Παρασκευή, 13 Νοε 2026, 11:01:48
    [Σήμερα στις 01:50]
    Σύνολο μηνυμάτων: 310066
    Online σήμερα: 131
    Επισκέπτες: 77
    Συνολικά: 78
    Αποστολέας Θέμα: Φωτια σε αμαξι στο μοντελοδρομιο απο LIPO  (Αναγνώστηκε 11012 φορές)
    « στις: Πέμπτη, 4 Ιουν 2009, 00:27:28 »
    Προσθήκη από administrator: http://runryder.com/helicopter/t519305p1/
    Αυτο το βρηκα γραμμενο απο το εξωτερικο δειτε τι μπορει να παθει κανεις...
    " Just a caution to all of you who play with Lipo's
    Hello
    I hope this email finds you in good health and spirits. Well
    I went flying today and went into my car to charge a battery
    like I've done a hundred times before. I hooked my battery
    up to the charger as usual and plugged in the balancer and
    set the charger to about 1,000 mh's it was a 2100mh lipo
    battery. So I went out of my van to talk to Gray Neil and
    about 3 or 4 minutes later so one yelled out that their was
    a fire in my car. I looked over at my car and theirs was
    flames coming out of the passenger front window. And then
    all hell broke out. The three lipo batteries in the front
    seat began to explode, then the car battery exploded the
    tires exploded the gas tank exploded the flames shot up and
    out thirty feet in the air. That caught the car
    cover/carport on fire too. The good news is that their is a
    fire house 5 hundred feet away the bad new is their was no
    one their. So my car burned 15 to twenty minutes before the
    fire trucks arrived. Well my car is a total loss.
    So my the lesson in this story is don't charge your lipo
    batteries unattended and maybe not charge them in your car
    either. I hope you all don't have to learn the hard way like
    me. The news people from channel 12 was their so I am sure
    you'll be seeing me on the news tonight and probable the
    hole weekend with my luck. You all have a nice weekend and
    be safe and oh yes I am ok but my nerve's are shoot."
    « Τελευταία τροποποίηση: Πέμπτη, 4 Ιουν 2009, 08:52:47 από Κώστας Κωστόπουλος » Καταγράφηκε
    Paulos
    « Απάντηση #1 στις: Πέμπτη, 4 Ιουν 2009, 01:09:24 »
    λυπάμαι .....
    @ με την ασφάλεια του μπορεί να γίνει κάτι ;
    BizGreece
    « Απάντηση #2 στις: Πέμπτη, 4 Ιουν 2009, 01:18:59 »
    Χρησιμοποιούμε μόνο επώνυμους φορτιστές και μπαταρίες
    Καλό το φθηνό αλλά το πληρώνεις  ακριβά στο τέλος
    tasospap
    « Απάντηση #3 στις: Πέμπτη, 4 Ιουν 2009, 01:25:36 »
    Νομιζω οτι για αποφυγη τετοιων ατυχηματων υπαρχουν και η σακουλες προστασιας Lipo safe.
    https://PrivateLadyEscorts.com - Local Live Chat Dating - No Verify - Anonymous Casual Dating -   Local Meet Private Lady
    Paulos
    « Απάντηση #4 στις: Πέμπτη, 4 Ιουν 2009, 06:59:40 »
    τί σχέση έχει αυτό με το αν πρέπει να φορτίζουμε μέσα ή έξω από το αμάξι ή σε οποιοδήποτε άλλο μέρος που υπάρχει πιθανότητα να γίνει κάτι τέτοιο ; - δηλαδή με επώνυμους φορτιστές και επώνυμες μπαταρίες θα έχουμε το κεφάλι μας ήσυχο ; θα λέμε φορτίζω με hyperion τις flight power μου και δεν πρόκειται να πάρω φωτιά ;
    ναι θα συμφωνήσω ότι μειώνουμε τις πιθανότητες αλλά όχι ότι δεν υπάρχουν
    καλημέρα σας...
    Αντώνης Παπαδόπουλος
    « Απάντηση #5 στις: Πέμπτη, 4 Ιουν 2009, 07:39:22 »
    Καλημέρα,
    Το συγκεκριμένο γεγονός μπορεί να συμβεί οχι μόνο στο αυτοκίνητο αλλά και στο σπίτι αν φορτίζουμε Lipo και εκεί.
    Παρόμοια περιστατικά έχουν γίνει και στην Ελλάδα (και σε αυτοκίνητο και σε σπίτι) και προκάλεσαν σημαντικές ζημιές.
    Η αερομοντελιστική ασφάλιση που υπάρχει αυτή την στιγμή δεν καλύπτει ανάλογες περιπτώσεις. Ενας λόγος για ακόμα μεγαλύτερη προσοχή στην φόρτιση των lipo's.
    « Απάντηση #6 στις: Πέμπτη, 4 Ιουν 2009, 07:47:29 »
    Η πιθανότητα να παρει φωτιά μια Lipo  μηδενίζεται , μόνο με την χρήση αντιπυρικής  σακούλας , τόσο κατά την φόρτιση , οσο και κατά την μεταφορά και αποθήκευση .
    Ετσι έχουμε το κεφάλι μας ήσυχο .
    Τωρα με τις ζέστες  γενικά αποφεύγω να αφήνω τις LIPO  στο αυτοκίνητο  κατα την διάρκεια των πτήσεων .Οχι τοσο γιατι φοβάμαι την πιθανότητα φωτιάς, οσο γιατι στη ζεστη του αυτοκινήτου ταλαιπωρούνται χωρίς λόγο .
    Αλλα και έξω απο το αυτοκίνητο  τις εχω πάντα μέσα στην σακούλα .
    ΥΣ. ( προσωπική άποψη )
    Οι φτηνές μπαταρίες εχουν πάψει προ πολλού να ειναι "ανώνυμα κινέζικα σκουπίδια ". Το ιδιο και οι φορτιστές .
    Ειναι ο λογος  που εχει αναπτυχθεί τοσο πολύ η ηλεκτροκίνηση  αερομοντελων  στην Ελλάδα.
    « Απάντηση #7 στις: Πέμπτη, 4 Ιουν 2009, 08:07:30 »
    Η προστασία με πυράντοχη σακούλα, ή βαλιτσάκι, είναι η λογικότερη κίνηση για την φάση της φόρτισης .
    Ομως, όπως και άλλοι συνάδελφοι είπαν, το ίδιο είναι λογικό και για την μεταφορά.
    Οι Lipo μπορούν να αναφλεγούν πολύ ώρα μετά το τέλος της φόρτισης, ή της εκφόρτισης.
    Φανταστείτε λοιπόν, το πρωϊ, μόλις τελειώσει η φόρτιση της Lipo, τις βάζουμε με την εργαλειοθήκη στο αυτοκίνητο και πάμε για πτήση.
    Από το μοντελοδρόμιο, μετά το τέλος της πτήσης, βγάζουμε την Lipo από το μοντέλο, και ξεκινάμε για το σπίτι.
    Η διαδρομή προς και από το μοντελοδρόμιο, εμπίπτει στην επικίνδυνη χρονική ζώνη. Γι' αυτό να μεταφέρετε τις Lipo, εντός κατάλληλου προστατευτικού περιβλήματος.
    Η αντίδραση του οδηγού αν διαπιστώσει ότι οι Lipo στο πίσω μέρος του αυτοκινήτου έχουν αρχίσει να φλέγονται, είναι απρόβλεπτη, το ατύχημα μπορεί να επεκταθεί και σε άλλα αυτοκίνητα με μία λάθος στραβοτιμονιά.
    Ακόμα και στο σπίτι, είναι λογικό να τις βάζουμε μέσα σε πυράντοχους περιέκτες.
    Σχετικά με το συμβάν με το αυτοκίνητο, ένα λάθος ήταν ότι η φόρτιση γινότανε μέσα στην καμπίνα, με τα εύφλεκτα καθίσματα. Αν γινότανε στο μέρος της μηχανής όπου βρίσκεται συνήθως και η μπαταρία του αυτοκινήτου, η πιθανότητα μετάδοσης της φλόγας ήταν περιορισμένη, εκτός φυσικά αν υπήρχε διαρροή βενζίνης στην περιοχή.
    Ακόμα ένα λάθος ήταν ότι, όπως είπε ο παθών, στον ίδιο χώρο που γινότανε η φόρτιση είχε και τις άλλες Lipo, που και αυτές πήραν φωτιά.
    Συμβουλή: αν το balancer καθυστερήσει να κάνει τη πτώση τάσης στα στοιχεία που είναι ανεβασμένη, αυτά θα ξεπεράσουν την μέγιστη επιτρεπτή, και οι πιθανότητες ανάφλεξης είναι περισσότερες.
    Γι' αυτό αν δεν είναι ανάγκη να φορτίσετε τις μπαταρίες σας στο 100% για αγωνιστική χρήση, χρησιμοποιείστε το πρόγραμμα Li-Ion, όπου η τάση είναι κατά 0,05 μικρότερη. Η φόρτιση θα γίνει στο 95% και είναι ανεκτή για κάθε άλλη χρήση.
    Χρηστος Βαγενας (vchris)
    « Απάντηση #8 στις: Πέμπτη, 4 Ιουν 2009, 08:27:35 »
    ισως ειναι και θεμα τυχης
    οταν αρχισα να τις χρησιμοποιω
    μου εχει συμβει μπαταρια κινεζικη να ειναι συνδεμενη με το αεροπλανο μια βδομαδα και να μη παθει τπτ
    και μια επωνυμη απο το πρωι μεχρι το βραδυ να εχει φουσκωσει
    παντως οτι και να ειναι καλο ειναι αυτες τις lipo να τις προσεχουμε και να μη ξεχναμε οτι ειναι κατι σαν ωρολογιακες βομβες η ναρκες δε ξερεις ποτε και που θα σου τη  κανουν τη ζημια
    (για μενα οι ειδικες σακουλες ειναι καλες μονο για τη μεταφορα απο και προς το μοντελοδρομιο καλο ειναι οποιος εχει τη δυνατοτητα να φτιαξει και ενα μεταλικο κουτι για το σπιτι )
    και μια ερωτηση
    οι αισθητηρες θερμοκρασιας που εχουν ορισμενοι φορτιστες ειναι ενα ειδος ασφαλειας κατα τη φορτιση?
    η αμα αρχισει να ανεβαζει θερμοκρασια ειναι πλεον αργα?
    προσωπικα βαζω το χειμωνα οριο τους 22 βαθμους και το καλοκαιρι 30-35
    και γω βρηκα αυτο
    Miraba encima mi coche y las suyas eran llamas que salían de la ventana del frente del pasajero. Y entonces todo el infierno explotó. Las tres baterías del lipo en el asiento delantero comenzaron a estallar, entonces la batería de coche estalló los neumáticos estalló el depósito de gasolina estalló las llamas tiradas para arriba y fuera de treinta pies en el aire. Eso cogió el coche cover/carport en el fuego también.
    « Τελευταία τροποποίηση: Πέμπτη, 4 Ιουν 2009, 09:07:55 από vchris » Καταγράφηκε
    « Απάντηση #9 στις: Πέμπτη, 4 Ιουν 2009, 09:14:22 »
    καλα τα λετε παιδια.... αντιπυρικη σακουλα για μενα πρωτο μετρο και δευτερο μετρο ποτε δεν τισ αφηνουμε να φορτισουν χωρις την επιβλεψη μας...
    Βεβαια ο φορτιστης δεν ηταν οτι καλυτερο ηταν καποιος που ειχε προκαλεσει αρκετες φορεσ προβληματα...
    Οσο για το κινεζικο ενταξει μην λεμε οτι θελουμε το 80% εχουμε κινεζικους οι οποιοι εχουν βγει αψογοι..
    ΓΙατι αν θες να παρεις καλο φορτιστη θες πανω απο 200ε το λιγοτεροο!
    Vchris δεν ξερουμε γαλλικα!
    « Απάντηση #10 στις: Πέμπτη, 4 Ιουν 2009, 09:21:29 »
    ουτε γω αγγλικα    idiot2
    αφου το κανεις το καλο καντο για ολους Wink
    Κωστης
    Playing some blues...
    « Απάντηση #11 στις: Πέμπτη, 4 Ιουν 2009, 10:26:28 »
      Ενα ενδιαφερων αποσπασμα για Lipo :
     شغل من البسكويت الآن كافية لذلك ، عندما كنا نأكل لتذوب في الفم. فلماذا عندما Lipo الحرق ، والحفاظ على كوب من الذرة الطازجة مع ملعقة صغيرة تضاف الكوكيز ، تذوب والسماح لهم التمتع بها. اختياريا ، يمكنك بديلا الكمأ والشوكولاته
        Tongue  Wink
    MarD
    « Απάντηση #12 στις: Πέμπτη, 4 Ιουν 2009, 10:29:48 »
    Εγώ το κατάλαβα! Λέει: "Πλήρωση της μπισκότα για να το κάνουν τώρα, όταν τρώμε να λιώσει στο στόμα. Lipo, γιατί, κατά την καύση, και η διατήρηση του φλιτζάνι καλαμπόκι νωπό με ένα μικρό κουτάλι, προστίθενται τα cookies, τα λιώσει και να τους επιτρέπει να απολαμβάνουν. Προαιρετικά, μπορείτε να αντικαταστήσετε Τρούφες σοκολάτας και"
     laugh  laugh
    Μετάφραση από google translate
    - Igor Sikorsky
    http://www.coolmodels.gr
    Κωστης
    « Απάντηση #13 στις: Πέμπτη, 4 Ιουν 2009, 10:31:32 »
     χαχαχαχαχα  Grin Grin Grin Grin  Ωραιος ο Μαριος.  Η σωστη μεταφραση ειναι η εξης:
     Η γέμιση του μπισκοτου ειναι πλεον αρκετη με αποτελεσμα, οταν το τρωμε να λιωνει στο στομα μας. Γι'αυτο λοιπον, οταν μια Lipo καιγεται, κραταμε μια κούπα φρεσκο γαλα με ενα κουταλακι , ριχνουμε τα μπισκοτα , τα αφηνουμε να λιωσουν και απολαμβανουμε. Προαιρετικα, μπορουμε να χρησιμοποιησουμε και τρουφα σοκολατας
     Περα απο την πλακα, εχω δει 2 φορες επωνυμες μπαταριες να πεφτουν απο μεγααααλο υψος επειδη ειχαν αποκολληθει απο το μοντελο και να μην παθαινουν τιποτα. Εχει τυχει ομως και επωνυμη να φουσκωσει μεσα στο πρωτο λεπτο χρησης της χωρις να δινει το 100% των Α που μπορει να δωσει. Ολα ειναι σχετικα. Συνηθως τα επωνυμα προιοντα ''κρατουν'' περισσοτερο. Ο jkon στο βιβλιο του στη σελιδα αυτη: http://jkon.aeromodelling.gr/ninter-073e.htm  δινει πολυ καλες πληροφοριες που μπορει να βοηθησουν!
    MarD
    « Απάντηση #14 στις: Πέμπτη, 4 Ιουν 2009, 10:39:12 »
     laugh  laugh
    Αυτές είναι συμβουλές!
    Γι' αυτό λοιπόν να προσέχουμε όταν πάμε να φορτίσουμε μια LiPo, να έχουμε πάντα μαζί μας και ένα μπρίκι με τα υπόλοιπα άλλα σύνεργα παρασκευής καφέ ή άλλου ροφήματος, ειδάλλως μπορεί να χάσουμε την ευκαιρία να ψήσουμε ΚΑΛΟ καφέ στην εξοχή!
    Πέρα από την πλάκα μια μπαταρία μολύβδου είναι καλή και φθηνή λύση.  Thumbs up
    - Igor Sikorsky
    Aeromodelling GR  |  Forum  |  Αερομοντελλισμός στο Aeromodelling GR  |  Aeromodelling GR - γενικές συζητήσεις (Συντονιστής: ArgyrisGiannetakis)  |  Θέμα: Φωτια σε αμαξι στο μοντελοδρομιο απο LIPO
    Δημιουργία σελίδας σε 0.071 δευτερόλεπτα. 27 ερωτήματα.
