Σάββατο, 14 Νοε 2026, 04:06:45
    Επισκέπτες: 91
    Συνολικά: 91
    Αποστολέας Θέμα: BLADE 550X Ανακοίνωση για ESC από την BLADE  (Αναγνώστηκε 3242 φορές)
    Fer De Lance
    « στις: Παρασκευή, 17 Μαΐ 2013, 21:58:03 »
    Βρήκα πριν από λίγο, αυτήν εδώ την ανακοίνωση και θεωρώντας ότι είναι σωστό να ενημερωθούν οι πιθανοί κάτοχοι άμεσα, την αναδημοσιεύω εδω:
    Εάν κρίνεται ότι κακώς δημοσιεύεται, διαγράψτε την. Πάντως μπράβο στην BLADE η οποία στην ουσία οργανώνει απόσυρση εξαρτήματος με επιστροφή χρημάτων.
    Δεν την μετάφρασα, αλλά το ρεζουμέ είναι ότι έχει πρόβλημα το ESC, με πιθανότητες 6% να είναι ελαττωματικό.
    On Behalf of Horizon Hobby:
    PRODUCT BULLETIN: E-flite 130-amp ESC (EFL3130H) Included with the Blade® 550 X
    May 17, 2013
    Product: E-flite 130Amp ESC (EFL3130H)
    Issue: Horizon Hobby is aware of a small percentage of Blade® 550 X owners who have experienced a failure of the E-flite® 130-amp ESC (EFL3130H) resulting in a loss of power to the motor. The actual number of ESC failures is still relatively low and our data indicates it is currently around 6%. This is only affecting a proportionately small number of Blade 550 X owners, but it is higher than what we consider reasonable. We have been working on a solution, but at this point have been unable to re-create the failure mode pattern as indicated by most customers reporting the problem. It is not required to stop use of the EFL3130H 130-Amp ESC.
    If you decide to discontinue use of the 130-amp ESC included with your 550 X, Horizon Hobby will issue you a $100 check. A sales receipt and return of the ESC is required to receive the check. If you decide to continue using the EFL3130H ESC, the original warranty is still valid, but any product support that necessitates replacement of the original ESC due to failure, will result in the customer receiving a $100 check. Horizon Hobby will no longer stock or issue replacement EFL3130H ESCs
    For customers who decide to return their 130-amp ESC, Horizon Hobby suggests the following products as possible alternatives:
    ESC Product Part Number/ Notes
    Castle Creations Phoenix Edge 100* CSE010010000 The red wire must be removed to disable internal BEC per the Castle Creations instruction manual. This option is only recommended for 14-tooth pinion/sport flying
    Castle Creations Phoenix Edge 130* CSE010009900 The red wire must be removed to disable internal BEC per the Castle Creations instruction manual.
    Castle Creations Phoenix Edge 120HV* CSE010010400
    *Soldering is required
    Other required components:
    E-flite EC2™ device connector w/4” wire (EC2EFLAEC04)
    E-flite EC5™ device connector (EFLAEC501)
    E-flite Gold bullet connector set, 4mm (EFLA249)
    If you decide to return the 130-amp ESC:
    1. Please complete the Return Request form.
    2. Upon receipt of the completed form, a prepaid shipping label will be sent to you. Return your ESC, along with a copy of the Return Request form and sales receipt to Horizon Hobby. Upon receipt of the ESC, Horizon Hobby will issue a check in the amount of $100. Please allow 14-21 days for processing and delivery.
    We apologize for this inconvenience.
    Horizon Hobby Contact Information Address
    Horizon Service Center
    (Repairs and Repair Requests) http://servicecenter.horizonhobby.com/RequestForm/
    4105 Fieldstone Rd
    Champaign, Illinois, 61822 USA
    Horizon Product Support (Product Technical Assistance) http://www.quickbase.com/db/bghj7ey8c?a=GenNewRecord
    888-959-2304
    Sales sales@horizonhobby.com
    888-959-2304
    For customers outside of the United States and Canada, please contact the retailer you purchased the product from.
    « Τελευταία τροποποίηση: Σάββατο, 18 Μαΐ 2013, 00:10:15 από Fer De Lance » Καταγράφηκε
    « Απάντηση #1 στις: Παρασκευή, 17 Μαΐ 2013, 23:53:45 »
    Καλά έκανες..! Μπράβο σου.!
    Aeromodelling GR  |  Forum  |  Ελικόπτερα R/C  |  Ελικόπτερα ηλεκτρικά (Συντονιστής: Γκούσκος Διονύσιος)  |  Θέμα: BLADE 550X Ανακοίνωση για ESC από την BLADE
