Τετάρτη, 14 Οκτ 2026, 21:04:12
    Online σήμερα: 87
    Επισκέπτες: 32
    Συνολικά: 33
    Σελίδες: 1 2 3 4 [5] 6 7 8 ... 20     Κάτω
    Αποστολέας Θέμα: Samos Model center  (Αναγνώστηκε 208121 φορές)
    samosrc
    « Απάντηση #60 στις: Σάββατο, 5 Δεκ 2009, 09:58:15 »
    rcmodelshop.gr
    samosrc
    « Απάντηση #61 στις: Τετάρτη, 16 Δεκ 2009, 11:22:01 »
    Νεα παραλαβη
    Futaba R617FS FASST 2.4Ghz receiver
    89.00€  74.00€
    Έκπτωση: 17%
    FEATURES: High sensitivity receiver weighs only .25oz (7g) without case
    yet is a full range system for all aircraft from giant scale to
    park flyer applications-no need to buy separate receiver for
    specific aircraft
    Simple one-touch binding - no plugs to mess with or lose
    Dual Antenna Diversity allows 2.4GHz FASST Futaba transmitter to
    select the best reception between the two receiver antennas with no
    signal loss
    Rubber grommets installed where antennas exit to eliminate stress
    and fraying of the two antenna wires
    SPECS: Size: 1.6 x 1.1 x .35" (40 x 27 x 9mm)
    Power Requirement: 4.8 - 6V
    Current Drain: 80mA (at no signal)
    Weight .25oz (7g) without case
    ΔΩΡΕΑΝ ΜΕΤΑΦΟΡΙΚΑ ΣΕ ΟΛΗ ΤΗΝ ΕΛΛΑΔΑ
    « Τελευταία τροποποίηση: Τετάρτη, 16 Δεκ 2009, 11:38:46 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #62 στις: Σάββατο, 19 Δεκ 2009, 19:06:31 »
    ΑΝΕΜΟΠΤΕΡΟ BLIZZARD
    http://www.rcmodelshop.gr/index.php?main_page=products_new
    A high-performance hot-line model exploiting
    ELAPORreg; technology. Modern brushless motors in
    conjunction with high-performance LiPo batteries provide the
    power for vertical hand-launches with either of the recommended
    power systems. Breath-taking high-speed passes - especially with
    the upgrade power system - and a superb glide angle thanks to
    the MPX wing airfoil, with a thickness of only 8.9%. Neither is the
    model a slouch when it comes to thermalling - the BLIZZARi s low
    all-up weight and carefully optimised aerodynamic layout enable
    the machine to keep up with many a conventional ldeal fly . The
    aeroplane has great aerobatic potential, but is nevertheless easy
    to land slowly - ldquo;like a feather - if the braking system (both ailerons
    raised) is used. At the slope you can really let the BLIZZARD tear
    up the sky in good lift. The wings feature two CFRP spars and four
    supplementary spar caps which endow the structure with great
    torsional rigidity and bending strength, while the fuselage features
    GRP longerons and a large number of innovative plastic parts. The
    net result is a highly practical aeroplane for everyday fl ying.
    bull; Ultra-broad speed range
    bull; Low sinking speed, good glide angle
    bull; Kit includes supplementary ldquo;glider nose-coner with aero-tow option
    bull; Landing aid - both ailerons raised
    bull; Can be fi nished using any standard spray-can paints after prior treatment with MULTIprimer 60 2700
    bull; Pre-fabricated moulded ELAPORreg; parts
    bull; High-quality plastic components
    bull; Aileron servos connect automatically when the wings are attached to the fuselage
    bull; Optional second elevator servo for supplementary rudder function
    Kit contents
    Moulded ELAPORreg; parts, CFRP spars, GRP spar caps and
    longerons, all plastic parts required to assemble the model,
    small items, linkage components, decal sheet, comprehensive
    illustrated instructions.
    Specification
    Wingspan 1380 mm
    Overall length 910 mm
    All-up weight min 775 g (glider) 975 g (electric)
    Wing loading 19,4 dmsup2;
    Wing loading (FAI) approx. 40 gdmsup2; (S) 50 gdmsup2; (E)
    Functions Aileron, elevator (optional rudder), throttle,
    spoilers (both ailerons raised
    ΑΝΕΜΟΠΤΕΡΟ BLIZZARD
    118.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #63 στις: Δευτέρα, 21 Δεκ 2009, 08:16:56 »
    .Νεα παραλαβη
    FUTABA 6EX 2.4 GHZ
    ./index.php?main_page=product_info&products_id=94[/url]
    179.00€
    Product Description
    Standard Programming Functions :
    •Model Select – six model memory.
    •Model Type – select airplane or heli programming in one transmitter.
    •Servo Reversing – on all six channels.
    •Dual Rate/Exponential – for ailerons, elevator and rudder.
    •End Point Adjustment – fine-tunes servo throws on all six channels.
    •Digital Trim – stores trim settings for each model for aileron, elevator, rudder and throttle.
    •Fail Safe – a safety throttle setting in case of loss of transmitter signal.
    •Battery Fail Safe – moves the throttle to a preset position when the airborne pack reaches 3.8V.
    •Stick Mode – choose from Mode 1 through 4.
    •Range Checking – Power Down reduces transmitter output power for up to one minute, allowing range checking from 50 paces away.
    •Changeable Throttle Stick – select ratchet for airplanes or smooth for helis.
    •Adjustable Stick Length – choose the length that suits your flying style.
    Airplane-Specific Programming Functions:
    •Wing Mixing – for flaperon, flap trim, V-tail and elevon.
    •Trainer System – with the transmitter as either the master or student system. Compatible with other Futaba systems.
    •Throttle Cut – pre-programmed for safely shutting off the engine.
    •Programmable Mixing (1 & 2) – two different mixes allow any two channels to be combined.
    Helicopter-Specific Programming Functions:
    •5-Point Normal and Idle Up Throttle/Pitch Curves.
    •Throttle Hold – for autorotation.
    •Revo (Revolution Mixing) – mixes rudder and pitch together.
    •Gyro Mixing – two gyro gain settings can be programmed and selected during flight.
    •Swash to Throttle Mixing – corrects slowing of the engine's speed caused by the swashplate.
    •Swashplate Types – choose from 1S (independent aileron, pitch and elevator servos linked to the swashplate), 3S (120° CCPM), or 3E (90° CCPM).
    •Swash AFR – Adjustable Function Rate, for use with 1S, 3S or 3E swash types.
    rcmodelshop.gr
    samosrc
    « Απάντηση #64 στις: Παρασκευή, 25 Δεκ 2009, 10:53:12 »
    Καλημερα και  Χρονια πολλα
    Καλα Χριστουγεννα  με υγεια
    και πανω απο ολα  καλες πτησεις
    ΜΑΡΓΑΡΩΝΗΣ.Γ
    rcmodelshop.gr
    samosrc
    « Απάντηση #65 στις: Παρασκευή, 8 Ιαν 2010, 08:09:58 »
    ΑΠΟΚΛΕΙΣΤΙΚΟΙ ΑΝΤΙΠΡΟΣΩΠΟΙ ΕΛΛΑΔΟΣ
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    YAK 54 FERTIGMODELL
    189.00€
    BRAND: MODEL TECH
    MANUFACTURER ITEM NUMBER: MT3173E-ARF
    CATALOG PAGE: 099
    GENERAL DESCRIPTION:
    MODEL TECH, one of the oldest ready to run-producers in Asia.
     The models have been proven for years and are among the best finished model in the market.
     All models are mainly geferigt of wood, finish and fitted with elaborate slide show finished, painted fiberglass parts.
    (only if the model available!). A comprehensive, illustrated instructions un English final assembly easier.
     Above-average comprehensive and proven equipment.
    ARTICLE DESCRIPTION:
    "YAK 54 is" specially designed for precise 3D aerobatics.
     Especially at slow implementation of the optimal control surface deflections has been reached.
    Not least by months of flight testing and modifications.
    TECHNICAL DESCRIPTION:
    Wingspan:   1690 mm
    Weight:   ca.3000 g (Leerg.)
    empf.Motor:   15-22ccm 2T/20-23 4T
    Control:   S, H, M, Q
    Manufacturer:   Model Tech
    Hull:   Wood
    Areas:   Wood / Rippenb.
    Execution:   F-Assembled
    Flug / Bau:   22
    rcmodelshop.gr
    TAKISC
    « Απάντηση #66 στις: Παρασκευή, 8 Ιαν 2010, 10:54:57 »
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    YAK 54 FERTIGMODELL
    189.00€
    BRAND: MODEL TECH
    CATALOG PAGE: 099
    Wingspan:   1690 mm
    Control:   S, H, M, Q
    Hull:   Wood
    Flug / Bau:   22
    χρονια πολλα καλη χρονια και καλες δουλειες
    (αν και νομιζω θα ηταν και καλυτερες αν κανατε το κοπο να μας τα γραψετε και στα Ελληνικα)
    samosrc
    « Απάντηση #67 στις: Δευτέρα, 11 Ιαν 2010, 08:07:42 »
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    EDGE 540T Assembled 1.4 M CMPro
    169.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=488
    rcmodelshop.gr
    samosrc
    « Απάντηση #68 στις: Τρίτη, 12 Ιαν 2010, 08:55:46 »
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    EXTRA 330L CMPRO
    222.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=495
    rcmodelshop.gr
    samosrc
    « Απάντηση #69 στις: Κυριακή, 17 Ιαν 2010, 20:05:41 »
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    ZIPPY Flightmax 2200mAh 3S1P 20C.
    19.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #70 στις: Τρίτη, 19 Ιαν 2010, 19:36:06 »
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    TX 12FG R6014HS TX E . (2,4G)
    ΜΟΝΟ 877€
    περειλαμβανει  πομπο -δεκτη R6014hS- μπαταρια πομπου -φοτριστη -neck stripe -διακοπτη
    « Τελευταία τροποποίηση: Σάββατο, 23 Ιαν 2010, 19:07:56 από samosrc » Καταγράφηκε
    rcmodelshop.gr
    samosrc
    « Απάντηση #71 στις: Σάββατο, 23 Ιαν 2010, 08:55:37 »
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    HANGAR-9 ShowTime 50
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=515
    235.00€
    Δωρεαν μεταφορικα για ολη την ελλαδα
    rcmodelshop.gr
    samosrc
    « Απάντηση #72 στις: Σάββατο, 23 Ιαν 2010, 19:04:17 »
    MINTOR & SEBART
    ΝΕΕΣ
    ΠΡΟΣΦΟΡΕΣ
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    Eratix 3D 25e Electric ARF
    139.00€
    http://www.rcmodelshop.gr/index.php?main_page=product_info&products_id=511
    rcmodelshop.gr
    samosrc
    « Απάντηση #73 στις: Τετάρτη, 3 Φεβ 2010, 20:44:24 »
    MINTOR & SEBART
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    sebart
    Sukhoi 29S 140E Yellow
    Sukhoi 29S 140E Yellow Outdoor 3D acro, 140 class, ready to fly, with all accessories. Wing Span 194 cm Lenght 192 cm Wing area 82 dm2 Weight 4.000/4…
    489.00€
    Sukhoi 29S 140E Red/Gree…
    Sukhoi 29S 140E Red/Green
    Sukhoi 29S 140E  Red/Green Outdoor 3D acro, 140 class, ready to fly, with all accessories. Wing Span 194 cm Lenght 192 cm Wing area 82 dm2 Weight 4.0…
    489.00€
    Katana S 120E Red/Blue
    Katana S 120E  Red/Blue Outdoor electric 3D acro, 120 class, ready to fly, with all accessories. Wing Span 187 cm Lenght 186 cm Wing area 78 dm2 Weigh…
    429.00€
    Miss Wind S 50E Red/Green
    Miss Wind S 50E Red/Green Wing Span: 152 cm Lenght: 158 cm Wing area 65 dm2 Weight 2.400/2.500 gr. w/o battery 3.100/3.200gr w. 4500-6S Top-Fuel Light…
    329.00€
    Miss Wind S 50E Red/Blue
    Miss Wind S 50E Red/Blue Wing Span: 152 cm Lenght: 158 cm Wing area 65 dm2 Weight 2.400/2.500 gr. w/o battery 3.100/3.200gr w. 4500-6S Top-Fuel Light …
    329.00€
    PittS 12 Python 50E White…
    PittS 12 Python 50E White/Red
    PittS 12 Python 50E White/Red Wing Span: 135 cm Lenght: 145 cm Weight 2.300 gr. w/o batt. 2.800 gr with Flight Power 4250 6S Radio: 6-Channel with 2 s…
    349.00€
    Angel S EVO 50E Wellow/B…
    Angel S EVO 50E Wellow/Black
    Angel S EVO 50E  Wellow/Black Red/Green version Red/Blue version Wing Span 62,6 in Lenght 65,4 in Weight: 77,4 oz RTF less battery Radio: 4-Channel wi…
    229.00€
    Angel S EVO 50E Red/Green
    Red/Green version Red/Blue version Wing Span 62,6 in Lenght 65,4 in Weight: 77,4 oz RTF less battery Radio: 4-Channel with 4 standard servos Engine: …
    229.00€
    Sukhoi 29S 50E Red/Green
    Sukhoi 29S 50E  Red/Green Wing Span 61 in Lenght 61 in Weight: 84,6 oz RTF less battery Radio: 4-Channel with 4 standard servos Engine: Hacker A50-16S…
    229.00€
    Angel S 30E Red/Green
    . Angel S 30E Red/Green Wing Span 128 cm Lenght 133 cm Wing area: 33,5dm2 Weight: 1.220gr. RTF whitout batteries 1.400gr. RTF with 2150-3S Flight Pow…
    209.00€
    Sukhoi 29S 30E Red/Blue
    Sukhoi 29S 30E  Red/Blue Specifications Wing Span:……….....130 cm (51,18 in.) Recommended power set up: Length:….......……
    189.00€
    Sukhoi 29S 30E Yellow Ve…
    Sukhoi 29S 30E Yellow Version
    Sukhoi 29S 30E  Yellow Version Specifications Wing Span:……….....130 cm (51,18 in.) Recommended power set up: Length:….......&#…
    189.00€
    Angel S 30E Yellow/Black
    . Angel S 30E Yellow/Black Wing Span 128 cm Lenght 133 cm Wing area: 33,5dm2 Weight: 1.220gr. RTF whitout batteries 1.400gr. RTF with 2150-3S Flight …
    209.00€
    Shark S 30E Red/Blue
    Shark S 30E  Red/Blue Wing Span 157 cm Lenght 140 cm Wing area: 44dm2 Weight: 1.430gr. RTF without batteries 1.700gr. RTF with 3300-3S Flight Power En…
    199.00€
    rcmodelshop.gr
    samosrc
    « Απάντηση #74 στις: Τρίτη, 16 Μαρ 2010, 07:36:57 »
    MINTOR & SEBART
    ΝΕΑ ΠΑΡΑΛΑΒΗ
    Acromaster 3d
    ΜΟΝΟ 119€
    rcmodelshop.gr
    Σελίδες: 1 2 3 4 [5] 6 7 8 ... 20     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ελληνικά καταστήματα-αντιπροσωπείες-βιοτεχνίες  |  Θέμα: Samos Model center
    Δημιουργία σελίδας σε 0.072 δευτερόλεπτα. 26 ερωτήματα.
