Δευτέρα, 12 Οκτ 2026, 02:11:16
    [Χθες στις 21:11]
    Σύνολο μηνυμάτων: 310014
    Online σήμερα: 37
    Επισκέπτες: 37
    Συνολικά: 38
    Αποστολέας Θέμα: Hyperion CX & VX G3 Li-po Batteries  (Αναγνώστηκε 1920 φορές)
    Paulos
    « στις: Παρασκευή, 17 Ιουλ 2009, 23:34:58 »
    Hyperion Generation 3 Lithium Polymer Packs are proving truly revolutionary in both performance and value. Compared to an average of the batteries on market last year, they provide up to up to 4x more cycles under the same discharge conditions.  And that makes them a bargain price-wise.
    But they also deliver the highest voltage and flattest discharge curves under load that we have ever seen, which makes them the best performer you can buy.  And tests have shown that at the 70%-discharged point in flight, they are delivering as much as 40% more power than previous generation LiPo.
    The fact that they can be safely charged at up to 5C rates - for charge times as low as 10 to 12 minutes - is just icing on a very tasty cake.
    The G3 packs are made with a new Hybrid RS construction technology, super-fine substrate materials, rigorous ISO 9001 Quality Control, and final cell matching process, which all guarantee you not only this superb performance, but also tightly balanced and long-lasting packs.
    The G3 LiPo come in two series.  "CX" 25C are appropriate for most models and deliver high capacity and power per gram at low cost.  The "VX" 35C series is the one for applications that need the highest possible voltage maintained at high discharge rates; for example highly aerobatic 3D airplanes and helicopters, competition gliders, pylon racers, and some EDF jets.
    επίσης διάβασα ότι και η flight power ετοιμάζει μπαταρίες με 9C φόρτιση
    spam on
    όταν με το καλό πέσουν οι τιμές για μεγάλα packs π.χ 5S - 6S με βλέπω να γίνομαι ηλεκτρικός   lalala
    spam off
    Pilot Haris
    « Απάντηση #1 στις: Σάββατο, 18 Ιουλ 2009, 03:36:40 »
    Eidi aytes oi mpataries arxisan kai kikloforoun. to thema einai na se afini o fortistis sou na mporis na tis dosis parapano amper. p.x mia mpataria 2000 mAmp o dikos mou fortistis den me afini na doso pano apo 2 A fortisis. ton exo vevaia merika xronia. oi kainourgoi fortistes mpori na to kanoun. den ksero. pantos tis mpataries aytes tis exo dei kai den exoun kamia apollitos diafora apo aytes pou kseroume mexri tora. kai sxedon stis idies times (an thimame kala) . milame panta gia Ellada kai oxi gia eksoteriko. Eksoteriko den exo dei - koitaksi kati tetoio.
    Aurora-
    Raptor X50-
    Gemini Multiplex-
    Fun Jet Multiplex-
    Twin Jet Multiplxex-
    Minimoa ArtTech-
    Yak 54 Thunder Tiger-
    DogFighter Multiplex-
    Tucan  Multiplex-
    EasyStar II  Multiplex-
    Paulos
    « Απάντηση #2 στις: Σάββατο, 18 Ιουλ 2009, 10:08:37 »
    καλημέρα
    όντως κυκλοφορούν και σε πολύ καλή τιμή
    http://www.hobbyworld.gr/shop/contents/en-us/d111.html
    http://www.skyhobbies.com.sg/Lipo_Batteries_HYPERION_LVX.htm
    το πρόβλημα δεν είναι τόσο ο φορτιστής όσο το πόσο μεγάλο τροφοδοτικό πρέπει κάποιος να έχει για να κάνει φόρτιση στα 5C & 9C μια μπαταρία ας πούμε 6S 5000mah
    βέβαια σιγά μη μείνουν πίσω και σε θέματα τροφοδοτικού απλά να τα κάνουν όσο μπορούν πιο μικρά και όχι τροφοδοτικά των 30 κιλών
    Serafim
    « Απάντηση #3 στις: Σάββατο, 18 Ιουλ 2009, 23:37:15 »
    Καλησπέρα κι από μένα
    Παύλο το πρόβλημα δεν είναι το τροφοδοτικό.  Στο σπίτι υπάρχει χρόνος και το 1C είναι υπέραρκετό.  Άλλωστε το νόημα αυτών των μπαταριών είναι να μπορείς να φορτίζεις γρηγορότερα στο μοντελοδρόμιο έτσι ώστε και να μην περιμένεις αλλά και να μην χρειάζεται να έχεις 4-5 μπαταρίες.  Και εκεί είναι το πρόβλημα.
    Όταν εμένα ο φορτιστής τραβάει 14A για να φορτίσει την 6S 5000mA στο 1C, που να βρεις φορτιστή που να τις φορτίσει με 25Α ή 45Α και με τι να βρεις 70A ή 126Α αντίστοιχα να του δώσεις?  Φυσικά λύσεις θα υπάρχουν αλλά δεν είναι απλά τα πράγματα (και φθηνά).
    Το πλεονέκτημα αυτών των μπαταριών είναι στα μικρά μεγέθη, τουλάχιστον προς το παρόν.
    Σεραφείμ
    Aeromodelling GR  |  Forum  |  Το αερομοντελιστικό εργαστήρι  |  Ηλεκτρονικά (Συντονιστές: DEPRON MANIAC, kolotoympas)  |  Θέμα: Hyperion CX & VX G3 Li-po Batteries
    Δημιουργία σελίδας σε 0.021 δευτερόλεπτα. 27 ερωτήματα.
