Τρίτη, 13 Οκτ 2026, 05:54:59
    [Χθες στις 13:52]
    Online σήμερα: 38
    Επισκέπτες: 36
    Συνολικά: 36
    Σελίδες: 1 ... 17 18 19 [20] 21 22 23 24     Κάτω
    Αποστολέας Θέμα: Buddy Price απο hobbyKIng...  (Αναγνώστηκε 171601 φορές)
    optimus79
    « Απάντηση #285 στις: Σάββατο, 19 Ιαν 2013, 16:55:06 »
    Find my codes here: http://hk.rc-international.info/swarm/sakis (valid until February 02, 2013)
    On Board Lipoly Low Voltage Alarm (2s~4s)          Save US$: 0.12
    Slow Fly Electric Prop 9047SF (4 pc)              Save US$: 0.39
    Slow Fly Electric Prop 9047R SF (4 pc Right Hand Rotation) Save US$: 0.39
    Slow Fly Electric Prop 9047 SF (4 pc - Green)      Save US$: 0.18
    M3 Nylon Nut (10pcs/bag)                          Save US$: 0.17
    5.6mm x 16mm M3 Nylon Threaded Spacer (10pc)      Save US$: 0.41
    GT450PRO Plastic Tail Boom Holder                  Save US$: 0.29
    HobbyKing Programming card for BlueSeries Brushless Speed Controller Save US$: 0.46
    Wing Skids 28x10x12mm (10pcs)                      Save US$: 0.18
    TGS Sport 5x5E Precision propeller                Save US$: 0.03
    TGS Sport 6x5E Precision propeller                Save US$: 1.16
    TGS Sport 6x4E Precision propeller                Save US$: 0.28
    Male XT60 connectors (5pcs/bag) GENUINE            Save US$: 0.20
    Glass Fiber Cloth 450x1000mm 48g/m2 (Ultra Thin)  Save US$: 0.19
    Balance Plug Savers (JST-XH 3s) (5pc Per Bag)      Save US$: 0.10
    Front Wheel Steering Arm and Mount Set 40mm (5sets) Save US$: 0.34
    Turnigy Pure-Silicone Wire 16AWG (1mtr) Red        Save US$: 0.61
    Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK      Save US$: 0.61
    Turnigy Heat Shrink Tube 25mm Transparent (1mtr)  Save US$: 0.18
    Linkage Stopper D2.1mm (10sets)                    Save US$: 0.08
    PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)      Save US$: 0.19
    HK450 carbon tail boom                            Save US$: 1.02
    USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.77
    Threaded Ends M2xL20mm (10pcs/set)                Save US$: 0.94
    Nylon Clevis 2x29mm (10pcs)                        Save US$: 0.16
    har28
    « Απάντηση #286 στις: Δευτέρα, 21 Ιαν 2013, 12:53:05 »
    1. http://www.hobbyking.com/buddy.asp?code=FB2CFD45-C9C5-4DCC-B55B-70F401A7EBB8
    2. http://www.hobbyking.com/buddy.asp?code=89E5A357-0C5B-4C0E-ABA2-F63127A14DCE
    3. http://www.hobbyking.com/buddy.asp?code=7566AAE3-7409-4FAF-8D71-6D24F0C27281
    4. http://www.hobbyking.com/buddy.asp?code=BE0E51B6-D546-46CF-99C6-C94DE721A8CC
    5. http://www.hobbyking.com/buddy.asp?code=CF338BFE-D9F0-4513-9331-24D8E7A685D8
    6. http://www.hobbyking.com/buddy.asp?code=41ED89C6-F35C-449E-B234-D30C95D714C8
    1. X-BLADE Precision knife with replaceable SK-5 blade
    2. Twelve 2-56 Gold-N-Clevises
    3. Turnigy Heat Shrink Tube 10mm BLACK (1mtr)
    4. Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
    5. Turnigy 6mm Heat Shrink Tube - RED (1mtr)
    6. Nose Art - "Pacific Princess" (L/R sided)
    ΧΑΡΗΣ ΠΡΕΒΕΖΑ!!!
    stavrakis
    « Απάντηση #287 στις: Πέμπτη, 24 Ιαν 2013, 11:21:58 »
    http://www.hobbyking.com/buddy.asp?code=02C55C20-0A14-49B1-8F48-D163350A15E9
    http://www.hobbyking.com/buddy.asp?code=50618FCE-9437-4A21-BB5C-BF84250D3E71
    1.HK15178 Analog Servo 10g / 1.4kg / 0.09s
    2.Hobby Hand Sander Set
    canibals
    « Απάντηση #288 στις: Παρασκευή, 25 Ιαν 2013, 12:19:48 »
    325mm Glass Fiber Main Blades (Blue/white)        Save US$: 0.63
    HK450V2 Feathering Shaft Set (41x4mmxM2)          Save US$: 0.78
    HK450V2 Main Shaft                                Save US$: 0.49
    Flybarless Head Assembly Trex 450 / HK450          Save US$: 0.23
    HK450V2 Screws                                    Save US$: 0.49
    HK-450 Metal Tail Rotor Shaft upgrade version (HS1203) Save US$: 0.18
    NTM Prop Drive 28-26 1000KV / 315W                Save US$: 2.55
    HXT Alloy Composite Stick Mount 20mm              Save US$: 0.19
    Insta-Set CA Accelerator 2. oz                    Save US$: 0.93
    Turnigy Soft Silicone Lipo Battery Protector (White) Save US$: 0.71
    HK450V2 Tail Boom                                  Save US$: 0.23
    Propeller Adapter (Colet Type) 4MM                Save US$: 0.44
    HXT 4mm to XT-60 Battery Adapter (2pcs/bag)        Save US$: 1.06
    christos77
    « Απάντηση #289 στις: Τετάρτη, 30 Ιαν 2013, 14:28:25 »
    Temperature Sensor w/ Futaba plug      Μόνο $2.42
    http://www.hobbyking.com/buddy.asp?code=976E3C3B-4193-4AE3-9E66-A2FF7AAF8016
    Cable Ties HS2.5x60mm 100pc (Natural White)      Μόνο $0.64
    http://www.hobbyking.com/buddy.asp?code=BA25E163-6A6B-433F-88CD-8DF338024BCA
    Ισχυουν μεχρι 13/2/12
    Belt cp - Παλευω να κανω ενα αξιοπρεπες hover...
    Προσεχως FPV plane...
    christos77
    « Απάντηση #290 στις: Δευτέρα, 4 Φεβ 2013, 12:24:50 »
    Turnigy 9XR Safety Protected 11.1v (3s) 2200mAh 1.5C Transmitter Pack      Μονο $10.87
    http://www.hobbyking.com/buddy.asp?code=E16B9BFF-5EBE-465C-912C-F9BDEA516C1E
    On Board Lipoly Low Voltage Alarm (2s~4s)      Μονο $1.79
    http://www.hobbyking.com/buddy.asp?code=EEC6F45D-ED8D-4D53-9E7B-D1B7F54AC75E
    45CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag)     Μονο $1.38
    http://www.hobbyking.com/buddy.asp?code=3E8755CF-26D1-45F5-88BC-C04FF306DE4F
    Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)      Μονο $0.07
    http://www.hobbyking.com/buddy.asp?code=D5C76F0B-F230-49FD-97F8-272AFFAD2F3F
    Ισχύουν μέχρι 18/2/13
    kostas_var
    « Απάντηση #291 στις: Δευτέρα, 11 Φεβ 2013, 17:56:48 »
    Find my codes here: http://hk.rc-international.info/swarm/kostas_var (valid until February 25, 2013)
    Turnigy Aerodrive SK3 - 42-XX Spare Accessory Pack Save US$: 1.70
    T-REX 550
    T-45 Goshawk
    P-51 Mustang
    Formoza I
    errikos
    « Απάντηση #292 στις: Παρασκευή, 15 Φεβ 2013, 15:55:29 »
    http://www.hobbyking.com/buddy.asp?code=08B9C3A8-9515-472B-9AB8-ACB68B85B5F6
    vilisdev
    SV2BLH
    « Απάντηση #293 στις: Σάββατο, 23 Φεβ 2013, 11:16:48 »
    SU-26 Gas 50cc 2260mm (ARF) (NL Warehouse)
    http://www.hobbyking.com/buddy.asp?code=35145636-5053-4F86-A4C2-3F97C9F33398
    Από 455$ αρχική βγαίνει στα 417,38$ συν 19,83$ μεταφορικά από Ολλανδία.
    Λήγει στις 9-3-2013
    * su26-sub1.jpg (33.25 KB, 565x414 - εμφανίστηκε 514 φορές.)
    « Τελευταία τροποποίηση: Σάββατο, 23 Φεβ 2013, 11:27:13 από vilisdev » Καταγράφηκε
    mihelone
    « Απάντηση #294 στις: Πέμπτη, 28 Φεβ 2013, 16:17:02 »
    http://www.hobbyking.com/buddy.asp?code=6DCDAA6B-4107-41B6-A799-6D3D75A7C54E,TGS 12x6.5F Precision Folding propeller
    http://www.hobbyking.com/buddy.asp?code=52AE493A-2FE7-4EF6-9909-DCD305BD052B, Steering Arms M3.2 (5pcs/bag)
    http://www.hobbyking.com/buddy.asp?code=279C4A43-762E-4C75-B7BD-AD157AB8779B, Canopy Lock 30x8mm (10pcs/bag)
    http://www.hobbyking.com/buddy.asp?code=D4ECE88B-0C42-417B-8C90-4317E88F659A, Steering Arms (Fullarm) 10x40mm (5pcs)
    http://www.hobbyking.com/buddy.asp?code=F8799D63-5EA5-4608-ADDD-20C8213A6BB4, Folding Propeller 13x7 W/ Alloy hub 40mm / 4.0mm shaft
    http://www.hobbyking.com/buddy.asp?code=9B84EB76-FE87-41DF-BE8F-34F7F5A14A8F, Steering Arms M5 (5pcs/bag)
    dodos
    « Απάντηση #295 στις: Παρασκευή, 1 Μαρ 2013, 09:45:50 »
     http://www.hobbyking.com/buddy.asp?code=585BCA91-4EB3-4D65-98E1-C6B69BFD2A2F     M4 x 60mm Stand-offs (Green)
    http://www.hobbyking.com/buddy.asp?code=E40F7C1F-A156-4A3A-8139-86A2D316708E      Teflon Coupler with clips (25mm Pipe) for Muffler
    http://www.hobbyking.com/buddy.asp?code=393220F3-260F-4B1E-819D-16B91F34C554        Alloy Fuel Dot for large scale Gas Planes
    http://www.hobbyking.com/buddy.asp?code=BA612411-004D-43BA-9784-8581B40A521C      Large Fuel Clunk with filter for Gas/Turbine powered models
    http://www.hobbyking.com/buddy.asp?code=DABD64E6-1CF1-426A-82CE-3CA9CB2EFDE2       Fuel Tank 240cc
    http://www.hobbyking.com/buddy.asp?code=FDD49DBC-FC5B-42DC-BD71-23D5A815D9B1      Fuel Tank Bung (Gas/Petrol)
    Bladedancer
    Θέλω να πετάξω τώρα!!!!
    « Απάντηση #296 στις: Παρασκευή, 1 Μαρ 2013, 10:50:39 »
    Hobbyking Parallel charging Board for 6 packs 2~6S (XT-60) Save US$: 3.61
    Fly.
    « Απάντηση #297 στις: Κυριακή, 10 Μαρ 2013, 17:46:33 »
      - http://www.hobbyking.com/buddy.asp?code=C8B69858-7145-4ADC-9079-94E987F59A1B / TURNIGY Plush 60amp Speed Controller
      - http://www.hobbyking.com/buddy.asp?code=603C955E-B10C-4B75-A1BD-2C75EDF72EEE /Turnigy TGY-9018MG Metal Gear Servo 2.5kg/13g/0.10
      - http://www.hobbyking.com/buddy.asp?code=B1290A94-90F6-4023-93C6-BE4501983D44 /HXT900 Replacement Gear Set
      - http://www.hobbyking.com/buddy.asp?code=FF3395C5-F926-47ED-8846-08681D9702DC /Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack
     Ισχύει για 14 ημέρες από σήμερα.
     FLY.
    gfdimopo
    « Απάντηση #298 στις: Τετάρτη, 20 Μαρ 2013, 12:07:23 »
    Turnigy 5000 mah 40C - 50C 6S   56.85 dollars από 67.16 dollars !
    http://www.hobbyking.com/buddy.asp?code=993C5D6B-1933-4C4B-A459-DC87D5A25E85
    Stargazer
    « Απάντηση #299 στις: Τρίτη, 26 Μαρ 2013, 22:08:43 »
    HobbyKing Glow Plug No.3 (HOT)   http://www.hobbyking.com/buddy.asp?code=8CECD238-F411-4A7F-AD1F-F3BD58944BE5
    Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack  http://www.hobbyking.com/buddy.asp?code=36C43CB1-A819-40D7-A526-74314F696017
    Male XT60 <-> Female T-Connector (1pc/bag)  http://www.hobbyking.com/buddy.asp?code=F9227EDC-66D7-4FB3-AE11-8AEBDE838EE6
    Turnigy nano-tech 850mah 2S 25~40C Lipo Pack  http://www.hobbyking.com/buddy.asp?code=776B99A2-C849-43B2-B1C4-3187F5A2A2AC
    HobbyKing 4-6min Epoxy Glue  http://www.hobbyking.com/buddy.asp?code=F5101BB0-5552-4016-9117-D537E50B235E
    Cyanoacrylate (Super Glue) Single Pack  http://www.hobbyking.com/buddy.asp?code=435B1C2B-A76F-4233-8DC6-43E1CE51BBC7
    Silicon fuel pipe (1 mtr) White for Nitro Engines 4x2.5mm  http://www.hobbyking.com/buddy.asp?code=7E54461A-7BAD-4835-93AA-E6720AEC3514
    10CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set)  http://www.hobbyking.com/buddy.asp?code=A11D4F46-2983-4B47-813B-72D4CA1ED50E
    HK15178 Analog Servo 10g / 1.4kg / 0.09s   http://www.hobbyking.com/buddy.asp?code=2276FF50-69A0-4B6B-96C3-0BA40E900D4C
    14 μέρες από σήμερα
    Live To Fly, Fly To Live
    Σελίδες: 1 ... 17 18 19 [20] 21 22 23 24     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ο Ελληνας αερομοντελλιστής και η αγορά υλικών (Συντονιστής: Serafim)  |  Θέμα: Buddy Price απο hobbyKIng...
    Δημιουργία σελίδας σε 0.045 δευτερόλεπτα. 24 ερωτήματα.
