Δευτέρα, 9 Νοε 2026, 16:04:10
    [Σήμερα στις 12:01]
    [Χθες στις 13:32]
    Σύνολο μηνυμάτων: 310063
    Online σήμερα: 87
    Επισκέπτες: 70
    Συνολικά: 72
    Αποστολέας Θέμα: TowerPro ESC Manual  (Αναγνώστηκε 1245 φορές)
    « στις: Κυριακή, 8 Ιουλ 2012, 19:29:01 »
    Για όποιον το χρειαστεί το Manual για αυτόν το τύπο ESC ανεξάρτητα απο Αμπέρ είναι το παρακάτω
    * 656.jpg (8.16 KB, 198x145 - εμφανίστηκε 237 φορές.)
    * TP25A.jpg (4.17 KB, 175x117 - εμφανίστηκε 217 φορές.)
    * HXT30A.jpg (4.33 KB, 175x132 - εμφανίστηκε 215 φορές.)
    « Απάντηση #1 στις: Κυριακή, 8 Ιουλ 2012, 19:29:26 »
    Programming the TowerPro ESC is a 2 stage process. The first stage enters programming mode for one of four variables that can be adjusted. The second stage programs the selected variable. The programming process is actually quite simple, once you understand the tones and can identify the variable you wish to change.
    STAGE 1 – Identifying the variable to change and entering programming mode.
    Connect the motor and speed controller to the receiver.
    Turn on the transmitter power and move throttle stick to the full on or UP position.
    Connect battery power to the speed controller.
    After a few seconds you will hear a sequence of tones. 3 tones in a rising melody followed by ID tones. 1 ID tone for Cell Type, 2 ID tones for Brake, 3 ID tones for Timing Mode and 4 ID tones for Cutoff Voltage. (Each sequence will repeat 3 times)
    ∮— CELL Type
    ∮— — BRAKE
    ∮— — — TIMING MODE
    ∮— — — — Cutoff Voltage
    To enter PROGRAMMING MODE for a variable you wish to change, simply move the throttle stick to the middle position when you hear the desired ID tone(s).
    STAGE 2 – Programming the Variable.
    Listen for short ID tone(s) followed by long option tone(s). (Each sequence will repeat 3 times)
    When the desired number of long option tones sounds, move the throttle stick to the UP position to save as indicated by a long beep.
    After saving your option, you will automatically be returned to step 4 of STAGE 1 for additional programming.
    To complete all programming, move the throttle stick to the off or down position and wait for 2 louder beeps.
    CELL Type - Use AUTO for 2 cell LIPO
    •— AUTO Select or NiMh/Nicd
    •— — Force 3 cell LIPO
    •— — — Force 4 cell LIPO
    •— — — — Force 5 cell LIPO
    BRAKE SET
    ••— NONE
    ••— — SOFT
    ••— — — MID
    ••— — — — HARD
    TIMING MODE SET
    •••— 2º
    •••— — 7 º
    •••— — — 15º
    •••— — — — 30º
    CUTOFF VOLTAGE
    ••••— 2.8V/CELL
    ••••— — 2.9V/CELL
    ••••— — — 3.0V/CELL[/quote]
    Aeromodelling GR  |  Forum  |  Το αερομοντελιστικό εργαστήρι  |  Ηλεκτρονικά (Συντονιστές: DEPRON MANIAC, kolotoympas)  |  Θέμα: TowerPro ESC Manual
    Δημιουργία σελίδας σε 0.304 δευτερόλεπτα. 24 ερωτήματα.
