Κυριακή, 15 Νοε 2026, 06:09:37
    [Χθες στις 14:01]
    Σύνολο μηνυμάτων: 310070
    Επισκέπτες: 85
    Συνολικά: 85
    Αποστολέας Θέμα: SAB Goblin 630 Flybarless!!!  (Αναγνώστηκε 4289 φορές)
    « στις: Τετάρτη, 18 Ιουλ 2012, 01:31:45 »
    Οι Ιταλοί έβγαλαν και το μικρότερο αδελφάκι, το Goblin 630!!!  Cheesy  Cheesy
    SAB Goblin 630 Flybarless Electric   part number: GOBLIN630
    SAB Goblin 630 – Fear Takes Flight; Competition Takes Cover.
    Evil has come out to play, and the SAB Goblin is ready to take flight, bringing an unworldly level of 3D power that simply cannot be matched. The Goblin 630 has arrived.
    The Italian designers at SAB have been up to no good, conjuring the Goblin for one menacing purpose – domination, and nothing short of it.
    Utilizing patent pending ingenuity, the SAB Goblin 630 takes performance to frightening heights by utilizing a state of the art dual belt drive power system, allowing massive brushless power to be directed to the main rotor without fear of failure so commonly seen with 600 sized electric helicopters today.
    By utilizing a dual stage belt drive system, the Goblin 630 transfers this power to a helical output gear, which in turn drives the main rotor system and driven tail rotor system. Simply put, the power this system can handle is fearsomely evil.
    Ingenuity flows throughout the Goblin, taking shape in the patent pending horizontal servo mounting system that directs servo torque directly to the flybarless main rotor system via short, stiff linkage rods that rotate via bearing raced support. This system is intensely strong, allowing power transfer to be as direct as mechanically possible, resulting in precision & rigidity that is simply unmatched.
    By laying the servos horizontally, instead of installing them as a vertical unit, the CG is optimally lowered, allowing the Goblin to take great advantage of stellar 3D performance. Lower CG (Center of Gravity) directly equates to precision maneuvers throughout the entire realm of flight, allowing the SAB Goblin 630 to perform like no other helicopter flying today.
    Craving performance not of this world? Take hold of the Goblin as it takes hold of you – RC helicopter performance that will bring true fear above, and sheer terror down low.
    Modular Power System – Simple, Elegant, Beautiful
    With the removal of a small handful of bolts, the entire power system will arise from the Goblin – cyclic servos, brushless motor, rotor system, main gear system – allowing this helicopter to be adjusted & repaired with great ease.
    Dual Belt Driven Performance – Simple, Robust, Light Weight
    By utilizing a belt driven main motor, immense power can be transferred without the fear of gear failure. Belt driven systems are amazingly efficient, incredibly durable, and best of all, belt drive systems are ethereally light in weight, cutting out the complexity, noise & added weight of a torque tube drive system.
    12S 44.4V Power – The Goblin is Ready
    Designed from the ground up with the insane power of 12S 44.4V systems, the Goblin was designed to handle every bit of power that can be thrown its way. With the dual stage belt drive system, the Goblin 630 can take full advantage of brutally high output brushless motors that are transforming the very nature of RC helicopter flight. Go for massive power – the Goblin demands it.
    Aerodynamic Boom Shroud – Form & Function in One Beautiful Package
    Italian designing takes one step further, coalescing the aerodynamic canopy with a near seamless transition to a carbon fiber tail boom covering. This aerodynamic shroud brings a unique beauty to the SAB Goblin, serving as an aerodynamic element that allows the Goblin to traverse the skies at mach speeds. Speed and power has never looked so good.
    CNC Aluminum Flybarless Main Rotor System – Nothing but the Best
    Taking full advantage of flybarless technology, the SAB Goblin 630 is offered in a flybarless kit only, utilizing a bearing raced blade grip control system for the absolute in precision & control. Nothing was held back throughout this build, and you can expect nothing less when the Goblin takes flight.
    Light Weight Build – Power that can be Used Like No Other
    By building the SAB Goblin with a keen eye on weight, SAB engineers were able to shave critical weight by utilizing carbon fiber materials & a dual belt driven gear system, which brings the Goblin to new worlds of power & performance.
    Brutalized by the Best – Tareq Alsaadi & Bert Kamerrer
    The SAB Goblin 630 was designed for the most intense flight regimes possible, and when it came to testing & performance, two of the best pilots in the world did their best to find the absolute limits of the Goblin. The Goblin personifies performance, and in the hands of the best, the Goblin is a fearsome sight to behold.
    Patented Carbon Fiber Tail Boom – Strong, Light & Vibration Free
    Reinforced with CNC aluminum for the utmost in strength, the patented carbon fiber tail system eliminates vibrations, allowing maximum rotor speeds to be achieved without the fear of vibration.
    SAB Rotor Blades – Simply the Best
    Rotor blades are the heart & soul of all helicopters, and the Goblin holds nothing back with included high performance, carbon fiber "green" SAB main rotor blades & tail rotor blades, specially designed for the Goblin helicopters, allowing this 3D monster to be pushed farther & faster than all others around.
    Specifications:
    Main rotor diameter: 1428mm (with 630mm blades)
    Main blade length: 600 to 630mm
    Tail rotor diameter: 278mm
    Tail blade length: 105mm
    Main shaft diameter 12mm
    Tail shaft diameter: 6mm
    Spindle diameter: 10mm
    Pinion 20T
    Motor pulley 20T
    Main gear 68T
    Tail pulley 27T
    main pulley 37T
    Ratio
    18T Pinion = ratio 11.3:1
    19T Pinion = ratio 10.7:1
    20T Pinion = ratio 10.2:1
    21T Pinion = ratio 9.7:1(stock ratio)
    22T Pinion = ratio 9.3:1
    23T Pinion = ratio 8.9:1
    24T Pinion = ratio 8.5:1
    26T Pinion = ratio 7.8:1
    With Scorpion motor HKIII 4035-560,
    normal= 20T
    Hard 3D= 21T
    Electronic Specifications:
    Weight including electronics 3220g (excluding batteries).
    Maximum motor size: 64mm diameter, maximum height 64mm
    Battery compartment: 60x58x350mm (adaptable to 64x58x350mm)
    « Απάντηση #1 στις: Τετάρτη, 18 Ιουλ 2012, 01:36:01 »
    Μερικά βίντεο από τους καλύτερους στο σπόρ!!
    Σφαίρα πάει και αυτό!!  Thumbs up
    « Απάντηση #2 στις: Τετάρτη, 18 Ιουλ 2012, 01:44:08 »
    Μερικές φωτογραφίες!!!
    « Απάντηση #3 στις: Τετάρτη, 18 Ιουλ 2012, 14:58:01 »
    Και το 500 βγαινει..!!!:)
    Και μιας και το ειδα τελος για τον tareq με την Sab kai thn Outrage..
    « Απάντηση #4 στις: Τετάρτη, 18 Ιουλ 2012, 20:03:08 »
    Σε ποιούς πάει ο tareq??
    « Απάντηση #5 στις: Τετάρτη, 18 Ιουλ 2012, 21:22:28 »
    Πουθενα προς το παρον..! ισως στην MSH . ειδωμεν.>!
    billiano
    « Απάντηση #6 στις: Τετάρτη, 18 Ιουλ 2012, 22:36:22 »
    Ελα ρε Παυλο ....τι λες τωρα.....θα δουμε το 500 σε Goblin ?
    Τωρα ψηθηκα ....
    « Απάντηση #7 στις: Τετάρτη, 18 Ιουλ 2012, 23:54:18 »
    Τωρα ψηθηκα ....
    Εχεις μία έφεση με τα 500άρια Βασίλη!!!  Cheesy  Thumbs up
    billiano
    « Απάντηση #8 στις: Τετάρτη, 18 Ιουλ 2012, 23:55:55 »
    Ναι Μαρκο ,οτι πιο compact και προσιτο και ευκολο.
    sakis.sofianos
    « Απάντηση #9 στις: Πέμπτη, 19 Ιουλ 2012, 05:23:47 »
    Τωρα ψηθηκα ....
    dhiotis
    « Απάντηση #10 στις: Πέμπτη, 19 Ιουλ 2012, 18:30:15 »
    MSH E ?....
    Welcome baby
     Grin Grin Grin
    « Απάντηση #11 στις: Παρασκευή, 7 Σεπ 2012, 00:54:31 »
    Ωραίο το ελικόπτερο αλλά και ο σχολιασμός είναι όλα τα λεφτά!!  Cheesy   Cheesy    Thumbs up
    Aeromodelling GR  |  Forum  |  Ελικόπτερα R/C  |  Ελικόπτερα ηλεκτρικά (Συντονιστής: Γκούσκος Διονύσιος)  |  Θέμα: SAB Goblin 630 Flybarless!!!
    Δημιουργία σελίδας σε 0.084 δευτερόλεπτα. 25 ερωτήματα.
