ÄåõôÝñá, 2 Íïå 2026, 03:14:41
    �ñüóöáôá è�ìáôá
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:11:29]
    [ÐáñáóêåõÞ, 30 Ïêô 2026, 23:07:37]
    áðü Markhelis
    áðü Yiannis_S
    áðü vilisdev
    áðü alex r/c
    áðü UH-1H
    áðü DeltaMan
    áðü CMarkop
    ÌÝëç
    Óýíïëï ìåëþí: 6301
    Ôåëåõôáßï: Clubdim
    ÓôáôéóôéêÜ
    Óýíïëï ìçíõìÜôùí: 310037
    Óýíïëï èåìÜôùí: 12401
    Online óÞìåñá: 39
    Online Ýùò ôþñá: 1547
    ÓõíäåäåìÝíïé ÷ñÞóôåò
    ÌÝëç: 0
    ÅðéóêÝðôåò: 40
    ÓõíïëéêÜ: 40
    Óôõë åìöÜíéóçò
    Óåëßäåò: 1 ... 17 18 19 [20] 21 22 23 ... 37     ÊÜôù
    Åêôýðùóç
    ÁðïóôïëÝáò ÈÝìá: Top Flite FW190 A3 ARF ãéá 50cc  (Áíáãíþóôçêå 144384 öïñÝò)
    Demetre
    Ìçíýìáôá: 265
    « ÁðÜíôçóç #285 óôéò: ÐÝìðôç, 8 Éáí 2015, 02:05:31 »
    Sorry about the Engl. but can't apply the convercion.
    I assume your temp. readings are in Fahrenheit,and you are readings are taken  from the muffler pipes, (EGT)= Exhaust Gas Temperature ,and not from the Heads (CHT)=Cylinder Head Temp.
    On Aluminum Engines CHT above 500 F* or ECT above 1300 F* is Border Line. When you start  passing those limits, the troubles are inevitable...Aluminum pistons melt  aprox. at temp. 1500 F*>
    Happy New Year .   Jim
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 1.411
    « ÁðÜíôçóç #286 óôéò: ÐÝìðôç, 8 Éáí 2015, 07:33:36 »
    ÄçìÞôñç,
    áí âÜëåéò ôï âéíôåï óå full screen èá äåéò üôé ôï üñãáíï äßíåé 1 äåêáäéêü øçößï, Üñá ïé èåñìïêñáóßåò åßíáé ì�÷ñé 120* Êåëóßïõ = áðïëýôùò öõóéïëïãéê�ò ãéá öïõë ãêÜæé
    ¸êôïñá,
    áðü üôé öáßíåôáé ôï äÜìáóåò ôï èçñßï!
    Ôþñá ÷ñåéÜæåóáé êáé �íá üñãáíï íá ìåôñÜåé ôï manifold pressure ôçò åéóáãùãÞò!
    * Fw-190A instr panel cr.jpg (115.35 KB, 632x369 - åìöáíßóôçêå 856 öïñÝò.)
    ÊáôáãñÜöçêå
    Ç ô�ëåéá ó÷åäßáóç åðéôõã÷Üíåôáé üôáí åßíáé ôüóï ëéôÞ þóôå äåí õðÜñ÷åé êÜôéé ðïõ ìðïñåß íá áöáéñåèåß - Antoine De Saint-Exupery (French writer and aviator)
    hpergm
    Ìçíýìáôá: 1.197
    « ÁðÜíôçóç #287 óôéò: ÐÝìðôç, 8 Éáí 2015, 09:12:48 »
    Happy New Year Jim.
    The temp. readings are in Centigrade (last digit is a decimal) and taken directly on the cylinder top between the fins, right next to the plug (i.e. CHT). That is basically the easiest place to fix the probe.
    I have contemplated placing the temperature gauge on the exhaust nut of each cylinder for an EGT reading, but still thinking how to fasten it..
    Lastly, I never let the temps to go above 390F or ~200C. When such instances did uccur (I was just getting to know how to tune the carb), I immediatelly throttled down to readjust the settings. That's why the multiple temp reading is indispensible with an R3...
    Hector.
    « Ôåëåõôáßá ôñïðïðïßçóç: ÐÝìðôç, 8 Éáí 2015, 09:36:09 áðü hpergm » ÊáôáãñÜöçêå
    Èá ðñïôéìïýóá íá ðåôÜù áíôß íá ãñÜöù!
    hpergm
    Ìçíýìáôá: 1.197
    « ÁðÜíôçóç #288 óôéò: ÐÝìðôç, 8 Éáí 2015, 09:24:29 »
    ÄçìÞôñç,
    ¸êôïñá,
    ¼÷é, ôþñá óôÞíù ìÃ�ôñçóç ïîõãüíïõ óôçí åîÜôìéóç êáé Ã�íá micro servo óôç âåëüíá Ã�ôóé þóôå íá áõôïññõèìßæåôáé óôïí áÃ�ñá...  laugh
    Óçì. Óôï full ãêÜæé ïé èåñìïêñáóßåò Þôáí ìåôáîý 170 êáé 185C. Êáé áõôü óå ìßá ì�ñá üðïõ öýóáãå ìå 7C (øüöïò óôï Åëëçíéêü, ìáò ð�óáíå ïé ìýôåò). ¢ñá óå ìéá áíïéîéÜôéêç ì�ñá ôùí 25C, ðåñéì�íù íá áí�âïõí ðÜíù áðü 200C. Ôï êáëü åßíáé üôé ïé èåñìïêñáóßåò ðáßñíïõí áñêåôÜ äåõôåñüëåðôá óôï WOT íá áí�âïõí áðü 120 óå 180 (ìéëÜìå ãéá ðÜíù áðü 20"), ðñÜãìá ôï ïðïßï äåí åßíáé áíáìåíüìåíï óå ìéá scale ðôÞóç üðïõ ç ìç÷áíÞ äåí åßíáé ïñéáêÞ ãéá ôï airframe.
    Talk about "flying the engine"... áêñéâþò üðùò êáé óôá full scale! (Ôá Ã�3/Ã�4 Ã�ðáó÷áí áðü cooling  Óôñéöïãýñéóìá ìáôéþí )
    « Ôåëåõôáßá ôñïðïðïßçóç: ÐÝìðôç, 8 Éáí 2015, 09:34:37 áðü hpergm » ÊáôáãñÜöçêå
    Demetre
    Ìçíýìáôá: 265
    « ÁðÜíôçóç #289 óôéò: ÐÝìðôç, 8 Éáí 2015, 17:39:30 »
    You'r on the right track then.
    I will  also remind you that EGT reading is going to show you  instantly  that there is some kind of problem,when CHT i'll take a few more minutes for the reading to rise,and perhaps by that time it is too late.  Good Flights !!!!
    ÊáôáãñÜöçêå
    hpergm
    Ìçíýìáôá: 1.197
    « ÁðÜíôçóç #290 óôéò: ÐáñáóêåõÞ, 9 Éáí 2015, 10:56:56 »
    ÄéÜâáóìá ôùí ìðïõæß ìåôÜ ôç ñýèìéóç...
    Çì�ñá ìå ôç íý÷ôá! Ìðïõæß îçñÜ (ü÷é ôçãáíéóì�íá), áêñïä�êôåò áíïéêôü êáö� , ìçä�í deposits.
    * 20150108_194525.jpg (13.8 KB, 360x480 - åìöáíßóôçêå 688 öïñÝò.)
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 11.117
    « ÁðÜíôçóç #291 óôéò: ÐáñáóêåõÞ, 9 Éáí 2015, 11:40:52 »
    Ößëå ¸êôïñá óïõðåñ!�é äéáöïñåò ðïõ âëåðåéò óôéò èåñìïêñáóßåò åéíáé êáé áðï ôçí äéáäéêáóéá ôïõ óôñùóßìáôïò .�ëëåò áíï÷�ò ï êÜèå êýëéíäñïò!!�é saito êáé åéäéêá âåíæéíá è�ëïõí ôåñáóôéá õðïìïíÞ óå óôñþóéìï!ÔÅÑ�ÓÔÉ�!Ôá ì�ôáëá ôïõò åéíáé êïñõöáßá êáé èåëïõí äéðëÜóéï ÷ñïíï óôñùóßìáôïò áðï ïðïéäÞðïôå Üëëïõ êáôáóêåõáóôÞ!Ìïôåñ èá äåéò ìåôá ôéò 20 ùñåò ëåéôïõñãåßáò.Äéðëáóßáóå êáôá ôçí ãíþìç ìïõ ðáíôá ôïí ÷ñüíï óôñùóßìáôïò êÜôù, 10 ëéôñá +, êáé ìåôá óôïí áåñá óå ðôçóç ìå ôá öïñôßá, åðßóçò ðïëý õðïìïíÞ ìå áñêåôåò ðôçóåéò 20+÷áëáñá êáé ìå êáë�ò óõíèÞêåò ( ÷åéìùíá )êáé õðïëüãéóå ôéò ðñùôåò êáé ÷ùñßò cowl.ÕðïìïíÞ × 2 × 3!
    �ðï ðñïð�ëá åßóáé óïýðåñ 22÷10!Ìáêñéá áðï âáñéÜ íïõìåñá êáé ôñßöõëëåò.èáíáôïò! Thumbs up
    « Ôåëåõôáßá ôñïðïðïßçóç: ÐáñáóêåõÞ, 9 Éáí 2015, 14:31:30 áðü ArgyrisGiannetakis » ÊáôáãñÜöçêå
    Ç ïìïñöéÜ åßíáé óôá ìÜôéá áõôïý ðïõ ôç âë�ðåé.
    hpergm
    Ìçíýìáôá: 1.197
    « ÁðÜíôçóç #292 óôéò: ÐáñáóêåõÞ, 9 Éáí 2015, 16:28:28 »
    �ñãýñç, ç ìç÷áíÞ �÷åé Þäç ôñ�îåé 8 ëßôñá êáé èá ôñ�îåé Üëëá 2-4 óôï stand íá åßìáóôå óßãïõñïé üôé èá �÷åé óôñþóåé êáé üôé �÷ïõìå ðåôý÷åé êáëÞ ñýèìéóç,
    ¸÷åéò äßêéï ãéá ôçí õðïìïíÞ: êáé ôç äéêýëéíäñç ôïõ Piper áêüìá "Üóôñùôç" ôç èåùñþ (ðïõ ôï ö�ñíù óôá scale ôïõ �êñáéöíßïõ áðü... ôï 2010!)
    (ÌÜëëïí äå âÜæù þñåò üðùò ðáëéÜ...  Tongue)
    ÊáôáãñÜöçêå
    MOGOLOS
    Ìçíýìáôá: 660
    « ÁðÜíôçóç #293 óôéò: ÊõñéáêÞ, 11 Éáí 2015, 09:15:37 »
    Ãéá íá êáôáëÜâù 170-185 âáèìïß êåëóßïõ åéíáé �ê ãéá �íá ìïôåñ?
    ÊáôáãñÜöçêå
    Ãéáôß åáí äåí å÷åé ðïëõâüëá äåí ðåôÜåé
    hpergm
    Ìçíýìáôá: 1.197
    « ÁðÜíôçóç #294 óôéò: ÊõñéáêÞ, 11 Éáí 2015, 10:45:05 »
    Mog, ãéá 4-÷ñïíç âåíæßíç "converted" áðü glow (äçë. ìå ìéêñÃ�ò øýêôñåò); Ã�ïìßæïõìå (read: åëðßæïõìå   Óôñéöïãýñéóìá ìáôéþí) ðùò íáß.
    Ìçí îå÷íÜìå üôé ç 4-÷ñïíç gas äïõëåýåé óå ìåãáëýôåñåò óõìðé�óåéò áðü üôé ç äß÷ñïíåò gas, åíþ ç âåíæßíç �÷åé ìåãáëýôåñç èåñìïêñáóßá êáýóçò áðü ôï glow.
    �ðüôå, ç èåñìïêñáóßá ìéáò ô�ôïéáò ìç÷áíÞò èá åßíáé ëïãéêÜ áñêåôÜ ðéï áíåâáóì�íç áðü åßôå 2-÷ñïíç gas (÷áìçëüôåñç óõìðßåóç + ìåãáëýôåñá fins) åßôå áðü 2-÷ñïíç/4-÷ñïíç glow (÷áìçëüôåñç èåñìïêñáóßá êáýóçò + áðïññüöçóç èåñìïêñáóßáò áðü ôçí áéèáíüëç).
    �áñáè�ôù êáé �íá test ìïíïêýëéíäñçò gas Saito - ïé èåñìïêñáóßåò CHT åßíáé áñêåôÜ ðéï áíåâáóì�íåò áðü ïðïéáäÞðïôå glow Þ 2-÷ñïíç gas....
    http://www.flyrc.com/saito-fg-36-engine/
    (Êáé ãéá íá ôï ðïýìå ðéï ìðáêáëßóôéêá: áöïý äåí ôçí ðÞñáìå óôï ÷Ã�ñé ìÃ�÷ñé óôéãìÞò...  Ã“ôñéöïãýñéóìá ìáôéþí )
    Åðßóçò, ֏Ã�ò äïêéìÜóáìå íá ìåôñÞóïõìå èåñìïêñáóßåò EGT (ü÷é áêñéâþò éäáíéêÜ, áëëÜ üðùò ìðïñïýóáìå  worry). Äåí åßäáìå ìåãÜëåò äéáöïñÃ�ò ìå ôéò CHT, åêôüò ôïõ üôé ìðïñÃ�óáìå êáé óõñìáôáóöáëßóáìå ôá èåñìïóôïé÷åßá óöéêôÜ êáé áõôÜ áö'åíüò äåí Ã�öåõãáí, áö'åôáßñïõ äåí åß÷áìå áìöéâïëßåò ãéá ôçí áêñßâåéá ôùí ìåôñÞóåùí ëüãù "êáêÞò" åðáöÞò.
    Âßíôåï:
    * 20150110_124335.jpg (45.52 KB, 640x480 - åìöáíßóôçêå 597 öïñÝò.)
    * 20150110_124343.jpg (33.75 KB, 360x480 - åìöáíßóôçêå 578 öïñÝò.)
    * 20150110_123543.jpg (34.14 KB, 360x480 - åìöáíßóôçêå 559 öïñÝò.)
    « Ôåëåõôáßá ôñïðïðïßçóç: ÊõñéáêÞ, 11 Éáí 2015, 13:01:53 áðü hpergm » ÊáôáãñÜöçêå
    MOGOLOS
    Ìçíýìáôá: 660
    « ÁðÜíôçóç #295 óôéò: ÊõñéáêÞ, 11 Éáí 2015, 13:52:18 »
    � 84 �ãñáøå 90 óôï �äáöïò êáé 65 óïí á�ñá
    ¸÷ù ôçí åíôýðùóç üôé ôï ìïô�ñ ðáåé íá ãßíåé ìåëéôæÜíá
    Åý÷ïìáé íá êÜíù ëÜèïò
    ÊáôáãñÜöçêå
    Ìçíýìáôá: 11.117
    « ÁðÜíôçóç #296 óôéò: ÊõñéáêÞ, 11 Éáí 2015, 15:24:54 »
    Óõìöùíþ ìå ôïí Ãéáííç ïôé åßíáé ðïëý 170-185  CHT áëëÜ åßíáé  Ã´Ã¥Ã±Ã¬Ã¡ ãêÜæé êáé ìåôá áðï 20 äåõôåñüëåðôá.Ã�áëé âÃ�âáéá åßíáé áñêåôÜ!ÅéäéêÜ ìå ôïóï êñýï êáéñü!Ôá ëïãéêÜ íïõìåñá åßíáé âáñéÜ ìå÷ñé 140!Ã�ðï 85 åùò 140.
    �éóô�õù ïðùò åßðá êáé ðáñáðÜíù ëüãù áóôñùóßáò áêüìá êáé ãéá ðïëý ðïëý áêüìá, ôá íïýìåñá áõôÜ èá õðÜñ÷ïõí óôï ôåñìá ãêÜæé.Êáëü åßíáé êáôá ôçí ãíþìç ìïõ ðÜíôá íá áðïö�õãåéò ôá ðïëëÜ óôáèåñÜ ãêÜæéá øçëÜ,áñêåôÜ ìðïõêùì�íï ôá êëáóéêÜ äçëáäÞ.Êáé ìéá äïêéìÞ åáí è�ò ÷ùñßò ôçí KELEO ðÜíù íá äåßò ôéò äéáöïñ�ò ìå êáé ÷ùñßò!�í�êáèåí ìå ôéò åîáôìÞóåéò �÷ù áìöéâïëßåò áñêåô�ò êáé áò åßíáé åðþíçìåò.�÷é ïôé �÷åé è�ìá áëëÜ éóùò ìåôÜ ïôáí óôñþóåé áñêåôÜ ,åáí äåéò äéáöïñ�ò!
    ÊáôáãñÜöçêå
    hpergm
    Ìçíýìáôá: 1.197
    « ÁðÜíôçóç #297 óôéò: ÊõñéáêÞ, 11 Éáí 2015, 17:37:20 »
    Åõ÷áñéóôþ ãéá ôï feedback ÃéÜííç êáé �ñãýñç.
    Ìðïñåß íá åßíáé áêüìá Üóôñùôç, üðùò ëÃ�ò Ã�ñãýñç. Êáé Ã�÷åéò äßêéï ãéá ôçí åîÜôìéóç, ôï óêÃ�öôçêá êáé åãþ ìÞðùò íá ðÜù óôéò ìáìßóéåò ãéá íá äþ äéáöïñÜ. Ã�ëëÜ... äÃ� ìïõ ðÜåé. ×Üíåôáé ï óåîïõáëéêüò Þ÷ïò..  Wink
    ÓÞìåñá ôçí ôñÃ�îáìå êáé óôïí ÅñìÞ. Äåí ðÞãå Üó÷çìá - ìüíï êÜôé "êïøßìáôá" Ã�êáíå óôá ðáñáôåôáìÃ�íá øçëÜ - ìðïñåß áðü áíÜöëåîç, ìðïñåß áðü ñýèìéóç,  Ã¬Ã°Ã¯Ã±Ã¥ÃŸ áðü  Ã¡Ã³Ã´Ã±Ã¹Ã³Ã©Ãœ. Åßäïìåí. Èá ðñÃ�ðåé íá äïýìå ôç ìç÷áíÞ óôïí áÃ�ñá ôåëéêÜ Mog. Äõóôõ÷þò äåí Þñèå ôï Üëëï FW190 ìå ôçí FG-84 íá ôï ÷áæÃ�øïõìå - ôçí Üëëç öïñÜ ßóùò..  Undecided
    Åõ÷áñéóôïýìå ôçí ðáñÃ�á ôïõ ÅñìÞ ãéá ôç öéëïîåíßá, âïÞèåéá ãéá ôç ñýèìéóç êáé ôçí ùñáßá êïõâÃ�íôá!  Thumbs up Õðïó÷üìáóôå åðéóôñïöÞ ìå áåñïðëÜíï ôçí åðüìåíç öïñÜ (íá äïêéìÜóïõìå êáé ôï äéÜäñïìï).
    ÊáôáãñÜöçêå
    Demetre
    Ìçíýìáôá: 265
    « ÁðÜíôçóç #298 óôéò: ÊõñéáêÞ, 11 Éáí 2015, 23:15:26 »
    Hi again. Your temp. readings are within the envelope.
    The EGT readings can only be taken from the exhaust gas (aprox.2-4cm from the exhaust port,where ever possible)  THROUHTH the exhaust pipe.
    Anotherwords,must drill a small holle on the pipe,insert the temp.prob , and connect to your temp. meter , but all this work  is not necessary.
    It is only a model airplane, and you'r not in it.(It is only money)
    The system you have installed , is ok to take readings and notice the rapid temp. change from idle to full throtle.
    If you notice a very quik and large difference then throtle back, and go rich on the carb. Play back and forth till you get it right.
    When you install on plane, it is important to remember  "cooling valume" (amount of air moving through the engine fins) and not weather temperature.
    Go to Rotax engines- operators manual- par.10 operating parameters,and you can see the temp. relations on engines.
    Not that all engines are the same ,but you'l get the idea.
    Also know this: even a small dent,or imperfection, on the intake or exhaust stacks it will make a different on the engine's /cilinders performance.
    Now as far as  running the engine on the ground part,i'll say after going through 2-3 tanks of gas(20 oz),and ajasting the engine,you wiil do a better job by just flying on  a fat setting and various throtle possitions in the air.(you don't brake in your car by running it outside on the parking lot)
     Have a good day and even better wondefull flights .  Jim
    « Ôåëåõôáßá ôñïðïðïßçóç: ÄåõôÝñá, 12 Éáí 2015, 02:11:42 áðü Demetre » ÊáôáãñÜöçêå
    hpergm
    Ìçíýìáôá: 1.197
    « ÁðÜíôçóç #299 óôéò: ÄåõôÝñá, 12 Éáí 2015, 10:59:50 »
    Hi Jim - thanks for all your comments!
    You are right in every account:
    - EGT must be in contact with the exhaust GAS and not a metal part of the exhaust manifold. This is why I say "sort of EGT". In reality, the readings are (slightly shifted) CHT..
    - I have done exactly as you said: look at the temps and in case of large delta peaks, go to idle and re-adlust back to safety. That was the whole point of the thermocouple set-up in the first place (avoiding to inadvertedly "cook" one cylinder).
    - Thanks for the Rotax resource - I will have a look. I have read a lot about Vedeneyev engines as well - as a primer to radials. Very useful.
    - Right again for the ground testing. This is anyway coming to a close after about 10 tanks or 5lt. Only problem is I am afraid to commit a warbird as a test bed. A little hickup means a lot of re-work (e.g. torn-off retracts, etc). I may put the motor on my 50CC Yak first...
    BR,
    Hector.
    ÊáôáãñÜöçêå
    Óåëßäåò: 1 ... 17 18 19 [20] 21 22 23 ... 37     ÐÜíù
    Åêôýðùóç
    Aeromodelling GR  |  Forum  |  Ã�åñïðëÜíá R/C - Êáýóéìï  |  Ãéãáíôéáßá, õðü êëßìáêá êáé ìå âåíæßíç (ÓõíôïíéóôÞò: ArgyrisGiannetakis)  |  ÈÝìá: Top Flite FW190 A3 ARF ãéá 50cc
    ÌåôáðÞäçóç óå:
    ÐïëéôéêÞ áðïññÞôïõ
    ¸ãêõñç XHTML 1.0! ¸ãêõñá CSS!
    Äçìéïõñãßá óåëßäáò óå 0.052 äåõôåñüëåðôá. 29 åñùôÞìáôá.
