Δευτέρα, 19 Οκτ 2026, 15:19:27
    Online σήμερα: 57
    Επισκέπτες: 46
    Συνολικά: 49
    Σελίδες: 1 ... 10 11 12 [13] 14 15 16 ... 20     Κάτω
    Αποστολέας Θέμα: Samos Model center  (Αναγνώστηκε 208557 φορές)
    samosrc
    « Απάντηση #180 στις: Δευτέρα, 18 Απρ 2011, 16:45:13 »
    ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    CALMATO 40 SPORTS blue
    SKY BLUE No.11215BL   ARF Kit □Available : 30 Oct 2004 The perfect introduction to low-wing flight. You’ll enjoy the ideal 40-s…
    109.00€
    ι
    CALMATO 40 SPORTS red
    CALMATO 40 SPORTS The perfect introduction to low-wing flight. You’ll enjoy the ideal 40-size flight performance. Delivers the excellent stability and…
    109.00€
    CALMATO 40 SPORTS yellow
    109.00€
    Black Horse Renegade EP/GP ARTF
    Black Horse Renegade EP/GP ARTF Styled on the latest generation of sleek high performance homebuilt aircraft, the new Black Horse Renegade is sure t…
    109.00€
    G.Planes Yak-55 Flightflex EP ARTF
    G.Planes Yak-55 Flightflex EP ARTF A-GPMA1274   SSP     £79.99   repStart(910) <!-- repEnd(&quot…
    89.00€
    Great Planes Seawind EP A…
    Great Planes Seawind EP ARTF A-GPMA1169
    Great Planes Seawind EP ARTFA-      "Seven-tenths of the world's surface becomes your runway!" exclaims the full-scale Seawind's manufactur…
    119.00€
    Great Planes U-Can-Do 3D 46 ARTF
    Great Planes U-Can-Do 3D 46 ARTF Hovering, knife edge and incredible 3D manoeuvres are all within the U-Can-Do 3D's envelope. Available in two versi…
    162.00€
    SERVO S3010 6,5Kg/0.16sec/6v
    SERVO S3010 6,5Kg/0.16sec/6v S3010Analog servo NiCd only 6.0V only Dimension 40.0 mm x 20.0 mm x 38.1 mm Weight 41 g Operating Speed 0.16 sec/60° Outp…
    26.00€  23.00€
    Έκπτωση: 12%
    ST Model Discovery ARTF T…
    ST Model Discovery ARTF Trainer
       ST Model Discovery ARTF Trainer        The ST model Discovery is all about learning to fly radio control model aircraft for the very first time. …
    139.00€
    Black Horse Diablo ARTF
    Black Horse Diablo ARTF Expressly designed for 3D aerobatics, the Diablo has the massive control surfaces you'd expect plus a very deep rear fuse…
    139.00€
    Black Horse Yak-54 ARTF
    If you're looking for a model that looks like a 'real' aeroplane, capable of performing aerobatics to the limit of your imagination, then look n…
    138.00€
    fazer subarou impreza w/gf16
    Ά£What is the FAZER series?Ά£ Simply the ideal beginner GP touring car machine! FAZER performance lets you relive GT racing. GP touring cars provide …
    189.00€
    Futaba R617FS FASST 2.4Ghz receiver
    Futaba R617FS FASST 2.4Ghz receiver FEATURES: High sensitivity receiver weighs only .25oz (7g) without case yet is a full range system for all aircraf…
    89.00€ 59.00€
    Έκπτωση: 34%
    http://www.rcmodelshop.gr/index.php?main_page=index&cPath=73&zenid=df2c8fec629e0d39db5195d73bea4c5b
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΑΝΩ ΤΩΝ 50Ε  ΣΕ ΟΛΗ  ΤΗΝ ΕΛΛΑΔΑ
    rcmodelshop.gr
    samosrc
    « Απάντηση #181 στις: Δευτέρα, 18 Απρ 2011, 18:03:49 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Black Horse Piper Cub EP ARTF
    105.00€
    With charismatic looks, the Cub is fun and smooth to fly!
    With all the charm of the ubiquitous 'Cub' this stunning new Black Horse version combines those classic lines with the high tech computer/Laser cutting techniques and heatshrink film of the 21st century to bring you a lightweight yet strong EP powered model that is fun just to look at, let alone fly!
    Like all Cubs, she needs a little finesse on the controls to look smooth and co-ordinated, but by careful design, there are no real vices to catch you out. A little practice and you'll look like a pro! Although small enough to fit in many cars in one piece, the wings can be easily removed for transport if required.
    Nice scale details like a dummy engine (on a GRP cowling) and functional struts make the Black Horse Cub a model to be proud of and the envy of your mates.
    Specification
    Wingspan:    1530mm (60.24in)
    Length:    940mm (37.01in)
    Weight:    1.2kg (2.65lbs)
    Radio System:    4 Channel with 4 servos
    Electric Motor:    KMS Quantum 2814/08
    LiPo:    Impulse 3S 2500/3200mAh
    Recommended Propeller:
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1467&zenid=df2c8fec629e0d39db5195d73bea4c5b
    rcmodelshop.gr
    samosrc
    « Απάντηση #182 στις: Τρίτη, 19 Απρ 2011, 11:31:43 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    HXT UBEC 5/6v output, 5.5~23v InputhexTronik UBEC. Will supply a solid 5v or 6v to your reciever with a  2 to 5S Lipoly pack. Specifications; Output: …
    11.00€
    TR 35-42D 1000kv Brushless Outrunner eq: AXi 2820
    TR 35-42D 1000kv Brushless Outrunner eq: AXi 2820 TURNIGY AerodriveXp Model : TR35-42-D Input Voltage : 7.4V~14.8V (2~4S Li-po) Kv : 1000 rpm/V within…
    29.00€
    TURNIGY 28-22-A 1600Kv Ou…
    TURNIGY 28-22-A 1600Kv Outrunner (Eq:2204)
    TURNIGY 28-22-A 1600Kv Outrunner (Eq:2204) TURNIGY AerodriveXp Model: TR28-22-A Max Eff: 5A Max Load: 8A Kv: 1600 Weight: 25.9gr Pull: 100~300gr Pro…
    16.00€
    Turnigy 3020 Brushless Ou…
    Turnigy 3020 Brushless Outrunner Motor 1200kv
    Dimension: 31mm x 23mm (including mount) Weight: 25g  (kv1200) (not including connectors) Diameter of shaft: F3mm Lamination thickness: . 2mm Spec. Ba…
    21.00€
    Turnigy Accucel-6 50W 5A Balancer/Charger
    The Turnigy Accucel 6 is an entry level balancing charger and discharger which can handle up to 6 cells and 5A. The Accucel-6 will handle LiPo/LiFe u…
    36.00€
    Turnigy G25 Brushless Out…
    Turnigy G25 Brushless Outrunner 870kv
    Turnigy G25 Brushless Outrunner 870kv Designed to be a direct swap out for your 25 size glow engine. This brushless outrunner will provi…
    26.00€
    TURNIGY Plush 40amp Speed…
    TURNIGY Plush 40amp Speed Controller
    TURNIGY Plush 40amp Speed Controller Plush 40A Brushless Speed Controller The Plush series ESC are a very good quality controller. They have a broad…
    32.00€
    Turnigy Typhoon 500H Heli…
    Turnigy Typhoon 500H Heli Motor 1800kv (500 Class)
    Turnigy Typhoon 500H Heli Motor 1800kv (500 Class) The Turnigy Typhoon is a very serious upgrade for any 500 size heli. Tight copper wire turns with h…
    39.00€
    MEGA-ADAPTER. Connect alm…
    MEGA-ADAPTER. Connect almost anything to anything!
    MEGA-ADAPTER. Connect almost anything to anything! Now you can connect your XT60, Traxxas, Tamiya, EC3 or Deans T-connector to any type of batt…
    7.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #183 στις: Πέμπτη, 21 Απρ 2011, 18:37:09 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    PIPER SUPER CUB 2.06 M MT
    179.00€
    PIPER SUPER CUB 2.06 M MT RTR
    BRAND: MODEL TECH
    MANUFACTURER ITEM NUMBER: MT3178D-1ARF
    CATALOGUE PAGE: 098
    GENERAL DESCRIPTION:
    TECH MODEL, one of the oldest ready-producers in Asia. The models have proved themselves over years and are among the best RTR on the market. All models are mostly made of timber, covered with an elaborate slide show ready to finish and painted fiberglass parts. (Only if the model available!). A comprehensive, illustrated instructions, English language simplifies the final assembly. Überdurschnittlich extensive and proven equipment.
    ITEM DESCRIPTION:
    Model Tech Piper's next! Now in the 2m class for the installation of E-drives or Verbrennermotoren. Standard flaps for easy landing.
    TECHNICAL DESCRIPTION:
    Wingspan:   2060 mm
    Weight:   ca.2900, 3400g (Flugg.)
    empf.Motor:   7.5-10 2T / 4T 8:5-13 cc
    Control:   S, H, M, Q, LK
    Manufacturer:   Model Tech
    Hull:   Wood
    Plot:   Wood / Rippenb.
    Execution:   F-Ready
    Flight / Construction:   22
    rcmodelshop.gr
    samosrc
    « Απάντηση #184 στις: Κυριακή, 24 Απρ 2011, 00:19:25 »
    ΚΑΛΟ ΠΑΣΧΑ ΣΕ ΟΛΟΥΣ KΑΙ  ΚΑΛΗ ΑΝΑΣΤΑΣΗ !
     ΕΥΧΟΜΑΙ ΥΓΕΙΑ ΣΕ ΕΣΑΣ ΚΑΙ ΤΙΣ ΟΙΚΟΓΕΝΕΙΕΣ ΣΑΣ
    ΚΑΙ ΘΕΛΩ ΝΑ  ΕΥΧΑΡΙΣΤΗΣΩ  ΤΟΥΣ ΑΓΑΠΗΤΟΥΣ ΜΟΥ ΠΕΛΑΤΕΣ ΚΑΙ ΦΙΛΟΥΣ ΓΙΑ ΤΗΝ ΕΜΠΙΣΤΟΣΥΝΗ ΠΟΥ ΜΟΥ ΔΕΙΞΑΤΕ ΟΛΟ ΑΥΤΟ ΤΟΝ ΚΑΙΡΟ.
    ΜΕ ΕΚΤΙΜΗΣΗ
    ΜΑΡΓΑΡΩΝΗΣ ΓΕΩΡΓΙΟΣ
    rcmodelshop.gr
    samosrc
    « Απάντηση #185 στις: Κυριακή, 1 Μαΐ 2011, 18:57:16 »
    [/color]
    rcmodelshop.gr
    samosrc
    « Απάντηση #186 στις: Τετάρτη, 4 Μαΐ 2011, 07:55:55 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Black Horse Decathlon ARTF
    136.00€
    Black Horse Decathlon ARTF    A-BH024
    A brand new model in the Black Horse range, this Decathlon is designed to suit the popular .40~.46 two stroke engine range and comes factory built, covered and trimmed to their usual high standard.
    There's no problem with transport this or rigging at the field as the two piece wing uses a lightweight aluminium joiner tube.
    The factory-finished wing struts locate quickly, so preparation at the flying field is no more tricky than any other 40 powered model.
    Lightweight fibreglass cowl and spats, large hardware selection and crystal clear cabin glazing complete the package.
    Recommended EP Conversion
    • Motor: KMS Quantum 4120/05
    • ESC: KMS Sentry 60
    • Battery: Impulse 4S 4000mAh LiPo
    Specification
    Wingspan:    1650mm
    Length:    1300mm
    Radio System:    4 Channel - 5 Servos
    IC Motor:    .40-.46 Two Stroke / .52 Four Stroke
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1518&zenid=df2c8fec629e0d39db5195d73bea4c5b
    rcmodelshop.gr
    samosrc
    « Απάντηση #187 στις: Πέμπτη, 5 Μαΐ 2011, 17:56:01 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    6ch Combo 2.4GHz FHSS (D)M2 R2006GS
    159.00€
    This brand new 6 channel system from Futaba is probably one of the most significant new radios for some time, incorporating as it does both FHSS and S-FHSS transmission modes, which allows the use of a wide and ever expanding range of receivers, including the new micro R2005GF unit. Supplied as standard as a dry battery combo together with the matching R2006GS six channel receiver, the transmitter can also be fitted with individual AA rechargeable cells or 4/5 cell battery packs. Packed with features normally only seen on much more expensive systems, these include 15 model memories, large 127 segment LCD screen, both aircraft and helicopter mixing functions, etc, etc, as well as a
    rotary auxiliary control, something that is lacking in most of its competitors. To improve still further the ease of programming the 6JG is provided with 3 buttons and 1 edit key, thus avoiding the endless scrolling through screens more basic systems require.
    • 15 Model Memory
    • Reverse on all functions
    • End Point Adjustment on all functions
    • Sub Trim on all functions
    • Dual rates
    • Exponential
    • Failsafe (all channels S-FHSS/ch3 FHSS)
    • Throttle Cut
    • Model Type
    • Data Reset
    • Timer
    • Trainer function
    Helicopter Specific
    • Swash Type (Four)
    • Swash/Throttle Mix
    • Five Point Throttle Curve (Two)
    • Five Point Pitch Curve (Three)
    • Throttle Hold
    • Hover Pitch
    • Pitch/Rudder Mix
    • Gyro Mix
    • Swash Ring
    Aircraft Specific
    • Elevon Mix
    • V-Tail Mix
    • Flaperon Mix
    • Flap Setting Mix
    • Programmable Mix (Two)
    • 2nd Aileron Channel
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1519&zenid=df2c8fec629e0d39db5195d73bea4c5b
    rcmodelshop.gr
    samosrc
    « Απάντηση #188 στις: Τετάρτη, 11 Μαΐ 2011, 12:51:36 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    ZIPPY Flightmax 2200mAh 3S1P 20C
    13.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=368
    rcmodelshop.gr
    samosrc
    « Απάντηση #189 στις: Τετάρτη, 11 Μαΐ 2011, 23:08:07 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    Extra 300-58" Red/White/Blue
    259.00€
    Extra 300-58" Red/White/Blue Specifications:
    Wingspan: 58 inches
    Length: 57 inches
    Wing Area: 700 sq. in.
    Weight: 5-6 lbs
    Power:
    Torque Revolution 4016T/500 Brushless Outrunner and Airboss Elite 80 Amp ESC
    .46-.82 glow engine (requires glow conversion kit sold separately).
    Radio:
    4 channel with channel mixing capability and 3 mini servos for elevator and aileron actuation, standard size servo for rudder..
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=1520&zenid=e5678bd72fa2d8cefbc18adb3aa7721f
    * red%2058.jpg (75.04 KB, 640x480 - εμφανίστηκε 2842 φορές.)
    « Τελευταία τροποποίηση: Τετάρτη, 11 Μαΐ 2011, 23:33:01 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #190 στις: Σάββατο, 2 Ιουλ 2011, 10:16:08 »
    [size30pt]ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ[/size][/size]
    FUNCUB MUL 214243
    103.00€
    Cularis Electric Glider A…
    Cularis Electric Glider ARF
    165.00€
    EASY STAR (silver edition…
    EASY STAR (silver edition)
    62.00€
    HS 81 SERVO bulk
    HS 81 SERVO bulk
    HS 81 SERVO HIT 112081 Γράψτε πρώτος μια αξιολόγηση για αυτό το προϊόν Πρόσθεση στα Επιθυμητά| Πρόσθεση στην Σύγκριση Γρήγορη Επισκόπηση You…
    14.00€
    6ch Combo 2.4GHz (N-Tx) M…
    6ch Combo 2.4GHz (N-Tx) M2 R617FS
    The 6EXP is Futaba's entry-level 2.4GHz aircraft/helicopter system and utilises the highly advanced FASST (Futaba Advanced Spread Spectrum Technolog…
    149.00€
    6ch Combo 2.4GHz FHSS (D)M2 R2006GS This brand new 6 channel system from Futaba is probably one of the most significant new radios for some time…
    146.00€
    BREEZE ES DEPRON OUTDOOR 3D MODELL DUALS
    BREEZE ES DEPRON OUTDOOR 3D MODELL DUALSMARKE: DUALSKY HERSTELLERARTIKELNUMMER: BREEZE-ES KATALOGSEITE: N&M007 ARTIKELBESCHREIBUNG: "Breeze E…
    34.00€
    109.00€
    109.00€
    DLE Engines DLE-20 20cc RC Model Gas Engine with Muffler and Ele
    DLE Engines DLE-20 20cc RC Model Gas Engine with Muffler and Electronic Ignition NOTE: The DLE-30 is replacing the DL-30. The new DLE-30 has a r…
    249.00€
    Gemini
     GeminiTECHNICAL DESCRIPTION:Wingspan:920 mmWeight:840g (Flugg.)empf.Motor:HimarkControl:H, S, Q, MManufacturer:MPXHull:ElaporPlot:ElaporExecution:F-…
    112.00€
    HEX DRIVER SET HT D003
    18.00€
    Quick-Cure 5 Min Epoxy 4.5 oz
    Quick-Cure 5 Min Epoxy 4.5 oz Quick-Cure 5 Min Epoxy 4.5 ozQUIK-CURE 5 min. epoxy cures to a slightly flexible consistency. This lack of brittleness …
    9.00€
     23.00€
    Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec
    Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec Weight: 13.4g Dimension: 22.8*12.2*28.5mm Stall torque: 1.8kg/cm (4.8V) - 2.2kg/cm (6.0V…
    7.00€
    32.00€
    TX 8FG R6008HS (2,4G) 8-channel 2.4GHz Computer System The "much more for far less" system! It's priced hundreds of dollars less than the…
    360.00€
    EASY GLIDER PRO
    The EasyGlider PRO is an updated model based on the popular and proven EasyGlider and EasyGlider electric. Just like the larger Cularis the Easy Glid…
    78.00€
    HANGAR-9 Piper J-3 Cub 40 ARF
      FEATURES Scale detail & scheme based on Pat Hartness’ full-sized J-3 CubEasy-to-transport 2-piece wing and tail sectionsStrong, lightweight sca…
    199.00€
    HKS-9257 High Speed Servo 4.5kg/ 25g/ 0.07sec
    HKS-9257 High Speed Servo 4.5kg/ 25g/ 0.07sec HKS-9257 is a high speed, high torque digital servo, Suitable
    16.00€
    « Τελευταία τροποποίηση: Σάββατο, 2 Ιουλ 2011, 10:32:22 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #191 στις: Τετάρτη, 6 Ιουλ 2011, 08:59:53 »
    MINTOR & SEBART
    NΕΑ ΠΑΡΑΛΑΒΗ
    GLOW PLUG NO.8
    GLOW PLUG NO.8 The O.S. #8 glow plug is the most widely used O.S. glow plug.
    6.00€
    GLOW PLUG TYPE F
    GLOW PLUG TYPE F The OS Max #F Glow Plug is Designed Especially for OS Max
    8.00€
    S9254 3,4Kg/0,06secSERVO DIGI
    SERVO DIGI S9254 3,4Kg/0,06sec S9254 High-speed servo for GY240/401/502 gyros NiCd only 4.8V only Dimension 40.0 mm x 20.0 mm x 36.6 mm Weight 49 g Op…
    69.00€
    SERVO S3003 BULK 3,2 kg
    4.8V or 6.0VDimension 40.4 mm x 19.8 mm x 36.0 mm Weight 37.2 g Operating Speed 0.23 sec/60° (4.8V) 0.19 sec/60° (6.0V) Output torque 3.2 kg-cm (4.8V)…
    10.00€
    HF-MODUL TM-8 FASST 2.4 GHZ FF7/FF-9/FC-1
      HF-MODUL TM-8 FASST 2.4 GHZ FF7/FF-9/FC-1 Order: 67 392 <!-- document.write('<a href="http://shop.lindinger.at/imag…
    109.00€
    MAX-46LA (SILVER) W/E-3030
    MAX-46LA(Silver)  For medium sized sport and trainer models Displacement 7.64cc(0.467cu.in)Output 1.2ps/15,000r.p.m. Bore 23.0mm(0.906in.)P…
    79.00€
    MAX-55AX W/E-3070 SILENCER
    MAX-55AX W/E-3070 SILENCER MAX-55AX   For scale and sport models   Displacement 8.93cc(0.545cu.in) Output 1.7ps/16,000r.p.m. …
    138.00€
    WOT 4 Foam-E Mk2 ARTF
    -CF020     SSP This is not just any foam model! It’s a very clever WOT 4…
    129.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #192 στις: Παρασκευή, 8 Ιουλ 2011, 15:32:41 »
    MINTOR & SEBART
    ΝΕΑ ΠΡΟΙΟΝΤΑ
    Servo SAVÖX SH-0253
    Servo SAVÖX SH-0253 Technische Daten: Klassizifierung Micro (12 - 13 mm) Abmessungen ca. 22,8 x 12,0 x 25,4 mm Gewicht ca. 14g …
    19.00€
    SkyCarver - Orange
    SkyCarver - Orange Beschreibung: Die Fortzetzung des Skyfighters: Größer, zahmer, super Segelflugeigenschaften Empfohlene Antriebskombinat…
    39.00€
    SkyCarver - Hacker-Team Design
    SkyCarver - Hacker-Team Design Beschreibung: Die Fortzetzung des Skyfighters: Größer, zahmer, super Segelflugeigenschaften Empfohlene Antr…
    39.00€
    A50-16 L V2
    Specifications: 20° - 25° Powerange max. 1650W (15 sec.) Idle Current @ 8,4V 1,7A Resistance (Ri) 0,031 Ohm RPM/Volt (kv) 272 U/m…
    152.00€
    A50-16 S V2
    A50-16 S V2 Specifications: 20° - 25° Powerange max. 1250W (15 sec.) Idle Current @ 8,4V 2,0A Resistance (Ri) 0,026 Ohm RPM/Volt (…
    125.00€
    P-S3050 Servo Digital Mtl/Gear 0.16s/6.5Kg
     P-S3050  Servo Digital Mtl/Ge This new digital servo gives the same high torque and speed as the very popular S3010 servo and then adds digital hol…
    39.00€
    BOOM EPP FERTIGMODELL MS-COMPOSIT GENERAL DESCRIPTION: Diese EPP Modellserie von MS-COMPOSIT sticht aus dem üblichen Einerlei wohltuend hervor. …
    46.00€
    KOMFORT KREUZRIEMEN UNI MODELLBAU LINDIN DESCRIPTION: Für sicheren Sitz des Senders. Der Kreuzriemen ist längenverstellbar und kann für…
    18.00€
    S-PULT ACRYL FF-7/T7 GRÜN
    S-PULT ACRYL FF-7/T7 GRÜNDESCRIPTION: Senderpult aus satiniertem Acrylglas. Das Senderpult wird, bis auf die beiliegenden Haltestäbe aus Alu…
    69.00€
    SANYO ENELOOP 2000MAH/4,8V
    SANYO ENELOOP 2000MAH/4,8V GENERAL DESCRIPTION: Unsere E-Akkupacks werden ausschließlich mit hochwertigen Zellen von Sanyo, Xcell , GP usw. gefer…
    20.00€
    CRP prop. 2-BL. 17/10 BIELA
    BRAND: BIELA MANUFACTURER ITEM NUMBER:  16x8 CATALOG PAGE: 438 GENERAL DESCRIPTION: BIELA carbon fiber propellers are manufactured exclusively f…
    28.00€
    CRP prop. 2-BL. 18 / 8 BIELA
    BRAND: BIELA MANUFACTURER ITEM NUMBER: 2/18X6 CATALOG PAGE: 438 GENERAL DESCRIPTION: BIELA carbon fiber propellers are manufactured exclusively…
    30.00€
    SANYO ENELOOP 2000MAH/6VGENERAL DESCRIPTION: Unsere E-Akkupacks werden ausschließlich mit hochwertigen Zellen von Sanyo, Xcell , GP usw. gefertig…
    26.00€
    SANYO HR-3U 2700MAH CATALOGUE PAGE: 439 GENERAL DESCRIPTION: Unsere E-Akkupacks werden ausschließlich mit hochwertigen Zellen von Sanyo, Xcell , …
    19.00€
    DUALSKY TF HARD C. 5200MAH/7,4V
    DUALSKY TF HARD C. 5200MAH/7,4V Spannung7,4 VForm2er-PackGewicht299 gTypeLipolyKapazität5200 mAhmax.Dauerstrom50C/CH6L/B/H mm139/47/23 HARD CASE
    70.00€
    DUALSKY XPOWER ES LIPO 150MAH/7,4V 20C
    DUALSKY XPOWER ES LIPO 150MAH/7,4V 20CSpannung7,4 VForm2er-PackGewicht10 gTypeLipolyKapazität150 mAhmax.Dauerstrom20CL/B/H mm38/12/12
    5.00€
    DUALSKY XPOWER ES LIPO 250MAH/7,4V 20C
    DUALSKY XPOWER ES LIPO 250MAH/7,4V 20CGENERAL DESCRIPTION: DUALSKY Lipo Akkupacks mit hoher Leistung und hervorragendem Preis/Leistungsverhältnis…
    6.00€
    DUALSKY XPOWER EX G5 LIPO
    DUALSKY XPOWER EX G5 LIPO GENERAL DESCRIPTION: DUALSKY Lipo Akkupacks mit hoher Leistung und hervorragendem Preis/Leistungsverhältnis. Alle Packs…
    24.00€
    DUALSKY XPOWER EX G5 LIPO 11,1V/800MAH
    DUALSKY XPOWER EX G5 LIPO 11,1V/800MAHGENERAL DESCRIPTION: DUALSKY Lipo Akkupacks mit hoher Leistung und hervorragendem Preis/Leistungsverhältnis…
    15.00€
    DLE-111 Gas Twin
    DLE-111 Gas Twin DLE-111 Gas Twin Giant-scale power to go. Mount it and start it, and the DLE-111 is ready to deliver the smooth, low-vibration oper…
    650.00€
    EDGE 540 RED BULL AIRR. EPP DESCRIPTION: Features • Vorbildgetreuer Nachbau des erfolgreichen Red Bull Airracer‘s • Leistungsstarker Brush…
    215.00€
    APC Electric 17X10
    APC Thin Electric 17x10
    12.00€
      APC SLOW PROP 11/7
    6.00€
    13/6.5  AERONAUT
    12.00€
    11 / 4 AERONAUT
    <!-- document.write('<a href="http://shop.lindinger.at/images/L46025.jpg" target="_blank" rel="lightbox[roa…
    8.00€
    10 / 7 AERONAUT
    BRAND: AERONAUT MANUFACTURER ITEM NUMBER: 7234/28 ARTICLE DESCRIPTION: The special feature of the CAM folding propeller are the enormous change…
    8.00€
    10 / 6 AERONAUT
    10 / 6 AERONAUT
    BRAND: AERONAUT MANUFACTURER ITEM NUMBER: 7234/28 CATALOG PAGE: 390 ARTICLE DESCRIPTION: The special feature of the CAM folding propeller are t…
    8.00€
    http://www.rcmodelshop.gr/index.php?main_page=products_new
    rcmodelshop.gr
    samosrc
    « Απάντηση #193 στις: Κυριακή, 10 Ιουλ 2011, 20:46:04 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    NEW Wind S 50E Yellow/Black Version
    Wind S 50E Yellow/Black Version - Acrobatico elettrico 3D outdoor, pronto al volo, completo di tutti gli accessori. Outdoor electric 3D acro, …
    266.00€
    NEW - Wind S 50E- White/Blue Version
    NEW - Wind S 50E Yellow/Black Version - Version Acrobatico elettrico 3D outdoor, pronto al volo, completo di tutti gli accessori. Outdoor elec…
    266.00€
    Sebart 30E White/Blue Version
     Sebart 30E - NEW! White/Blue Version - Yellow/Black Version Acrobatico elettrico 3D outdoor, pronto al volo, completo di tutti gli accessor…
    199.00€
    Sebart 30E Yellow/Black Version
    199.00€
    Sebart Sukhoi 29S 140E Red/Blue
    Sebart Sukhoi 29S 140E Red/Blue Outdoor 3D acro, 140 class, ready to fly, with all accessories. Wing Span 194 cm Lenght 192 cm Wing area 82 dm2 Weigh…
    489.00€
    Sukhoi 29S 140E Yellow
    Sukhoi 29S 140E Yellow Outdoor 3D acro, 140 class, ready to fly, with all accessories. Wing Span 194 cm Lenght 192 cm Wing area 82 dm2 Weight 4.000/4…
    489.00€
    Sukhoi 29S 30E Yellow Version
    Sebart - Sukhoi 29S 30E  Yellow Version Specifications Wing Span:……….....130 cm (51,18 in.) Recommended power set up: Length:……
    199.00€
    Sukhoi 29S 50E V2 Red/Blue
    Sebart Planes  NEW - Sukhoi 29S 50E V2NEW - Sukhoi 29S 50E V2 Yellow/Black Version - Red/Blue Version Nuova versione "V2", acrobatic…
    257.00€
    « Τελευταία τροποποίηση: Δευτέρα, 11 Ιουλ 2011, 09:12:14 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #194 στις: Πέμπτη, 21 Ιουλ 2011, 09:32:19 »
    MINTOR & SEBART
    ΝΕΕΣ ΠΑΡΑΛΑΒΕΣ
    OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
    OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver   Compatible with Futaba FASST receivers: TM7, TM8, TM10, TM14 + more. Th…
    33.00€
    ZIPPY Flightmax 2200mAh 3…
    ZIPPY Flightmax 2200mAh 3S1P 20C Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the ho…
    13.00€
    rcmodelshop.gr
    Σελίδες: 1 ... 10 11 12 [13] 14 15 16 ... 20     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: Samos Model center
    Δημιουργία σελίδας σε 0.065 δευτερόλεπτα. 28 ερωτήματα.
