetry functions are available, such as voltages, current, rpm, speed, and power consumption of the batteries (may need aditional hardware).
    Storage of event log files like VBar event log, VBar Control event log, GPS way points, voltage/current logging etc.
    Multiple timer functions available with warnings and reminders via sound, voice, or vibration output.
    Wireless buddy boxing with two VBar Control transmitters, fully configurable.
    Easy bind process, allows bind and fly of any model equipped with VBar Control (e.g. a buddy‘s heli) with your own transmitter (Model Sharing).
    Software updates via internet using a simple VBar Control Manager app and the web browser.
    Option for adding new features via apps, simple installation via internet, supports both Windows and Mac OS X-PCs, no drivers needed.
    Additional airplane software will be available in summer 2014.
    Hardware Highlights:
    80 Channel 2.4 GHz FHSS bidirectional flight control, programming/setup and telemetry remote control system.
    VBar Control Satellite Receiver connects directly to VBar flybarless controller via 2.4GHz VBar-Link protocol.
    Unlimited model memory.
    Virtually unlimited number of control channels.
    High range, low latency, antenna diversity on both transmitter and receiver.
    Intelligent antenna monitoring and management.
    XXtra Bright Graphic Display featuring high contrast and ambient light sensor to automatically control the display brightness, making it equally well readable in bright sunlight and in the dark.
    Easy Dialog System with rotary dial for convenient and safe inputs, with optical, tactile and acoustic feedback.
    Precision gimbals with four ball bearings, fully adjustable.
    Collective stick equipped with optional throw limiter.
    Fully equipped with four 3-position-switches, two quick-break-switches and two rotation knobs, all fully programmable.
    Delicate rubber lining for comfortable, slip-free and safe holding.
    3-point neck-strap attachment, for optimum balance.
    Large 2 Watt loudspeaker for alarms and voice output.
    Vibration alarm (adjustable).
    Internal 8 MB flash memory.
    Memory accessible as a USB memory stick, no drivers needed.
    4.000 mAh Lithium Polymer battery allows for long run times.
    Charge through USB connector or built-in charger.
    Power Supply for fast charging included.
    papabill
    « Απάντηση #2 στις: Παρασκευή, 21 Φεβ 2014, 17:13:48 »
    * vc_front_schraeg41.jpg (79.94 KB, 600x600 - εμφανίστηκε 600 φορές.)
    « Απάντηση #3 στις: Παρασκευή, 21 Φεβ 2014, 23:06:22 »
    Καλό φένεται..!
    Παράξενο που βγάλανε και τηλεκατ….! ΓΕνικα κάνουν πολλές παράξενες κινήσεις.>!
    dhiotis
    « Απάντηση #4 στις: Σάββατο, 22 Φεβ 2014, 09:28:39 »
    Δεν μας είπαν όμως,  τι κάνεις με τα αλλα μοντέλα, εκτός
    ελικοπτέρων, τι γίνεται.
    Μόνο ελικόπτερα πετας με αυτήν
    Heli.Maniac
    « Απάντηση #5 στις: Σάββατο, 22 Φεβ 2014, 09:31:18 »
    Το ερωτημα ομως ειναι, είναι μονο για vbar?
    Andreas
    COMPASS 7HV
    TREX 600EFL Pro
    « Απάντηση #6 στις: Σάββατο, 22 Φεβ 2014, 10:31:45 »
    Φένεται ότι είναι μόνο για  vbar..!
    dhiotis
    « Απάντηση #7 στις: Σάββατο, 22 Φεβ 2014, 11:31:44 »
    Εαν Παύλο έτσι είναι, που προφανώς είναι, τότε ...  Sad
    kgiova
    « Απάντηση #8 στις: Σάββατο, 22 Φεβ 2014, 11:48:05 »
    υπομονή !!!!
    Additional airplane software will be available in summer 2014.   Thumbs up
    απο το ποστ του papabil Wink
    « Απάντηση #9 στις: Σάββατο, 22 Φεβ 2014, 15:12:43 »
    Για το ελικόπτερο είναι λογικό… Οι φανατικοί του vbar θα το πέρνουν..
    Οσο για το αεροπλάνο λογικά θα βγάλουν εναν δέκτη που θα είναι και για αεροπλάνο..!
    Είδωμεν.!
    FlyingDoctor
    Βασιλης
    « Απάντηση #10 στις: Σάββατο, 22 Φεβ 2014, 15:14:51 »
    Αν προσεξατε δεν εχει και τριμ το συστημα.
    BizGreece
    « Απάντηση #11 στις: Κυριακή, 23 Φεβ 2014, 01:14:52 »
    To σκεφτομαι πολυ καιρο τωρα να αλλαξω τηλεκατευθυνση και κοιτουσα ολα τα τελευταια μοντελα .
    Δεν ειχα κατα νου αυτο . Αλλα τωρα αλλαζουν τα σχεδια .
    Προφανως την εχουν βγαλει για ελικοπτερα μονο .
    Να δουμε ομως και την τιμη της
    « Τελευταία τροποποίηση: Κυριακή, 23 Φεβ 2014, 09:20:22 από BizGreece » Καταγράφηκε
    Heli.Maniac
    « Απάντηση #12 στις: Κυριακή, 23 Φεβ 2014, 09:11:31 »
    Μάλλον επειδη στοχευει κυριως σε vbar που το τριμ ειναι αχρηστο. Αν βγαλουνε και κανα δέκτη τυπου s-bus για ελικοπτερα για αυτους που δεν εχουν vbar πιστευω πως θα ειναι πολυ επιτυχημενο.
    Andreas
    COMPASS 7HV
    TREX 600EFL Pro
    Hobby-Shop.gr
    « Απάντηση #13 στις: Κυριακή, 23 Φεβ 2014, 18:38:37 »
    η εξελιξη των ειδων ... μετα τα fbl units που απαγορευεται να τριμαρεις να και οι τηλεκατευθυνσεις χωρις τριμ .. τι αλλο θα δουμε θεε μου. idiot2
    εγω τηλεκατευθυνση χωρις τριμ δε τη θελω..σε λιγο θα παταμε το κομβίον και θα κανει back το home το Calmato
    itf68
    « Απάντηση #14 στις: Κυριακή, 23 Φεβ 2014, 19:35:46 »
    Υπάρχουν ήδη φίλε μου και τέτοια αλλά αν μπουν και πάνω σε Τ/Κ να δω παράδες που θα βρούμε να την πάρουμε....! Thumbs up
    Τάσος  希腊
    T-Rex 250SE
    T-rex 450 pro
    Genius 500
    Vibe 500E FBL
    T-Rex 550E DFC V3
    T-Rex 600EFL PRO
    Vibe 50NEX FBL
    Logo 550SX
    2 Χ Logo 600SE
    Kasama Dune 600
    2 Χ Kasama Srimok 90
    Kasama Srimok 90E FAIFA
    Logo 800 xtreme
    και κανα δυό ανεμοπλάνα...!
    Aeromodelling GR  |  Forum  |  Το αερομοντελιστικό εργαστήρι  |  Η τηλεκατεύθυνση και τα αξεσουάρ (Συντονιστές: DEPRON MANIAC, kolotoympas)  |  Θέμα: new Mikado Vbar control radio
    Δημιουργία σελίδας σε 0.075 δευτερόλεπτα. 24 ερωτήματα.
