Τρίτη, 13 Οκτ 2026, 19:45:22
    [Χθες στις 13:52]
    Online σήμερα: 38
    Επισκέπτες: 34
    Συνολικά: 36
    Σελίδες: 1 ... 8 9 10 [11] 12 13 14 ... 24     Κάτω
    Αποστολέας Θέμα: Buddy Price απο hobbyKIng...  (Αναγνώστηκε 171658 φορές)
    Galans
    « Απάντηση #150 στις: Τρίτη, 25 Οκτ 2011, 11:59:36 »
    HobbyKing 30min Epoxy Glue
    http://www.hobbyking.com/buddy.asp?code=85BF208B-288E-466D-AFAA-FF82D85817E0
    Cyanoacrylate (Super Glue) Single Pack
    http://www.hobbyking.com/buddy.asp?code=552FC89A-07DC-4D59-BB2F-85CE6050DC4C
    Nylon & Pinned Hinge 20x36 (10pcs)
    http://www.hobbyking.com/buddy.asp?code=8AE28C94-1C9B-449B-8913-68D61BEA71DB
    Servo Covers
    http://www.hobbyking.com/buddy.asp?code=1D39B83E-E467-4C3A-BEB9-FC926D665066
    Nylon Clevis 1.8x27mm (10pcs/set)
    http://www.hobbyking.com/buddy.asp?code=75AD52F2-35F4-438B-882B-4EDA07A90CBF
    Nylon Clevis 2x29mm (10pcs)
    http://www.hobbyking.com/buddy.asp?code=A3F907A6-7FDF-4BA8-8EDB-985B42D98541
    OrangeRx R100 Satellite Receiver
    http://www.hobbyking.com/buddy.asp?code=9589008F-CCFB-4EE2-87CE-7CB55388CF6F
    Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set
    http://www.hobbyking.com/buddy.asp?code=A0188E3A-A0A3-4C4A-8749-CBB6EB784CE5
    Push Rod Sleeves (2pc/bag)
    http://www.hobbyking.com/buddy.asp?code=9F2D419F-CA28-43C3-A4BD-BCFC3836CE46
    Battery Monitor 2-6S
    http://www.hobbyking.com/buddy.asp?code=320116D1-4303-499E-B1F9-431A423D55D3
    20CM Servo Lead (Futaba) 32AWG Ultra Light (
    http://www.hobbyking.com/buddy.asp?code=69B470BB-03A9-4DA1-9B6D-79FC74AB0F86
    HobbyKing Super Glue CA (50g / 1.7oz) Thi
    http://www.hobbyking.com/buddy.asp?code=99B36A21-975D-4A6A-BA3C-7767B53AF5BC
    Nylon T-Connectors 10 Pairs (20pc)
    http://www.hobbyking.com/buddy.asp?code=18A06F6A-C6F9-46A4-BB55-5A8A81DDE5EF
    XH Adapter Coversion Board W/ Polyquest Char
    http://www.hobbyking.com/buddy.asp?code=15D09510-C807-49BD-AE45-5F6209652C53
    Turnigy 3mm Heat Shrink Tube - RED (1
    http://www.hobbyking.com/buddy.asp?code=A025C5F7-EAB0-4A16-B51F-3E1D7C33B7AD
    Turnigy 3mm Heat Shrink Tube Blue (1mtr)
    http://www.hobbyking.com/buddy.asp?code=BBCA3DEB-5DB7-43D7-BAAD-1720FCCCF7D2
    Turnigy 3mm Heat Shrink Tube Yellow (1mtr)
    http://www.hobbyking.com/buddy.asp?code=13AAE748-58F2-4469-A532-CF92B6AEA46C
    GWS EP Propeller (RD-9070 228x178mm) (6pcs/s
    http://www.hobbyking.com/buddy.asp?code=BC880BEF-24FB-4A43-8895-86223130B5A1
    ILIASDJ
    « Απάντηση #151 στις: Πέμπτη, 27 Οκτ 2011, 20:03:18 »
    Turnigy nano-tech 850mah 3S 25~40C Lipo Pack
    http://www.hobbyking.com/buddy.asp?code=FC4762BF-7583-47A0-B0CB-C70A5F05B7E0
    Turnigy nano-tech 2650mah 6S 45~90C Lipo Pac
    http://www.hobbyking.com/buddy.asp?code=00F8A81F-583E-4179-98E7-1118DB75C08E
    EC5 5mm Connector (Pair)
    http://www.hobbyking.com/buddy.asp?code=CC56D15D-B104-4C93-9303-07F829E511D3
    ΝΕΟΣ ΑΡΙΘΜΟΣ  6957501000
    fazerdreamer
    « Απάντηση #152 στις: Κυριακή, 30 Οκτ 2011, 08:30:24 »
    Wire Mesh Guard Orange 6mm (1mtr)
    http://www.hobbyking.com/buddy.asp?code=0E011764-9E3F-4E72-B5A5-EBF7ED65CEE1
    Η σιωπή είναι χρυσός...
    .Skywalker.
    Όταν δεν βρέχει και δεν φυσάει, πετάμε...
    « Απάντηση #153 στις: Τρίτη, 1 Νοε 2011, 21:24:13 »
    Την αγορά την έκανα πριν λίγο οπότε αν τα υπολόγισα σωστά λήγει στις 15 Νοεμβρίου.
    Turnigy 160mAh 1S 30C (Eflite, Minium compatible)
    Βάζετε τον κωδικό: http://www.hobbyking.com/buddy.asp?code=B92119EC-C1B0-46A4-93DF-1B945BB6EA14
    Πληρώνετε: $1.48
    nickboul
    « Απάντηση #154 στις: Δευτέρα, 14 Νοε 2011, 08:33:02 »
    Twin pack charge lead (2 x 3S)6S w/ XT60
    http://www.hobbyking.com/buddy.asp?code=BFFEB83C-309A-4E13-B4AC-0DCFF776D1E7
    Self Locking Washers #3 (bag of 100pc)
    http://www.hobbyking.com/buddy.asp?code=AC4773E7-E90D-440E-8A6D-D4F1A7377579
    Turnigy 10mm Hex Socket Screwdriver
    http://www.hobbyking.com/buddy.asp?code=BBE1C684-B9A6-44E0-ABDD-5FAA649B350C
    BMS-20325 Metal Gears for BMS-306MAX
    http://www.hobbyking.com/buddy.asp?code=4C4D61BB-942D-42F4-A396-6B68821EB927
    Nikos 3D
    « Απάντηση #155 στις: Τρίτη, 15 Νοε 2011, 00:15:31 »
       GWS Park HPX Servo 19g/.05sec/3.6kg (JR Plug
    http://www.hobbyking.com/buddy.asp?code=7DE818ED-D682-49FB-BFAD-652119C6385A
       Turnigy Ultra-light wood propeller 12x6
    http://www.hobbyking.com/buddy.asp?code=6A3F0F41-7D17-41FF-A98A-88C3B6D3EDCC
    cessna206t-r3d τελος-flip 3d-u can do 60-breeze es
    nyk1970
    « Απάντηση #156 στις: Κυριακή, 20 Νοε 2011, 07:20:23 »
    Extra BuddyCodes, you can save 35.35% for all of this items!
                6inch Quick Release Bar Clamp Tool
                Savings:  35.35 % / $0.35
                    PriceAfter:  $0.64
                    Weight:  105 g
                        Extra BuddyCodes, you can save 36.03% for all of this items!
                Fuel Dot D11xL12mm
                Savings:  36.03 % / $0.89
                    PriceAfter:  $1.58
                    Weight:  30 g
                                  Extra BuddyCodes, you can save 6.2% for all of this items!
                Rhino 2150mAh 2S1P 20C Lipoly Pack
                Savings:  6.2 % / $0.58
                    PriceAfter:  $8.78
                    Weight:  162 g
                        Extra BuddyCodes, you can save 37.44% for all of this items!
                Self-Tapping Screws 2x6 (bag of 100pc)
                Savings:  37.44 % / $0.73
                    PriceAfter:  $1.22
                    Weight:  20 g
                Fuel Dot D11xL12mm
                    PriceAfter:  $1.58
                    Weight:  30 g
    simos gr
    « Απάντηση #157 στις: Πέμπτη, 24 Νοε 2011, 13:47:39 »
    OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
    http://www.hobbyking.com/buddy.asp?code=5FE0F961-23A8-4707-ACD7-62C97C627B2B
    NE-B918 120mAh 1S 10C (V2) OEM Replacement for: NE4950001
    http://www.hobbyking.com/buddy.asp?code=96273029-F030-4A5D-B85C-896ACD40558E
    http://www.hobbyking.com/buddy.asp?code=21489657-974E-4716-BF9C-F11D8B0A59C9
    Turnigy nano-tech 5000mah 6S 35~70C Lipo Pack
    http://www.hobbyking.com/buddy.asp?code=910100A5-EF34-482A-8D3C-517961161361
    Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack
    http://www.hobbyking.com/buddy.asp?code=4726B987-DDDC-4A1A-A359-5AA9CE31E3E0
    Round Heli Landing Pad - 7mm (Blue)
    http://www.hobbyking.com/buddy.asp?code=89B13E96-B363-4FB9-842A-F251844EC527
    http://www.hobbyking.com/buddy.asp?code=08B1F13D-23E4-46DD-8E89-CAB2B77E17FC
    Round Heli Landing Pad - 7mm (Green)
    http://www.hobbyking.com/buddy.asp?code=26F1954F-297B-47DD-8277-CF00EBFF25AB
    Busy Bee FPV 1120mm (ARF)
    http://www.hobbyking.com/buddy.asp?code=EC20A0C9-F9C3-458C-AEAC-512C74A4FF61
    JXF 9x5 / 229 x 127mm Poly Composite propeller (2pcs/bag)
    http://www.hobbyking.com/buddy.asp?code=1953BF81-CFEB-41A1-BE34-9EF0DB8B575C
    2 in 1 Magnetizer and Demagnetizer Tool
    http://www.hobbyking.com/buddy.asp?code=C063A553-D79C-4B66-9F87-915BF376CDF6
    325mm Fibreglass Main Blade (1pair)
    http://www.hobbyking.com/buddy.asp?code=137E5C8C-182F-4952-97D5-16DFAEB3DBA0
    Hands free small item holder
    http://www.hobbyking.com/buddy.asp?code=2319F3EF-BC45-49D5-846F-E93BD9C2487D
    http://www.hobbyking.com/buddy.asp?code=108F0148-F5D3-4D99-803C-E5737D5D8E39
    ZIPPY Flightmax 2200mAh 3S1P 40C
    http://www.hobbyking.com/buddy.asp?code=DD424EA4-511E-45ED-B4A6-88F56874D8A0
    http://www.hobbyking.com/buddy.asp?code=BBBD2A33-B96C-4D83-9BD7-2072DA026313
    Lumifly Thin Strip LED system
    http://www.hobbyking.com/buddy.asp?code=73DB37ED-26C7-406E-B5F4-BF87FCBE1A8D
    Super Gold Plus Odorless CA 1/2 oz (Foam Safe)
    http://www.hobbyking.com/buddy.asp?code=B602CB84-22CA-4838-A36F-D207741224F3
    PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
    http://www.hobbyking.com/buddy.asp?code=CD597658-FCBE-4E16-88C6-25EA4BA49C87
    4mm Gold Connectors 10 pairs (20pc)
    http://www.hobbyking.com/buddy.asp?code=FD6119ED-DFDD-447D-8793-1577C164AB19
    HXT 4mm Gold Connector w/ Protector (10pcs/set)
    http://www.hobbyking.com/buddy.asp?code=5514EB2C-EE0C-491D-AA45-B3C6E6C44E4D
    HXT 3.5mm Gold Connector w/ Protector (10pcs/set)
    http://www.hobbyking.com/buddy.asp?code=12EF9887-CB2B-4985-A422-6711B7AACCBD
    http://www.hobbyking.com/buddy.asp?code=8ACC10C3-C490-48F1-8711-727205093A5F
    http://www.hobbyking.com/buddy.asp?code=5B6D57D8-FE0E-4CC0-B75A-3743E42A64A4
    FPV Tilt Camera Mount with Landing Gear
    http://www.hobbyking.com/buddy.asp?code=4BBF8FD3-825C-4726-ADED-D4EC91EB8184
    HXT4mm Battery Harness 14AWG for 2 Packs in Series
    http://www.hobbyking.com/buddy.asp?code=BC07A744-95E0-4FBE-84CE-68DA0DDBF5C0
    Turnigy nano-tech 3300mah 6S 35~70C Lipo Pack
    http://www.hobbyking.com/buddy.asp?code=D18D262D-D685-47D6-A7A3-7DCC19036EB3
    Temperature Sensor w/ Futaba plug
    http://www.hobbyking.com/buddy.asp?code=D886BDF0-F733-4A78-B867-E90D246B940F
    12V 5A 110/240V 50/60Hz Power Supply
    http://www.hobbyking.com/buddy.asp?code=F5338375-5C6F-49B0-B0C1-3C09F6003529
    APC style propeller 14x7-E
    http://www.hobbyking.com/buddy.asp?code=94429B8A-96AC-4704-AE8D-99303E14DCBD
    TURNIGY Basic 25A v3.1 Speed Controller
    http://www.hobbyking.com/buddy.asp?code=19C7BF59-32B6-4587-A0DE-6BC8622CA819
    HobbyKing Cell Key - 6s Lipoly Cell checker
    http://www.hobbyking.com/buddy.asp?code=056FC694-2F85-4910-84C9-F8A15E5D54AE
    Quick-Cure 5 Min Epoxy 4.5 oz
    http://www.hobbyking.com/buddy.asp?code=377091E1-F4BA-404A-B459-B662D596F5C1
    YAK54 EPP 3D Profile KIT (35.4in)
    http://www.hobbyking.com/buddy.asp?code=6EAAE43D-6433-41EC-A964-B14AD5922240
    APC style propeller 12x6-E
    http://www.hobbyking.com/buddy.asp?code=F1BD1E27-8E9B-434D-9A24-7E1409F50E55
    APC style Sport propeller 13x6
    http://www.hobbyking.com/buddy.asp?code=58D62191-C5BD-4A4D-8603-C1392D9E573C
    http://www.hobbyking.com/buddy.asp?code=F2C7E059-10D5-4D6D-B1BD-F35D592BB79C
    Carbon Fiber Rod (solid) 1.5x750mm
    http://www.hobbyking.com/buddy.asp?code=73AFC435-84D1-49B9-AF61-7EB5161C291B
    Woven Carbon Fiber Sheet 300x100 (1.0MM Thick)
    http://www.hobbyking.com/buddy.asp?code=99D325BC-28F0-4AC5-B0B3-FA9B17DB1EEB
    TurboThumbs Super Big Futaba Rocker
    http://www.hobbyking.com/buddy.asp?code=5E4CE3E4-4075-43F0-ACAF-0412519AD061
    CNC Metal Transmitter Stand JR & Futaba
    http://www.hobbyking.com/buddy.asp?code=D1F22085-0AB2-4717-BBC6-74FFCB191935
    Futaba Y Servo Lead 15cm Length (5pcs/bag)
    http://www.hobbyking.com/buddy.asp?code=47A01D9D-FD14-4E50-B838-E528B12C1F5E
    Turnigy 3mm Heat Shrink Tube - RED (1mtr)
    http://www.hobbyking.com/buddy.asp?code=39AADBE8-C5BC-420E-BD27-C9F7ED6DBE07
    Turnigy 3mm Heat Shrink Tube - BLACK (1mtr)
    http://www.hobbyking.com/buddy.asp?code=4A3C7EDC-E802-488E-A13B-63EFAD68105C
    TGS Sport 14x7E Precision propeller
    http://www.hobbyking.com/buddy.asp?code=38CBEFCC-3B5E-46CD-994D-F7E3EECF53BF
    HobbyKing PPM Signal Mixer version B for Head-Movement-Tracker Gyro
    http://www.hobbyking.com/buddy.asp?code=43DE0663-9A76-46E1-AFA7-0E13CEA945C8
    simos gr
    « Απάντηση #158 στις: Πέμπτη, 24 Νοε 2011, 15:08:24 »
    KD Colet adapter for 3mm shafts
    http://www.hobbyking.com/buddy.asp?code=A8925572-8FEA-4909-85B5-3955B731A067
    http://www.hobbyking.com/buddy.asp?code=83242293-A43F-48B9-A484-D7002A1A2D01
    Nylon Screw 6x30mm (10pcs)
    http://www.hobbyking.com/buddy.asp?code=10B2595C-FC88-4AA0-A153-6B88942799C1
    HobbyKing 2824 Brushless Outrunner 1300KV
    http://www.hobbyking.com/buddy.asp?code=E0C8A1B6-3925-452D-BF1E-9DFC987BE7BC
    Turnigy R/C LED Lighting System
    http://www.hobbyking.com/buddy.asp?code=90DC5C1C-B077-452A-A7FF-2B9B16D7ED80
    Nikers
    Fly fast,Crash Hard.
    « Απάντηση #159 στις: Πέμπτη, 24 Νοε 2011, 19:52:47 »
    Find my codes here: http://hk.rc-international.info/swarm/nikers (valid until December 08, 2011)
    HK15288A Analog BB/MG Servo 51g / 9kg / 0.20s                    Save US$: 0.38
    HK2627 EDF Outrunner 4300kv for 64mm                             Save US$: 1.16
    Prop Saver w/ Band 4mm (10pcs)                                   Save US$: 1.31
    nickboul
    « Απάντηση #160 στις: Τρίτη, 13 Δεκ 2011, 08:08:06 »
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8909
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8423
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=19940
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11117
    DIMISX1
    « Απάντηση #161 στις: Τετάρτη, 14 Δεκ 2011, 14:21:58 »
    http://www.hobbyking.com/buddy.asp?code=5CF47A7B-8356-4489-B3AA-58B2F7C9E4A2
    Buddy code για τον κλώνο του trex 100 φρέσκο πράμα!!!
    * 21316-main.jpg (53.35 KB, 565x414 - εμφανίστηκε 387 φορές.)
    Lama V4
    BELT-CP RTF
    T-REX 500 ESP
    ΒΕΑΜ Ε4 V2
    « Απάντηση #162 στις: Πέμπτη, 15 Δεκ 2011, 03:09:49 »
    Turnigy 3mm long shaft Hex Screwdriver
    http://www.hobbyking.com/buddy.asp?code=4B079D29-96F9-4813-A265-8F51C2C8F87B
    Turnigy 7mm Hex Socket Screwdriver
    http://www.hobbyking.com/buddy.asp?code=902236B7-E503-45B4-B62F-72D124DCCC12
    Turnigy 6mm Heat Shrink Tube - RED (1mtr)
    http://www.hobbyking.com/buddy.asp?code=9B016A03-FEED-4FB3-A2DC-60E68BCA7A4A
    johnraptor
    « Απάντηση #163 στις: Πέμπτη, 15 Δεκ 2011, 08:59:02 »
    Και μερικά από εμένα.
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7962
                 TGS Sport 12x10E Precision propeller
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20684
                     OrangeRx R710 Spektrum DSM2 Compatible 7Ch w/Failsafe
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9392
                          Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8319
                             HexTronik VA-Tester (Voltage & Current indicator)
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14521
                         Hobby King Discovery Buzzer
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10040
                        GWS EP Propeller (DD-4025 102x64mm) (6pcs/set)
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7942
                       TGS Sport 7x6E Precision propeller
    Με ληξη 24/12/2011
    « Απάντηση #164 στις: Κυριακή, 18 Δεκ 2011, 22:07:11 »
       HXT900 Replacement Gear Set
    http://www.hobbyking.com/buddy.asp?code=BDD46312-006C-4FA9-8076-3D0B660CD473
       Master Airscrew propeller 8x4
    http://www.hobbyking.com/buddy.asp?code=9F46C6CC-25CF-4D92-AC46-63BE3ABAD258
            Twisted 15CM Servo Lead Extention (Futaba) 2
    http://www.hobbyking.com/buddy.asp?code=8282CFBD-07FB-49E6-B105-E1B4642ED682
    Σελίδες: 1 ... 8 9 10 [11] 12 13 14 ... 24     Πάνω
    Aeromodelling GR  |  Forum  |  Η αγορά αερομοντελλιστικού υλικού  |  Ο Ελληνας αερομοντελλιστής και η αγορά υλικών (Συντονιστής: Serafim)  |  Θέμα: Buddy Price απο hobbyKIng...
    Δημιουργία σελίδας σε 0.053 δευτερόλεπτα. 24 ερωτήματα.
