310.035 ìçíýìáôá óå 12.400 èÝìáôá áðü 6.301 ÌÝëç / Ôåëåõôáßï ìÝëïò: Clubdim
ÐáñáóêåõÞ, 30 Ïêô 2026, 20:06:48
    �ñüóöáôá è�ìáôá
    áðü Markhelis
    áðü spirost
    [ÊõñéáêÞ, 25 Ïêô 2026, 14:50:50]
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    [ÐáñáóêåõÞ, 4 Óåð 2026, 16:34:37]
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310035
    Óýíïëï èåìÜôùí: 12400
    Online óÞìåñá: 105
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 2
    ÅðéóêÝðôåò: 86
    ÓõíïëéêÜ: 88
    Óôõë åìöÜíéóçò
    Óåëßäåò: [1]     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: Mercury Alloy 64mm EDF  (Áíáãíþóôçêå 4775 öïñÝò)
    kakofonixx
    Ìçíýìáôá: 492
    « óôéò: ÔåôÜñôç, 21 Äåê 2011, 14:09:19 »
    �åá öáíá (edf) óôá 64mm, ìåôáëëéêç ìå ôñïìåñç áðïäïóç êáé áðéóôåõôï ç÷ï ãéá ôï ìåãåèïò ôçò!
    ðéèáíïôáôá ïôé êáëõôåñï êáé áðïäïôéêïôåñï óå áõôï ôï ìåãåèïò!
    êõêëïöïñåé óå äõï åêäïóåéò:
    ìå ìïôåñ óôá 3700kv Þ óôá 4700kv
    1. åêäïóç 3700kv
    Motor: 2430-3700kv High Performance EDF Brushless
    EDF Unit: 64mm
    Battery: 11.1v ~ 18.5v (3s ~ 5s Max)
    AMP Draw: 76 amp (Max)
    Watts: 1482 watts (Max)
    Thrust: 1800g
    ESC: 40A~80A
    Unit Weight: 162g
    Test Data:
    11.9v (3s) 2600mah / 35amp / 417watt / 840g Thrust
    12.2v (3s) 5200mah / 37amp / 451watt / 870g Thrust
    15.5v (4s) 2600mah / 54amp / 837watt / 1300g Thrust
    16.0v (4s) 5200mah / 56amp / 896watt / 1400g Thrust
    19.0v (5s) 2600mah / 73amp / 1387watt / 1650g Thrust
    19.5v (5s) 5200mah / 76amp / 1482watt / 1800g Thrust
    2. åêäïóç 4700kv
    Motor: 2430-4700kv High Performance EDF Brushless
    EDF Unit: 64mm
    Battery: 7.4v ~ 14.8v (2s ~ 4s Max)
    Watts: 1140 watts (Max)
    Thrust: 1600g
    ESC: 40A~80A
    Unit Weight: 162g
    Test Data:
    11.6v (3s) 2600mah / 54amp / 626watt / 1040g Thrust
    12.0v (3s) 5200mah / 57amp / 684watt / 1100g Thrust
    14.6v (4s) 2600mah / 73amp / 1066watt / 1550g Thrust
    15.0v (4s) 5200mah / 76amp / 1140watt / 1600g Thrust
    óêåöôïìáé íá áãïñáóù ôçí åêäïóç ôùí 3700kv ãéá íåï jetáêé ðïõ å÷ù óôá óêáñéá!
    ðåñéóóïôåñá åäù:
    http://www.epf.com.tw/goods.php?id=125
    http://www.epf.com.tw/goods.php?id=124
    * Mercury 64A 5S-2.JPG (36.26 KB, 640x480 - åìöáíßóôçêå 763 öïñÝò.)
    ÊáôáãñÜöçêå
    kakofonixx
    Ìçíýìáôá: 492
    « ÁðÜíôçóç #1 óôéò: ÔåôÜñôç, 21 Äåê 2011, 14:14:56 »
    êáé äõï âéíôåáêéá! åíá óôïí ðáãêï êáé åíá óôïí áåñá!
    ÊáôáãñÜöçêå
    ÄçìÞôñçò ¢ñôá
    Ìçíýìáôá: 2.317
    « ÁðÜíôçóç #2 óôéò: ÔåôÜñôç, 21 Äåê 2011, 22:04:29 »
    ÓêÃ�øïõ üìùò....!Ãéá íá áðïäüóåé ôï ìÃ�ãéóôï ôçò(ôá 1800ãñ). èÃ�ëåé  ìðáôáñßá 19.5v (5s) 5200mah / 76amp.....!Ã�ðüôå Üí âÜëåéò, ìðáôáñßá, öÜíá ,speed control êáé óÃ�ñâï....ôüôå ðëçóéÜæåéò ôá 1200-1300ãñ.Ã�ïõ èá âñåßò ôæåôÜêé üìùò, ãýñù óôï Ã�íá êéëü ðåñßðïõ, ðïõ íá Ã�÷åé êáé ôï êáôÜëëçëï ìÃ�ãåèïò íá ôá ÷ùñÜåé üëá ôá ðáñáðÜíù!??
    Äõóôõ÷þò ç ðéü óõìöÃ�ñïõóá åðéëïãÞ áðü ôïí HobbyKing åßíáé áõôÞ åäþ   http://www.hobbyking.com/hobbyking/store/__17223__Alloy_DPS_Series_90mm_EDF_unit_with_1900kv_Motor_1750watt.html
    Ã�ëëÜ ôï êáêü óôçí éóôïñßá åßíáé üôé èá ðÜò óå  ìåãáëýôåñï ìÃ�ãåèïò ôæåôÜêé....!
    ÊáôáãñÜöçêå
    �åôÜìå ?
    Dimhack
    Ìçíýìáôá: 1.441
    « ÁðÜíôçóç #3 óôéò: ÐÝìðôç, 22 Äåê 2011, 06:21:58 »
    áñêåôÜ êáëÞ áëëá ü÷é êáé ç äõíáôüôåñç.
    ìå ìéá åîßóïõ êáëÞ öáíÜ åðþíõìç ìðïñåßò íá ðéÜóåéò áõôÞ ôçí osi.åéäéêÜ ìå ôçí êáéíïýñãéá ôçí STUMAX 69 ç ôçí íÃ�á TAMJET 68  ìå ëéãüôåñá óôïé÷åéá âëÃ�ðåéò êáé 2 kg, ðÜíôá ìå ìïôÃ�ñ NEU,HET,OREX. SCORPOION IN RUNNER,
    äåí áîßæåé óå êáìéá ðåñßðôùóç íá äüóåéò ÷ñÞìáôá ãéá ìéá öáíÜ ô�ôïéïõ ìåã�èïõò. ëüãï ôïõ üôé ðñïóáñìüæïíôáé ìïíï óå ìéêñÜ ìïíô�ëá êáé ìå åëÜ÷éóôï âÜñïò ôï max ôéò "öáíáò" 64mm äåí èá ôï äåéò ðïôå.
    óå ðïéï ìïíôÃ�ëï èá âÜëåéò 64MM EDF  5 óôïé÷åéá 5000 MAH? ìéáò êáé áðü êáôáíÜëùóç èá õðÜñ÷åé áñêåôÞ áí êñßíù áðü ôá 76 amp ðïõ æçôÜåé óôéò ôóßôåò.
    ìïíï ôï âÜñïò ãéá ðñïóãåßùóç åîßóïõ êáé ãéá áðïãåßùóç èá óå îåíåñþóåé ôüóï ðïõ èá ôï óêåöôåßò íá ôï îáíÜ ðåôÜîåéò.
    ðÜíôá áðü ðñïóùðéêÞ åìðåéñßá ôï ë�ù ìéá êáé �÷ù äïêéìÜóåé 64 öáíÜ óôá ô�ñìáôá ôéò êáé ôï ìïíô�ëï åß÷å âãåé 2kg ðåñßðïõ âÜñïò. ìéëÜìå ãéá �íá "ôæåôáêé" 70 ðüíôïõò �êëåéíåò ôï ãêÜæé êáé åñ÷üôáí óáí ôïýâëï êÜôù.
    ìçí ÷áëÜôå ÷ñÞìáôá ãéá áêñéâÜ setup óå ôüóï ìéêñ�ò öáí�ò.
    ðÜíôá öéëéêÜ äçìÞôñçò. Wink
    ÊáôáãñÜöçêå
    kakofonixx
    Ìçíýìáôá: 492
    « ÁðÜíôçóç #4 óôéò: ÐÝìðôç, 22 Äåê 2011, 10:14:50 »
    èá óõìöùíçóù êáé ìå ôïõò äõï Äçìçôñçäåò! ×áìüãåëï
    áðëá åãù ôçí åâáëá ãéá íá ôç äïõìå êáé íá ìïéñáóôïõìå ãíùìåò êáé åìðåéñéåò
    ðéóôåõù ôï éäáíéêï óåôáð ãéá ôç óõãêåêñéìåíç öáíá åéíáé óôá 4S ãéá ôïõò ëïãïõò ðïõ áíåöåñáí êáé ôá ðáéäéá ðéï ðáíù
    ìå ìéá êáôáíáëùóç ~55� èá å÷åé åíá ëïãéêï ÷ñïíï ìåéêôçò (áñãçò-ãñçãïñçò) ðôçóçò êáé ìéá êáëç ó÷åóç âáñïõò/áðïäïóçò
    ôï ìïíôåëï ðïõ óêåöôïìáé íá ôçí âáëù åéíáé ôï Stinger áðï ÇÊ
    ìå ôç óõãêåêñéìåíç öáíá + ìðáôáñéá Ôurnigy nano-tech 2650mah 4S 35~70C (ðïõ å÷ù äéáèåóéìåò) õðïëïãéæù åíá ïëéêï âáñïò ãéá ðôçóç ðåñé ôá 850ãñ
    áí âáóåé ôùí specs ç öáíá óôá 4S äéíåé ùóç 1400ãñ ôïôå ìéëáìå ãéá öïâåñç äõíáìç óôï ìïíôåëï (+ôïí åîáéñåôéêï ç÷ï!) Wink
    ÊáôáãñÜöçêå
    Dimhack
    Ìçíýìáôá: 1.441
    « ÁðÜíôçóç #5 óôéò: ÐÝìðôç, 22 Äåê 2011, 14:41:04 »
    ç öáíÜ ç óõãêåêñéì�íç �÷åé 8 blades êáé �÷åé âÞìá ó÷åäüí 5 ìå 6 stet, èá áêïýãåôáé ðïëý êáëÜ áëëá èá ëåðôïóöõñßæåé êáé ðïëý ëüãï âÞìáôïò êáé blades.
    ÊáôáãñÜöçêå
    kakofonixx
    Ìçíýìáôá: 492
    « ÁðÜíôçóç #6 óôéò: Ôñßôç, 24 Éáí 2012, 12:52:28 »
     Cheesy Cheesy
    ìïëéò åöôáóå óôá ÷åñéá ìïõ!!  áðï èåìá êáôáóêåõçò öáéíåôáé õðåñï÷ç!
    ôåëéêá êáôåëçîá óôçí åêäïóç ôùí 4700kv ãéá ÷ñçóç (áñ÷éêá) ìå 3S ìðáôáñéá!
    áíõðïìïíù íá êáíù ôéò áðáñáéôçôåò êïëëçóåéò êáé íá öïñôéóïõí ïé ìðáôáñéåò ãéá íá ãéíïõí ïé ðñùôåò äïêéìåò!!
    ÊáôáãñÜöçêå
    kakofonixx
    Ìçíýìáôá: 492
    « ÁðÜíôçóç #7 óôéò: Ôñßôç, 24 Éáí 2012, 12:54:33 »
    êáé ìéá öùôï áðï ôï ìïíôåëï óôï ïðïéï èá ìðåé!
    HobbyKing Stinger 64 EDF Sport Jet
    ÊáôáãñÜöçêå
    kakofonixx
    Ìçíýìáôá: 492
    « ÁðÜíôçóç #8 óôéò: Ôñßôç, 24 Éáí 2012, 14:40:50 »
    åãéíáí ïé ðñùôåò äïêéìåò!
    ìå ìðáôáñéá Rhino 2250mAh 3S 25C Lipo:
    45Amps peak, ãõñù óôá 500Watts
    on Turnigy nano-tech 2650mah 4S 35~70C Lipo:
    65Amps peak, ãõñù óôá 900Watts
    ïé äïêéìåò åãéíáí ìå esc Topfire 70A óåôáñéóìåíï óå high timing
    ç öáíá äïõëåøå ðïëõ ïìáëá, çôáí áðïëõôá æõãéóìåíç êáé ïëá çôáí åëá÷éóôá æåóôá åðåéôá áðï ìåñéêá äåõôåñïëåðôá öïõë ãêáæé
    Ã�åñéìåíá ëéãï êáëõôåñç áðïäïóç... Ã�éóôåõù ïôé ìáëëïí èá ðñåðåé íá áíáâáèìéóù ôéò ìðáôáñéåò ìïõ ìå áëëåò ìå ðåñéóóïôåñá C åêöïñôéóçò ãéá íá öáíåé ç ðñáãìáôéêç äõíáìç ôçò öáíáò  Ã—áìüãåëï
    ÊáôáãñÜöçêå
    smartalex
    Ìçíýìáôá: 360
    « ÁðÜíôçóç #9 óôéò: Ôñßôç, 15 Éáí 2013, 15:25:30 »
    ãåéá óïõ öéëå ,
    ôåëéêá ìå ôï stigner ôé åêáíåò , ôïõ åâáëåò åðáíù ôçí öáíá .
    óå ñùôáù ãéá ôï øá÷íù áðåëðéóìåíá êáé èåëù íá å÷ù åéêïíá ãéá ôï óôçóéìï ôïõ .
    ÊáôáãñÜöçêå
    Óåëßäåò: [1]     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Ã�åñïðëÜíá R/C - Êáýóéìï  |  Ôæåô êáé ôïõñìðßíåò  |  ÈÝìá: Mercury Alloy 64mm EDF
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.038 äåõôåñüëåðôá. 25 åñùôÞìáôá.
