Πέμπτη, 12 Νοε 2026, 15:12:52
    Online σήμερα: 142
    Επισκέπτες: 88
    Συνολικά: 89
    Σελίδες: 1 2 3 [4] 5 6 7 ... 9     Κάτω
    Αποστολέας Θέμα: ΠΡΟΓΡΑΜΜΑ ΕΟΡΤΑΣΜΟΥ ΠΟΛΕΜΙΚΗΣ ΑΕΡΟΠΟΡΙΑΣ !  (Αναγνώστηκε 28177 φορές)
    guest713
    Επισκέπτη
    « Απάντηση #45 στις: Δευτέρα, 8 Νοε 2010, 12:27:51 »
    Το πιο μεγαλόπρεπο & εντυπωσιακά εντυπωσιακό
    κατ'εμέ,
    ήταν το F4E  angel
    Specifications (F-4E)
    Orthographically projected diagram of the F-4E/F Phantom II.
    J79 with components labeled
    Cutaway of an air start system of a General Electric J79 turbojet. The small turbine and epicyclic gearing are clearly visible.
    Από Wikipedia !
    General characteristics :
        * Crew: 2
        * Length: 63 ft 0 in (19.2 m)
        * Wingspan: 38 ft 4.5 in (11.7 m)
        * Height: 16 ft 6 in (5.0 m)
        * Wing area: 530.0 ft² (49.2 m²)
        * Airfoil: NACA 0006.4-64 root, NACA 0003-64 tip
        * Empty weight: 30,328 lb (13,757 kg)
        * Loaded weight: 41,500 lb (18,825 kg)
        * Max takeoff weight: 61,795 lb (28,030 kg)
        * Powerplant: 2× General Electric J79-GE-17A axial compressor turbojets, 17,845 lbf (79.4 kN) each
        * Zero-lift drag coefficient: 0.0224
        * Drag area: 11.87 ft² (1.10 m²)
        * Aspect ratio: 2.77
        * Fuel capacity: 1,994 U.S. gal (7,549 L) internal, 3,335 U.S. gal (12,627 L) with three external tanks (370 U.S. gal (1,420 L) tanks on the outer wing hardpoints and either a 600 or 610 U.S. gal (2,310 or 2,345 L) tank for the centerline station).
        * Maximum landing weight: 36,831 lb (16,706 kg)
    Performance :
        * Maximum speed: Mach 2.23 (1,472 mph, 2,370 km/h) at 40,000 ft (12,190 m)
        * Cruise speed: 506 kn (585 mph, 940 km/h)
        * Combat radius: 367 nmi (422 mi, 680 km)
        * Ferry range: 1,403 nmi (1,615 mi, 2,600 km) with 3 external fuel tanks
        * Service ceiling: 60,000 ft (18,300 m)
        * Rate of climb: 41,300 ft/min (210 m/s)
        * Wing loading: 78 lb/ft² (383 kg/m²)
        * lift-to-drag: 8.58
        * Thrust/weight: 0.86 at loaded weight, 0.58 at MTOW
        * Takeoff roll: 4,490 ft (1,370 m) at 53,814 lb (24,410 kg)
        * Landing roll: 3,680 ft (1,120 m) at 36,831 lb (16,706 kg)
    Armament :
        * Up to 18,650 lb (8,480 kg) of weapons on nine external hardpoints, including general purpose bombs, cluster bombs, TV- and laser-guided bombs, rocket pods (UK Phantoms 6 × Matra rocket pods with 18 × SNEB 68 mm rockets each), air-to-ground missiles, anti-runway weapons, anti-ship missiles, targeting pods, reconnaissance pods, and nuclear weapons. Baggage pods and external fuel tanks may also be carried.
        * 4× AIM-7 Sparrow in fuselage recesses plus 4 × AIM-9 Sidewinders on wing pylons; upgraded Hellenic F-4E and German F-4F ICE carry AIM-120 AMRAAM, Japanese F-4EJ Kai carry AAM-3, Hellenic F-4E will carry IRIS-T in future. Iranian F-4s could potentially carry Russian and Chinese missiles. UK Phantoms carried Skyflash missiles[111]
        * 1× 20 mm (0.787 in) M61 Vulcan 6-barreled gatling cannon, 640 rounds
        * 4× AIM-9 Sidewinder, Python-3 (F-4 Kurnass 2000), IRIS-T (F-4E AUP Hellenic Air Force)
        * 4× AIM-7 Sparrow, AAM-3(F-4EJ Kai)
        * 4× AIM-120 AMRAAM for F-4F ICE, F-4E AUP (Hellenic Air Force)
        * 6× AGM-65 Maverick
        * 4× AGM-62 Walleye
        * 4× AGM-45 Shrike, AGM-88 HARM, AGM-78 Standard ARM
        * 4× GBU-15
        * 18× Mk.82, GBU-12
        * 5× Mk.84, GBU-10, GBU-14
        * 18× CBU-87, CBU-89, CBU-58
    panyaek
    « Απάντηση #46 στις: Δευτέρα, 8 Νοε 2010, 17:09:43 »
    * DSC00bhvdx998.JPG (36.82 KB, 640x480 - εμφανίστηκε 887 φορές.)
    * DSC00bygfuy986.JPG (33.54 KB, 640x480 - εμφανίστηκε 856 φορές.)
    panyaek
    « Απάντηση #47 στις: Δευτέρα, 8 Νοε 2010, 17:11:54 »
    * DSC01bvcg004.JPG (50.99 KB, 640x480 - εμφανίστηκε 855 φορές.)
    * DSC01vhgfdf014.JPG (51.4 KB, 640x480 - εμφανίστηκε 865 φορές.)
    guest713
    Επισκέπτη
    « Απάντηση #48 στις: Δευτέρα, 8 Νοε 2010, 17:14:43 »
    Ωραίο το CL-415....
    Άλλες από τα F4 ? Thumbs up
    _ΤΑΣΟΣ_
    « Απάντηση #49 στις: Δευτέρα, 8 Νοε 2010, 19:31:31 »
    Ρε MirAage-άκια ανακάλυψες τα Phantom και εχασες τα μυαλά σου ?
    χα χα χα πλάκα έχεις, στο ένα post πνέεις διθυράμβους για τα Mirage και μετά ξετρελάθηκες με τον spooky !
    Στον σωστό δρόμο είσαι Κώστα.
    GRE-F-0611
    guest713
    Επισκέπτη
    « Απάντηση #50 στις: Δευτέρα, 8 Νοε 2010, 19:39:37 »
    Αναστάση
    ελπίζω το post σου να μήν ήταν * επιθετικό *
    Έχω την εντύπωση πως μπορώ να εκφράζω την γνώμη μου ,
    για ο,τιδήποτε , σωστά ?
    Σας προσέβαλα με το Θέμα που έχω ανοίξει ?
    Άν και εσείς βρισκόσασταν ανάμεσα σε μια τέτοια κατασκευή
    όπως το F-4E
    & δίπλα σε ένα Mirage 2000
    θα καταλαβαίνατε την διαφορά του όγκου μεταξύ των δύο αεροδυναμικών σχημάτων  Thumbs up
    Φιλικά πάντα & με την θέληση να μην ξεφύγουμε από το θέμα μας ,
    Κωνσταντίνος
    _ΤΑΣΟΣ_
    « Απάντηση #51 στις: Δευτέρα, 8 Νοε 2010, 19:53:30 »
    Βρε ΟΧΙ, ισα ισα με πολυ χαρά διαπιστώνω ότι υπάρχουν και άλλοι σαν και εμένα !!!
    Phantom maniacs
    GRE-F-0611
    guest713
    Επισκέπτη
    « Απάντηση #52 στις: Δευτέρα, 8 Νοε 2010, 23:15:52 »
    Phantom maniacs
    Χαχαα έτσι το δέχομαι  Thumbs up
    Μακάρι να είχε κάποιος και άλλες φωτό να ποστάρει
    _ΤΑΣΟΣ_
    « Απάντηση #53 στις: Δευτέρα, 8 Νοε 2010, 23:20:10 »
    Phantom maniacs
    Κώστα, ξεφύγαμε απο το θέμα μας .... δυστυχώς όμως απο τους τόσους αερομοντελιστές και συλλόγους τελικά 3 - 4 "γιόρτασαν" τον προστάτη μας Αρχάγγελο.
    Φωτο έχω και θα ποστάρω με το αγαπημένο σου θέμα, "spooky".
    Αυριο
    GRE-F-0611
    argiris_big
    « Απάντηση #54 στις: Τρίτη, 9 Νοε 2010, 00:06:48 »
     Μοντελιστικη Ενωση Μεσσηνιας στην  120 ΠΕΑ
    argiris_big
    « Απάντηση #55 στις: Τρίτη, 9 Νοε 2010, 00:07:47 »
    argiris_big
    « Απάντηση #56 στις: Τρίτη, 9 Νοε 2010, 00:08:50 »
    panyaek
    « Απάντηση #57 στις: Τρίτη, 9 Νοε 2010, 00:15:27 »
     police
    * DSC0ghwu0999.JPG (37.26 KB, 640x480 - εμφανίστηκε 763 φορές.)
    * DSC023fghk1012.JPG (30.23 KB, 640x480 - εμφανίστηκε 804 φορές.)
    guest713
    Επισκέπτη
    « Απάντηση #58 στις: Τρίτη, 9 Νοε 2010, 09:24:05 »
    T-33
    F-86
    ΕΛΛΗΝΙΚΗ ΦΛΟΓΑ
    Mirage F1-CG
    ΣΠΑΡΤΗ
    Mirage F1-CG
    F-102
    F-104
    STARFIGHTER
    _ΤΑΣΟΣ_
    « Απάντηση #59 στις: Τρίτη, 9 Νοε 2010, 10:01:26 »
    Επειδή στο υποσχέθηκα Κώστα
    F-4E
    * Endoftheday.JPG (63.4 KB, 1024x768 - εμφανίστηκε 748 φορές.)
    GRE-F-0611
    Σελίδες: 1 2 3 [4] 5 6 7 ... 9     Πάνω
    Aeromodelling GR  |  Forum  |  Αερομοντελλισμός στο Aeromodelling GR  |  Aeromodelling GR - γενικές συζητήσεις (Συντονιστής: ArgyrisGiannetakis)  |  Θέμα: ΠΡΟΓΡΑΜΜΑ ΕΟΡΤΑΣΜΟΥ ΠΟΛΕΜΙΚΗΣ ΑΕΡΟΠΟΡΙΑΣ !
    Δημιουργία σελίδας σε 0.042 δευτερόλεπτα. 24 ερωτήματα.
