Παρασκευή, 9 Οκτ 2026, 17:45:20
    [Σήμερα στις 14:18]
    Σύνολο μηνυμάτων: 310012
    Επισκέπτες: 24
    Συνολικά: 25
    Σελίδες: 1 ... 14 15 16 [17] 18 19 20 ... 24     Κάτω
    Αποστολέας Θέμα: Buddy Price απο hobbyKIng...  (Αναγνώστηκε 171339 φορές)
    zoombii
    « Απάντηση #240 στις: Δευτέρα, 3 Σεπ 2012, 14:16:42 »
    http://www.hobbyking.com/buddy.asp?code=A4DA9E78-B853-4220-8E73-721F4B1BB71E
    http://www.hobbyking.com/buddy.asp?code=0D33ED5E-7E1C-40EE-AA9A-08D05DF62FA4
    http://www.hobbyking.com/buddy.asp?code=8AD86B63-36A2-4F8A-860D-F79665376BF2
    http://www.hobbyking.com/buddy.asp?code=8CD66375-F49D-4F33-857B-F9715F0691DC
    http://www.hobbyking.com/buddy.asp?code=B96ED675-4496-4A87-AB70-8B4B63ACAA44
    http://www.hobbyking.com/buddy.asp?code=EF6C1561-5739-4200-9824-86F4FFA4A752
    http://www.hobbyking.com/buddy.asp?code=6E1DB324-8C03-45AA-8ED6-0211ED2D74AE
    http://www.hobbyking.com/buddy.asp?code=6812D01F-E8E8-4BEF-9CAA-6FC9D51FF190
    http://www.hobbyking.com/buddy.asp?code=851DC208-D29A-4484-920C-B3EB6155523D
    http://www.hobbyking.com/buddy.asp?code=DAD3BD58-236C-458B-8659-23415F473D8A
     και απο μενα σαν καινουργιος
    ΠΑΥΛΟΣ ΘΕΟΔΩΡΙΔΗΣ
    « Απάντηση #241 στις: Δευτέρα, 3 Σεπ 2012, 15:06:22 »
     WireLabels - servo wire label heatshrink (14mm x 1m)
    http://www.hobbyking.com/buddy.asp?code=42407C51-97CA-4D94-B68C-8362FECA4F02
     Control Surface Throw Gauge
    http://www.hobbyking.com/buddy.asp?code=78F8FF4C-BF45-40EF-BD91-B21C2DE216B3
     X-BLADE Spare SK-5 Steel blades (10pcs/set)
    http://www.hobbyking.com/buddy.asp?code=375DCD89-AFF3-450F-A4A0-90FF740055D0
     Silicon fuel pipe (1 mtr) Yellow for Gas/Nitro Engines 4x2.5mm
    http://www.hobbyking.com/buddy.asp?code=21DCF5D6-4B95-490E-B3D4-7A29F1FC4EC3
     Fuel Tank 550cc
    http://www.hobbyking.com/buddy.asp?code=E8800364-9D39-4FCB-862B-C35EAC6E0FA3
     Fuel Line Guard with Silver Coupler
    http://www.hobbyking.com/buddy.asp?code=906D636C-4DE2-4460-AFE7-4DB66DE1C986
     Quick-Cure 5 Min Epoxy 4.5 oz
    http://www.hobbyking.com/buddy.asp?code=1D27867A-1915-4C8D-81AA-2891343A40E0
    angel 50, T-REX 600 limited edition    http://www.serresairclub.gr/
    http://www.airphotos.gr/
    kefalonitis
    « Απάντηση #242 στις: Τρίτη, 4 Σεπ 2012, 13:08:17 »
    http://www.hobbyking.com/buddy.asp?code=E03281A0-BAF2-484C-B827-048D695DC761
    Turnigy R/C LED Lighting System
    http://www.hobbyking.com/buddy.asp?code=98283B57-327D-4C3F-8000-2DE9FF5AF703
    Turnigy nano-tech 460mah 2S 25~40C Lipo Pack
    http://www.hobbyking.com/buddy.asp?code=06704FF3-71FB-4D73-8F0E-FAAA2B1E3F86
    Turnigy Magnetic Precision Prop Balancer
    http://www.hobbyking.com/buddy.asp?code=13DB4E3A-A496-4377-83EA-7C96791B58B6
    canibals
    « Απάντηση #243 στις: Πέμπτη, 6 Σεπ 2012, 12:33:43 »
    HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA)
    http://www.hobbyking.com/buddy.asp?code=0841E69D-08D2-471F-A04F-E7B60B242A26
    http://www.hobbyking.com/buddy.asp?code=1A9E998F-FFE3-4935-8506-DECA858F1B7D
    Master Airscrew propeller 8.5x6 (Pusher)
    http://www.hobbyking.com/buddy.asp?code=B0FDA802-30CD-4740-85D3-627E2A3DC5AF
    Landing Gear Wheel Stop Set Collar 8x3.1mm (10pcs)
    http://www.hobbyking.com/buddy.asp?code=815CA297-437E-4832-97D2-24119A9BDC51
    Front Lower Suspension Arms L/R (2pcs) - A2029 and A2035
    http://www.hobbyking.com/buddy.asp?code=1AB43FDC-85BF-4881-B3C6-100F74614CA5
    Front Upper Suspension arms (left/right) - 110BS, A2029 and A2035
    http://www.hobbyking.com/buddy.asp?code=9573FB35-453C-47C4-AC31-E00AAFED419C
    Hobbyking X666 Glass Fiber Quadcopter Frame 666mm
    http://www.hobbyking.com/buddy.asp?code=2CF2E74E-C7F8-42E3-8006-7525A9615D95
    Diff.Pinion Gear S (3pc) - 110BS, A2003T, A2029 and A2035
    http://www.hobbyking.com/buddy.asp?code=03B27920-8A31-4A02-924D-CACB5D5B3192
    Flat 26AWG servo wire 1mtr (R/B/W)
    http://www.hobbyking.com/buddy.asp?code=71F730CB-728D-41F6-BAD2-AFC7A1C8FC92
    http://hk.rc-international.info/swarm/canibals
    ΜΟΝΟ ΓΙΑ 14 ΗΜΕΡΕΣ....
    tzidis
    « Απάντηση #244 στις: Παρασκευή, 7 Σεπ 2012, 01:10:47 »
    Αυτά και από εμένα
    Alloy Motor Heat Sink for 28mm Motor
    http://www.hobbyking.com/buddy.asp?code=FEB395A5-0E1D-4ED6-938D-0EFFAED90247
    2inch Quick G-Clamp Tool
    http://www.hobbyking.com/buddy.asp?code=352EEE85-E6DD-4C11-B476-7AEF49434952
    Peel-n-stick foam tape. 10x5inch 4mm thick
    http://www.hobbyking.com/buddy.asp?code=1F2CF1B4-0656-4896-8E82-08D755F7DF2A
    Alloy E-Prop Spinners AC376 3.17mm to 6.35mm
    http://www.hobbyking.com/buddy.asp?code=3C9AEF96-F59E-4F0F-804A-09E08C4C2AD1
    Prop adapter w/ Alu Cone M5x3mm shaft (Grub
    http://www.hobbyking.com/buddy.asp?code=3F909C82-6039-41D2-81C2-C9B90D35F94C
    Landing Gear for Micro Indoor Plane (1pair)
    http://www.hobbyking.com/buddy.asp?code=735FD03A-39E6-4BE4-BD0B-C399C33A5AB5
    Wing Skids 28x10x12mm (10pcs)
    http://www.hobbyking.com/buddy.asp?code=B30B641D-B3F3-429D-A335-5DA19248DF32
    Slow Fly Electric Prop 9047 SF (4 pc - Green
    http://www.hobbyking.com/buddy.asp?code=7944628B-9B2D-4566-B38E-BC0DAC01F4E3
    ZIPPY Compact 2700mAh 3S 25C Lipo Pack
    http://www.hobbyking.com/buddy.asp?code=061C0191-8615-49E6-B173-281DB0C63D27
    HobbyKing Red Brick 70A ESC (Opto)
    http://www.hobbyking.com/buddy.asp?code=C7AC0D79-BB71-4C0C-8F6B-F1A3BF0202E4
    Slow Fly Electric Prop 11X4.7SF (4 pc)
    http://www.hobbyking.com/buddy.asp?code=C669903E-FA2C-4805-B740-6DB028B9B11C
    Master Airscrew propeller 8x6 (Pusher)
    http://www.hobbyking.com/buddy.asp?code=F69D87B7-5D1C-41B5-9608-0DF2E2CC1ACA
    αυτά!!  Wink
    ημερομηνεία λήξης : 15/09/2012
    Galans
    « Απάντηση #245 στις: Παρασκευή, 7 Σεπ 2012, 23:42:01 »
    Parallel charging Board for 6 packs 2~6S (T
    http://www.hobbyking.com/buddy.asp?code=9FC2861A-52E7-4498-BA9D-AD744914576B
    Turnigy 130A Watt Meter and Power Analyzer
    http://www.hobbyking.com/buddy.asp?code=1195B0B1-BB15-453F-B748-8FE3335C2B1C
    Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set
    http://www.hobbyking.com/buddy.asp?code=8DA39DEA-D972-40B8-BFF9-3A6CD0A96FBA
    canibals
    « Απάντηση #246 στις: Σάββατο, 8 Σεπ 2012, 00:30:57 »
    και λιγα ακομα....
    Hobbyking Bixler EPO 1400mm KIT
    http://www.hobbyking.com/buddy.asp?code=BD7448A7-F141-4DDA-B892-32FA718E901A
    NTM Prop Drive Series 28-30A 750kv / 140w
    http://www.hobbyking.com/buddy.asp?code=A27A9C51-EC3B-4F7F-A23A-2E7238AE9D30
    NTM Prop Drive 28-26 1000KV / 315W
    http://www.hobbyking.com/buddy.asp?code=D728D4FE-2C71-4BAE-A751-6203B1340312
    http://www.hobbyking.com/buddy.asp?code=6090D2B6-F1F1-4571-9DB6-D7C9E498E4A0
    http://www.hobbyking.com/buddy.asp?code=B26DF2A5-67D6-42F0-B315-2EEB0E820147
    10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Green)
    http://www.hobbyking.com/buddy.asp?code=F7131FEE-072C-4BCA-B6A0-02B7D8BF8BC4
    XT60 to T-Connector Battery Adapter Lead (2pc)
    http://www.hobbyking.com/buddy.asp?code=4F89F5F3-BAB2-4F92-A4BC-73DD708CFE91
    NTM Prop Drive 3530 Series Replacement Shaft
    http://www.hobbyking.com/buddy.asp?code=83726074-00F2-4B74-A47A-FCA98E8F0C01
    μονο για 14 ημερες και μονο εδω.....
    « Τελευταία τροποποίηση: Κυριακή, 9 Σεπ 2012, 23:28:15 από canibals » Καταγράφηκε
    errikos
    « Απάντηση #247 στις: Δευτέρα, 10 Σεπ 2012, 19:57:08 »
    hk 450 tt pro v2 torgue tube
    http://www.hobbyking.com/buddy.asp?code=E8B3CE99-D164-4E63-ABDE-370FD17929DF
    μονο 53 δολαρια!!!! για 7 μερες ακομα
    « Απάντηση #248 στις: Τρίτη, 11 Σεπ 2012, 13:49:51 »
    Rhino 2250mAh 3S 11.1v 40C Lipoly Pack
    http://www.hobbyking.com/buddy.asp?code=6DD9E1F2-FFC6-44DF-A0CA-B896AA6B2577
    Μόνο 15,45$ από 24,26$!!   Cheesy   Cheesy
    cygamer
    « Απάντηση #249 στις: Τρίτη, 11 Σεπ 2012, 19:48:01 »
       Turnigy FBL100 3D Micro Helicopter (RTF)
    http://www.hobbyking.com/buddy.asp?code=0C98D134-8251-4ED1-808D-9EFC37082703
            TURNIGY Plush 30amp Speed Controller
    http://www.hobbyking.com/buddy.asp?code=589F3B5C-EA11-4AFE-8B52-60795422CB56
            Turnigy 2632 Brushless Motor 3400kv
    http://www.hobbyking.com/buddy.asp?code=5B792C4B-79AB-474B-9947-EF8F95ACA1CD
            Turnigy nano-tech 1300mAh 3S 45~90C Lipo Pac
    http://www.hobbyking.com/buddy.asp?code=AB17C254-BA7C-4547-A6DF-12C921181B36
            Turnigy nano-tech 300mah 1S 45C Lipo Pack
    http://www.hobbyking.com/buddy.asp?code=5259D010-2B95-4DB8-B192-427A3C0DC61C
            Turnigy R/C Helicopter Pitch Gauge
    http://www.hobbyking.com/buddy.asp?code=8F8572D4-E63A-4F70-B0C8-BE91AA02547F
             HobbyKing ParkJet (KIT)
    http://www.hobbyking.com/buddy.asp?code=D777EC0A-BC37-4673-BACA-0319568CE8BE
    « Τελευταία τροποποίηση: Τρίτη, 11 Σεπ 2012, 20:00:43 από cygamer » Καταγράφηκε
    kakofonixx
    « Απάντηση #250 στις: Τρίτη, 18 Σεπ 2012, 13:34:57 »
    Καλημερα, δυο κωδικοι και απο εμενα:
    H-King Cellmeter-7 Lipo/Life/Li-ion/Nimh/Nicd Digital Battery Checker
    http://www.hobbyking.com/buddy.asp?code=874D4D98-E552-40D9-95C2-D64F98BE93E6
    Insta-Set CA Accelerator 2. oz
    http://www.hobbyking.com/buddy.asp?code=95262802-9233-4B1B-9BC9-E4EF32518199
    0 teo
    ουδέν κρυπτόν υπό του ηλίου
    « Απάντηση #251 στις: Τρίτη, 18 Σεπ 2012, 18:31:10 »
    Συνήθως όταν δεν περιμένω κάτι δεν κοιτάζω καν το γραμματοκιβώτιο.
    Και σήμερα ήταν μια τέτοια μέρα... δεν περίμενα κάτι άρα δεν θα το κοίταζα.
    Κάτι όμως με έσπρωξε να πάω να το τσεκάρω.
    Βρήκα μέσα αυτό:
    Μπορώ να πω δεν το περίμενα ποτέ από το HobbyKing ένα καθαρά e-shop να μου στείλει τον κατάλογό του σε έντυπη μορφή.
    Γι αυτό και ενθουσιάστηκα και το φωτογράφησα όλο.
    Εντάξει... να στείλει ένα διαφημιστικό φυλλάδιο το καταλαβαίνω... να θέλει να προωθήσει μια νέα σειρά το καταλαβαίνω... μα να στήσει 36σέλιδο με 6άρια γράμματα;!
    Για όσους έχουν καλή όραση λοιπόν, αλλά δεν έχουν εύκολα πρόσβαση στο internet ή για όσους θέλουν να συζητήσουν κάτι στην αλάνα θα είναι χρήσιμο.
    Για όσους δεν το έχουν λάβει ακόμα μπορούν να το δουν εδώ (κατεβείτε λίγο στη σελίδα).
    Καλή μελέτη!
    Αν πρέπει ας μεταφερθεί σε άλλο θέμα ή αν ξεκινήσει κουβέντα για αυτό ας ανοιχτεί ξεχωριστό θέμα.
    FrSky ACCST @ Spektrum-DX7
    asterixx25
    Τρία πουλάκια κάθονται...
    « Απάντηση #252 στις: Τρίτη, 18 Σεπ 2012, 20:44:43 »
    Βρήκα μέσα αυτό:
    Καλή μελέτη!
    Ηρθε και σε εμένα. Πολύ πυκνογραμμένο, έχει στριμώξει σχεδόν όλα τα προιόντα, με σχετικά λίγες φωτογραφίες για τον όγκο των προιόντων (εντάξει δεν θα μπορούσε να τις βάλεις όλες), αλλά μετά απο 3-5 λεπτά διαβάσματος κουράζει...
    0 teo
    « Απάντηση #253 στις: Τρίτη, 25 Σεπ 2012, 12:38:59 »
    Find my codes here: http://hk.rc-international.info/swarm/0-teo (valid until October 09, 2012)
    Slow-Cure 30 Min Epoxy 9. oz                       Save US$: 2.30
    Control Surface Throw Gauge                       Save US$: 1.27
    3K Woven Carbon Fiber Cloth (160g/m2) 1mtr         Save US$: 3.09
    185mm BEC Eliminator Cable                         Save US$: 0.14
    Glass Fiber Cloth 500x1000mm (Light weight)       Save US$: 1.52
    Carbon Fiber Control Horn 32x24mm (2pcs/bag)       Save US$: 0.34
    ssmr
    « Απάντηση #254 στις: Τετάρτη, 26 Σεπ 2012, 09:48:47 »
    Καλημερα ,
    Βρειτε τους κωδικους μου εδω : http://hk.rc-international.info/swarm/ssmr
    (valid until October 10, 2012)
    Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack      Save US$: 5.93
    CNC Metal Transmitter Stand JR and Futaba          Save US$: 1.60
    RC Car Camber Gauge - General Purpose              Save US$: 1.38
    Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
    Σελίδες: 1 ... 14 15 16 [17] 18 19 20 ... 24     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ο Ελληνας αερομοντελλιστής και η αγορά υλικών (Συντονιστής: Serafim)  |  Θέμα: Buddy Price απο hobbyKIng...
    Δημιουργία σελίδας σε 0.031 δευτερόλεπτα. 24 ερωτήματα.
