ÊõñéáêÞ, 1 Íïå 2026, 03:38:17
    Ðñüóöáôá èÝìáôá
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:11:29]
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:07:37]
    áðü Markhelis
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310037
    Óýíïëï èåìÜôùí: 12401
    Online óÞìåñá: 52
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 0
    ÅðéóêÝðôåò: 51
    ÓõíïëéêÜ: 51
    Óôõë åìöÜíéóçò
    Óåëßäåò: [1]     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: ×ÑÏÍÏÓ ÐÔÇÓÇÓ ??  (Áíáãíþóôçêå 4186 öïñÝò)
    ×ñçóôïò Âáãåíáò (vchris)
    Ìçíýìáôá: 1.339
    « óôéò: ÄåõôÝñá, 28 Éïõí 2010, 08:58:29 »
     Êáëçìåñá óáò
    å÷ù åíá áíåìïðôåñï ìå ìïôåñ 480-size, 960Kv brushless outrunner
    êáé óõãêåêñéìåíá áõôï ParkZone Radian PNP
    # Wingspan:�78.7 in (2 m)
    # Overall Length:�44.7 in (1140mm)
    # Flying Weight:�30 oz
    # Motor Size:�480-size, 960Kv brushless outrunner from ParkZone
    # Radio:�Minimum 4-channel recommended (not included)
    # Servos:�3-wire servos (included)
    # Trim Scheme Colors:�White with blue and green
    # CG (center of gravity):�62mm behind the leading edge of the wing
    # Speed Control :�E-flite's 30A brushless ESC with Switch-Mode BEC (included)
    # Recommended Battery:�11.1V 1300mAh Li-Po
    åêáíá ôéò ðñùôåò ìïõ ðôçóåéò ìå äõï ìðáôáñéåò
    ìéá 1500 mAh 20c & ç äåõôåñç 2200mAh 25-30c
     ìå ôç ðñùôç ìðáôáñéá ìåôá áðï 25 ëåðôá åé÷å áäåéáóåé (ôï ìïôåñ äïõëåøå ôñåéò öïñåò áðï 40 äåõôåñïëåðôá ðåñéðïõ
    êáé ìå ôç äåõôåñç åêáíá ðôçóç ãéá 32 ëåðôá (ôï ìïôåñ äïõëåøå 4 öïñåò áðï 40 äåõôåñá ðáëé)
    êáé óôéò äõï ðåñéðôùóåéò ïé ìðáôáñéåò óôï ôåëïò åé÷áí 11.2 volt áðï 12.4 óôçí áñ÷ç
    åéíáé ëïãéêï? ç êáôé åéíáé ëáèïò?
    ðåñéìåíá ðåñéóóïôåñç ùñá ðôçóçò
    áí âáëù ìðáôáñéá ìå ëéãïôåñá ç ðåñéóóïôåñá (c) èá áëëáîåé êáôé?
    ÊáôáãñÜöçêå
    pakos_65
    Ìçíýìáôá: 237
    « ÁðÜíôçóç #1 óôéò: ÄåõôÝñá, 28 Éïõí 2010, 12:07:44 »
    Ìå ôé ðñïðÝëá ðåôïýóåò êáé ðüóá ÁìðÝñ "ôñáâïýóå" ôï ìïôÝñ óïõ?
    ÊáôáãñÜöçêå
    Ç áðïãåßùóç åßíáé ðñïáéñåôéêÞ.....áëëÜ ç ðñïóãåßùóç ÕÐÏ×ÑÅÙÔÉÊÇ.......!!!!!
    http://users.otenet.gr/~pakos_65/index.htm
    Ìçíýìáôá: 1.339
    « ÁðÜíôçóç #2 óôéò: ÄåõôÝñá, 28 Éïõí 2010, 12:15:44 »
    äå îåñù ðïóá áìðåñ ôñáâáåé
    ï åëéêáò êáé ôï ìïôåñ åéíáé áõôá ðïõ äéíåé ï êáôáóêåõáóôçò êáé áíáöåñù ðïéï ðáíù
    êáé ôï manual ëååé ïôé ìå 1300 mAh ìðáôáñéá ðåôáò ìéóç ùñá
    ïôáí ôï ëååé áõôï åíùåé ìéóç ùñá ìå ôï ìïôåñ íá äïõëåõåé ç äéáêåêïìåíá?
    áëëá êáé ðáëé ìå 2200 ìðáôáñéá äå èá åðñåðå íá å÷ù 45 ëåðôá ôï ëéãïôåñï??
    ÊáôáãñÜöçêå
    ÃéÜííçò ÊùíóôáíôáêÜôïò
    Ìçíýìáôá: 6.297
    AKA "jkon" Þ "èåßïò ÃéÜííçò"
    « ÁðÜíôçóç #3 óôéò: ÄåõôÝñá, 28 Éïõí 2010, 12:55:47 »
    Êáô' áñ÷Þ, üôáí ìéëÜìå ãéá ìðáôáñßåò 20-25 C, ç ùöÝëéìç ÷ùñçôéêüôçôá åßíáé êÜðùò ìéêñüôåñç áðü ôçí ïíïìáóôéêÞ.
    Åóôù ëïéðüí üôé âÜæåéò ôçí 3S/1500mAh. ÁõôÞ èá ôçí õðïëïãßæåéò üôé äßíåé 1300 mAh = 1,3 Áh ìå ÷áìçëÜ áìðÝñ, Þ 1200mAh = 1,2 Ah üôáí äßíåé ðåñéóóüôåñá áìðÝñ.
    ÌåôáôñÝðïõìå ôá áìðåñþñéá óå áìðåñïëåðôÜ, ðïëëáðëáóéÜæïíôáò *60
    Áñá 1,3Ah * 60 min (ëåðôÜ) = 78 Amin (Þ 78 áìðåñïëåðôÜ)
    Áñá 1,2Ah * 60 min (ëåðôÜ) = 72 Ámin (Þ 72 áìðåñïëåðôÜ)
    Áí ëïéðüí ôï ìïôÝñ ìå ôçí Ýëéêá ðïõ Ý÷åé ôñáâÜåé ð.÷. 20 ÁìðÝñ, ï ÷ñüíïò ëåéôïõñãßáò óôï öïõë ôùí óôñïöþí èá åßíáé:
    78 áìðåñïëåðôÜ / 20 áìðÝñ = 3,9 ëåðôÜ ëåéôïõñãßáò (ðåñßðïõ).
    Áí ôñáâÜåé ð.÷. 25 ÁìðÝñ, ï ÷ñüíïò ëåéôïõñãßáò óôï öïõë ôùí óôñïöþí èá åßíáé:
    72 áìðåñïëåðôÜ / 25 áìðÝñ = 2,9 ëåðôÜ ëåéôïõñãßáò (ðåñßðïõ).
    ÊáôáãñÜöçêå
    Ðñüåäñïò Å.Á.Á.
    Ìçíýìáôá: 1.339
    « ÁðÜíôçóç #4 óôéò: ÄåõôÝñá, 28 Éïõí 2010, 14:10:16 »
    âáóç áõôùí ëïéðïí êáé åðåéäç åéíáé êáé ïé ìðáôáñéåò ëéãï ðáëéåò åéíáé åíôáîåé ï ÷ñïíïò
    åõ÷áñéóôù
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 6.297
    « ÁðÜíôçóç #5 óôéò: ÄåõôÝñá, 28 Éïõí 2010, 16:59:53 »
    ÐñÜãìáôé ïé ìéêñüôåñïé ÷ñüíïé óôçí ðåñßðôùóÞ óïõ ìðïñïýí íá ïöåßëïíôáé óå ðáëéÜ ìðáôáñßá, ç óôï üôé ôï ìïôÝñ æïñßæåôáé ðåñéóóüôåñï, ôñáâþíôáò 25 êáé 30 ÁìðÝñ. ÊÜíå ôéò äéáéñÝóåéò íá äåéò ôá áðïôåëÝóìáôá.
    Ôï ìïôÝñ ðïõ áíáöÝñåéò Ý÷åé óôáèåñÜ Kv= 960, ðïõ óçìáßíåé üôé ãéá êÜèå Âïëô ðïõ ôïõ äéíåéò ãõñßæåé 960 óôñïöÝò ôï ëåðôü (÷ùñßò öïñôßï).
    Ìßá ìðáôáñßá 3 óôïé÷åßùí, Ý÷åé êáôÜ ôçí åêöüñôéóç ìÝóç ôÜóç 11 Âïëôò, Üñá ôï èåùñçôéêü üñéï óôñïöþí óôï óõãêåêñéìÝíï ìïôÝñ èá åßíáé ôï ãéíüìåíï 960 * 11= 10560 ó.á.ë.
    Ïé ðñáãìáôéêÝò óôñïöÝò èá êõìáíèïýí ìåôáîý 8500 - 9500 êáé áõôü óõíåðÜãåôáé ìéêñÞ äéÜìåôñï Ýëéêáò, êáé ìéêñü âÞìá, ãéá íá ìçí óôïëÜñåé.
    Äåí ãíùñßæù ðüóï âáñý (ðüóá ãñáììÜñéá) åßíáé ôï ìïôÝñ, ãéá íá ôï êáôáôÜîù óå ïìÜäá ìå üìïéá êáé íá êÜíù óõãêñßóåéò.
    Ôï ðéèáíüôåñï åßíáé üôé èá áðÝäéäå êáëýôåñá ìå äýï óôïé÷åßá óôéò 5000-5500 ó.á.ë., ìå ìåãáëýôåñç Ýëéêá.
    ÊáôáãñÜöçêå
    Ðñüåäñïò Å.Á.Á.
    DEPRON MANIAC
    Ìçíýìáôá: 1.118
    Ìçí áíáãêÜæåéò Üëëïõò íá áãáðÞóïõí áõôü ðïõ êÜíåéò
    « ÁðÜíôçóç #6 óôéò: ÄåõôÝñá, 28 Éïõí 2010, 23:32:08 »
      Βάση της ιστοσελίδας του μοντέλου. και εκεί που αναφέρει:
    Approx. Flying Duration: Flight times in excess of 30 minutes when using the ParkZone 1300mAh Li-Po battery and limited motor run
      Τα κόκκινα μεταφράζονται: περιορισμένη χρήση μοτέρ
      Πιο κάτω και στην ενότητα Support-> parts listing μεταφέρει στα ανταλακτικά και θα σταθώ στην έλικα η οποία είναι 9,75χ7,5 Åêðëçîç Μάλλον έχει μεγάλο βήμα που κατα τη γνώμη δικαιολογεί και τα λίγα Κν του μοτέρ. Όμως νομίζω δεν χρειάζεται τόσο μεγάλο βήμα για τόσο μεγάλο άνοιγμα φτερού. Δεν μπορεί να κερδίσει σε ταχύτητα.
      Πιστεύω οτι με μια έλικα 10χ5 ή 11χ5 θα έχει καλύτερα αποτελέσματα απόδοσης και διάρκειας πτήσης.
    ÊáôáãñÜöçêå
    Ôá êáýóéìá êÜðïôå èá ôåëåéþóïõí. Ôá çëåêôñüíéá äåí ôåëåéþíïõí ðïôÝ
    Âñå ìáíßá ìå ôï depron
     Ï flight controller åßíáé èáõìÜóéï ìç÷Üíçìá áëëÜ äåí êÜíåé èáýìáôá
    êáé ðñïðáíôþò äåí Ý÷åé íïçìïóýíç, ãé'áõôü ÷ñçóéìïðïßçóå ôçí äéêÞ óïõ
     ¼óï ðéï smart ãßíåôáé ç ôå÷íïëïãßá ôüóï ðéï ÷áæüò ãßíåôáé ï Üíèñùðïò
    Ìçíýìáôá: 1.339
    « ÁðÜíôçóç #7 óôéò: Ôñßôç, 29 Éïõí 2010, 01:12:00 »
    ôá çëåêôñéêá äåí åéíáé ôïóï áðëá ïóï öáéíïíôáé  Sad
    âáóç ôïõ ôõðïõ ìïõ âãçêå êáé ï ÷ñïíïò ðôçóçò åí ìåñç
    ïôáí ôåëåéùóá ôç ðôçóç åé÷á âáëåé ìïôåñ ðåñéðïõ 1 ëåðôï
    öïñôéóá ôç ìðáôáñéá êáé ðçñå 468mAh
    ïðïôå 0.468*60=28.08/20=1.4 ëåðôá
    ç ìðáôáñéá åéíáé 1500mAh êáé åé÷å 12.58 volt êáé óôï ôåëïò 11.25 volt
    ðïéï êáôù áðï 11.2 äå ðñåðåé íá ðáåé ç  ìðáôáñéá åôóé?
    ìå÷ñé åêåé åé÷å êáôáíáëùóåé 468 áñá ìåíïõí áëëá 1032
    ïðïôå ôï 1.5*60=90/20=4.5 ëåðôá äåí éó÷õåé
    óùóôï ç êáðïõ êáíù ëáèïò?
    åêôïò êáé ç ïíïìáóôéêç åíäåéîç 1500mAh äåí éó÷õåé êáé åéíáé ôá ìéóá (ç äå ðáéæåé áõôï?)
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 6.297
    « ÁðÜíôçóç #8 óôéò: Ôñßôç, 29 Éïõí 2010, 07:26:20 »
    âáóç ôïõ ôõðïõ ìïõ âãçêå êáé ï ÷ñïíïò ðôçóçò åí ìåñç ïôáí ôåëåéùóá ôç ðôçóç åé÷á âáëåé ìïôåñ ðåñéðïõ 1 ëåðôï
    öïñôéóá ôç ìðáôáñéá êáé ðçñå 468mAh ïðïôå 0.468*60=28.08/20=1.4 ëåðôá
    ðïéï êáôù áðï 11.2 äå ðñåðåé íá ðáåé ç  ìðáôáñéá åôóé? ìå÷ñé åêåé åé÷å êáôáíáëùóåé 468 áñá ìåíïõí áëëá 1032
    ïðïôå ôï 1.5*60=90/20=4.5 ëåðôá äåí éó÷õåé óùóôï ç êáðïõ êáíù ëáèïò?
    Téò áðáíôÞóåéò óôéò ðáñáðÜíù åñùôÞóåéò óïõ ôéò Ý÷ù Þäç ðáñïõóéÜóåé óôï ðñïçãïýìåíï post ìïõ. Ôï ìüíï ðïõ èá ðñïóèÝóù åßíáé üôé ç ôÜóç ìðïñåß íá ðÝóåé Ýùò êáé 3 Âïëôò áíÜ óôïé÷åßï (9 Âïëôò óôá 3 óôïé÷åßá).
    ÊáôáãñÜöçêå
    Ðñüåäñïò Å.Á.Á.
    Ìçíýìáôá: 6.297
    « ÁðÜíôçóç #9 óôéò: Ôñßôç, 29 Éïõí 2010, 07:37:00 »
    Åíá ðïëý åíäéáöÝñïí ìÞíõìá åìöáíßæåôáé óôçí éóôïóåëßäá ôïõ åí ëüãù ìïôïáíåìüðôåñïõ.
    Ç åôáéñåßá áðïóýñåé ôçí áñ÷éêÞ Ýëéêá ëüãù ìéêñÞò áíôï÷Þò êáé ôçí áíôéêáèéóôÜ ìå ßäéïõ ìåãÝèïõò óùóôÞò áíôï÷Þò.
    ÊáôáãñÜöçêå
    Ðñüåäñïò Å.Á.Á.
    Ìçíýìáôá: 1.339
    « ÁðÜíôçóç #10 óôéò: Ôñßôç, 29 Éïõí 2010, 08:18:53 »
    åõ÷áñéóôù ãéá ôéò áðáíôçóåéò êáé ôéò äéåõêñéíéóåéò
    êáé ìéá ôåëåõôáéá (åëðéæù)
    áí êïøù ôï êáëùäéï (+) ðïõ ðáåé áðï ôï esc óôï äåêôç êáé âáëù îå÷ùñéóôç ìðáôáñéá äåí õðáñ÷åé ðñïâëçìá åôóé?
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 8.631
    Ðñïóùðéêç ìïõ ãíùìç,äåí åðéâáëëù óå êáíåíá êáé ôðô
    « ÁðÜíôçóç #11 óôéò: Ôñßôç, 29 Éïõí 2010, 12:16:37 »
    ï÷é êáíåíá åéíáé óáí íá áðåíåñãïðïéåéò ôï Bec...!
    ÊáôáãñÜöçêå
    N/JOI
    Ìçíýìáôá: 185
    « ÁðÜíôçóç #12 óôéò: Ôñßôç, 29 Éïõí 2010, 17:47:14 »
    Xñçóôï êáé åãþ ôï Ý÷ù êüøåé êáé å÷ù ôçí Ýîôñá ìðáôáñßá
    ÊáôáãñÜöçêå
    N/JOI WORKS
    Ìçíýìáôá: 1.339
    « ÁðÜíôçóç #13 óôéò: Ôñßôç, 29 Éïõí 2010, 22:03:42 »
    åõ÷áñéóôù èá ôï êáíù ôïõëá÷éóôïí íá å÷ù äåêôç ãéáôé ìå áõôï ôï ðñáãìá îå÷íéåóáé åõêïëá ×áìüãåëï
    ÊáôáãñÜöçêå
    Óåëßäåò: [1]     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Áíåìüðôåñá R/C  |  Ïëá ôá áíåìüðôåñá R/C (ÓõíôïíéóôÝò: ÃéÜííçò ÐáîéìáäÜêçò, _ÔÁÓÏÓ_)  |  ÈÝìá: ×ÑÏÍÏÓ ÐÔÇÓÇÓ ??
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.042 äåõôåñüëåðôá. 25 åñùôÞìáôá.
