Δευτέρα, 19 Οκτ 2026, 11:06:37
    Online σήμερα: 52
    Επισκέπτες: 50
    Συνολικά: 51
    Σελίδες: 1 ... 74 75 76 [77] 78 79 80 ... 99     Κάτω
    Αποστολέας Θέμα: Εντυπωσιακά βίντεο #2  (Αναγνώστηκε 430242 φορές)
    Chris71
    « Απάντηση #1140 στις: Δευτέρα, 7 Νοε 2016, 16:20:42 »
    Το λές και θηρίο...
    https://www.youtube.com/watch?v=ig5egVomOZs
    « Απάντηση #1141 στις: Δευτέρα, 7 Νοε 2016, 23:29:39 »
    « Απάντηση #1142 στις: Τρίτη, 8 Νοε 2016, 10:15:31 »
    « Απάντηση #1143 στις: Πέμπτη, 10 Νοε 2016, 00:11:15 »
    The prototype YF-16 was rolled out at Fort Worth on December 13, 1973 and was air freighted by C-5A to Edwards AFB on January 8, 1974. Its first flight was an unintended short hop around the pattern on January 21, 1974 at the hands of test pilot Phil Oestricher.
    John G. Williams, a structural flight test engineer on the YF-16, recalls:
    During the first high-speed taxi test, a violent lateral oscillation had set in as a direct result of pilot-commanded oscillations (several maximum left/right commands) as the airplane reached rotation speed (~120 kt). Remember, this was the first airplane to have a fixed stick, and there was no opportunity for Phil to gain any feel for the airplane, until that high-speed taxi test. As the nose of the aircraft rose, the tailplane inadvertently scraped on the runway. The left wingtip missile and the right tail static probe also lightly contacted the runway. Phil chose to take off because the bird had begun to veer off to the left side of the runway, and he was faced with plowing through the desert or flying. Thankfully he chose to fly and possibly saved the entire program. After take off, Phil regained control and stayed up for six minutes, and landed uneventfully. Prior to the next flight, the stick sensitivity was reduced by 50% with gear down. Later, after complaints of not enough sensitivity, it was returned to the original."
    « Απάντηση #1144 στις: Πέμπτη, 10 Νοε 2016, 22:12:28 »
    Μπορει να μην πεταει κανονικά αλλα ο τυπος ειναι απιστευτος.....!!
    « Απάντηση #1145 στις: Παρασκευή, 11 Νοε 2016, 06:39:12 »
    Μπα.. δεν έχει πιλότους που κουνάνε το κεφάλι  Cheesy Grin
    « Απάντηση #1146 στις: Σάββατο, 12 Νοε 2016, 12:57:48 »
    Ομορφιές.....!!!
    « Απάντηση #1147 στις: Σάββατο, 12 Νοε 2016, 14:54:21 »
    « Απάντηση #1148 στις: Κυριακή, 13 Νοε 2016, 19:04:20 »
    BYRON GODBERSEN ΘΕΟΣ.....1987!  AVIATION EXPO.....
    « Απάντηση #1149 στις: Δευτέρα, 14 Νοε 2016, 09:54:58 »
    « Απάντηση #1150 στις: Δευτέρα, 14 Νοε 2016, 12:04:28 »
    Διασωση σου λεει μετά........Δεν τον αφηνε να πεθανει καλύτερα......μπουαχα
    « Απάντηση #1151 στις: Τετάρτη, 16 Νοε 2016, 09:53:26 »
    « Απάντηση #1152 στις: Πέμπτη, 17 Νοε 2016, 09:55:11 »
    « Απάντηση #1153 στις: Σάββατο, 19 Νοε 2016, 01:41:01 »
    Ειμαι σιγουρος οτι ο τυπος ............καλά δεν παιζεται ετσι και αλλιως για αυτο που εφτιαξε.....αλλα ειναι σιγουρο οτι μπορει να γραφτει στα βραβεια γκινες για το οτι ειναι ο ο πρωτος αερομοντελιστης που εβαλε μπροστά σε 15 δευτερολεπτα 12 glow engines....!!!!!!!!!!!!!!!!!!!!!!!
    « Απάντηση #1154 στις: Σάββατο, 19 Νοε 2016, 16:17:26 »
    Σελίδες: 1 ... 74 75 76 [77] 78 79 80 ... 99     Πάνω
    Aeromodelling GR  |  Forum  |  Αερομοντελλισμός στο Aeromodelling GR  |  Aeromodelling GR - γενικές συζητήσεις (Συντονιστής: ArgyrisGiannetakis)  |  Θέμα: Εντυπωσιακά βίντεο #2
    Δημιουργία σελίδας σε 0.065 δευτερόλεπτα. 26 ερωτήματα.
