Σάββατο, 17 Οκτ 2026, 06:29:32
    [Χθες στις 23:03]
    Σύνολο μηνυμάτων: 310019
    Online σήμερα: 73
    Επισκέπτες: 44
    Συνολικά: 44
    Σελίδες: 1 ... 75 76 77 [78] 79 80 81 ... 99     Κάτω
    Αποστολέας Θέμα: Εντυπωσιακά βίντεο #2  (Αναγνώστηκε 429351 φορές)
    « Απάντηση #1155 στις: Κυριακή, 20 Νοε 2016, 00:30:12 »
    « Απάντηση #1156 στις: Κυριακή, 20 Νοε 2016, 10:43:44 »
    mikmerll
    « Απάντηση #1157 στις: Κυριακή, 20 Νοε 2016, 22:48:19 »
    https://www.youtube.com/watch?v=hG9LzT60RLM
    « Τελευταία τροποποίηση: Δευτέρα, 21 Νοε 2016, 00:45:53 από evan » Καταγράφηκε
    « Απάντηση #1158 στις: Δευτέρα, 21 Νοε 2016, 10:18:14 »
    The SR-71 Black Bird is truly a wonder of engineering. You can tell that's the case just by looking at it even if you have no prior knowledge of aviation. The way it looks just screams "radical design."
    Now add to that what it actually did. To this day, it holds the world record for the fastest air-breathing manned aircraft. Clocking in at 2,200 mph (and that's what we're allowed to know), this plane could get you from the East to the West coast in 65 minutes and 54 seconds, which is also a record that was never broken.  Also, it could soar up to 85,000 ft, which is right by the Stratosphere.
    Now here's the kicker. This plane was already in the works in the later part of 1950s with its first flight taking place in 1964. That's only 20 years after World War II when prop planes dominated the sky. Just think about that for a second.
    Designed in part by Clarence "Kelly" Johnson for Lockheed and its secret division called Skunk Works, this bird was years ahead in innovation. At those heights and speeds, the external temperatures rose above 500° F and somehow the plane and its crew had to stay together. Everything about it had to be carefully considered.
    That's the point of this article. It had to be thought through. In the early 60s no computers existed that could render or even come close to computing how this aircraft should be built. It was all done on drawing boards with pencils, rulers and protractors (if you remember what any of these are.) That's one incredible feat if you think about it.
    What's even more incredible is that in the 2000s this design was ran through a sophisticated computer program used to design planes. You're talking about thousands of rivets, angles of the fuselage and about a million other factors that this computer checks for.
    The end result? The computer wouldn't do anything different. The design is as efficient as it could be. It was perfect.
    « Απάντηση #1159 στις: Δευτέρα, 21 Νοε 2016, 10:28:45 »
    « Απάντηση #1160 στις: Δευτέρα, 21 Νοε 2016, 14:56:23 »
    Μανούλα......
    « Απάντηση #1161 στις: Τρίτη, 22 Νοε 2016, 18:18:45 »
    « Απάντηση #1162 στις: Τετάρτη, 23 Νοε 2016, 22:22:37 »
    « Απάντηση #1163 στις: Παρασκευή, 25 Νοε 2016, 15:55:23 »
    billistitan
    MINI TITAN V.2
    « Απάντηση #1164 στις: Παρασκευή, 25 Νοε 2016, 18:30:47 »
    Making A Molded Fuselage - YouTube
    « Απάντηση #1165 στις: Παρασκευή, 25 Νοε 2016, 21:35:45 »
    « Απάντηση #1166 στις: Σάββατο, 26 Νοε 2016, 22:06:30 »
    « Απάντηση #1167 στις: Δευτέρα, 28 Νοε 2016, 12:22:38 »
    Αυτο πως και δεν το εχει δει ο Αρναουτογλου να κανει εκπομπή......Το δικό μοu multicopter μαγειρευει καλύτερα απο το δικό σου........ Grin Grin
    χαχαχαχαχα
    jnkmilos
    « Απάντηση #1168 στις: Τρίτη, 29 Νοε 2016, 20:11:08 »
       Ετσι για να παιρνουν καποιοι ιδεες μια και πλησιαζει και η συγκεντρωσh https://www.youtube.com/watch?v=1sfZJPEZP4E
    « Τελευταία τροποποίηση: Παρασκευή, 2 Δεκ 2016, 15:05:20 από evan » Καταγράφηκε
    « Απάντηση #1169 στις: Παρασκευή, 2 Δεκ 2016, 13:30:57 »
    Καταπληκτκή μπράβο της!!!  Thumbs up   Thumbs up
    Σελίδες: 1 ... 75 76 77 [78] 79 80 81 ... 99     Πάνω
    Aeromodelling GR  |  Forum  |  Αερομοντελλισμός στο Aeromodelling GR  |  Aeromodelling GR - γενικές συζητήσεις (Συντονιστής: ArgyrisGiannetakis)  |  Θέμα: Εντυπωσιακά βίντεο #2
    Δημιουργία σελίδας σε 0.031 δευτερόλεπτα. 29 ερωτήματα.
